Misra changes
Rule 8.3: All declarations of an object or function shall
use the same names and type qualifiers.
Change-Id: Iff384187c74a598a4e73f350a1893b60e9d16cec
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
During the warm boot sequence:
1. The MMU is enabled with the data cache disabled. The MMU table walker
is set up to access the translation tables as in cacheable memory,
but its accesses are non-cacheable because SCTLR_EL3.C controls them
as well.
2. The interconnect is set up and the CPU enters coherency with the
rest of the system.
3. The data cache is enabled.
If the support for dynamic translation tables is enabled and another CPU
makes changes to a region, the changes may only be present in the data
cache, not in RAM. The CPU that is booting isn't in coherency with the
rest of the system, so the table walker of that CPU isn't either. This
means that it may read old entries from RAM and it may have invalid TLB
entries corresponding to the dynamic mappings.
This is not a problem for the boot code because the mapping is 1:1 and
the regions are static. However, the code that runs after the boot
sequence may need to access the dynamically mapped regions.
This patch invalidates all TLBs during warm boot when the dynamic
translation tables support is enabled to prevent this problem.
Change-Id: I80264802dc0aa1cb3edd77d0b66b91db6961af3d
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
On some platforms it may be necessary to discover the SMCCC version
via a PSCI features call.
Change-Id: I95281ac2263ca9aefda1809eb03464fbdb8ac24d
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
The suspend hook is published at the start of a CPU powerdown
operation. The resume hook is published at the end of a CPU powerup
operation.
Change-Id: I50c05e2dde0d33834095ac41b4fcea4c161bb434
Support ARMv7 architectures
There is an edge case where the cache maintaince done in
psci_do_cpu_off may not seen by some cores. This case is handled in
psci_cpu_on_start but it hasn't handled in psci_affinity_info.
Change-Id: I4d64f3d1ca9528e364aea8d04e2d254f201e1702
If ARMv7 based platform does not set ARM_CORTEX_Ax=yes, platform
shall define ARMV7_SUPPORTS_GENERIC_TIMER to enable generic timer
support.
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
This patch includes various fixes for PSCI STAT functionality
relating to timestamp collection:
1. The PSCI stat accounting for retention states for higher level
power domains were done outside the locks which could lead to
spurious values in some race conditions. This is moved inside
the locks. Also, the call to start the stat accounting was redundant
which is now removed.
2. The timestamp wrap-around case when calculating residency did
not cater for AArch32. This is now fixed.
3. In the warm boot path, `plat_psci_stat_accounting_stop()` was
getting invoked prior to population of target power states. This
is now corrected.
Change-Id: I851526455304fb74ff0a724f4d5318cd89e19589
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This allows other EL3 components to subscribe to CPU on events.
Update Firmware Design guide to list psci_cpu_on_finish as an available
event.
Change-Id: Ida774afe0f9cdce4021933fcc33a9527ba7aaae2
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
With this patch the PSCI_FEATURES API correctly reports availability
of the PSCI_MEM_PROTECT_CHECK API - PSCI_MEM_CHK_RANGE_AARCH64 is
added to the PSCI capabilities mask, PSCI_CAP_64BIT_MASK
Change-Id: Ic90ee804deaadf0f948dc2d46ac5fe4121ef77ae
This patch implements PSCI_SYSTEM_RESET2 API as defined in PSCI
v1.1 specification. The specification allows architectural and
vendor-specific resets via this API. In the current specification,
there is only one architectural reset, the warm reset. This reset is
intended to provide a fast reboot path that guarantees not to reset
system main memory.
Change-Id: I057bb81a60cd0fe56465dbb5791d8e1cca025bd3
This patch adds the generic code that links the psci smc handler
with the platform function that implements the mem_protect and
mem_check_range functionalities. These functions are optional
APIs added in PSCI v1.1 (ARM DEN022D).
Change-Id: I3bac1307a5ce2c7a196ace76db8317e8d8c8bb3f
psci_set_power_off_state only initializes a local variable, so there
isn't any reason why it should be done while the lock is held.
