Implement workaround for CVE-2018-3639 on Cortex A57/A72/A73 and A75
services/arm_arch_svc/arm_arch_svc_setup.c
This patch adds a new build option, ENABLE_SVE_FOR_NS, which when set
to one EL3 will check to see if the Scalable Vector Extension (SVE) is
implemented when entering and exiting the Non-secure world.
If SVE is implemented, EL3 will do the following:
- Entry to Non-secure world: SIMD, FP and SVE functionality is enabled.
- Exit from Non-secure world: SIMD, FP and SVE functionality is
disabled. As SIMD and FP registers are part of the SVE Z-registers
then any use of SIMD / FP functionality would corrupt the SVE
registers.
The build option default is 1. The SVE functionality is only supported
on AArch64 and so the build option is set to zero when the target
archiecture is AArch32.
This build option is not compatible with the CTX_INCLUDE_FPREGS - an
assert will be raised on platforms where SVE is implemented and both
ENABLE_SVE_FOR_NS and CTX_INCLUDE_FPREGS are set to 1.
Also note this change prevents secure world use of FP&SIMD registers on
SVE-enabled platforms. Existing Secure-EL1 Payloads will not work on
such platforms unless ENABLE_SVE_FOR_NS is set to 0.
Additionally, on the first entry into the Non-secure world the SVE
functionality is enabled and the SVE Z-register length is set to the
maximum size allowed by the architecture. This includes the use case
where EL2 is implemented but not used.
Change-Id: Ie2d733ddaba0b9bef1d7c9765503155188fe7dae
Signed-off-by: David Cunado <david.cunado@arm.com>
The `ENABLE_AMU` build option can be used to enable the
architecturally defined AMU counters. At present, there is no support
for the auxiliary counter group.
Change-Id: Ifc7532ef836f83e629f2a146739ab61e75c4abc8
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
Change-Id: I7ea0c0a00327f463199d1b0a481f01dadb09d312
Factor out SPE operations in a separate file. Use the publish
subscribe framework to drain the SPE buffers before entering secure
world. Additionally, enable SPE before entering normal world.
A side effect of this change is that the profiling buffers are now
only drained when a transition from normal world to secure world
happens. Previously they were drained also on return from secure
world, which is unnecessary as SPE is not supported in S-EL1.
Change-Id: I17582c689b4b525770dbb6db098b3a0b5777b70a
Factor out extension enabling to a separate function that is called
before exiting from EL3 for first entry into Non-secure world.
Change-Id: Ic21401ebba531134d08643c0a1ca9de0fc590a1b
The FPEXC32_EL2 register controls SIMD and FP functionality when the
lower ELs are executing in AArch32 mode. It is architecturally mapped
to AArch32 system register FPEXC.
This patch removes FPEXC32_EL2 register from the System Register context
and adds it to the floating-point context. EL3 only saves / restores the
floating-point context if the build option CTX_INCLUDE_FPREGS is set to 1.
The rationale for this change is that if the Secure world is using FP
functionality and EL3 is not managing the FP context, then the Secure
world will save / restore the appropriate FP registers.
NOTE - this is a break in behaviour in the unlikely case that
CTX_INCLUDE_FPREGS is set to 0 and the platform contains an AArch32
Secure Payload that modifies FPEXC, but does not save and restore
this register
Change-Id: Iab80abcbfe302752d52b323b4abcc334b585c184
Add events that trigger before entry to normal/secure world. The
events trigger after the normal/secure context has been restored.
Similarly add events that trigger after leaving normal/secure world.
The events trigger after the normal/secure context has been saved.
Change-Id: I1b48a7ea005d56b1f25e2b5313d77e67d2f02bc5
Currently TF does not initialise the PMCR_EL0 register in
the secure context or save/restore the register.
In particular, the DP field may not be set to one to prohibit
cycle counting in the secure state, even though event counting
generally is prohibited via the default setting of MDCR_EL3.SMPE
to 0.
This patch initialises PMCR_EL0.DP to one in the secure state
to prohibit cycle counting and also initialises other fields
that have an architectually UNKNOWN reset value.
