Add tzc380 support.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
Add interface to enable FIQ routing in SCR_EL3 to make
interrupts can wake up ARM from WFI when executing in EL3,
as all interrupts are signaled as FIQ in EL3.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Add bool/true/false type to make it easy for porting
code from other platforms.
This patch makes the necessary changes to enable ARM platform to
successfully integrate CryptoCell during Trusted Board Boot. The
changes are as follows:
* A new build option `ARM_CRYPTOCELL_INTEG` is introduced to select
the CryptoCell crypto driver for Trusted Board boot.
* The TrustZone filter settings for Non Secure DRAM is modified
to allow CryptoCell to read this memory. This is required to
authenticate BL33 which is loaded into the Non Secure DDR.
* The CSS platforms are modified to use coherent stacks in BL1 and BL2
when CryptoCell crypto is selected. This is because CryptoCell makes
use of DMA to transfer data and the CryptoCell SBROM library allocates
buffers on the stack during signature/hash verification.
Change-Id: I1e6f6dcd1899784f1edeabfa2a9f279bbfb90e31
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This patch adds header files with required declarations and
macro definitions to enable integration with CryptoCell SBROM
version `CC712 – Release 1.0.0.1061`. These headers enable ARM
Trusted Firmware to build and link with CryptoCell SBROM
library.
Change-Id: I501eda7fe1429acb61db8e1cab78cc9aee9c1871
Minor build fixes
aarch64: Enable Statistical Profiling Extensions for lower ELs
Fully initialise essential control registers
This change avoids warning when setting -Wmissing-prototypes to
compile bl1_context_mgmt.c.
Reported-by: Yann Gautier <yann.gautier@st.com>
Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
security_state is either 0 or 1. Prevent sign conversion potential
error (setting -Werror=sign-conversion results in a build error).
Signed-off-by: Yann Gautier <yann.gautier@st.com>
TLBI instructions for monitor mode won't have the desired effect under
specific circumstances in Cortex-A57 r0p0. The workaround is to
execute DSB and TLBI twice each time.
Even though this errata is only needed in r0p0, the current errata
framework is not prepared to apply run-time workarounds. The current one
is always applied if compiled in, regardless of the CPU or its revision.
The `DSB` instruction used when initializing the translation tables has
been changed to `DSB ISH` as an optimization and to be consistent with
the barriers used for the workaround.
NOTE: This workaround is present in AArch64 TF and already enabled by
default on Juno.
Change-Id: I10b0baa304ed64b13b7b26ea766e61461e759dfa
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
SPE is only supported in non-secure state. Accesses to SPE specific
registers from SEL1 will trap to EL3. During a world switch, before
`TTBR` is modified the SPE profiling buffers are drained. This is to
avoid a potential invalid memory access in SEL1.
SPE is architecturally specified only for AArch64.
Change-Id: I04a96427d9f9d586c331913d815fdc726855f6b0
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
This patch updates the el3_arch_init_common macro so that it fully
initialises essential control registers rather then relying on hardware
to set the reset values.
The context management functions are also updated to fully initialise
the appropriate control registers when initialising the non-secure and
secure context structures and when preparing to leave EL3 for a lower
EL.
This gives better alignement with the ARM ARM which states that software
must initialise RES0 and RES1 fields with 0 / 1.
This patch also corrects the following typos:
"NASCR definitions" -> "NSACR definitions"
Change-Id: Ia8940b8351dc27bc09e2138b011e249655041cfc
Signed-off-by: David Cunado <david.cunado@arm.com>
Fixes ARM-software/tf-issues#495
Change-Id: I6a0aea78f670cc199873218a18af1d9cc2a6fafd
This brings the implementation on par with the software
errata workarounds for AArch64.
Change-Id: Id103602e35b1c0ad3705a5b2b7cdb34dd8a8c5e2
On ARM platforms before exiting from SP_MIN ensure that
the default console is switched to the runtime serial port.
Change-Id: I0ca0d42cc47e345d56179eac16aa3d6712767c9b
This patch uses the U() and ULL() macros for constants, to fix some
of the signed-ness defects flagged by the MISRA scanner.
This patch adds the U(_x) macros to utils_def.h to allow constants to
be shared between C and other sources.
This patch makes all the defines in the CPU libraries unique,
by prefixing them with the CPU name.
