Misra changes
Rule 8.4: A compatible declaration shall be visible when
an object or function with external linkage is defined.
Change-Id: I26e042cb251a6f9590afa1340fdac73e42f23979
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
Rule 8.3: All declarations of an object or function shall
use the same names and type qualifiers.
Change-Id: Iff384187c74a598a4e73f350a1893b60e9d16cec
When a Yielding SMC is preempted, it's possible that Non-secure world is
resumed afterwards. In this case, Non-secure execution would find itself
in a state where the SMC has returned. However, the dispatcher might not
get an opportunity to populate the corrected return code for having
been preempted, and therefore the caller of the Yielding SMC cannot
reliably determine whether the SMC had successfully completed or had
been preempted.
To solve this, this patch introduces a new parameter to the
ehf_allow_ns_preemption() API. An SPD, through this parameter, would
provide the expected error code when a Yielding SMC is preempted. EHF
can then populate the specified value in x0 of the Non-secure context so
that the caller of the Yielding SMC correctly identifies the SMC return
as a preemption.
Documentation updates to follow.
Change-Id: Ia9c3f8f03f9d72d81aa235eaae2ee0374b972e1e
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
When ARM Trusted Firmware is built with EL3_EXCEPTION_HANDLING=1,
EL3 interrupts (INTR_TYPE_EL3) will always preempt both Non-secure and
secure execution.
The interrupt management framework currently treats EL3 interrupt
routing as valid. For the above reason, this patch makes them invalid
when EL3_EXCEPTION_HANDLING is in effect.
Change-Id: I95bca8f5dc8df8eb0ff6f305cfba098611522a39
On GICv3 systems, as a side effect of adding provision to handle EL3
interrupts (unconditionally routing FIQs to EL3), pending Non-secure
interrupts (signalled as FIQs) may preempt execution in lower Secure ELs
[1]. This will inadvertently disrupt the semantics of Fast SMC
(previously called Atomic SMC) calls.
To retain semantics of Fast SMCs, the GIC PMR must be programmed to
prevent Non-secure interrupts from preempting Secure execution. To that
effect, two new functions in the Exception Handling Framework subscribe
to events introduced in an earlier commit:
- Upon 'cm_exited_normal_world', the Non-secure PMR is stashed, and
the PMR is programmed to the highest Non-secure interrupt priority.
- Upon 'cm_entering_normal_world', the previously stashed Non-secure
PMR is restored.
The above sequence however prevents Yielding SMCs from being preempted
by Non-secure interrupts as intended. To facilitate this, the public API
exc_allow_ns_preemption() is introduced that programs the PMR to the
original Non-secure PMR value. Another API
exc_is_ns_preemption_allowed() is also introduced to check if
exc_allow_ns_preemption() had been called previously.
API documentation to follow.
[1] On GICv2 systems, this isn't a problem as, unlike GICv3, pending NS
IRQs during Secure execution are signalled as IRQs, which aren't
routed to EL3.
Change-Id: Ief96b162b0067179b1012332cd991ee1b3051dd0
EHF is a framework that allows dispatching of EL3 interrupts to their
respective handlers in EL3.
This framework facilitates the firmware-first error handling policy in
which asynchronous exceptions may be routed to EL3. Such exceptions may
be handed over to respective exception handlers. Individual handlers
might further delegate exception handling to lower ELs.
The framework associates the delegated execution to lower ELs with a
priority value. For interrupts, this corresponds to the priorities
programmed in GIC; for other types of exceptions, viz. SErrors or
Synchronous External Aborts, individual dispatchers shall explicitly
associate delegation to a secure priority. In order to prevent lower
priority interrupts from preempting higher priority execution, the
framework provides helpers to control preemption by virtue of
programming Priority Mask register in the interrupt controller.
This commit allows for handling interrupts targeted at EL3. Exception
handlers own interrupts by assigning them a range of secure priorities,
and registering handlers for each priority range it owns.
Support for exception handling in BL31 image is enabled by setting the
build option EL3_EXCEPTION_HANDLING=1.
Documentation to follow.
NOTE: The framework assumes the priority scheme supported by platform
interrupt controller is compliant with that of ARM GIC architecture (v2
or later).
Change-Id: I7224337e4cea47c6ca7d7a4ca22a3716939f7e42
The GIC driver initialization currently allows an array of interrupts to
be configured as secure. Future use cases would require more interrupt
configuration other than just security, such as priority.
