This patch enables BL2 to execute at the highest exception level
without any dependancy on TF BL1. This enables platforms which already
have a non-TF Boot ROM to directly load and execute BL2 and subsequent BL
stages without need for BL1. This is not currently possible because
BL2 executes at S-EL1 and cannot jump straight to EL3.
Change-Id: Ief1efca4598560b1b8c8e61fbe26d1f44e929d69
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
xlat v2: Correctly unmap regions on map error
If AMU is not supported by the hardware but it is enabled in Trusted
Firmware, the console will be spammed with warnings every time a CPU
is brought up with a CPU ON call.
Remove the warning message as this is more in line with how other
extensions like SPE and SVE are handled.
Change-Id: Iba6d367e4d1375ab554d23d2eaceab3ae1362c5a
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
AMUv1 support
Change-Id: I504d3f65ca5829bc1f4ebadb764931f8379ee81f
On some systems, the AMU counters might reset to 0 when a CPU
powerdown happens. This behaviour conflicts with the intended
use-case of AMU as lower ELs are only expected to see non-decreasing
counter values.
Change-Id: If25519965d4e6e47e09225d0e732947986cbb5ec
Add some AMU helper functions to allow configuring, reading and
writing of the Group 0 and Group 1 counters. Documentation for these
helpers will come in a separate patch.
Change-Id: I656e070d2dae830c22414f694aa655341d4e2c40
A new platform macro `PLAT_AMU_GROUP1_COUNTERS_MASK` controls which
group 1 counters should be enabled. The maximum number of group 1
counters supported by AMUv1 is 16 so the mask can be at most 0xffff.
If the platform does not define this mask, no group 1 counters are
enabled.
A related platform macro `PLAT_AMU_GROUP1_NR_COUNTERS` is used by
generic code to allocate an array to save and restore the counters on
CPU suspend.
Change-Id: I6d135badf4846292de931a43bb563077f42bb47b
The suspend hook is published at the start of a CPU powerdown
operation. The resume hook is published at the end of a CPU powerup
operation.
Change-Id: I50c05e2dde0d33834095ac41b4fcea4c161bb434
If the CSV2 field reads as 1 then branch targets trained in one
context cannot affect speculative execution in a different context.
In that case skip the workaround on Cortex A75.
Change-Id: I4d5504cba516a67311fb5f0657b08f72909cbd38
Invalidate the Branch Target Buffer (BTB) on entry to EL3 by
temporarily dropping into AArch32 Secure-EL1 and executing the
`BPIALL` instruction.
This is achieved by using 3 vector tables. There is the runtime
vector table which is used to handle exceptions and 2 additional
tables which are required to implement this workaround. The
additional tables are `vbar0` and `vbar1`.
The sequence of events for handling a single exception is
as follows:
1) Install vector table `vbar0` which saves the CPU context on entry
to EL3 and sets up the Secure-EL1 context to execute in AArch32 mode
with the MMU disabled and I$ enabled. This is the default vector table.
2) Before doing an ERET into Secure-EL1, switch vbar to point to
another vector table `vbar1`. This is required to restore EL3 state
when returning from the workaround, before proceeding with normal EL3
exception handling.
3) While in Secure-EL1, the `BPIALL` instruction is executed and an
SMC call back to EL3 is performed.
4) On entry to EL3 from Secure-EL1, the saved context from step 1) is
restored. The vbar is switched to point to `vbar0` in preparation to
handle further exceptions. Finally a branch to the runtime vector
table entry is taken to complete the handling of the original
exception.
This workaround is enabled by default on the affected CPUs.
NOTE
There are 4 different stubs in Secure-EL1. Each stub corresponds to
an exception type such as Sync/IRQ/FIQ/SError. Each stub will move a
different value in `R0` before doing an SMC call back into EL3.
Without this piece of information it would not be possible to know
what the original exception type was as we cannot use `ESR_EL3` to
distinguish between IRQs and FIQs.
Change-Id: I90b32d14a3735290b48685d43c70c99daaa4b434
Invalidate the Branch Target Buffer (BTB) on entry to EL3 by disabling
and enabling the MMU. To achieve this without performing any branch
instruction, a per-cpu vbar is installed which executes the workaround
and then branches off to the corresponding vector entry in the main
vector table. A side effect of this change is that the main vbar is
configured before any reset handling. This is to allow the per-cpu
reset function to override the vbar setting.