Change-Id: I1c62f4cd5d860d102532e5a5350152180d41d127
Previously commit 555ebb34db8f3424c1b394df2f10ecf9c1f70901 attmpted to fix this
GCC issue:
services/std_svc/psci/psci_common.c: In function 'psci_do_state_coordination':
services/std_svc/psci/psci_common.c:220:27: error: array subscript is above
array bounds [-Werror=array-bounds]
psci_req_local_pwr_states[pwrlvl - 1][cpu_idx] = req_pwr_state;
This fix doesn't work as asserts aren't built in non-debug build flows.
Let's use GCCs #pragma option (documented here:
https://gcc.gnu.org/onlinedocs/gcc/Diagnostic-Pragmas.html) to avoid
this false positive instead.
Signed-off-by: Alistair Francis <alistair.francis@xilinx.com>
This patch adds an early suspend handler, that executes with
SMP and data cache enabled. This handler allows platforms to
perform any early actions during the CPU suspend entry sequence.
This handler is optional and platforms can choose to implement it
depending on their needs. The `pwr_domain_suspend` handler still
exists and platforms can keep on using it without any side effects.
There is a theoretical edge case during CPU_ON where the cache
may contain stale data for the target CPU data - this can occur
under the following conditions:
- the target CPU is in another cluster from the current
- the target CPU was the last CPU to shutdown on its cluster
- the cluster was removed from coherency as part of the CPU shutdown
In this case the cache maintenace that was performed as part of the
target CPUs shutdown was not seen by the current CPU's cluster. And
so the cache may contain stale data for the target CPU.
This patch adds a cache maintenance operation (flush) for the
cache-line containing the target CPU data - this ensures that the
target CPU data is read from main memory.
Change-Id: If8cfd42639b03174f60669429b7f7a757027d0fb
Signed-off-by: David Cunado <david.cunado@arm.com>
This fix modifies the order of system includes to meet the ARM TF coding
standard. There are some exceptions in order to retain header groupings,
minimise changes to imported headers, and where there are headers within
the #if and #ifndef statements.
Change-Id: I65085a142ba6a83792b26efb47df1329153f1624
Signed-off-by: Isla Mitchell <isla.mitchell@arm.com>
Minor build fixes
Signed-off-by: Yann Gautier <yann.gautier@st.com>
Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
Call svc_suspend_finish if registered.
psci_get_stat() is static to psci_stat.c
Fix types used in comparison.
Fix coding style (empty line between variable definition and instructions
block).
This patch enables the 'sign-compare' flag, to enable warning/errors
for comparisons between signed/unsigned variables. The warning has
been enabled for all the Tegra platforms, to start with.
Execution state switch
In AArch64, privileged exception levels control the execution state
(a.k.a. register width) of the immediate lower Exception Level; i.e.
whether the lower exception level executes in AArch64 or AArch32 state.
For an exception level to have its execution state changed at run time,
it must request the change by raising a synchronous exception to the
higher exception level.
This patch implements and adds such a provision to the ARM SiP service,
by which an immediate lower exception level can request to switch its
execution state. The execution state is switched if the request is:
- raised from non-secure world;
- raised on the primary CPU, before any secondaries are brought online
with CPU_ON PSCI call;
- raised from an exception level immediately below EL3: EL2, if
implemented; otherwise NS EL1.
If successful, the SMC doesn't return to the caller, but to the entry
point supplied with the call. Otherwise, the caller will observe the SMC
returning with STATE_SW_E_DENIED code. If ARM Trusted Firmware is built
for AArch32, the feature is not supported, and the call will always
fail.
For the ARM SiP service:
- Add SMC function IDs for both AArch32 and AArch64;
- Increment the SiP service minor version to 2;
- Adjust the number of supported SiP service calls.
Add documentation for ARM SiP service.
Fixes ARM-software/tf-issues#436
Change-Id: I4347f2d6232e69fbfbe333b340fcd0caed0a4cea
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
This patch introduces a build option to enable D-cache early on the CPU
after warm boot. This is applicable for platforms which do not require
interconnect programming to enable cache coherency (eg: single cluster
platforms). If this option is enabled, then warm boot path enables
D-caches immediately after enabling MMU.
Fixes ARM-Software/tf-issues#456
Change-Id: I44c8787d116d7217837ced3bcf0b1d3441c8d80e
Call console_flush() before execution either terminates or leaves an
exception level.
Fixes: ARM-software/tf-issues#123
Change-Id: I64eeb92effb039f76937ce89f877b68e355588e3
The current PSCI implementation can apply certain optimizations upon the
assumption that all PSCI participants are cache-coherent.
