This patch adds support for the new Memory Tagging Extension arriving in
ARMv8.5. MTE support is now enabled by default on systems that support
at EL0. To enable it at ELx for both the non-secure and the secure
world, the compiler flag CTX_INCLUDE_MTE_REGS includes register saving
and restoring when necessary in order to prevent register leakage
between the worlds.
Change-Id: I2d4ea993d6b11654ea0d4757d00ca20d23acf36c
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
The SHA256 DMA driver can be used by multiple SoCs. Move it to the
common directory.
Signed-off-by: Carlo Caione <ccaione@baylibre.com>
Change-Id: I96319eeeeeebd503ef0dcb07c0e4ff6a67afeaa5
Meson is the internal code name for the SoC family. The correct name for
the platform should be Amlogic. Change the name of the platform
directory.
Change-Id: Icc140e1ea137f12117acbf64c7dcb1a8b66b345d
The #include "mbedtls/check_config.h" directive first searches for
the header in the relative path to mbedtls_config.h, i.e.
include/drivers/auth/mbedtls/mbedtls/check_config.h
Obviously, it does not exist since check_config.h is located in
the mbedtls project.
It is more sensible to use #include <...> form.
Change-Id: If72a71381f84e7748a2c9f07dd1176559d9bb1d2
If the max-frequency property is provided in the device tree mmc node,
it should be managed. The max allowed frequency will be the min between
this property value and what the card can support.
Change-Id: I885b676c3300d2670a0fe4c6ecab87758b5893ad
Signed-off-by: Yann Gautier <yann.gautier@st.com>
Introduce driver for STM32 IWDG peripheral (Independent Watchdog).
It is configured according to device tree content and should be enabled
from there.
The watchdog is not started by default. It can be started after an HW
reset if the dedicated OTP is fused.
The watchdog also needs to be frozen if a debugger is attached.
This is done by configuring the correct bits in DBGMCU.
This configuration is allowed by checking BSEC properties.
An increase of BL2 size is also required when adding this new code.
Change-Id: Ide7535d717885ce2f9c387cf17afd8b5607f3e7f
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
Signed-off-by: Nicolas Le Bayon <nicolas.le.bayon@st.com>
This patch fixes an issue when secure world timing information
can be leaked because Secure Cycle Counter is not disabled.
For ARMv8.5 the counter gets disabled by setting MDCR_El3.SCCD
bit on CPU cold/warm boot.
For the earlier architectures PMCR_EL0 register is saved/restored
on secure world entry/exit from/to Non-secure state, and cycle
counting gets disabled by setting PMCR_EL0.DP bit.
'include\aarch64\arch.h' header file was tided up and new
ARMv8.5-PMU related definitions were added.
Change-Id: I6f56db6bc77504634a352388990ad925a69ebbfa
Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
into integration
Currently, console drivers prepend '\r' to '\n' by themselves. This is
common enough to be supported in the framework.
Add a new flag, CONSOLE_FLAG_TRANSLATE_CRLF. A driver can set this
flag to ask the framework to transform LF into CRLF instead of doing
it by itself.
Change-Id: I4f5c5887591bc0a8749a105abe62b6562eaf503b
This patch fixes FVP_Base_AEMv8A model hang issue with
ARMv8.4+ with cache modelling enabled configuration.
Incorrect L1 cache flush operation to PoU, using CLIDR_EL1
LoUIS field, which is required by the architecture to be
zero for ARMv8.4-A with ARMv8.4-S2FWB feature is replaced
with L1 to L2 and L2 to L3 (if L3 is present) cache flushes.
FVP_Base_AEMv8A model can be configured with L3 enabled by
setting `cluster0.l3cache-size` and `cluster1.l3cache-size`
to non-zero values, and presence of L3 is checked in
`aem_generic_core_pwr_dwn` function by reading
CLIDR_EL1.Ctype3 field value.
Change-Id: If3de3d4eb5ed409e5b4ccdbc2fe6d5a01894a9af
This patch modifies crash reporting for AArch64 to provide
aligned output of register dump and GIC registers.
Change-Id: I8743bf1d2d6d56086e735df43785ef28051c5fc3
NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200
Signed-off-by: Julius Werner <jwerner@chromium.org>
NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
Change-Id: Ie0a94783d0c8e111ae19fd592304e6485f04ca29
Signed-off-by: Balint Dobszay <balint.dobszay@arm.com>
* changes:
marvell/a3700: Prevent SError accessing PCIe link while it is down
marvell: Switch to xlat_tables_v2
* changes:
cryptocell: add product version awareness support
cryptocell: move Cryptocell specific API into driver
Add support for multiple Cryptocell revisions which
use different APIs.
This commit only refactors the existing code in preperation to the addition
of another Cryptocell revisions later on.
