path: root/fdts/fvp-base-gicv3-psci-aarch32.dts
2018-02-26FVP: Fix AArch32 dts for `interrupts` nodeSoby Mathew
The commit 8d2c497 changed the interrupt map in `rtsm_ve-motherboard.dtsi` for the Linux FDT sources to be compatible for FreeBSD. But this also introduced a regression for FVP AArch32 mode but was undetected till now because the corresponding DTB was not updated. This patch creates a new `rtsm_ve-motherboard-aarch32.dtsi` which reverts the change and is now included by the AArch32 DTS files. Change-Id: Ibefbbf43a91c8fb890f0fa7a22be91f0227dad34 Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2017-06-01Device tree changes to boot FreeBSD on FVPsAchin Gupta
FreeBSD does not understand #interrupt-map in a device tree. This prevents the GIC from being set up correctly. This patch removes the #interrupt-map in the device trees for the Base and Foundation FVPs. This enables correct boot of FreeBSD on these platforms. These changes have been tested with FreeBSD and an Ubuntu cloud image (ubuntu-16.04-server-cloudimg-arm64-uefi1.img) to ensure compatibility with Linux. Change-Id: I1347acdcf994ec4b1dd843ba32af9951aa54db73 Signed-off-by: Achin Gupta <achin.gupta@arm.com>
2016-10-11AArch32: Update user-guide and add DTBsSoby Mathew
This patch adds necessary updates for building and running Trusted Firmware for AArch32 to user-guide.md. The instructions for running on both `FVP_Base_AEMv8A-AEMv8A` in AArch32 mode and `FVP_Base_Cortex-A32x4` models are added. The device tree files for AArch32 Linux kernel are also added in the `fdts` folder. Change-Id: I0023b6b03e05f32637cb5765fdeda8c8df2d0d3e