Change-Id: I97788d38463a5840a410e3cea85ed297a1678265
`mm_cursor` doesn't have the needed data because the `memmove()` that
is called right before it overwrites that information. In order to get
the information of the region that was being mapped, `mm` has to be used
instead (like it is done to fill the fields of `unmap_mm`).
If the incorrect information is read, this check isn't reliable and
`xlat_tables_unmap_region` may be requested to unmap memory that isn't
mapped at all, triggering assertions.
Change-Id: I602d4ac83095d4e5dac9deb34aa5d00d00e6c289
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Enable SVE for Non-secure world
Replace macro ASM_ASSERTION with macro ENABLE_ASSERTIONS
This patch adds a new build option, ENABLE_SVE_FOR_NS, which when set
to one EL3 will check to see if the Scalable Vector Extension (SVE) is
implemented when entering and exiting the Non-secure world.
If SVE is implemented, EL3 will do the following:
- Entry to Non-secure world: SIMD, FP and SVE functionality is enabled.
- Exit from Non-secure world: SIMD, FP and SVE functionality is
disabled. As SIMD and FP registers are part of the SVE Z-registers
then any use of SIMD / FP functionality would corrupt the SVE
registers.
The build option default is 1. The SVE functionality is only supported
on AArch64 and so the build option is set to zero when the target
archiecture is AArch32.
This build option is not compatible with the CTX_INCLUDE_FPREGS - an
assert will be raised on platforms where SVE is implemented and both
ENABLE_SVE_FOR_NS and CTX_INCLUDE_FPREGS are set to 1.
Also note this change prevents secure world use of FP&SIMD registers on
SVE-enabled platforms. Existing Secure-EL1 Payloads will not work on
such platforms unless ENABLE_SVE_FOR_NS is set to 0.
Additionally, on the first entry into the Non-secure world the SVE
functionality is enabled and the SVE Z-register length is set to the
maximum size allowed by the architecture. This includes the use case
where EL2 is implemented but not used.
Change-Id: Ie2d733ddaba0b9bef1d7c9765503155188fe7dae
Signed-off-by: David Cunado <david.cunado@arm.com>
The `ENABLE_AMU` build option can be used to enable the
architecturally defined AMU counters. At present, there is no support
for the auxiliary counter group.
Change-Id: Ifc7532ef836f83e629f2a146739ab61e75c4abc8
Change-Id: I7ea0c0a00327f463199d1b0a481f01dadb09d312
The Cortex A75 has 5 AMU counters. The first three counters are fixed
and the remaining two are programmable.
A new build option is introduced, `ENABLE_AMU`. When set, the fixed
counters will be enabled for use by lower ELs. The programmable
counters are currently disabled.
Change-Id: I4bd5208799bb9ed7d2596e8b0bfc87abbbe18740
Support ARMv7 architectures
Flush the affinity data in psci_affinity_info
This patch replaces the macro ASM_ASSERTION with the macro
ENABLE_ASSERTIONS in ARM Cortex-A53/57/72 MPCore Processor
related files. There is build error when ASM_ASSERTION is set
to 1 and ENABLE_ASSERTIONS is set to 0 because function
asm_assert in common/aarch32/debug.S is defined in the macro
ENABLE_ASSERTIONS but is called with the macro ASM_ASSERTION.
There is also the indication to use ENABLE_ASSERTIONS but not
ASM_ASSERTION in the Makefile.
Signed-off-by: Matt Ma <matt.ma@spreadtrum.com>
Add ARMv8.2 ID_AA64MMFR0_EL1.PARange value
There is an edge case where the cache maintaince done in
psci_do_cpu_off may not seen by some cores. This case is handled in
psci_cpu_on_start but it hasn't handled in psci_affinity_info.
Change-Id: I4d64f3d1ca9528e364aea8d04e2d254f201e1702
Factor out SPE operations in a separate file. Use the publish
subscribe framework to drain the SPE buffers before entering secure
world. Additionally, enable SPE before entering normal world.
A side effect of this change is that the profiling buffers are now
only drained when a transition from normal world to secure world
happens. Previously they were drained also on return from secure
world, which is unnecessary as SPE is not supported in S-EL1.
Change-Id: I17582c689b4b525770dbb6db098b3a0b5777b70a
Factor out extension enabling to a separate function that is called
before exiting from EL3 for first entry into Non-secure world.
Change-Id: Ic21401ebba531134d08643c0a1ca9de0fc590a1b
If an implementation of ARMv8.2 includes ARMv8.2-LPA, the value 0b0110
is permitted in ID_AA64MMFR0_EL1.PARange, which means that the Physical
Address range supported is 52 bits (4 PiB). It is a reserved value
otherwise.
