path: root/fdts/fvp-foundation-motherboard.dtsi
2017-06-01Device tree changes to boot FreeBSD on FVPsAchin Gupta
FreeBSD does not understand #interrupt-map in a device tree. This prevents the GIC from being set up correctly. This patch removes the #interrupt-map in the device trees for the Base and Foundation FVPs. This enables correct boot of FreeBSD on these platforms. These changes have been tested with FreeBSD and an Ubuntu cloud image (ubuntu-16.04-server-cloudimg-arm64-uefi1.img) to ensure compatibility with Linux. Change-Id: I1347acdcf994ec4b1dd843ba32af9951aa54db73 Signed-off-by: Achin Gupta <achin.gupta@arm.com>
2016-12-14Fix incorrect copyright noticesAntonio Nino Diaz
Some files have incorrect copyright notices, this patch fixes all files with deviations from the standard notice. Change-Id: I66b73e78a50a235acb55f1e2ec2052a42c0570d2 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2014-08-19Add support for PSCI SYSTEM_OFF and SYSTEM_RESET APIsJuan Castillo
This patch adds support for SYSTEM_OFF and SYSTEM_RESET PSCI operations. A platform should export handlers to complete the requested operation. The FVP port exports fvp_system_off() and fvp_system_reset() as an example. If the SPD provides a power management hook for system off and system reset, then the SPD is notified about the corresponding operation so it can do some bookkeeping. The TSPD exports tspd_system_off() and tspd_system_reset() for that purpose. Versatile Express shutdown and reset methods have been removed from the FDT as new PSCI sys_poweroff and sys_reset services have been added. For those kernels that do not support yet these PSCI services (i.e. GICv3 kernel), the original dtsi files have been renamed to *-no_psci.dtsi. Fixes ARM-software/tf-issues#218 Change-Id: Ic8a3bf801db979099ab7029162af041c4e8330c8
2014-01-17Update year in copyright text to 2014Dan Handley
Change-Id: Ic7fb61aabae1d515b9e6baf3dd003807ff42da60
2013-12-05Enable third party contributionsDan Handley
- Add instructions for contributing to ARM Trusted Firmware. - Update copyright text in all files to acknowledge contributors. Change-Id: I9311aac81b00c6c167d2f8c889aea403b84450e5
2013-11-14FDTs for v5.2 Foundation modelHarry Liebel
- The Foundation FVP is a cut down version of the Base FVP and as such lacks some components. - Three FDTs are provided. fvp-foundation-gicv2legacy-psci: Use this when setting the Foundation FVP to use GICv2. In this mode the GIC is located at the VE location, as described in the VE platform memory map. fvp-foundation-gicv3-psci : Use this when setting the Foundation FVP to use GICv3. In this mode the GIC is located at the Base location, as described in the Base platform memory map. fvp-foundation-gicv2-psci : Use this when setting the Foundation FVP to use GICv3, but Linux is expected to use GICv2 emulation mode. In this mode the GIC is located at the Base location, but the GICv3 is used in GICv2 emulation mode. Change-Id: I9d69bcef35c64cc8f16550efe077f578e55aaae5