Additionally, PMCR_EL0 is added to the list of registers that are
saved and restored during a world switch.
Similar changes are made for PMCR for the AArch32 execution state.
NOTE: secure world code at lower ELs that assume other values in PMCR_EL0
will be impacted.
Change-Id: Iae40e8c0a196d74053accf97063ebc257b4d2f3a
CPU_DATA_LOG2SIZE depends on cache line size
Platform may use specific cache line sizes. Since CACHE_WRITEBACK_GRANULE
defines the platform specific cache line size, it is used to define the
size of the cpu data structure CPU_DATA_SIZE aligned on cache line size.
Introduce assembly macro 'mov_imm' for AArch32 to simplify implementation
of function '_cpu_data_by_index'.
Change-Id: Ic2d49ffe0c3e51649425fd9c8c99559c582ac5a1
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
which will cause write_sctlr_el2 use all sctlr_el1 value except the EE bit
The code doesn't "Use SCTLR_EL1.EE value to initialise sctlr_el2"
but, read out SCTLR_EL1 and clear EE bit, then set to sctlr_el2
Signed-off-by: Ken Kuang <ken.kuang@spreadtrum.com>
SPE is only supported in non-secure state. Accesses to SPE specific
registers from SEL1 will trap to EL3. During a world switch, before
`TTBR` is modified the SPE profiling buffers are drained. This is to
avoid a potential invalid memory access in SEL1.
SPE is architecturally specified only for AArch64.
Change-Id: I04a96427d9f9d586c331913d815fdc726855f6b0
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
This patch updates the el3_arch_init_common macro so that it fully
initialises essential control registers rather then relying on hardware
to set the reset values.
The context management functions are also updated to fully initialise
the appropriate control registers when initialising the non-secure and
secure context structures and when preparing to leave EL3 for a lower
EL.
This gives better alignement with the ARM ARM which states that software
must initialise RES0 and RES1 fields with 0 / 1.
This patch also corrects the following typos:
"NASCR definitions" -> "NSACR definitions"
Change-Id: Ia8940b8351dc27bc09e2138b011e249655041cfc
Execution state switch
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Replace all instances of checks with the new macro.
Change-Id: I0eec39b9376475a1a9707a3115de9d36f88f8a2a
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
Replace all use of memset by zeromem when zeroing moderately-sized
structure by applying the following transformation:
memset(x, 0, sizeof(x)) => zeromem(x, sizeof(x))
As the Trusted Firmware is compiled with -ffreestanding, it forbids the
compiler from using __builtin_memset and forces it to generate calls to
the slow memset implementation. Zeromem is a near drop in replacement
for this use case, with a more efficient implementation on both AArch32
and AArch64.
Change-Id: Ia7f3a90e888b96d056881be09f0b4d65b41aa79e
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
One nasty part of ATF is some of boolean macros are always defined
as 1 or 0, and the rest of them are only defined under certain
conditions.
For the former group, "#if FOO" or "#if !FOO" must be used because
"#ifdef FOO" is always true. (Options passed by $(call add_define,)
are the cases.)
For the latter, "#ifdef FOO" or "#ifndef FOO" should be used because
checking the value of an undefined macro is strange.
Here, IMAGE_BL* is handled by make_helpers/build_macro.mk like
follows:
$(eval IMAGE := IMAGE_BL$(call uppercase,$(3)))
$(OBJ): $(2)
@echo " CC $$<"
$$(Q)$$(CC) $$(TF_CFLAGS) $$(CFLAGS) -D$(IMAGE) -c $$< -o $$@
This means, IMAGE_BL* is defined when building the corresponding
image, but *undefined* for the other images.
So, IMAGE_BL* belongs to the latter group where we should use #ifdef
or #ifndef.
The AArch32 Procedure call Standard mandates that the stack must be aligned
to 8 byte boundary at external interfaces. This patch does the required
changes.
This problem was detected when a crash was encountered in
`psci_print_power_domain_map()` while printing 64 bit values. Aligning
the stack to 8 byte boundary resolved the problem.
