As suspend with last CPU power down needs SCFW support,
and it is NOT ready now, in order to enable kernel suspend
function earlier for modules to start debugging suspend
resume function, this patch adds standby suspend for now.
Will add last CPU power down suspend function when SCFW
is ready.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add basic support for i.MX8MQ.
1. SMP support is ok.
2. basic suspend/resume support is ok.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
When secondary CPUs are offline, some platforms do NOT
support shutting down secondary CPUs by themself, need
to use other online CPU to shutdown those CPUs which
are being offline, this patch adds killing offline CPUs.
Use TF_LDFLAGS from the Makefiles, and still append LDFLAGS as well to
the compiler's invocation. This allows passing extra options from the
make command line using LDFLAGS.
Document new LDFLAGS Makefile option.
Change-Id: I88c5ac26ca12ac2b2d60a6f150ae027639991f27
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
Apply workarounds for A53 Cat A Errata 835769 and 843419
Resolve signed-unsigned comparison issues
Minor build fixes
A recent commit 030567e6f51731982a7e71cbd387de93bc0e35fd added U()/ULL()
macro to TF constants. This has caused some signed-unsigned comparison
warnings / errors in the TF static analysis.
This patch addresses these issues by migrating impacted variables from
signed ints to unsigned ints and vice verse where applicable.
Change-Id: I4b4c739a3fa64aaf13b69ad1702c66ec79247e53
Signed-off-by: David Cunado <david.cunado@arm.com>
Fix FWU and cache helper optimization
psci: minor fixes in lib
aarch64: Enable Statistical Profiling Extensions for lower ELs
Fully initialise essential control registers
Signed-off-by: Yann Gautier <yann.gautier@st.com>
Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
Call svc_suspend_finish if registered.
psci_get_stat() is static to psci_stat.c
Fix types used in comparison.
Fix coding style (empty line between variable definition and instructions
block).
These errata are only applicable to AArch64 state. See the errata notice
for more details:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.epm048406/index.html
Introduce the build options ERRATA_A53_835769 and ERRATA_A53_843419.
Enable both of them for Juno.
Apply the 835769 workaround as following:
* Compile with -mfix-cortex-a53-835769
* Link with --fix-cortex-a53-835769
Apply the 843419 workaround as following:
* Link with --fix-cortex-a53-843419
The erratum 843419 workaround can lead the linker to create new sections
suffixed with "*.stub*" and 4KB aligned. The erratum 835769 can lead the
linker to create new "*.stub" sections with no particular alignment.
Also add support for LDFLAGS_aarch32 and LDFLAGS_aarch64 in Makefile for
architecture-specific linker options.
Change-Id: Iab3337e338b7a0a16b0d102404d9db98c154f8f8
TLBI instructions for monitor mode won't have the desired effect under
specific circumstances in Cortex-A57 r0p0. The workaround is to
execute DSB and TLBI twice each time.
Even though this errata is only needed in r0p0, the current errata
framework is not prepared to apply run-time workarounds. The current one
is always applied if compiled in, regardless of the CPU or its revision.
The `DSB` instruction used when initializing the translation tables has
been changed to `DSB ISH` as an optimization and to be consistent with
the barriers used for the workaround.
NOTE: This workaround is present in AArch64 TF and already enabled by
default on Juno.
Change-Id: I10b0baa304ed64b13b7b26ea766e61461e759dfa
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
SPE is only supported in non-secure state. Accesses to SPE specific
registers from SEL1 will trap to EL3. During a world switch, before
`TTBR` is modified the SPE profiling buffers are drained. This is to
avoid a potential invalid memory access in SEL1.
SPE is architecturally specified only for AArch64.
Change-Id: I04a96427d9f9d586c331913d815fdc726855f6b0
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
This patch updates the el3_arch_init_common macro so that it fully
initialises essential control registers rather then relying on hardware
to set the reset values.
The context management functions are also updated to fully initialise
the appropriate control registers when initialising the non-secure and
secure context structures and when preparing to leave EL3 for a lower
EL.
This gives better alignement with the ARM ARM which states that software
must initialise RES0 and RES1 fields with 0 / 1.
