Implement support for SMCCC v1.1 and optimize security mitigations for CVE-2017-5715 on AArch64
Add amu_context_save() and amu_context_restore() functions for aarch32
Change-Id: I4df83d447adeaa9d9f203e16dc5a919ffc04d87a
Signed-off-by: Joel Hutton <joel.hutton@arm.com>
Change-Id: Id6dfe885a63561b1d2649521bd020367b96ae1af
Fix udelay issues that can make duration slightly too short
In the initial implementation of this workaround we used a dedicated
workaround context to save/restore state. This patch reduces the
footprint as no additional context is needed.
Additionally, this patch reduces the memory loads and stores by 20%,
reduces the instruction count and exploits static branch prediction to
optimize the SMC path.
Change-Id: Ia9f6bf06fbf8a9037cfe7f1f1fb32e8aec38ec7d
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
SMCCC v1.1 comes with a relaxed calling convention for AArch64
callers. The caller only needs to save x0-x3 before doing an SMC
call.
This patch adds support for SMCCC_VERSION and SMCCC_ARCH_FEATURES.
Refer to "Firmware Interfaces for mitigating CVE_2017_5715 System
Software on Arm Systems"[0] for more information.
[0] https://developer.arm.com/-/media/developer/pdf/ARM%20DEN%200070A%20Firmware%20interfaces%20for%20mitigating%20CVE-2017-5715_V1.0.pdf
Change-Id: If5b1c55c17d6c5c7cb9c2c3ed355d3a91cdad0a9
SPM: Declare explicit width based types in secure_partition_boot_info…
Workarounds for CVE-2017-5715 on A9/A15 and A17 + serial console reporting
New console API and coreboot support [v4]
The current div_round_up() implementation relies on round_up() which
only works correctly for boundaries that are a power of 2. It is
documented as such, but this still seems dangerously easy to overlook,
especially since many other environments (e.g. the Linux kernel) have a
similar macro without these limitations.
There is a different way to calculate this that can deal with all kinds
of divisors without other drawbacks, so let's just use that instead.
Change-Id: Id382736683f5d4e880ef00c53cfa23a2f9208440
Signed-off-by: Julius Werner <jwerner@chromium.org>
structure
The secure_partition_boot_info_t structure is used to communicate boot
parameters with the StandaloneMM code executing at S-EL0 through a
shared buffer. Certain data types used for members of this structure
are opaque with their size depending on the toolchain being used.
Declare the members of the structure with explicit width based data
types, which would maintain compatibility across toolchains.
Signed-off-by: Sughosh Ganu <sughosh.ganu@arm.com>
emmc: add macros CMD21, BUS_WIDTH_DDR_4 and BUS_WIDTH_DDR_8
coreboot supports an in-memory console to store firmware logs even when
no serial console is available. It is widely supported by
coreboot-compatible bootloaders (including SeaBIOS and GRUB) and can be
read by the Linux kernel.
This patch allows BL31 to add its own log messages to this console. The
driver will be registered automatically if coreboot support is compiled
in and detects the presence of a console buffer in the coreboot tables.
Change-Id: I31254dfa0c2fdeb7454634134b5707b4b4154907
This patch adds the foundation for a platform-independent coreboot
support library that can be shared by all platforms that boot BL31 from
coreboot (acting as BL2). It adds code to parse the "coreboot table", a
data structure that coreboot uses to communicate different kinds of
information to later-stage firmware and certain OS drivers.
As a first small use case for this information, allow platforms to
access the serial console configuration used by coreboot, removing the
need to hardcode base address and divisors and allowing Trusted Firmware
to benefit from coreboot's user configuration (e.g. which UART to pick
and which baud rate to use).
Change-Id: I2bfb39cd2609ce6640b844ab68df6c9ae3f28e9e
This patch updates the Cadence CDNS console driver to support the new
console API. The driver will continue to support the old API as well by
checking the MULTI_CONSOLE_API compile-time flag.
Change-Id: I2ef8fb0d6ab72696997db1e0243a533499569d6b
This patch updates the ARM PL011 console driver to support the new
Change-Id: Ic34e4158addbb0c5fae500c9cff899c05a4f4206
This patch updates the TI 16550 console driver to support the new
Change-Id: I60a44b7ba3c35c74561824c04b8dbe3e3039324c
Add BL2_AT_EL3 build option
A per-cpu vbar is installed that implements the workaround by
invalidating the branch target buffer (BTB) directly in the case of A9
and A17 and indirectly by invalidating the icache in the case of A15.
For Cortex A57 and A72 there is currently no workaround implemented
when EL3 is in AArch32 mode so report it as missing.
For other vulnerable CPUs (e.g. Cortex A73 and Cortex A75), there are
no changes since there is currently no upstream AArch32 EL3 support
for these CPUs.
Change-Id: Ib42c6ef0b3c9ff2878a9e53839de497ff736258f
This patch introduces two workarounds for ARMv7 systems. The
workarounds need to be applied prior to any `branch` instruction in
secure world. This is achieved using a custom vector table where each
entry is an `add sp, sp, #1` instruction.