Fixes ARM-Software/tf-issues#437
Change-Id: I517bd8203601bb88e9311bd36d477fb7b3efb292
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This patch resets EL2 and EL3 registers that have architecturally
UNKNOWN values on reset and that also provide EL2/EL3 configuration
and trap controls.
Specifically, the EL2 physical timer is disabled to prevent timer
interrups into EL2 - CNTHP_CTL_EL2 and CNTHP_CTL for AArch64 and AArch32,
respectively.
Additionally, for AArch64, HSTR_EL2 is reset to avoid unexpected traps of
non-secure access to certain system registers at EL1 or lower.
For AArch32, the patch also reverts the reset to SDCR which was
incorrectly added in a previous change.
Change-Id: If00eaa23afa7dd36a922265194ccd6223187414f
In order to avoid unexpected traps into EL3/MON mode, this patch
resets the debug registers, MDCR_EL3 and MDCR_EL2 for AArch64,
and SDCR and HDCR for AArch32.
MDCR_EL3/SDCR is zero'ed when EL3/MON mode is entered, at the
start of BL1 and BL31/SMP_MIN.
For MDCR_EL2/HDCR, this patch zero's the bits that are
architecturally UNKNOWN values on reset. This is done when
exiting from EL3/MON mode but only on platforms that support
EL2/HYP mode but choose to exit to EL1/SVC mode.
Fixes ARM-software/tf-issues#430
Change-Id: Idb992232163c072faa08892251b5626ae4c3a5b6
The values of CP15BEN, nTWI & nTWE bits in SCTLR_EL1 are architecturally
unknown if EL3 is AARCH64 whereas they reset to 1 if EL3 is AArch32. This
might be a compatibility break for legacy AArch32 normal world software if
these bits are not set to 1 when EL3 is AArch64. This patch enables the
CP15BEN, nTWI and nTWE bits in the SCTLR_EL1 if the lower non-secure EL is
AArch32. This unifies the SCTLR settings for lower non-secure EL in AArch32
mode for both AArch64 and AArch32 builds of Trusted Firmware.
Fixes ARM-software/tf-issues#428
Change-Id: I3152d1580e4869c0ea745c5bd9da765f9c254947
This patch fixes a bug in context management library when writing
SCTLR register during context initialization. The write happened
prior to initialization of the register context pointer. This
resulted in the compiler optimizing the write sequence from the
final binary and hence SCTLR remains uninitialized when
entering normal world. The bug is fixed by doing the
initialization of the register context pointer earlier in the
sequence.
Change-Id: Ic7465593a74534046b79f40446ffa1165c52ed76
This patch adds AArch32 support to cpu ops, context management,
per-cpu data and spinlock libraries. The `entrypoint_info`
structure is modified to add support for AArch32 register
arguments. The CPU operations for AEM generic cpu in AArch32
mode is also added.
Change-Id: I1e52e79f498661d8f31f1e7b3a29e222bc7a4483
This patch moves the PSCI services and BL31 frameworks like context
management and per-cpu data into new library components `PSCI` and
`el3_runtime` respectively. This enables PSCI to be built independently from
BL31. A new `psci_lib.mk` makefile is introduced which adds the relevant
PSCI library sources and gets included by `bl31.mk`. Other changes which
are done as part of this patch are:
* The runtime services framework is now moved to the `common/` folder to
enable reuse.
* The `asm_macros.S` and `assert_macros.S` helpers are moved to architecture
specific folder.
* The `plat_psci_common.c` is moved from the `plat/common/aarch64/` folder
to `plat/common` folder. The original file location now has a stub which
just includes the file from new location to maintain platform compatibility.
Most of the changes wouldn't affect platform builds as they just involve
changes to the generic bl1.mk and bl31.mk makefiles.
NOTE: THE `plat_psci_common.c` FILE HAS MOVED LOCATION AND THE STUB FILE AT
THE ORIGINAL LOCATION IS NOW DEPRECATED. PLATFORMS SHOULD MODIFY THEIR
MAKEFILES TO INCLUDE THE FILE FROM THE NEW LOCATION.
Change-Id: I6bd87d5b59424995c6a65ef8076d4fda91ad5e86