This patch also corrects the following typos:
"NASCR definitions" -> "NSACR definitions"
Change-Id: Ia8940b8351dc27bc09e2138b011e249655041cfc
This patch enables cache helper functions `flush_dcache_range`,
`clean_dcache_range` and `invalidate_dcache_range` to exit early
if the size argument specified is zero
Change-Id: I0b63e8f4bd3d47ec08bf2a0b0b9a7ff8a269a9b0
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
aarch32: Implement errata workarounds for Cortex A53 and A57
This brings the implementation on par with the software
errata workarounds for AArch64.
Change-Id: I98a85fd92e32ae4259f4ec5b3e93cffc87090064
Change-Id: Id103602e35b1c0ad3705a5b2b7cdb34dd8a8c5e2
Helper function to assist with errata workaround application.
Change-Id: Idba42ca238442cc826f43444dbfa754e433a5e5e
This patch changes input param level in xlat_tables_print_internal() to
an unsigned int to fix the signed/unsigned comparison warnings. The
compiler complains about these warnings, thus halting the build flow
for Tegra platforms.
Change-Id: Ieccc262a63daca7a26ca6a14d81466397af8b89f
This patch makes all the defines in the CPU libraries unique,
by prefixing them with the CPU name.
NOTE: PLATFORMS USING THESE MACROS WILL HAVE TO UPDATE THEIR CODE
TO START USING THE UPDATED NAMES
This patch enables the 'sign-compare' flag, to enable warning/errors
for comparisons between signed/unsigned variables. The warning has
been enabled for all the Tegra platforms, to start with.
Both Cortex-A75 and Cortex-A55 CPUs use the ARM DynamIQ Shared Unit
(DSU). The power-down and power-up sequences are therefore mostly
managed in hardware, and required software operations are considerably
simpler.
Change-Id: I68b30e6e1ebe7c041d5e67f39c59f08575fc7ecc
Co-authored-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
Change-Id: I32fc523e3178b7e50191682241904d52499ff708
x8 is not a callee-saved register and can be corrupted.
Use x19 instead to be AAPCS-compliant.
Fixes ARM-software/tf-issues#478
Change-Id: Ib4f114c36f4c11351ae856f953c45dca92b27c3b
xlat: Fix missing header file dependency
Add TBBR and FWU support for AArch32
xlat_tables_arch.h uses the platform macro `PLAT_VIRT_ADDR_SPACE_SIZE`.
This macro is defined in xlat_tables_private.h only if the platform
still uses the deprecated `ADDR_SPACE_SIZE`.
Change-Id: I1c3b12ebd96bdfe9bf94b26d440c03bc0f8c0b24
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
The behaviour of assert() now depends on the value of the new optional
platform define `PLAT_LOG_LEVEL_ASSERT`. This defaults to `LOG_LEVEL` if
not defined by the platform.
- If `PLAT_LOG_LEVEL_ASSERT` >= `LOG_LEVEL_VERBOSE`, it prints the file
name, line and asserted expression.
- If `PLAT_LOG_LEVEL_ASSERT` >= `LOG_LEVEL_INFO`, it prints the file
name and line.
- If not, it doesn't print anything.
Note the old behaviour was to print the function name whereas now it
prints the file name. This reduces memory usage because the file name is
shared between all assert calls in a given file. Also, the default
behaviour in debug builds is to no longer print the asserted expression,
greatly reducing the string usage.
For FVP debug builds this change saves approximately:
No TBBR TBBR
BL1 1.6 KB 2.2 KB
BL2 1.7 KB 2.1 KB
BL31 2.6 KB 3.3 KB
Change-Id: I2947569d593df0b25611dc3c7a6096f42155c115
Minor fixes to the xlat tables lib v2
This patch enables compiler-rt for the AArch32 target. The code is
not used for AArch64 as the architecture supports the 64-bit division
and modulo operations natively.
Change-Id: I1703a92872b0bb56ac0b98c67193830683963b13
These are needed to provide division and modulo operations
This code is entirely unmodified. Imported from compiler-rt
master branch as of May 4 2017.
Change-Id: I001e1809f2afd4bf8d4cc3d2296798809f607144
Execution state switch
- Fix some comments.
- Remove duplicated definition.
- Make xlat_arch_get_max_supported_pa() private in aarch64.