This patch introduces a new interrupt property array as part of both
GICv2 and GICv3 driver data. The platform can populate the array with
interrupt numbers and respective properties. The corresponding driver
initialization iterates through the array, and applies interrupt
configuration as required.
This capability, and the current way of supplying array (or arrays, in
case of GICv3) of secure interrupts, are however mutually exclusive.
Henceforth, the platform should supply either:
- A list of interrupts to be mapped as secure (the current way).
Platforms that do this will continue working as they were. With this
patch, this scheme is deprecated.
- A list of interrupt properties (properties include interrupt group).
Individual interrupt properties are specified via. descriptors of
type 'interrupt_prop_desc_t', which can be populated with the macro
INTR_PROP_DESC().
A run time assert checks that the platform doesn't specify both.
Henceforth the old scheme of providing list of secure interrupts is
deprecated. When built with ERROR_DEPRECATED=1, GIC drivers will require
that the interrupt properties are supplied instead of an array of secure
interrupts.
Add a section to firmware design about configuring secure interrupts.
Fixes ARM-software/tf-issues#262
Change-Id: I8eec29e72eb69dbb6bce77879febf32c95376942
SPIs can be routed to either a specific PE, or to any one of all
available PEs.
API documentation updated.
Change-Id: I28675f634568aaf4ea1aa8aa7ebf25b419a963ed
Co-authored-by: Yousuf A <yousuf.sait@arm.com>
This patch uses the U() and ULL() macros for constants, to fix some
of the signed-ness defects flagged by the MISRA scanner.
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
This patch introduces the PSCI Library interface. The major changes
introduced are as follows:
* Earlier BL31 was responsible for Architectural initialization during cold
boot via bl31_arch_setup() whereas PSCI was responsible for the same during
warm boot. This functionality is now consolidated by the PSCI library
and it does Architectural initialization via psci_arch_setup() during both
cold and warm boots.
* Earlier the warm boot entry point was always `psci_entrypoint()`. This was
not flexible enough as a library interface. Now PSCI expects the runtime
firmware to provide the entry point via `psci_setup()`. A new function
`bl31_warm_entrypoint` is introduced in BL31 and the previous
`psci_entrypoint()` is deprecated.
* The `smc_helpers.h` is reorganized to separate the SMC Calling Convention
defines from the Trusted Firmware SMC helpers. The former is now in a new
header file `smcc.h` and the SMC helpers are moved to Architecture specific
header.
* The CPU context is used by PSCI for context initialization and
restoration after power down (PSCI Context). It is also used by BL31 for SMC
handling and context management during Normal-Secure world switch (SMC
Context). The `psci_smc_handler()` interface is redefined to not use SMC
helper macros thus enabling to decouple the PSCI context from EL3 runtime
firmware SMC context. This enables PSCI to be integrated with other runtime
firmware using a different SMC context.
NOTE: With this patch the architectural setup done in `bl31_arch_setup()`
is done as part of `psci_setup()` and hence `bl31_platform_setup()` will be
invoked prior to architectural setup. It is highly unlikely that the platform
setup will depend on architectural setup and cause any failure. Please be
be aware of this change in sequence.
Change-Id: I7f497a08d33be234bbb822c28146250cb20dab73
This patch moves the PSCI services and BL31 frameworks like context
management and per-cpu data into new library components `PSCI` and
`el3_runtime` respectively. This enables PSCI to be built independently from
BL31. A new `psci_lib.mk` makefile is introduced which adds the relevant
PSCI library sources and gets included by `bl31.mk`. Other changes which
are done as part of this patch are:
* The runtime services framework is now moved to the `common/` folder to
enable reuse.
* The `asm_macros.S` and `assert_macros.S` helpers are moved to architecture
specific folder.
* The `plat_psci_common.c` is moved from the `plat/common/aarch64/` folder
to `plat/common` folder. The original file location now has a stub which
just includes the file from new location to maintain platform compatibility.
Most of the changes wouldn't affect platform builds as they just involve
changes to the generic bl1.mk and bl31.mk makefiles.
NOTE: THE `plat_psci_common.c` FILE HAS MOVED LOCATION AND THE STUB FILE AT
THE ORIGINAL LOCATION IS NOW DEPRECATED. PLATFORMS SHOULD MODIFY THEIR
MAKEFILES TO INCLUDE THE FILE FROM THE NEW LOCATION.
Change-Id: I6bd87d5b59424995c6a65ef8076d4fda91ad5e86
This patch fixes some coding guideline warnings reported by the checkpatch
script. Only files related to upcoming feature development have been fixed.
