Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
As per design team's suggestion, L2 cache's ECC & parity
should be enabled for A72 cluster.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add system_reset2 support for i.MX8QM/i.MX8QX to support
WARM/COLD/BOARD reset.
Change-Id: I497072575231730a216220f84a6d349a48eaf5e3
Signed-off-by: Balint Dobszay <balint.dobszay@arm.com>
Coherent I-cache is causing a prefetch violation where when the core
executes an instruction that has recently been modified, the core might
fetch a stale instruction which violates the ordering of instruction
fetches.
The workaround includes an instruction sequence to implementation
defined registers to trap all EL0 IC IVAU instructions to EL3 and a trap
handler to execute a TLB inner-shareable invalidation to an arbitrary
address followed by a DSB.
Signed-off-by: Lauren Wehrmeister <lauren.wehrmeister@arm.com>
Change-Id: Ic3b7cbb11cf2eaf9005523ef5578a372593ae4d6
Change-Id: I1ea2bf088f1e001cdbd377cbfb7c6a2866af0422
Signed-off-by: Imre Kis <imre.kis@arm.com>
Change-Id: I645442d52a295706948e2cac88c36c1a3cb0bc47
Not tested on FVP Model.
Change-Id: Iedebc5c1fbc7ea577e94142b7feafa5546f1f4f9
Signed-off-by: Artsem Artsemenka <artsem.artsemenka@arm.com>
This PSCI hook is similar to pwr_domain_on_finish but is
guaranteed to be invoked with the respective core and cluster are
participating in coherency. This will be necessary to safely invoke
the new GICv3 API which modifies shared GIC data structures concurrently.
Change-Id: I8e54f05c9d4ef5712184c9c18ba45ac97a29eb7a
Signed-off-by: Madhukar Pappireddy <madhukar.pappireddy@arm.com>
This patch provides the following features and makes modifications
listed below:
- Individual APIAKey key generation for each CPU.
- New key generation on every BL31 warm boot and TSP CPU On event.
- Per-CPU storage of APIAKey added in percpu_data[]
of cpu_data structure.
- `plat_init_apiakey()` function replaced with `plat_init_apkey()`
which returns 128-bit value and uses Generic timer physical counter
value to increase the randomness of the generated key.
The new function can be used for generation of all ARMv8.3-PAuth keys
- ARMv8.3-PAuth specific code placed in `lib\extensions\pauth`.
- New `pauth_init_enable_el1()` and `pauth_init_enable_el3()` functions
generate, program and enable APIAKey_EL1 for EL1 and EL3 respectively;
pauth_disable_el1()` and `pauth_disable_el3()` functions disable
PAuth for EL1 and EL3 respectively;
`pauth_load_bl31_apiakey()` loads saved per-CPU APIAKey_EL1 from
cpu-data structure.
- Combined `save_gp_pauth_registers()` function replaces calls to
`save_gp_registers()` and `pauth_context_save()`;
`restore_gp_pauth_registers()` replaces `pauth_context_restore()`
and `restore_gp_registers()` calls.
- `restore_gp_registers_eret()` function removed with corresponding
code placed in `el3_exit()`.
- Fixed the issue when `pauth_t pauth_ctx` structure allocated space
for 12 uint64_t PAuth registers instead of 10 by removal of macro
CTX_PACGAKEY_END from `include/lib/el3_runtime/aarch64/context.h`
and assigning its value to CTX_PAUTH_REGS_END.
- Use of MODE_SP_ELX and MODE_SP_EL0 macro definitions
in `msr spsel` instruction instead of hard-coded values.
- Changes in documentation related to ARMv8.3-PAuth and ARMv8.5-BTI.
Change-Id: Id18b81cc46f52a783a7e6a09b9f149b6ce803211
Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
integration
* changes:
mediatek: mt8183: Support coreboot configuration
mediatek: mt8183: support system reset
mediatek: mt8183: pass platform parameters
mediatek: mt8183: add GPIO driver
mediatek: mt8183: support system off
mediatek: mt8183: support CPU hotplug
mediatek: mt8183: refine GIC driver
Sparse warns this:
lib/libc/assert.c:29:6: error: symbol '__assert' redeclared with different type (originally declared at include/lib/libc/assert.h:36) - different modifiers
Add __dead2 to match the header declaration and C definition.
I also changed '__dead2 void' to 'void __dead2' for the consistency
with other parts.