Change-Id: Ie0147218e9650aa09f0034a9ee03c1cca8db908a
The FPEXC32_EL2 register controls SIMD and FP functionality when the
lower ELs are executing in AArch32 mode. It is architecturally mapped
to AArch32 system register FPEXC.
This patch removes FPEXC32_EL2 register from the System Register context
and adds it to the floating-point context. EL3 only saves / restores the
floating-point context if the build option CTX_INCLUDE_FPREGS is set to 1.
The rationale for this change is that if the Secure world is using FP
functionality and EL3 is not managing the FP context, then the Secure
world will save / restore the appropriate FP registers.
NOTE - this is a break in behaviour in the unlikely case that
CTX_INCLUDE_FPREGS is set to 0 and the platform contains an AArch32
Secure Payload that modifies FPEXC, but does not save and restore
this register
Change-Id: Iab80abcbfe302752d52b323b4abcc334b585c184
Introduce Secure Partition Manager
This function can be useful to setup TCR_ELx by callers that don't use
the translation tables library to setup the system registers related
to them. By making it common, it can be reused whenever it is needed
without duplicating code.
Change-Id: Ibfada9e846d2a6cd113b1925ac911bb27327d375
ARMv7-A architectures that do not support the Virtualization extensions
do not support instructions for the 32bit division. This change provides
a software implementation for 32bit division.
The division implementation is dumped from the OP-TEE project
http://github.com/OP-TEE/optee_os. The code was slightly modified
to pass trusted firmware checkpatch requirements and copyright is
given to the ARM trusted firmware initiative and its contributors.
Change-Id: Idae0c7b80a0d75eac9bd41ae121921d4c5af3fa3
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
If ARMv7 based platform does not set ARM_CORTEX_Ax=yes, platform
shall define ARMV7_SUPPORTS_GENERIC_TIMER to enable generic timer
support.
ARCH_SUPPORTS_LARGE_PAGE_ADDRESSING allows build environment to
handle specific case when target ARMv7 core only supports 32bit MMU
descriptor mode.
shall define ARMV7_SUPPORTS_LARGE_PAGE_ADDRESSING to enable
large page addressing support.
As Cortex-A9 needs to manually enable program flow prediction,
do not reset SCTLR[Z] at entry. Platform should enable it only
once MMU is enabled.
Change-Id: I34e1ee2da73221903f7767f23bc6fc10ad01e3de
Also need to add a SEV instruction in ARMv7 spin_unlock which
is implicit in ARMv8.
This patch includes various fixes for PSCI STAT functionality
relating to timestamp collection:
1. The PSCI stat accounting for retention states for higher level
power domains were done outside the locks which could lead to
spurious values in some race conditions. This is moved inside
the locks. Also, the call to start the stat accounting was redundant
which is now removed.
2. The timestamp wrap-around case when calculating residency did
not cater for AArch32. This is now fixed.
3. In the warm boot path, `plat_psci_stat_accounting_stop()` was
getting invoked prior to population of target power states. This
is now corrected.
Change-Id: I851526455304fb74ff0a724f4d5318cd89e19589
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Add events that trigger before entry to normal/secure world. The
events trigger after the normal/secure context has been restored.
Similarly add events that trigger after leaving normal/secure world.
The events trigger after the normal/secure context has been saved.
Change-Id: I1b48a7ea005d56b1f25e2b5313d77e67d2f02bc5
This allows other EL3 components to subscribe to CPU on events.
Update Firmware Design guide to list psci_cpu_on_finish as an available
event.
Change-Id: Ida774afe0f9cdce4021933fcc33a9527ba7aaae2
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
Add APIs to get and modify attributes of memory regions
Init and save / restore of PMCR_EL0 / PMCR
Update PSCI to v1.1
The implementation is the same as those used to disable it in EL3.
Change-Id: Ibfe7e69034a691fbf57477c5a76a8cdca28f6b26
This patch introduces a new API in the translation tables library
(v2), that allows to change the memory attributes of a memory
region. It may be used to change its execution permissions and
data access permissions.
As a prerequisite, the memory must be already mapped. Moreover, it
must be mapped at the finest granularity (currently 4 KB).
Change-Id: I242a8c6f0f3ef2b0a81a61e28706540462faca3c
Co-authored-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
(v2), that allows to query the memory attributes of a memory block
or a memory page.
Change-Id: I45a8b39a53da39e7617cbac4bff5658dc1b20a11
Integration of reset2 PSCI v1.1 functionality