Change-Id: I26fbce75c02ed62f00493ed6c106fe7c863ddbc5
This patch reworks type usage in generic code, drivers and ARM platform files
to make it more portable. The major changes done with respect to
type usage are as listed below:
* Use uintptr_t for storing address instead of uint64_t or unsigned long.
* Review usage of unsigned long as it can no longer be assumed to be 64 bit.
* Use u_register_t for register values whose width varies depending on
whether AArch64 or AArch32.
* Use generic C types where-ever possible.
In addition to the above changes, this patch also modifies format specifiers
in print invocations so that they are AArch64/AArch32 agnostic. Only files
related to upcoming feature development have been reworked.
Change-Id: I9f8c78347c5a52ba7027ff389791f1dad63ee5f8
This patch adds following optional PSCI STAT functions:
- PSCI_STAT_RESIDENCY: This call returns the amount of time spent
in power_state in microseconds, by the node represented by the
`target_cpu` and the highest level of `power_state`.
- PSCI_STAT_COUNT: This call returns the number of times a
`power_state` has been used by the node represented by the
`target_cpu` and the highest power level of `power_state`.
These APIs provides residency statistics for power states that has
been used by the platform. They are implemented according to v1.0
of the PSCI specification.
By default this optional feature is disabled in the PSCI
implementation. To enable it, set the boolean flag
`ENABLE_PSCI_STAT` to 1. This also sets `ENABLE_PMF` to 1.
Change-Id: Ie62e9d37d6d416ccb1813acd7f616d1ddd3e8aff
This patch adds a new optional platform hook `pwr_domain_pwr_down_wfi()` in
the plat_psci_ops structure. This hook allows the platform to perform platform
specific actions including the wfi invocation to enter powerdown. This hook
is invoked by both psci_do_cpu_off() and psci_cpu_suspend_start() functions.
The porting-guide.md is also updated for the same.
This patch also modifies the `psci_power_down_wfi()` function to invoke
`plat_panic_handler` incase of panic instead of the busy while loop.
Fixes ARM-Software/tf-issues#375
Change-Id: Iba104469a1445ee8d59fb3a6fdd0a98e7f24dfa3
Migrate all direct usage of __attribute__ to usage of their
corresponding macros from cdefs.h.
e.g.:
- __attribute__((unused)) -> __unused
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
This patch changes the anonymous initialization of `rt_svc_desc_t` structure
by the `DECLARE_RT_SVC` macro to designated initialization. This makes the
code more robust and less sensitive to potential changes to the
`rt_svc_desc_t` structure.
Change-Id: If6f1586730c0d29d92ef09e07eff7dd0d22857c7
Change-Id: I6f49bd779f2a4d577c6443dd160290656cdbc59b
The upcoming Firmware Update feature needs transitioning across
Secure/Normal worlds to complete the FWU process and hence requires
context management code to perform this task.
Currently context management code is part of BL31 stage only.
This patch moves the code from (include)/bl31 to (include)/common.
Some function declarations/definitions and macros have also moved
to different files to help code sharing.
Change-Id: I3858b08aecdb76d390765ab2b099f457873f7b0c
This patch enables support for EL3 interrupts in the Interrupt Management
Framework (IMF) of ARM Trusted Firmware. Please note that although the
registration of the EL3 interrupt type is now supported, it has not been
tested on any of the ARM Standard platforms.
Change-Id: If4dcdc7584621522a2f3ea13ea9b1ad0a76bb8a1
Re-design bakery lock allocation and algorithm
This patch unifies the bakery lock api's across coherent and normal
memory implementation of locks by using same data type `bakery_lock_t`
and similar arguments to functions.
A separate section `bakery_lock` has been created and used to allocate
memory for bakery locks using `DEFINE_BAKERY_LOCK`. When locks are
allocated in normal memory, each lock for a core has to spread
across multiple cache lines. By using the total size allocated in a
separate cache line for a single core at compile time, the memory for
other core locks is allocated at link time by multiplying the single
core locks size with (PLATFORM_CORE_COUNT - 1). The normal memory lock
algorithm now uses lock address instead of the `id` in the per_cpu_data.
For locks allocated in coherent memory, it moves locks from
tzfw_coherent_memory to bakery_lock section.
The bakery locks are allocated as part of bss or in coherent memory
depending on usage of coherent memory. Both these regions are
initialised to zero as part of run_time_init before locks are used.
Hence, bakery_lock_init() is made an empty function as the lock memory
is already initialised to zero.
The above design lead to the removal of psci bakery locks from
non_cpu_power_pd_node to psci_locks.