Change-Id: Iefa4f0e787c24fa7e7e499d2e7baf54d4deb49ef
- Add DCM driver
- Add SPMC driver
- Implement core and cluster power on/off handlers
Change-Id: I902002f8ea6f98fd73bf259188162b10d3939c72
Signed-off-by: kenny liang <kenny.liang@mediatek.com>
This patch adds support for the new Memory Tagging Extension arriving in
ARMv8.5. MTE support is now enabled by default on systems that support
at EL0. To enable it at ELx for both the non-secure and the secure
world, the compiler flag CTX_INCLUDE_MTE_REGS includes register saving
and restoring when necessary in order to prevent register leakage
between the worlds.
Change-Id: I2d4ea993d6b11654ea0d4757d00ca20d23acf36c
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
This patch fixes an issue when secure world timing information
can be leaked because Secure Cycle Counter is not disabled.
For ARMv8.5 the counter gets disabled by setting MDCR_El3.SCCD
bit on CPU cold/warm boot.
For the earlier architectures PMCR_EL0 register is saved/restored
on secure world entry/exit from/to Non-secure state, and cycle
counting gets disabled by setting PMCR_EL0.DP bit.
'include\aarch64\arch.h' header file was tided up and new
ARMv8.5-PMU related definitions were added.
Change-Id: I6f56db6bc77504634a352388990ad925a69ebbfa
NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200
Signed-off-by: Julius Werner <jwerner@chromium.org>
NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
Change-Id: Ie0a94783d0c8e111ae19fd592304e6485f04ca29
integration
* changes:
plat/mediatek/mt81*: Use new bl31_params_parse() helper
plat/rockchip: Use new bl31_params_parse_helper()
Add helper to parse BL31 parameters (both versions)
Factor out cross-BL API into export headers suitable for 3rd party code
Use explicit-width data types in AAPCS parameter structs
plat/rockchip: Switch to use new common BL aux parameter library
Introduce lightweight BL platform parameter library
This patch adds a new include/export/ directory meant for inclusion in
third-party code. This is useful for cases where third-party code needs
to interact with TF-A interfaces and data structures (such as a custom
BL2-implementation like coreboot handing off to BL31). Directly
including headers from the TF-A repository avoids having to duplicate
all these definitions (and risk them going stale), but with the current
header structure this is not possible because handoff API definitions
are too deeply intertwined with other TF code/headers and chain-include
other headers that will not be available in the other environment.
The new approach aims to solve this by separating only the parts that
are really needed into these special headers that are self-contained and
will not chain-include other (non-export) headers. TF-A code should
never include them directly but should instead always include the
respective wrapper header, which will include the required prerequisites
(like <stdint.h>) before including the export header. Third-party code
can include the export headers via its own wrappers that make sure the
necessary definitions are available in whatever way that environment can
provide them.
Change-Id: Ifd769320ba51371439a8e5dd5b79c2516c3b43ab
This patch adds some common helper code to support a lightweight
platform parameter passing framework between BLs that has already been
used on Rockchip platforms but is more widely useful to others as well.
It can be used as an implementation for the SoC firmware configuration
file mentioned in the docs, and is primarily intended for platforms
that only require a handful of values to be passed and want to get by
without a libfdt dependency. Parameters are stored in a linked list and
the parameter space is split in generic and vendor-specific parameter
types. Generic types will be handled by this code whereas
vendor-specific types have to be handled by a vendor-specific handler
function that gets passed in.
Change-Id: If3413d44e86b99d417294ce8d33eb2fc77a6183f
Change-Id: Iab767e9937f5c6c8150953fcdc3b37e8ee83fa63
Signed-off-by: Louis Mayencourt <louis.mayencourt@arm.com>
This patch adds 128-bit integer types int128_t and uint128_t
for "__int128" and "unsigned __int128" supported by GCC and
Clang for AArch64.
Change-Id: I0e646d026a5c12a09fd2c71dc502082052256a94
Change-Id: I755e4c42242d9a052570fd1132ca3d937acadb13
Neoverse N1 erratum 1262888 is a Cat B erratum [1],
present in older revisions of the Neoverse N1 processor core.
The workaround is to set a bit in the implementation defined
CPUECTLR_EL1 system register, which disables the MMU hardware prefetcher.
[1] http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.pjdoc-466751330-10325/index.html
Change-Id: Ib733d748e32a7ea6a2783f3d5a9c5e13eee01105
Neoverse N1 erratum 1262606 is a Cat B erratum [1],
CPUACTLR_EL1 system register, which delays instruction fetch after
branch misprediction.