- Skip performing cache maintenance during power-up.
- Skip performing cache maintenance during power-down:
At present, on the power-down path, CPU driver disables caches and
MMU, and performs cache maintenance in preparation for powering down
the CPU. This means that PSCI must perform additional cache
maintenance on the extant stack for correct functioning.
If all participating CPUs are cache-coherent, CPU driver would
neither disable MMU nor perform cache maintenance. The CPU being
powered down, therefore, remain cache-coherent throughout all PSCI
call paths. This in turn means that PSCI cache maintenance
operations are not required during power down.
- Choose spin locks instead of bakery locks:
The current PSCI implementation must synchronize both cache-coherent
and non-cache-coherent participants. Mutual exclusion primitives are
not guaranteed to function on non-coherent memory. For this reason,
the current PSCI implementation had to resort to bakery locks.
If all participants are cache-coherent, the implementation can
enable MMU and data caches early, and substitute bakery locks for
spin locks. Spin locks make use of architectural mutual exclusion
primitives, and are lighter and faster.
The optimizations are applied when HW_ASSISTED_COHERENCY build option is
enabled, as it's expected that all PSCI participants are cache-coherent
in those systems.
Change-Id: Iac51c3ed318ea7e2120f6b6a46fd2db2eae46ede
The PSCI implementation performs cache maintenance operations on its
data structures to ensure their visibility to both cache-coherent and
non-cache-coherent participants. These cache maintenance operations
can be skipped if all PSCI participants are cache-coherent. When
HW_ASSISTED_COHERENCY build option is enabled, we assume PSCI
For usage abstraction, this patch introduces wrappers for PSCI cache
maintenance and barrier operations used for state coordination: they are
effectively NOPs when HW_ASSISTED_COHERENCY is enabled, but are
applied otherwise.
Also refactor local state usage and associated cache operations to make
it clearer.
Change-Id: I77f17a90cba41085b7188c1345fe5731c99fad87
Use DC ZVA instruction to zero memory
Perform stat accounting for retention/standby states also when
requested at multiple power levels.
Change-Id: I2c495ea7cdff8619bde323fb641cd84408eb5762
This patch introduces the following three platform interfaces:
* void plat_psci_stat_accounting_start(const psci_power_state_t *state_info)
This is an optional hook that platforms can implement in order
to perform accounting before entering a low power state. This
typically involves capturing a timestamp.
* void plat_psci_stat_accounting_stop(const psci_power_state_t *state_info)
to perform accounting after exiting from a low power state. This
* u_register_t plat_psci_stat_get_residency(unsigned int lvl,
const psci_power_state_t *state_info,
unsigned int last_cpu_index)
to calculate the PSCI stat residency.
If any of these interfaces are overridden by the platform, it is
recommended that all of them are.
By default `ENABLE_PSCI_STAT` is disabled. If `ENABLE_PSCI_STAT`
is set but `ENABLE_PMF` is not set then an alternative PSCI stat
collection backend must be provided. If both are set, then default
weak definitions of these functions are provided, using PMF to
calculate the residency.
NOTE: Previously, platforms did not have to explicitly set
`ENABLE_PMF` since this was automatically done by the top-level
Makefile.
Change-Id: I17b47804dea68c77bc284df15ee1ccd66bc4b79b
Replace all use of memset by zeromem when zeroing moderately-sized
structure by applying the following transformation:
memset(x, 0, sizeof(x)) => zeromem(x, sizeof(x))
As the Trusted Firmware is compiled with -ffreestanding, it forbids the
compiler from using __builtin_memset and forces it to generate calls to
the slow memset implementation. Zeromem is a near drop in replacement
for this use case, with a more efficient implementation on both AArch32
and AArch64.
Change-Id: Ia7f3a90e888b96d056881be09f0b4d65b41aa79e
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
The errata reporting policy is as follows:
- If an errata workaround is enabled:
- If it applies (i.e. the CPU is affected by the errata), an INFO
message is printed, confirming that the errata workaround has been
applied.
- If it does not apply, a VERBOSE message is printed, confirming
that the errata workaround has been skipped.
- If an errata workaround is not enabled, but would have applied had
it been, a WARN message is printed, alerting that errata workaround
is missing.