NOTE: THE BAKERY LOCK API WHEN USE_COHERENT_MEM IS NOT SET HAS CHANGED.
THIS IS A BREAKING CHANGE FOR ALL PLATFORM PORTS THAT ALLOCATE BAKERY
LOCKS IN NORMAL MEMORY.
Change-Id: Ic3751c0066b8032dcbf9d88f1d4dc73d15f61d8b
In certain Trusted OS implementations it is a requirement to pass them the
highest power level which will enter a power down state during a PSCI
CPU_SUSPEND or SYSTEM_SUSPEND API invocation. This patch passes this power level
to the SPD in the "max_off_pwrlvl" parameter of the svc_suspend() hook.
Currently, the highest power level which was requested to be placed in a low
power state (retention or power down) is passed to the SPD svc_suspend_finish()
hook. This hook is called after emerging from the low power state. It is more
useful to pass the highest power level which was powered down instead. This
patch does this by changing the semantics of the parameter passed to an SPD's
svc_suspend_finish() hook. The name of the parameter has been changed from
"suspend_level" to "max_off_pwrlvl" as well. Same changes have been made to the
parameter passed to the tsp_cpu_resume_main() function.
NOTE: THIS PATCH CHANGES THE SEMANTICS OF THE EXISTING "svc_suspend_finish()"
API BETWEEN THE PSCI AND SPD/SP IMPLEMENTATIONS. THE LATTER MIGHT NEED
UPDATES TO ENSURE CORRECT BEHAVIOUR.
Change-Id: If3a9d39b13119bbb6281f508a91f78a2f46a8b90
This patch reworks the PSCI generic implementation to conform to ARM
Trusted Firmware coding guidelines as described here:
https://github.com/ARM-software/arm-trusted-firmware/wiki
This patch also reviews the use of signed data types within PSCI
Generic code and replaces them with their unsigned counterparts wherever
they are not appropriate. The PSCI_INVALID_DATA macro which was defined
to -1 is now replaced with PSCI_INVALID_PWR_LVL macro which is defined
to PLAT_MAX_PWR_LVL + 1.
Change-Id: Iaea422d0e46fc314e0b173c2b4c16e0d56b2515a
As per PSCI1.0 specification, the error code to be returned when an invalid
non secure entrypoint address is specified by the PSCI client for CPU_SUSPEND,
CPU_ON or SYSTEM_SUSPEND must be PSCI_E_INVALID_ADDRESS. The current PSCI
implementation returned PSCI_E_INVAL_PARAMS. This patch rectifies this error
and also implements a common helper function to validate the entrypoint
information to be used across these PSCI API implementations.
Change-Id: I52d697d236c8bf0cd3297da4008c8e8c2399b170
This patch migrates the rest of Trusted Firmware excluding Secure Payload and
the dispatchers to the new platform and context management API. The per-cpu
data framework APIs which took MPIDRs as their arguments are deleted and only
the ones which take core index as parameter are retained.
Change-Id: I839d05ad995df34d2163a1cfed6baa768a5a595d
This patch defines deprecated platform APIs to enable Trusted
Firmware components like Secure Payload and their dispatchers(SPD)
to continue to build and run when platform compatibility is disabled.
This decouples the migration of platform ports to the new platform API
from SPD and enables them to be migrated independently. The deprecated
platform APIs defined in this patch are : platform_get_core_pos(),
platform_get_stack() and platform_set_stack().
The patch also deprecates MPIDR based context management helpers like
cm_get_context_by_mpidr(), cm_set_context_by_mpidr() and cm_init_context().
A mechanism to deprecate APIs and identify callers of these APIs during
build is introduced, which is controlled by the build flag WARN_DEPRECATED.
If WARN_DEPRECATED is defined to 1, the users of the deprecated APIs will be
flagged either as a link error for assembly files or compile time warning
for C files during build.
Change-Id: Ib72c7d5dc956e1a74d2294a939205b200f055613
This commit does the switch to the new PSCI framework implementation replacing
the existing files in PSCI folder with the ones in PSCI1.0 folder. The
corresponding makefiles are modified as required for the new implementation.
The platform.h header file is also is switched to the new one
as required by the new frameworks. The build flag ENABLE_PLAT_COMPAT defaults
to 1 to enable compatibility layer which let the existing platform ports to
continue to build and run with minimal changes.
The default weak implementation of platform_get_core_pos() is now removed from
platform_helpers.S and is provided by the compatibility layer.