Signed-off-by: Gilad Ben-Yossef <gilad.benyossef@arm.com>
Change-Id: I16d80b31afb6edd56dc645fee5ea619cc74f09b6
Code using Cryptocell specific APIs was used as part of the
arm common board ROT support, instead of being abstracted
in Cryptocell specific driver code, creating two problems:
- Any none arm board that uses Cryptocell wuld need to
copy and paste the same code.
- Inability to cleanly support multiple versions of Cryptocell
API and products.
Move over Cryptocell specific API calls into the Cryptocell
driver, creating abstraction API where needed.
Change-Id: I9e03ddce90fcc47cfdc747098bece86dbd11c58e
* changes:
Refactor SPSR initialisation code
SSBS: init SPSR register with default SSBS value
integration
* changes:
plat/mediatek/mt81*: Use new bl31_params_parse() helper
plat/rockchip: Use new bl31_params_parse_helper()
Add helper to parse BL31 parameters (both versions)
Factor out cross-BL API into export headers suitable for 3rd party code
Use explicit-width data types in AAPCS parameter structs
plat/rockchip: Switch to use new common BL aux parameter library
Introduce lightweight BL platform parameter library
This patch introduces an additional precautionary step to further
enhance protection against variant 4. During the context initialisation
before we enter the various BL stages, the SPSR.SSBS bit is explicitly
set to zero. As such, speculative loads/stores are by default disabled
for all BL stages when they start executing. Subsequently, each BL
stage, can choose to enable speculative loads/stores or keep them
disabled.
This change doesn't affect the initial execution context of BL33 which
is totally platform dependent and, thus, it is intentionally left up to
each platform to initialise.
For Arm platforms, SPSR.SSBS is set to zero for BL33 too. This means
that, for Arm platforms, all BL stages start with speculative
loads/stores disabled.
Change-Id: Ie47d39c391d3f20fc2852fc59dbd336f8cacdd6c
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
BL31 used to take a single bl31_params_t parameter structure with entry
point information in arg0. In commit 726002263 (Add new version of image
loading.) this API was changed to a more flexible linked list approach,
and the old parameter structure was copied into all platforms that still
used the old format. This duplicated code unnecessarily among all these
platforms.
This patch adds a helper function that platforms can optionally link to
outsource the task of interpreting arg0. Many platforms are just
interested in the BL32 and BL33 entry point information anyway. Since
some platforms still need to support the old version 1 parameters, the
helper will support both formats when ERROR_DEPRECATED == 0. This allows
those platforms to drop a bunch of boilerplate code and asynchronously
update their BL2 implementation to the newer format.
Change-Id: I9e6475adb1a7d4bccea666118bd1c54962e9fc38
This patch adds a new include/export/ directory meant for inclusion in
third-party code. This is useful for cases where third-party code needs
to interact with TF-A interfaces and data structures (such as a custom
BL2-implementation like coreboot handing off to BL31). Directly
including headers from the TF-A repository avoids having to duplicate
all these definitions (and risk them going stale), but with the current
header structure this is not possible because handoff API definitions
are too deeply intertwined with other TF code/headers and chain-include
other headers that will not be available in the other environment.
The new approach aims to solve this by separating only the parts that
are really needed into these special headers that are self-contained and
will not chain-include other (non-export) headers. TF-A code should
never include them directly but should instead always include the
respective wrapper header, which will include the required prerequisites
(like <stdint.h>) before including the export header. Third-party code
can include the export headers via its own wrappers that make sure the
necessary definitions are available in whatever way that environment can
provide them.
Change-Id: Ifd769320ba51371439a8e5dd5b79c2516c3b43ab
It's not a good idea to use u_register_t for the members of
aapcs64_params_t and aapcs32_params_t, since the width of that type
always depends on the current execution environment. This would cause
problems if e.g. we used this structure to set up the entry point of an
AArch32 program from within an AArch64 program. (It doesn't seem like
any code is doing that today, but it's probably still a good idea to
write this defensively. Also, it helps with my next patch.)
Change-Id: I12c04a85611f2b6702589f3362bea3e6a7c9f776
The watchdog is configured with a default value of 256 seconds in order
to implement the Trusted Board Boot Requirements.
For the FVP and Juno platforms, the FWU process relies on a watchdog
reset. In order to automate the test of FWU, the length of this process
needs to be as short as possible. Instead of waiting for those 4 minutes
to have a reset by the watchdog, tell it to reset immediately.
There are no side effects as the value of the watchdog's load register
resets to 0xFFFFFFFF.
Tested on Juno.
Change-Id: Ib1aea80ceddc18ff1e0813a5b98dd141ba8a3ff2
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
This patch adds some common helper code to support a lightweight
platform parameter passing framework between BLs that has already been
used on Rockchip platforms but is more widely useful to others as well.
It can be used as an implementation for the SoC firmware configuration
file mentioned in the docs, and is primarily intended for platforms
that only require a handful of values to be passed and want to get by
without a libfdt dependency. Parameters are stored in a linked list and
the parameter space is split in generic and vendor-specific parameter
types. Generic types will be handled by this code whereas
vendor-specific types have to be handled by a vendor-specific handler
function that gets passed in.