NOTE: PLATFORMS USING THESE MACROS WILL HAVE TO UPDATE THEIR CODE
TO START USING THE UPDATED NAMES
Some of the macro defines in the header files of `include/lib/stdlib/machine/`
folder are not correct for AArch32. This patch fixes the same.
Change-Id: I8bfaf638a7986fd902648d2074537bd26c313cb3
Add the support of AARCH32 in endian head file. The code is also
imported from FreeBSD 11.0. It's based on commit in below.
commit 4e3a5b429989b4ff621682ff1462f801237bd551
Author: mmel <mmel@FreeBSD.org>
Date: Tue Nov 10 12:02:41 2015 +0000
ARM: Remove trailing whitespace from sys/arm/include
No functional changes.
Approved by: kib (mentor)
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Import endian head files from FreeBSD 11.0. The link of FreeBSD source code
is https://github.com/freebsd/freebsd
Import machine/endian.h from sys/arm64/include/endian.h in FreeBSD.
commit d09ff72cef8e35dbf62f7363dcbf07b453f06243
Author: andrew <andrew@FreeBSD.org>
Date: Mon Mar 23 11:54:56 2015 +0000
Add the start of the arm64 machine headers. This is the subset needed to
start getting userland libraries building.
Reviewed by: imp
Sponsored by: The FreeBSD Foundation
Import sys/endian.h from sys/sys/endian.h in FreeBSD.
commit 3c3fa2f5b0c7640373fcbcc3f667bf7794e8e609
Author: phk <phk@FreeBSD.org>
Date: Thu May 20 06:16:13 2010 +0000
Fix some way-past-brucification complaints from FlexeLint.
Add support for RSASSAPSS algorithm
Add SCMI power domain and system power protocol support
Add support for Cortex-A75 and Cortex-A55 CPUs
FWU: Check for overlaps when loading images, introduce `FWU_SMC_IMAGE_RESET`
This patch adds the memory map region for the SCMI payload memory
and maps the Juno core indices to SCMI power domains via the
`plat_css_core_pos_to_scmi_dmn_id_map` array.
Change-Id: I0d2bb2a719ff5b6a9d8e22e91e1625ab14453665
This patch adds the SCMI driver for communicating with SCP. The power
domain management and system power management protocol of the SCMI
specification[1] is implemented in the driver. The SCP power management
abstraction layer for SCMI for CSS power management is also added.
A new buid option `CSS_USE_SCMI_DRIVER` is introduced to select SCMI
driver over SCPI.
[1] ARM System Control and Management Interface v1.0 (SCMI)
Document number: ARM DEN 0056A
Change-Id: I67265615a17e679a2afe810b9b0043711ba09dbb
This patch adds support for RSASSA-PSS Signature Algorithm for
X509 certificates in mbedtls crypto driver. Now the driver supports
RSA PKCS2_1 standard as mandated by TBBR.
NOTE: With this patch, the PKCS1_5 standard compliant RSA signature
is deprecated.
Change-Id: I9cf6d073370b710cc36a7b374a55ec96c0496461
This SMC is as a means for the image loading state machine to go from
COPYING, COPIED or AUTHENTICATED states to RESET state. Previously, this
was only done when the authentication of an image failed or when the
execution of the image finished.
Documentation updated.
Change-Id: Ida6d4c65017f83ae5e27465ec36f54499c6534d9
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Both Cortex-A75 and Cortex-A55 CPUs use the ARM DynamIQ Shared Unit
(DSU). The power-down and power-up sequences are therefore mostly
managed in hardware, and required software operations are considerably
simpler.
Change-Id: I68b30e6e1ebe7c041d5e67f39c59f08575fc7ecc
Co-authored-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
Add ufs stack and designware phy
Initialized the designware UFS PHY.
If UFS device is initialized, we could just make it out of
hibernation by UFS_FLAGS_SKIPINIT. And vendor's dirver is always
focus on PHY setting. We could use UFS driver directly if it
exits from hibernation.
There're eight LUNs in UFS device. The UFS driver only provides
the read/write API with LUN. User could define his own read/write
since user may want to access different LUNs.
Reduce code size when building with Trusted Board Boot enabled
Add some bit definitions of CPUACTLR register in Cortex-A53
CPU library.