Note: The Secure Payloads and their dispatchers still use the old platform
and framework APIs and hence it is expected that the ENABLE_PLAT_COMPAT build
flag will remain enabled in subsequent patch. The compatibility for SPDs using
the older APIs on platforms migrated to the new APIs will be added in the
following patch.
Change-Id: I18c51b3a085b564aa05fdd98d11c9f3335712719
The new PSCI topology framework and PSCI extended State framework introduces
a breaking change in the platform port APIs. To ease the migration of the
platform ports to the new porting interface, a compatibility layer is
introduced which essentially defines the new platform API in terms of the
old API. The old PSCI helpers to retrieve the power-state, its associated
fields and the highest coordinated physical OFF affinity level of a core
are also implemented for compatibility. This allows the existing
platform ports to work with the new PSCI framework without significant
rework. This layer will be enabled by default once the switch to the new
PSCI framework is done and is controlled by the build flag ENABLE_PLAT_COMPAT.
Change-Id: I4b17cac3a4f3375910a36dba6b03d8f1700d07e3
There used to be 2 warm reset entry points:
- the "on finisher", for when the core has been turned on using a
PSCI CPU_ON call;
- the "suspend finisher", entered upon resumption from a previous
PSCI CPU_SUSPEND call.
The appropriate warm reset entry point used to be programmed into the
mailboxes by the power management hooks.
However, it is not required to provide this information to the PSCI
entry point code, as it can figure it out by itself. By querying affinity
info state, a core is able to determine on which execution path it is.
If the state is ON_PENDING then it means it's been turned on else
it is resuming from suspend.
This patch unifies the 2 warm reset entry points into a single one:
psci_entrypoint(). The patch also implements the necessary logic
to distinguish between the 2 types of warm resets in the power up
finisher.
The plat_setup_psci_ops() API now takes the
secure entry point as an additional parameter to enable the platforms
to configure their mailbox. The platform hooks `pwr_domain_on`
and `pwr_domain_suspend` no longer take secure entry point as
a parameter.
Change-Id: I7d1c93787b54213aefdbc046b8cd66a555dfbfd9
The state-id field in the power-state parameter of a CPU_SUSPEND call can be
used to describe composite power states specific to a platform. The current PSCI
implementation does not interpret the state-id field. It relies on the target
power level and the state type fields in the power-state parameter to perform
state coordination and power management operations. The framework introduced
in this patch allows the PSCI implementation to intepret generic global states
like RUN, RETENTION or OFF from the State-ID to make global state coordination
decisions and reduce the complexity of platform ports. It adds support to
involve the platform in state coordination which facilitates the use of
composite power states and improves the support for entering standby states
at multiple power domains.
The patch also includes support for extended state-id format for the power
state parameter as specified by PSCIv1.0.
The PSCI implementation now defines a generic representation of the power-state
parameter. It depends on the platform port to convert the power-state parameter
(possibly encoding a composite power state) passed in a CPU_SUSPEND call to this
representation via the `validate_power_state()` plat_psci_ops handler. It is an
array where each index corresponds to a power level. Each entry contains the
local power state the power domain at that power level could enter.
The meaning of the local power state values is platform defined, and may vary
between levels in a single platform. The PSCI implementation constrains the
values only so that it can classify the state as RUN, RETENTION or OFF as
required by the specification:
* zero means RUN
* all OFF state values at all levels must be higher than all RETENTION
* the platform provides PLAT_MAX_RET_STATE and PLAT_MAX_OFF_STATE values
to the framework
The platform also must define the macros PLAT_MAX_RET_STATE and
PLAT_MAX_OFF_STATE which lets the PSCI implementation find out which power
domains have been requested to enter a retention or power down state. The PSCI
implementation does not interpret the local power states defined by the
platform. The only constraint is that the PLAT_MAX_RET_STATE <
PLAT_MAX_OFF_STATE.
For a power domain tree, the generic implementation maintains an array of local
power states. These are the states requested for each power domain by all the
cores contained within the domain. During a request to place multiple power
domains in a low power state, the platform is passed an array of requested
power-states for each power domain through the plat_get_target_pwr_state()
API. It coordinates amongst these states to determine a target local power
state for the power domain. A default weak implementation of this API is
provided in the platform layer which returns the minimum of the requested
power-states back to the PSCI state coordination.
Finally, the plat_psci_ops power management handlers are passed the target
local power states for each affected power domain using the generic
representation described above. The platform executes operations specific to
these target states.
The platform power management handler for placing a power domain in a standby
state (plat_pm_ops_t.pwr_domain_standby()) is now only used as a fast path for
placing a core power domain into a standby or retention state should now be
used to only place the core power domain in a standby or retention state.