Change-Id: If3413d44e86b99d417294ce8d33eb2fc77a6183f
Change-Id: Iab767e9937f5c6c8150953fcdc3b37e8ee83fa63
Signed-off-by: Louis Mayencourt <louis.mayencourt@arm.com>
Use v2 xlat tables library instead of v1 for marvell platforms.
Signed-off-by: Remi Pommarel <repk@triplefau.lt>
Change-Id: I838a6a878a8353e84eea9529721761b478943f0a
Update the skeleton implementation of the console interface.
The 32 bit version was outdated and has been copied from the 64 bit
version.
Change-Id: Ib3e4eb09402ffccb1a30c703a53829a7bf064dfe
* changes:
Enable -Wshift-overflow=2 to check for undefined shift behavior
Update base code to not rely on undefined overflow behaviour
Update hisilicon drivers to not rely on undefined overflow behaviour
Update synopsys drivers to not rely on undefined overflow behaviour
Update imx platform to not rely on undefined overflow behaviour
Update mediatek platform to not rely on undefined overflow behaviour
Update layerscape platform to not rely on undefined overflow behaviour
Update intel platform to not rely on undefined overflow behaviour
Update rockchip platform to not rely on undefined overflow behaviour
Update renesas platform to not rely on undefined overflow behaviour
Update meson platform to not rely on undefined overflow behaviour
Update marvell platform to not rely on undefined overflow behaviour
This patch enables MTE for Normal world if the CPU suppors it. Enabling
MTE for secure world will be done later.
Change-Id: I9ef64460beaba15e9a9c20ab02da4fb2208b6f7d
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This consists of ensuring that the left operand of each shift is
unsigned when the operation might overflow into the sign bit.
Change-Id: Iddd6f38139a4c6e500468b4fc48d04e0939f574e
This patch adds 128-bit integer types int128_t and uint128_t
for "__int128" and "unsigned __int128" supported by GCC and
Clang for AArch64.
Change-Id: I0e646d026a5c12a09fd2c71dc502082052256a94
This patch removes incorrect SCTLR_V_BIT definition and adds
definitions for ARMv8.3-Pauth EnIB, EnDA and EnDB bits.
Change-Id: I1384c0a01f56f3d945833464a827036252c75c2e
Change-Id: I755e4c42242d9a052570fd1132ca3d937acadb13
* changes:
Removing redundant ISB instructions
Workaround for Neoverse N1 erratum 1275112
Workaround for Neoverse N1 erratum 1262888
Workaround for Neoverse N1 erratum 1262606
Workaround for Neoverse N1 erratum 1257314
Workaround for Neoverse N1 erratum 1220197
Workaround for Neoverse N1 erratum 1207823
Workaround for Neoverse N1 erratum 1165347
Workaround for Neoverse N1 erratum 1130799
Workaround for Neoverse N1 erratum 1073348
Neoverse N1 erratum 1262888 is a Cat B erratum [1],
present in older revisions of the Neoverse N1 processor core.
The workaround is to set a bit in the implementation defined
CPUECTLR_EL1 system register, which disables the MMU hardware prefetcher.
[1] http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.pjdoc-466751330-10325/index.html
Change-Id: Ib733d748e32a7ea6a2783f3d5a9c5e13eee01105
Signed-off-by: Lauren Wehrmeister <lauren.wehrmeister@arm.com>
Neoverse N1 erratum 1262606 is a Cat B erratum [1],
CPUACTLR_EL1 system register, which delays instruction fetch after
branch misprediction.
Change-Id: Idd980e9d5310232d38f0ce272862e1fb0f02ce9a
Neoverse N1 erratum 1257314 is a Cat B erratum [1],
CPUACTLR3_EL1 system register, which prevents parallel
execution of divide and square root instructions.
Change-Id: I54f0f40ff9043efee40d51e796b92ed85b394cbb
Neoverse N1 erratum 1220197 is a Cat B erratum [1],
The workaround is to set two bits in the implementation defined
CPUECTLR_EL1 system register, which disables write streaming to the L2.
Change-Id: I9c3373f1b6d67d21ee71b2b80aec5e96826818e8
Neoverse N1 erratum 1207823 is a Cat B erratum [1],
CPUACTLR2_EL1 system register.
Change-Id: Ia932337821f1ef0d644db3612480462a8d924d21
Neoverse N1 erratum 1165347 is a Cat B erratum [1],
Change-Id: I163d0ea00578245c1323d2340314cdc3088c450d
Neoverse N1 erratum 1130799 is a Cat B erratum [1],
Change-Id: I252bc45f9733443ba0503fefe62f50fdea61da6d
Neoverse N1 erratum 1073348 is a Cat B erratum [1],
CPUACTLR_EL1 system register, which disables static prediction.
Change-Id: I674126c0af6e068eecb379a190bcf7c75dcbca8e