Change-Id: I142fd8ac4b06dd651a32e22951e71cdebbea123a
Signed-off-by: Dan Handley <dan.handley@arm.com>
Only the compiler is switched to clang. The assembler and linker are
provided by the GCC toolchain.
clang is used to build TF when the base name of the path assigned to
`CC` contains the string 'clang'.
`CROSS_COMPILE` is still needed and should point to the appropriate
GCC toolchain.
Tested with clang 3.9.x and 4.0.x.
Change-Id: I53236d64e3c83ad27fc843bae5fcdae30f2e325e
Collect headers shared between TF and host-tools into include/tools_share
The Trusted Firmware uses a subset of the APIs provided by mbed TLS.
This subset internally uses `snprintf`, but the only format specifier
used is '%d', which is supported by `tf_snprintf`.
This patch makes mbed TLS use `tf_snprintf` instead of `snprintf`,
saving 3 KB in both debug and release builds when TBBR is enabled.
Change-Id: I7f992a21015930d7c0f4660e7a28ceefd60b9597
This is a reduced version of `snprintf` that only supports formats '%d',
'%i' and '%u'. It can be used when the full `snprintf` is not needed in
order to save memory. If it finds an unknown format specifier, it
prints an error message and panics.
Change-Id: I2cb06fcdf74cda2c43caf73ae0762a91499fc04e
Platforms aligned with TBBR are supposed to use their own OIDs, but
defining the same macros with different OIDs does not provide any
value (at least technically).
For easier use of TBBR, this commit allows platforms to reuse the OIDs
obtained by ARM Ltd. This will be useful for non-ARM vendors that
do not need their own extension fields in their certificate files.
The OIDs of ARM Ltd. have been moved to include/tools_share/tbbr_oid.h
Platforms can include <tbbr_oid.h> instead of <platform_oid.h> by
defining USE_TBBR_DEFS as 1. USE_TBBR_DEFS is 0 by default to keep the
backward compatibility.
For clarification, I inserted a blank line between headers from the
include/ directory (#include <...>) and ones from a local directory
(#include "..." ).
Some header files need to be shared between TF and host programs.
For fiptool, two headers are copied to the tools/fiptool directory,
but it looks clumsy.
This commit introduces a new directory, include/tools_share, which
collects headers that should be shared between TF and host programs.
This will clarify the interface exposed to host tools. We should
add new headers to this directory only when we really need to do so.
(#include "..." ).
Add TBBR and FWU support for AArch32
Simplify assert() to reduce memory usage
mbedtls: Namespace update for TF specific macros
The behaviour of assert() now depends on the value of the new optional
platform define `PLAT_LOG_LEVEL_ASSERT`. This defaults to `LOG_LEVEL` if
not defined by the platform.
- If `PLAT_LOG_LEVEL_ASSERT` >= `LOG_LEVEL_VERBOSE`, it prints the file
name, line and asserted expression.
- If `PLAT_LOG_LEVEL_ASSERT` >= `LOG_LEVEL_INFO`, it prints the file
name and line.
- If not, it doesn't print anything.
Note the old behaviour was to print the function name whereas now it
prints the file name. This reduces memory usage because the file name is
shared between all assert calls in a given file. Also, the default
behaviour in debug builds is to no longer print the asserted expression,
greatly reducing the string usage.
For FVP debug builds this change saves approximately:
No TBBR TBBR
BL1 1.6 KB 2.2 KB
BL2 1.7 KB 2.1 KB
BL31 2.6 KB 3.3 KB
Change-Id: I2947569d593df0b25611dc3c7a6096f42155c115
Add support for firmware upgrade on AArch32.
This patch has been tested on the FVP models.
NOTE: Firmware upgrade on Juno AArch32 is not currently supported.
Change-Id: I1ca8078214eaf86b46463edd14740120af930aec
Co-Authored-By: Yatharth Kochar <yatharth.kochar@arm.com>
This patch adds `TRUSTED_BOARD_BOOT` support for AArch32 mode.
To build this patch the "mbedtls/include/mbedtls/bignum.h"
needs to be modified to remove `#define MBEDTLS_HAVE_UDBL`
when `MBEDTLS_HAVE_INT32` is defined. This is a workaround
for "https://github.com/ARMmbed/mbedtls/issues/708"
NOTE: TBBR support on Juno AArch32 is not currently supported.
Change-Id: I86d80e30b9139adc4d9663f112801ece42deafcf
Minor fixes to the xlat tables lib v2