The extended state-id power state format can be enabled by setting the
build flag PSCI_EXTENDED_STATE_ID=1 and it is disabled by default.
Change-Id: I9d4123d97e179529802c1f589baaa4101759d80c
This patch removes the assumption in the current PSCI implementation that MPIDR
based affinity levels map directly to levels in a power domain tree. This
enables PSCI generic code to support complex power domain topologies as
envisaged by PSCIv1.0 specification. The platform interface for querying
the power domain topology has been changed such that:
1. The generic PSCI code does not generate MPIDRs and use them to query the
platform about the number of power domains at a particular power level. The
platform now provides a description of the power domain tree on the SoC
through a data structure. The existing platform APIs to provide the same
information have been removed.
2. The linear indices returned by plat_core_pos_by_mpidr() and
plat_my_core_pos() are used to retrieve core power domain nodes from the
power domain tree. Power domains above the core level are accessed using a
'parent' field in the tree node descriptors.
The platform describes the power domain tree in an array of 'unsigned
char's. The first entry in the array specifies the number of power domains at
the highest power level implemented in the system. Each susbsequent entry
corresponds to a power domain and contains the number of power domains that are
its direct children. This array is exported to the generic PSCI implementation
via the new `plat_get_power_domain_tree_desc()` platform API.
The PSCI generic code uses this array to populate its internal power domain tree
using the Breadth First Search like algorithm. The tree is split into two
arrays:
1. An array that contains all the core power domain nodes
2. An array that contains all the other power domain nodes
A separate array for core nodes allows certain core specific optimisations to
be implemented e.g. remove the bakery lock, re-use per-cpu data framework for
storing some information.
Entries in the core power domain array are allocated such that the
array index of the domain is equal to the linear index returned by
plat_core_pos_by_mpidr() and plat_my_core_pos() for the MPIDR
corresponding to that domain. This relationship is key to be able to use
an MPIDR to find the corresponding core power domain node, traverse to higher
power domain nodes and index into arrays that contain core specific
information.
An introductory document has been added to briefly describe the new interface.
Change-Id: I4b444719e8e927ba391cae48a23558308447da13
This patch introduces new platform APIs and context management helper APIs
to support the new topology framework based on linear core position. This
framework will be introduced in the follwoing patch and it removes the
assumption that the MPIDR based affinity levels map directly to levels
in a power domain tree. The new platforms APIs and context management
helpers based on core position are as described below:
* plat_my_core_pos() and plat_core_pos_by_mpidr()
These 2 new mandatory platform APIs are meant to replace the existing
'platform_get_core_pos()' API. The 'plat_my_core_pos()' API returns the
linear index of the calling core and 'plat_core_pos_by_mpidr()' returns
the linear index of a core specified by its MPIDR. The latter API will also
validate the MPIDR passed as an argument and will return an error code (-1)
if an invalid MPIDR is passed as the argument. This enables the caller to
safely convert an MPIDR of another core to its linear index without querying
the PSCI topology tree e.g. during a call to PSCI CPU_ON.
Since the 'plat_core_pos_by_mpidr()' API verifies an MPIDR, which is always
platform specific, it is no longer possible to maintain a default implementation
of this API. Also it might not be possible for a platform port to verify an
MPIDR before the C runtime has been setup or the topology has been initialized.
This would prevent 'plat_core_pos_by_mpidr()' from being callable prior to
topology setup. As a result, the generic Trusted Firmware code does not call
this API before the topology setup has been done.
The 'plat_my_core_pos' API should be able to run without a C runtime.
Since this API needs to return a core position which is equal to the one
returned by 'plat_core_pos_by_mpidr()' API for the corresponding MPIDR,
this too cannot have default implementation and is a mandatory API for
platform ports. These APIs will be implemented by the ARM reference platform
ports later in the patch stack.
* plat_get_my_stack() and plat_set_my_stack()
These APIs are the stack management APIs which set/return stack addresses
appropriate for the calling core. These replace the 'platform_get_stack()' and
'platform_set_stack()' APIs. A default weak MP version and a global UP version
of these APIs are provided for the platforms.
* Context management helpers based on linear core position
A set of new context management(CM) helpers viz cm_get_context_by_index(),
cm_set_context_by_index(), cm_init_my_context() and cm_init_context_by_index()
are defined which are meant to replace the old helpers which took MPIDR
as argument. The old CM helpers are implemented based on the new helpers to
allow for code consolidation and will be deprecated once the switch to the new
framework is done.