On entry to monitor mode, once the sequence of `ADD` instructions is
executed, the branch target buffer (BTB) is invalidated. The bottom
bits of `SP` are then used to decode the exception entry type.
A side effect of this change is that the exception vectors are
installed before the CPU specific reset function. This is now
consistent with how it is done on AArch64.
Note, on AArch32 systems, the exception vectors are typically tightly
integrated with the secure payload (e.g. the Trusted OS). This
workaround will need porting to each secure payload that requires it.
The patch to modify the AArch32 per-cpu vbar to the corresponding
workaround vector table according to the CPU type will be done in a
later patch.
Change-Id: I5786872497d359e496ebe0757e8017fa98f753fa
This patch change the name of the section containing the functions
defined in assembly files from text.* to text.asm.*. This change
makes possible to select in the linker script the functions
defined in those files.
Change-Id: If35e44ef1b43ffd951dfac5e052db75d7198e2e0
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
This patch add supports for the new API added for BL2 at EL3 for
FVP. We don't have a non-TF Boot ROM for FVP, but this option can be
tested setting specific parameters in the model.
The bl2 image is loaded directly in memory instead of being loaded
by a non-TF Boot ROM and the reset address is changed:
--data cluster0.cpu0=bl2.bin@0x4001000
-C cluster0.cpu0.RVBAR=0x4001000
These parameters mean that in the cold boot path the processor will
jump to BL2 again. For this reason, BL2 is loaded in dram in this
case, to avoid other images reclaiming BL2 memory.
Change-Id: Ieb2ff8535a9e67ccebcd8c2212cad366e7776422
This patch enables BL2 to execute at the highest exception level
without any dependancy on TF BL1. This enables platforms which already
have a non-TF Boot ROM to directly load and execute BL2 and subsequent BL
stages without need for BL1. This is not currently possible because
BL2 executes at S-EL1 and cannot jump straight to EL3.
Change-Id: Ief1efca4598560b1b8c8e61fbe26d1f44e929d69
Add some macros according to JEDEC Standard Embedded Multi-Media
Card (eMMC) Electrical Standard (5.1)": Table 145 - Bus Mode
Selection.
Change-Id: Iaa45e0582653ef4290efd60d039f0bdc420eeb47
Signed-off-by: Qixiang Xu <qixiang.xu@arm.com>
typedef mem_region_t mem_region_t;
... seems to work because they belong to different name-spaces,
but humans are confused even if compilers are not.
SPM: Fix version header definitions
spd: tlkd: support for "NS memory ranges" function ID
AMUv1 support
Workarounds for CVE-2017-5715 on Cortex A57/A72/A73 and A75
On some build configurations BL31 is running out of space. Now that
TSP is moved to secure dram, we have a bit of additional space to use
in BL31.
Change-Id: Ib89fcd8bae99c85c9c5e5d9228bb42fb7048dcb6
Signed-off-by: David Cunado <david.cunado@arm.com>
Change-Id: I504d3f65ca5829bc1f4ebadb764931f8379ee81f
On some systems, the AMU counters might reset to 0 when a CPU
powerdown happens. This behaviour conflicts with the intended
use-case of AMU as lower ELs are only expected to see non-decreasing
counter values.
Change-Id: If25519965d4e6e47e09225d0e732947986cbb5ec
Add some AMU helper functions to allow configuring, reading and
writing of the Group 0 and Group 1 counters. Documentation for these
helpers will come in a separate patch.
Change-Id: I656e070d2dae830c22414f694aa655341d4e2c40
A new platform macro `PLAT_AMU_GROUP1_COUNTERS_MASK` controls which
group 1 counters should be enabled. The maximum number of group 1
counters supported by AMUv1 is 16 so the mask can be at most 0xffff.
If the platform does not define this mask, no group 1 counters are
enabled.
A related platform macro `PLAT_AMU_GROUP1_NR_COUNTERS` is used by
generic code to allocate an array to save and restore the counters on
CPU suspend.
Change-Id: I6d135badf4846292de931a43bb563077f42bb47b
The suspend hook is published at the start of a CPU powerdown
operation. The resume hook is published at the end of a CPU powerup
operation.
Change-Id: I50c05e2dde0d33834095ac41b4fcea4c161bb434
If the CSV2 field reads as 1 then branch targets trained in one
context cannot affect speculative execution in a different context.
In that case skip the workaround on Cortex A75.
Change-Id: I4d5504cba516a67311fb5f0657b08f72909cbd38
Invalidate the Branch Target Buffer (BTB) on entry to EL3 by
temporarily dropping into AArch32 Secure-EL1 and executing the
`BPIALL` instruction.
This is achieved by using 3 vector tables. There is the runtime
vector table which is used to handle exceptions and 2 additional
tables which are required to implement this workaround. The
additional tables are `vbar0` and `vbar1`.
The sequence of events for handling a single exception is
as follows:
1) Install vector table `vbar0` which saves the CPU context on entry
to EL3 and sets up the Secure-EL1 context to execute in AArch32 mode
with the MMU disabled and I$ enabled. This is the default vector table.