Change-Id: I629237209cfb2ce7b0c4bd539d63dd81d45b2edd
Fix execute-never permissions in xlat tables libs
Use SPDX license identifiers
In AArch64, privileged exception levels control the execution state
(a.k.a. register width) of the immediate lower Exception Level; i.e.
whether the lower exception level executes in AArch64 or AArch32 state.
For an exception level to have its execution state changed at run time,
it must request the change by raising a synchronous exception to the
higher exception level.
This patch implements and adds such a provision to the ARM SiP service,
by which an immediate lower exception level can request to switch its
execution state. The execution state is switched if the request is:
- raised from non-secure world;
- raised on the primary CPU, before any secondaries are brought online
with CPU_ON PSCI call;
- raised from an exception level immediately below EL3: EL2, if
implemented; otherwise NS EL1.
If successful, the SMC doesn't return to the caller, but to the entry
point supplied with the call. Otherwise, the caller will observe the SMC
returning with STATE_SW_E_DENIED code. If ARM Trusted Firmware is built
for AArch32, the feature is not supported, and the call will always
fail.
For the ARM SiP service:
- Add SMC function IDs for both AArch32 and AArch64;
- Increment the SiP service minor version to 2;
- Adjust the number of supported SiP service calls.
Add documentation for ARM SiP service.
Fixes ARM-software/tf-issues#436
Change-Id: I4347f2d6232e69fbfbe333b340fcd0caed0a4cea
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Replace all instances of checks with the new macro.
Change-Id: I0eec39b9376475a1a9707a3115de9d36f88f8a2a
Translation regimes that only support one virtual address space (such as
the ones for EL2 and EL3) can flag memory regions as execute-never by
setting to 1 the XN bit in the Upper Attributes field in the translation
tables descriptors. Translation regimes that support two different
virtual address spaces (such as the one shared by EL1 and EL0) use bits
PXN and UXN instead.
The Trusted Firmware runs at EL3 and EL1, it has to handle translation
tables of both translation regimes, but the previous code handled both
regimes the same way, as if both had only 1 VA range.
When trying to set a descriptor as execute-never it would set the XN
bit correctly in EL3, but it would set the XN bit in EL1 as well. XN is
at the same bit position as UXN, which means that EL0 was being
prevented from executing code at this region, not EL1 as the code
intended. Therefore, the PXN bit was unset to 0 all the time. The result
is that, in AArch64 mode, read-only data sections of BL2 weren't
protected from being executed.
This patch adds support of translation regimes with two virtual address
spaces to both versions of the translation tables library, fixing the
execute-never permissions for translation tables in EL1.
The library currently does not support initializing translation tables
for EL0 software, therefore it does not set/unset the UXN bit. If EL1
software needs to initialize translation tables for EL0 software, it
should use a different library instead.
Change-Id: If27588f9820ff42988851d90dc92801c8ecbe0c9
xlat lib: Don't set mmap_attr_t enum to be -1
-1 is not a defined mmap_attr_t type. Instead of using invalid enum
types, we can either choose to define a INVALID type OR handle the
condition specifically.
Since the usage of mmap_region_attr is limited, it is easier to just
handle the error condition specifically and return 0 or -1 depending
on success or fail.
Fixes: ARM-Software/tf-issues#473
Fixes: 28fa2e9ee8f4 ("xlat lib: Use mmap_attr_t type consistently")
Signed-off-by: Nishanth Menon <nm@ti.com>
utils.h is included in various header files for the defines in it.
Some of the other header files only contain defines. This allows the
header files to be shared between host and target builds for shared defines.
Recently types.h has been included in utils.h as well as some function
prototypes.
Because of the inclusion of types.h conflicts exist building host tools
abd these header files now. To solve this problem,
move the defines to utils_def.h and have this included by utils.h and
change header files to only include utils_def.h and not pick up the new
types.h being introduced.
Fixes ARM-software/tf-issues#461
Signed-off-by: Scott Branden <scott.branden@broadcom.com>
Remove utils_def.h from utils.h
This patch removes utils_def.h from utils.h as it is not required.
And also makes a minor change to ensure Juno platform compiles.
Change-Id: I10cf1fb51e44a8fa6dcec02980354eb9ecc9fa29
Add AArch32 support for Juno