Change-Id: I89758632b370c2812973a4b2efdd9b81a41f9b69
As per Section 4.2.2. in the PSCI specification, the term "affinity"
is used in the context of describing the hierarchical arrangement
of cores. This often, but not always, maps directly to the processor
power domain topology of the system. The current PSCI implementation
assumes that this is always the case i.e. MPIDR based levels of
affinity always map to levels in a power domain topology tree.
This patch is the first in a series of patches which remove this
assumption. It removes all occurences of the terms "affinity
instances and levels" when used to describe the power domain
topology. Only the terminology is changed in this patch. Subsequent
patches will implement functional changes to remove the above
mentioned assumption.
Change-Id: Iee162f051b228828310610c5a320ff9d31009b4e
This patch optimizes the invocation of the platform power management hooks for
ON, OFF and SUSPEND such that they are called only for the highest affinity
level which will be powered off/on. Earlier, the hooks were being invoked for
all the intermediate levels as well.
This patch requires that the platforms migrate to the new semantics of the PM
hooks. It also removes the `state` parameter from the pm hooks as the `afflvl`
parameter now indicates the highest affinity level for which power management
operations are required.
Change-Id: I57c87931d8a2723aeade14acc710e5b78ac41732
This patch creates a copy of the existing PSCI files and related psci.h and
platform.h header files in a new `PSCI1.0` directory. The changes for the
new PSCI power domain topology and extended state-ID frameworks will be
added incrementally to these files. This incremental approach will
aid in review and in understanding the changes better. Once all the
changes have been introduced, these files will replace the existing PSCI
files.
Change-Id: Ibb8a52e265daa4204e34829ed050bddd7e3316ff
This patch adds support for SYSTEM_SUSPEND API as mentioned in the PSCI 1.0
specification. This API, on being invoked on the last running core on a
supported platform, will put the system into a low power mode with memory
retention.
The psci_afflvl_suspend() internal API has been reused as most of the actions
to suspend a system are the same as invoking the PSCI CPU_SUSPEND API with the
target affinity level as 'system'. This API needs the 'power state' parameter
for the target low power state. This parameter is not passed by the caller of
the SYSTEM_SUSPEND API. Hence, the platform needs to implement the
get_sys_suspend_power_state() platform function to provide this information.
Also, the platform also needs to add support for suspending the system to the
existing 'plat_pm_ops' functions: affinst_suspend() and
affinst_suspend_finish().
Change-Id: Ib6bf10809cb4e9b92f463755608889aedd83cef5
The cpu-ops pointer was initialized before enabling the data cache in the cold
and warm boot paths. This required a DCIVAC cache maintenance operation to
invalidate any stale cache lines resident in other cpus.
This patch moves this initialization to the bl31_arch_setup() function
which is always called after the data cache and MMU has been enabled.
This change removes the need:
1. for the DCIVAC cache maintenance operation.
2. to initialise the CPU ops upon resumption from a PSCI CPU_SUSPEND
call since memory contents are always preserved in this case.
Change-Id: Ibb2fa2f7460d1a1f1e721242025e382734c204c6
This patch provides an option to specify a interrupt routing model
where non-secure interrupts (IRQs) are routed to EL3 instead of S-EL1.
When such an interrupt occurs, the TSPD arranges a return to
the normal world after saving any necessary context. The interrupt
routing model to route IRQs to EL3 is enabled only during STD SMC
processing. Thus the pre-emption of S-EL1 is disabled during Fast SMC
and Secure Interrupt processing.
A new build option TSPD_ROUTE_NS_INT_EL3 is introduced to change
the non secure interrupt target execution level to EL3.
Fixes ARM-software/tf-issues#225
Change-Id: Ia1e779fbbb6d627091e665c73fa6315637cfdd32
This patch:
* Bumps the PSCI VERSION to 1.0. This means that
the PSCI_VERSION API will now return the value 0x00010000
to indicate the version as 1.0. The firmware remains
compatible with PSCI v0.2 clients.
* The firmware design guide is updated to document the
APIs supported by the Trusted Firmware generic code.
* The FVP Device Tree Sources (dts) and Blobs(dtb) are also
updated to add "psci-1.0" and "psci-0.2" to the list of
compatible PSCI versions.
Change-Id: Iafc2f549c92651dcd65d7e24a8aae35790d00f8a
This patch implements the PSCI_FEATURES function which is a mandatory
API in the PSCI 1.0 specification. A capability variable is
constructed during initialization by examining the plat_pm_ops and
spd_pm_ops exported by the platform and the Secure Payload Dispatcher.