Change-Id: Idd980e9d5310232d38f0ce272862e1fb0f02ce9a
Neoverse N1 erratum 1257314 is a Cat B erratum [1],
CPUACTLR3_EL1 system register, which prevents parallel
execution of divide and square root instructions.
Change-Id: I54f0f40ff9043efee40d51e796b92ed85b394cbb
Neoverse N1 erratum 1220197 is a Cat B erratum [1],
The workaround is to set two bits in the implementation defined
CPUECTLR_EL1 system register, which disables write streaming to the L2.
Change-Id: I9c3373f1b6d67d21ee71b2b80aec5e96826818e8
Neoverse N1 erratum 1207823 is a Cat B erratum [1],
CPUACTLR2_EL1 system register.
Change-Id: Ia932337821f1ef0d644db3612480462a8d924d21
Neoverse N1 erratum 1165347 is a Cat B erratum [1],
Change-Id: I163d0ea00578245c1323d2340314cdc3088c450d
Neoverse N1 erratum 1130799 is a Cat B erratum [1],
Change-Id: I252bc45f9733443ba0503fefe62f50fdea61da6d
Neoverse N1 erratum 1073348 is a Cat B erratum [1],
CPUACTLR_EL1 system register, which disables static prediction.
Change-Id: I674126c0af6e068eecb379a190bcf7c75dcbca8e
Neoverse N1 erratum 1315703 is a Cat A (rare) erratum [1], present in
The workaround is to set a bit in the implementation defined CPUACTLR2_EL1
system register, which will disable the load-bypass-store feature.
[1] http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.pjdocpjdoc-466751330-1032/index.html
Change-Id: I5c708dbe0efa4daa0bcb6bd9622c5efe19c03af9
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
The workaround is added to the Cortex-A55 cpu specific file. The
workaround is disabled by default and have to be explicitly enabled by
the platform integrator.
Change-Id: I3e6fd10df6444122a8ee7d08058946ff1cc912f8
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
This patch adds the functionality needed for platforms to provide
Branch Target Identification (BTI) extension, introduced to AArch64
in Armv8.5-A by adding BTI instruction used to mark valid targets
for indirect branches. The patch sets new GP bit [50] to the stage 1
Translation Table Block and Page entries to denote guarded EL3 code
pages which will cause processor to trap instructions in protected
pages trying to perform an indirect branch to any instruction other
than BTI.
BTI feature is selected by BRANCH_PROTECTION option which supersedes
the previous ENABLE_PAUTH used for Armv8.3-A Pointer Authentication
and is disabled by default. Enabling BTI requires compiler support
and was tested with GCC versions 9.0.0, 9.0.1 and 10.0.0.
The assembly macros and helpers are modified to accommodate the BTI
instruction.
This is an experimental feature.
Note. The previous ENABLE_PAUTH build option to enable PAuth in EL3
is now made as an internal flag and BRANCH_PROTECTION flag should be
used instead to enable Pointer Authentication.
Note. USE_LIBROM=1 option is currently not supported.
Change-Id: Ifaf4438609b16647dc79468b70cd1f47a623362e
The workarounds for errata 1257314, 1262606, 1262888 and 1275112 are
added to the Cortex-A76 cpu specific file. The workarounds are disabled
by default and have to be explicitly enabled by the platform integrator.
Change-Id: I70474927374cb67725f829d159ddde9ac4edc343
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This patch forces all cacheable atomic instructions to be near, which
improves performance in highly contended parallelized use-cases.
Change-Id: I93fac62847f4af8d5eaaf3b52318c30893e947d3
Under certain near idle conditions, DSU may miss response transfers on
the ACE master or Peripheral port, leading to deadlock. This workaround
disables high-level clock gating of the DSU to prevent this.
Change-Id: I820911d61570bacb38dd325b3519bc8d12caa14b
Change-Id: I50708f6ccc33059fbfe6d36fd66351f0b894311f
Under specific conditions, the processor might issue an eviction and an
L2 cache clean operation to the interconnect in the wrong order. Set
the CPUACTLR.ENDCCASCI bit to 1 to avoid this.
Change-Id: Ide7393adeae04581fa70eb9173b742049fc3e050
Change-Id: I0a81f4ea94d41245cd5150de341b51fc70babffe
The Cortex-A12's primary part number is 0xC0D not 0xC0C, so
fix that to make the A12's cpu operations findable.
Change-Id: I4440a039cd57a2fe425fd8a8ec5499ca8e895e31
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Fix MIDR_EL1 value for Neoverse E1
Change-Id: I75ee39d78c81ecb528a671c0cfadfc2fe7b5d818
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