The CPU errata messages are printed by both BL1 (primary CPU only) and
runtime firmware on debug builds, once for each CPU/errata combination.
Relevant output from Juno r1 console when ARM Trusted Firmware is built
with PLAT=juno LOG_LEVEL=50 DEBUG=1:
VERBOSE: BL1: cortex_a57: errata workaround for 806969 was not applied
VERBOSE: BL1: cortex_a57: errata workaround for 813420 was not applied
INFO: BL1: cortex_a57: errata workaround for disable_ldnp_overread was applied
WARNING: BL1: cortex_a57: errata workaround for 826974 was missing!
WARNING: BL1: cortex_a57: errata workaround for 826977 was missing!
WARNING: BL1: cortex_a57: errata workaround for 828024 was missing!
WARNING: BL1: cortex_a57: errata workaround for 829520 was missing!
WARNING: BL1: cortex_a57: errata workaround for 833471 was missing!
VERBOSE: BL31: cortex_a57: errata workaround for 806969 was not applied
VERBOSE: BL31: cortex_a57: errata workaround for 813420 was not applied
INFO: BL31: cortex_a57: errata workaround for disable_ldnp_overread was applied
WARNING: BL31: cortex_a57: errata workaround for 826974 was missing!
WARNING: BL31: cortex_a57: errata workaround for 826977 was missing!
WARNING: BL31: cortex_a57: errata workaround for 828024 was missing!
WARNING: BL31: cortex_a57: errata workaround for 829520 was missing!
WARNING: BL31: cortex_a57: errata workaround for 833471 was missing!
VERBOSE: BL31: cortex_a53: errata workaround for 826319 was not applied
INFO: BL31: cortex_a53: errata workaround for disable_non_temporal_hint was applied
Also update documentation.
Change-Id: Iccf059d3348adb876ca121cdf5207bdbbacf2aba
Add provision to extend CPU operations at more levels
Add two timestamps to measure PSCI cache flush overhead
Various CPU drivers in ARM Trusted Firmware register functions to handle
power-down operations. At present, separate functions are registered to
power down individual cores and clusters.
This scheme operates on the basis of core and cluster, and doesn't cater
for extending the hierarchy for power-down operations. For example,
future CPUs might support multiple threads which might need powering
down individually.
This patch therefore reworks the CPU operations framework to allow for
registering power down handlers on specific level basis. Henceforth:
- Generic code invokes CPU power down operations by the level
required.
- CPU drivers explicitly mention CPU_NO_RESET_FUNC when the CPU has no
reset function.
- CPU drivers register power down handlers as a list: a mandatory
handler for level 0, and optional handlers for higher levels.
All existing CPU drivers are adapted to the new CPU operations framework
without needing any functional changes within.
Also update firmware design guide.
Change-Id: I1826842d37a9e60a9e85fdcee7b4b8f6bc1ad043
Testing showed that the time spent in a cluster power down
operation is dominated by cache flushes. Add two more timestamps
in runtime instrumentation to keep track of the time spent
flushing the L1/L2 caches.
Change-Id: I4c5a04e7663543225a85d3c6b271d7b706deffc4
AArch32: Fix the stack alignment issue
The AArch32 Procedure call Standard mandates that the stack must be aligned
to 8 byte boundary at external interfaces. This patch does the required
changes.
This problem was detected when a crash was encountered in
`psci_print_power_domain_map()` while printing 64 bit values. Aligning
the stack to 8 byte boundary resolved the problem.
Fixes ARM-Software/tf-issues#437
Change-Id: I517bd8203601bb88e9311bd36d477fb7b3efb292
There are many instances in ARM Trusted Firmware where control is
transferred to functions from which return isn't expected. Such jumps
are made using 'bl' instruction to provide the callee with the location
from which it was jumped to. Additionally, debuggers infer the caller by
examining where 'lr' register points to. If a 'bl' of the nature
described above falls at the end of an assembly function, 'lr' will be
left pointing to a location outside of the function range. This misleads
the debugger back trace.
This patch defines a 'no_ret' macro to be used when jumping to functions
from which return isn't expected. The macro ensures to use 'bl'
instruction for the jump, and also, for debug builds, places a 'nop'
instruction immediately thereafter (unless instructed otherwise) so as
to leave 'lr' pointing within the function range.