This is used by the PSCI FEATURES function to determine which
PSCI APIs are supported by the platform.
Change-Id: I147ffc1bd5d90b469bd3cc4bbe0a20e95c247df7
This patch reworks the PSCI MIGRATE, MIGRATE_INFO_TYPE and
MIGRATE_INFO_UP_CPU support for Trusted Firmware. The
implementation does the appropriate validation of parameters
and invokes the appropriate hook exported by the SPD.
The TSP is a MP Trusted OS. Hence the ability to actually
migrate a Trusted OS has not been implemented. The
corresponding function is not populated in the spd_pm_hooks
structure for the TSPD.
The `spd_pm_ops_t` has undergone changes with this patch.
SPD PORTS MAY NEED TO BE UPDATED.
Fixes ARM-software/tf-issues#249
Change-Id: Iabd87521bf7c530a5e4506b6d3bfd4f1bf87604f
This patch allows the platform to validate the power_state and
entrypoint information from the normal world early on in PSCI
calls so that we can return the error safely. New optional
pm_ops hooks `validate_power_state` and `validate_ns_entrypoint`
are introduced to do this.
As a result of these changes, all the other pm_ops handlers except
the PSCI_ON handler are expected to be successful. Also, the PSCI
implementation will now assert if a PSCI API is invoked without the
corresponding pm_ops handler being registered by the platform.
NOTE : PLATFORM PORTS WILL BREAK ON MERGE OF THIS COMMIT. The
pm hooks have 2 additional optional callbacks and the return type
of the other hooks have changed.
Fixes ARM-Software/tf-issues#229
Change-Id: I036bc0cff2349187c7b8b687b9ee0620aa7e24dc
This patch adds support to save the "power state" parameter before the
affinity level specific handlers are called in a CPU_SUSPEND call.
This avoids the need to pass the power_state as a parameter to the
handlers and Secure Payload Dispatcher (SPD) suspend spd_pm_ops.
The power_state arguments in the spd_pm_ops operations are now reserved
and must not be used. The SPD can query the relevant power_state fields
by using the psci_get_suspend_afflvl() & psci_get_suspend_stateid() APIs.
NOTE: THIS PATCH WILL BREAK THE SPD_PM_OPS INTERFACE. HENCE THE SECURE
PAYLOAD DISPATCHERS WILL NEED TO BE REWORKED TO USE THE NEW INTERFACE.
Change-Id: I1293d7dc8cf29cfa6a086a009eee41bcbf2f238e
This patch removes the non-secure entry point information being passed
to the platform pm_ops which is not needed. Also, it removes the `mpidr`
parameter for platform pm hooks which are meant to do power management
operations only on the current cpu.
NOTE: PLATFORM PORTS MUST BE UPDATED AFTER MERGING THIS COMMIT.
Change-Id: If632376a990b7f3b355f910e78771884bf6b12e7
This patch moves the bakery locks out of coherent memory to normal memory.
This implies that the lock information needs to be placed on a separate cache
line for each cpu. Hence the bakery_lock_info_t structure is allocated in the
per-cpu data so as to minimize memory wastage. A similar platform per-cpu
data is introduced for the platform locks.
As a result of the above changes, the bakery lock api is completely changed.
Earlier, a reference to the lock structure was passed to the lock implementation.
Now a unique-id (essentially an index into the per-cpu data array) and an offset
into the per-cpu data for bakery_info_t needs to be passed to the lock
implementation.
Change-Id: I1e76216277448713c6c98b4c2de4fb54198b39e0
This patch fixes a crash due to corruption of cpu_ops
data structure. During the secondary CPU boot, after the
cpu_ops has been initialized in the per cpu-data, the
dcache lines need to invalidated so that the update in
memory can be seen later on when the dcaches are turned ON.
Also, after initializing the psci per cpu data, the dcache
lines are flushed so that they are written back to memory
and dirty dcache lines are avoided.
Fixes ARM-Software/tf-issues#271
Change-Id: Ia90f55e9882690ead61226eea5a5a9146d35f313
This patch introduces a framework which will allow CPUs to perform
implementation defined actions after a CPU reset, during a CPU or cluster power
down, and when a crash occurs. CPU specific reset handlers have been implemented
in this patch. Other handlers will be implemented in subsequent patches.
Also moved cpu_helpers.S to the new directory lib/cpus/aarch64/.
Change-Id: I1ca1bade4d101d11a898fb30fea2669f9b37b956