2) Before doing an ERET into Secure-EL1, switch vbar to point to
another vector table `vbar1`. This is required to restore EL3 state
when returning from the workaround, before proceeding with normal EL3
exception handling.
3) While in Secure-EL1, the `BPIALL` instruction is executed and an
SMC call back to EL3 is performed.
4) On entry to EL3 from Secure-EL1, the saved context from step 1) is
restored. The vbar is switched to point to `vbar0` in preparation to
handle further exceptions. Finally a branch to the runtime vector
table entry is taken to complete the handling of the original
exception.
This workaround is enabled by default on the affected CPUs.
NOTE
There are 4 different stubs in Secure-EL1. Each stub corresponds to
an exception type such as Sync/IRQ/FIQ/SError. Each stub will move a
different value in `R0` before doing an SMC call back into EL3.
Without this piece of information it would not be possible to know
what the original exception type was as we cannot use `ESR_EL3` to
distinguish between IRQs and FIQs.
Change-Id: I90b32d14a3735290b48685d43c70c99daaa4b434
Invalidate the Branch Target Buffer (BTB) on entry to EL3 by disabling
and enabling the MMU. To achieve this without performing any branch
instruction, a per-cpu vbar is installed which executes the workaround
and then branches off to the corresponding vector entry in the main
vector table. A side effect of this change is that the main vbar is
configured before any reset handling. This is to allow the per-cpu
reset function to override the vbar setting.
Change-Id: I97788d38463a5840a410e3cea85ed297a1678265
Rename SP_VERSION macros to MM_VERSION, which is the name used in the MM
specification [1]. Also, a few more helper macros have been added.
MM-specific definitions have been moved to their own header file.
[1] http://infocenter.arm.com/help/topic/com.arm.doc.den0060a/DEN0060A_ARM_MM_Interface_Specification.pdf
Change-Id: Ia10e48c7e81a7a1f5eeca29a5270cae740a4a88a
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
This patch adds support to receive function ID with NS world's
memory ranges to provide the memory snapshot to TLK.
To allow BL31 to grow in SRAM, move TSP in TZC secured DRAM
by default.
Increase the BL31 max limit by one page.
Change-Id: Idd3479be02f0f9bafac2f275376d7db0c2015431
With this patch, ARM platforms are expected to define the macros
PLAT_ARM_SDEI_PRIVATE_EVENTS and PLAT_ARM_SDEI_SHARED_EVENTS as a list
of private and shared events, respectively. This allows for individual
platforms to define their own events.
Change-Id: I66851fdcbff83fd9568c2777ade9eb12df284b49
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
This patch overhauls the console API to allow for multiple console
instances of different drivers that are active at the same time. Instead
of binding to well-known function names (like console_core_init),
consoles now provide a register function (e.g. console_16550_register())
that will hook them into the list of active consoles. All console
operations will be dispatched to all consoles currently in the list.
The new API will be selected by the build-time option MULTI_CONSOLE_API,
which defaults to ${ERROR_DEPRECATED} for now. The old console API code
will be retained to stay backwards-compatible to older platforms, but
should no longer be used for any newly added platforms and can hopefully
be removed at some point in the future.
The new console API is intended to be used for both normal (bootup) and
crash use cases, freeing platforms of the need to set up the crash
console separately. Consoles can be individually configured to be active
active at boot (until first handoff to EL2), at runtime (after first
handoff to EL2), and/or after a crash. Console drivers should set a sane
default upon registration that can be overridden with the
console_set_scope() call. Code to hook up the crash reporting mechanism
to this framework will be added with a later patch.
This patch only affects AArch64, but the new API could easily be ported
to AArch32 as well if desired.
Change-Id: I35c5aa2cb3f719cfddd15565eb13c7cde4162549
In assembly code it can be useful to have a constant for the width of a
register in the current architecture, so this patch adds one to
<utils_def.h> and replaces the existing custom one in crash_reporting.S
with that. It also fixes up the BIT() macro in the same file so that it
can be safely used in assembly code.
Change-Id: I10513a311f3379e767396e6ddfbae8d2d8201464
Enable SVE for Non-secure world
SPM: Move S-EL1/S-EL0 xlat tables to TZC DRAM
Unify cache flush code path after image load
Rename some macros in SPM code
Replace magic numbers in linkerscripts by PAGE_SIZE
A new platform define, `PLAT_SP_IMAGE_XLAT_SECTION_NAME`, has been
introduced to select the section where the translation tables used by
the S-EL1/S-EL0 are placed.
This define has been used to move the translation tables to DRAM secured
by TrustZone.
Most of the extra needed space in BL31 when SPM is enabled is due to the
large size of the translation tables. By moving them to this memory
region we can save 44 KiB.
A new argument has been added to REGISTER_XLAT_CONTEXT2() to specify the
region where the translation tables have to be placed by the linker.
Change-Id: Ia81709b4227cb8c92601f0caf258f624c0467719
