Misra changes
Rule 8.4: A compatible declaration shall be visible when
an object or function with external linkage is defined.
Change-Id: I26e042cb251a6f9590afa1340fdac73e42f23979
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
Change-Id: I38470528111410cf12b187eb1397d87b812c9416
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
AArch32 uses odd-even pairs when passing 64-bit arguments to
functions. For example in `amu_group0_cnt_write_internal()` the
second argument is a uint64_t which is passed in r2 and r3.
In `amu_group1_set_evtype_internal()` the value that needs to be
written to the system register is in r1 not in r0.
Change-Id: I20196268fdb1dc9ef6c4ebe61e761fba9623b3f2
Before suspend the AMU counters should be enabled and after resume
they should be disabled. Assert that to be consistent with the
AArch64 implementation of `amu_context_{save,restore}()`.
Change-Id: Ia46f77e4062b93afb93721a2890a9b9d2a7f300e
Implement helpers to test if the core supports SPE/SVE. We have a
similar helper for AMU and this patch makes all extensions consistent
in their implementation.
Change-Id: I3e6f7522535ca358259ad142550b19fcb883ca67
Add amu_context_save() and amu_context_restore() functions for aarch32
Change-Id: I4df83d447adeaa9d9f203e16dc5a919ffc04d87a
Signed-off-by: Joel Hutton <joel.hutton@arm.com>
Change-Id: Id6dfe885a63561b1d2649521bd020367b96ae1af
If AMU is not supported by the hardware but it is enabled in Trusted
Firmware, the console will be spammed with warnings every time a CPU
is brought up with a CPU ON call.
Remove the warning message as this is more in line with how other
extensions like SPE and SVE are handled.
Change-Id: Iba6d367e4d1375ab554d23d2eaceab3ae1362c5a
On some systems, the AMU counters might reset to 0 when a CPU
powerdown happens. This behaviour conflicts with the intended
use-case of AMU as lower ELs are only expected to see non-decreasing
counter values.
Change-Id: If25519965d4e6e47e09225d0e732947986cbb5ec
Add some AMU helper functions to allow configuring, reading and
writing of the Group 0 and Group 1 counters. Documentation for these
helpers will come in a separate patch.
Change-Id: I656e070d2dae830c22414f694aa655341d4e2c40
A new platform macro `PLAT_AMU_GROUP1_COUNTERS_MASK` controls which
group 1 counters should be enabled. The maximum number of group 1
counters supported by AMUv1 is 16 so the mask can be at most 0xffff.
If the platform does not define this mask, no group 1 counters are
enabled.
A related platform macro `PLAT_AMU_GROUP1_NR_COUNTERS` is used by
generic code to allocate an array to save and restore the counters on
CPU suspend.
Change-Id: I6d135badf4846292de931a43bb563077f42bb47b
This patch adds a new build option, ENABLE_SVE_FOR_NS, which when set
to one EL3 will check to see if the Scalable Vector Extension (SVE) is
implemented when entering and exiting the Non-secure world.
If SVE is implemented, EL3 will do the following:
- Entry to Non-secure world: SIMD, FP and SVE functionality is enabled.
- Exit from Non-secure world: SIMD, FP and SVE functionality is
disabled. As SIMD and FP registers are part of the SVE Z-registers
then any use of SIMD / FP functionality would corrupt the SVE
registers.
The build option default is 1. The SVE functionality is only supported
on AArch64 and so the build option is set to zero when the target
archiecture is AArch32.
This build option is not compatible with the CTX_INCLUDE_FPREGS - an
assert will be raised on platforms where SVE is implemented and both
ENABLE_SVE_FOR_NS and CTX_INCLUDE_FPREGS are set to 1.
Also note this change prevents secure world use of FP&SIMD registers on
SVE-enabled platforms. Existing Secure-EL1 Payloads will not work on
such platforms unless ENABLE_SVE_FOR_NS is set to 0.
Additionally, on the first entry into the Non-secure world the SVE
functionality is enabled and the SVE Z-register length is set to the
maximum size allowed by the architecture. This includes the use case
where EL2 is implemented but not used.
Change-Id: Ie2d733ddaba0b9bef1d7c9765503155188fe7dae
Signed-off-by: David Cunado <david.cunado@arm.com>
The `ENABLE_AMU` build option can be used to enable the
architecturally defined AMU counters. At present, there is no support
for the auxiliary counter group.
Change-Id: Ifc7532ef836f83e629f2a146739ab61e75c4abc8
Change-Id: I7ea0c0a00327f463199d1b0a481f01dadb09d312
Factor out SPE operations in a separate file. Use the publish
subscribe framework to drain the SPE buffers before entering secure
world. Additionally, enable SPE before entering normal world.
A side effect of this change is that the profiling buffers are now
only drained when a transition from normal world to secure world
happens. Previously they were drained also on return from secure
world, which is unnecessary as SPE is not supported in S-EL1.
Change-Id: I17582c689b4b525770dbb6db098b3a0b5777b70a