Change-Id: Ib34c69fc09197cfd57bc06e147cc8252910e01b0
Co-authored-by: Douglas Raillard <douglas.raillard@arm.com>
In order to quantify the overall time spent in the PSCI software
implementation, an initial collection of PMF instrumentation points
has been added.
Instrumentation has been added to the following code paths:
- Entry to PSCI SMC handler. The timestamp is captured as early
as possible during the runtime exception and stored in memory
before entering the PSCI SMC handler.
- Exit from PSCI SMC handler. The timestamp is captured after
normal return from the PSCI SMC handler or if a low power state
was requested it is captured in the bl31 warm boot path before
return to normal world.
- Entry to low power state. The timestamp is captured before entry
to a low power state which implies either standby or power down.
As these power states are mutually exclusive, only one timestamp
is defined to describe both. It is possible to differentiate between
the two power states using the PSCI STAT interface.
- Exit from low power state. The timestamp is captured after a standby
or power up operation has completed.
To calculate the number of cycles spent running code in Trusted Firmware
one can perform the following calculation:
(exit_psci - enter_psci) - (exit_low_pwr - enter_low_pwr).
The resulting number of cycles can be converted to time given the
frequency of the counter.
Change-Id: Ie3b8f3d16409b6703747093b3a2d5c7429ad0166
This patch introduces a `psci_lib_args_t` structure which must be
passed into `psci_setup()` which is then used to initialize the PSCI
library. The `psci_lib_args_t` is a versioned structure so as to enable
compatibility checks during library initialization. Both BL31 and SP_MIN
are modified to use the new structure.
SP_MIN is also modified to add version string and build message as part
of its cold boot log just like the other BLs in Trusted Firmware.
NOTE: Please be aware that this patch modifies the prototype of
`psci_setup()`, which breaks compatibility with EL3 Runtime Firmware
(excluding BL31 and SP_MIN) integrated with the PSCI Library.
Change-Id: Ic3761db0b790760a7ad664d8a437c72ea5edbcd6
Support for PSCI NODE_HW_STATE
This patch adds support for NODE_HW_STATE PSCI API by introducing a new
PSCI platform hook (get_node_hw_state). The implementation validates
supplied arguments, and then invokes this platform-defined hook and
returns its result to the caller. PSCI capabilities are updated
accordingly.
Also updates porting and firmware design guides.
Change-Id: I808e55bdf0c157002a7c104b875779fe50a68a30
The `psci_plat_pm_ops` global pointer is initialized during cold boot by the
primary CPU and will be accessed by the secondary CPUs before enabling data
cache during warm boot. This patch adds a missing data cache flush of
`psci_plat_psci_ops` after initialization during psci_setup() so that
secondaries can see the updated `psci_plat_psci_ops` pointer.
Fixes ARM-software/tf-issues#424
Change-Id: Id4554800b5646302b944115a33be69507d53cedb
This patch adds AArch32 support to PSCI library, as follows :
* The `psci_helpers.S` is implemented for AArch32.
* AArch32 version of internal helper function `psci_get_ns_ep_info()` is
defined.
* The PSCI Library is responsible for the Non Secure context initialization.
Hence a library interface `psci_prepare_next_non_secure_ctx()` is introduced
to enable EL3 runtime firmware to initialize the non secure context without
invoking context management library APIs.
Change-Id: I25595b0cc2dbfdf39dbf7c589b875cba33317b9d
This patch moves the assembly exclusive lock library code
`spinlock.S` into architecture specific folder `aarch64`.
A stub file which includes the file from new location is
retained at the original location for compatibility. The BL
makefiles are also modified to include the file from the new
location.
Change-Id: Ide0b601b79c439e390c3a017d93220a66be73543
Fix use of stale power states in PSCI standby finisher
A PSCI CPU_SUSPEND request to place a CPU in retention states at power levels
higher than the CPU power level is subject to the same state coordination as a
power down state. A CPU could implement multiple retention states at a
particular power level. When exiting WFI, the non-CPU power levels may be in a
different retention state to what was initially requested, therefore each CPU
should refresh its view of the states of all power levels.
Previously, a CPU re-used the state of the power levels when it entered the
retention state. This patch fixes this issue by ensuring that a CPU upon exit
from retention reads the state of each power level afresh.
Change-Id: I93b5f5065c63400c6fd2598dbaafac385748f989
