Add support for multiple Cryptocell revisions which
use different APIs.
This commit only refactors the existing code in preperation to the addition
of another Cryptocell revisions later on.
Signed-off-by: Gilad Ben-Yossef <gilad.benyossef@arm.com>
Change-Id: I16d80b31afb6edd56dc645fee5ea619cc74f09b6
Code using Cryptocell specific APIs was used as part of the
arm common board ROT support, instead of being abstracted
in Cryptocell specific driver code, creating two problems:
- Any none arm board that uses Cryptocell wuld need to
copy and paste the same code.
- Inability to cleanly support multiple versions of Cryptocell
API and products.
Move over Cryptocell specific API calls into the Cryptocell
driver, creating abstraction API where needed.
Change-Id: I9e03ddce90fcc47cfdc747098bece86dbd11c58e
integration
* changes:
rcar_gen3: drivers: ddr-a: Fix E3 DDR init coding style
rcar_gen3: drivers: ddr-a: Pass ddrBackup around
rcar_gen3: drivers: ddr-a: Inline ddr_init_e3.h
rcar_gen3: drivers: ddr-a: Fix V3M DDR init coding style
rcar_gen3: drivers: ddr-a: Fix D3 DDR init coding style
rcar_gen3: drivers: ddr-a: Replace {Read,Write}Reg_32() with mmio_{read,write}_32()
rcar_gen3: drivers: ddr-a: Unify register definitions
Update the skeleton implementation of the console interface.
The 32 bit version was outdated and has been copied from the 64 bit
version.
Change-Id: Ib3e4eb09402ffccb1a30c703a53829a7bf064dfe
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
* changes:
Enable -Wshift-overflow=2 to check for undefined shift behavior
Update base code to not rely on undefined overflow behaviour
Update hisilicon drivers to not rely on undefined overflow behaviour
Update synopsys drivers to not rely on undefined overflow behaviour
Update imx platform to not rely on undefined overflow behaviour
Update mediatek platform to not rely on undefined overflow behaviour
Update layerscape platform to not rely on undefined overflow behaviour
Update intel platform to not rely on undefined overflow behaviour
Update rockchip platform to not rely on undefined overflow behaviour
Update renesas platform to not rely on undefined overflow behaviour
Update meson platform to not rely on undefined overflow behaviour
Update marvell platform to not rely on undefined overflow behaviour
Coding style cleanup, no functional change.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Change-Id: I689418768e87a8c1b6eeeb9f1a48dfb333908017
Pass the ddrBackup variable around instead of making it a global variable.
Change-Id: Ib796181247712e464b77f5f8be5f851745727d74
NOTE: The camelcase is fixed in later patch.
Partly inline ddr_init_e3.h into ddr_init_e3.c . Drop duplicate
INITDRAM_* macros, which are defined in boot_init_dram.h .
Change-Id: I758661d337a86b6a07f82cd4067fbc149cbaed1e
Change-Id: I4f3e3812ffaa24fec50857756539b563eff33cdd
Change-Id: I9b26b838e8c45d9b4f53c67663ec94002dd9edfe
Replace ad-hoc register accessors with generic ones, remove the ad-hoc
implementation. No functional change.
Change-Id: I21446a00a38c6a39d6a48652c34f59814074e831
Unify boot_init_dram_regdef_*.h into boot_init_dram_regdef.h and
clean up it's coding style a bit.
Change-Id: Iae3375969c05f80209ebf7b1ebc3633a7f6317ff
Remove the ad-hoc BITn macros and replace them with generic BIT(n) macro.
Change-Id: I5d0b44d6cba5a69895fed505f6ff780d3574907f
Modify PFC code and rename macro of MFIS according to Errata of
Hardware User's Manual
Signed-off-by: Toshiyuki Ogasahara <toshiyuki.ogasahara.bo@hitachi.com>
Signed-off-by: Yoshifumi Hosoya <yoshifumi.hosoya.wj@renesas.com>
Change-Id: I0ece522647319286350843bbbe8b8ba8b0ae9bac
Modify RPC code according to Errata of Hardware User's Manual
Change-Id: I82d0a2136c7f18870842f84c49343977708eef1e
[IPL/DDR]
- Update H3, M3, M3N DDR setting rev.0.36.
Signed-off-by: Chiaki Fujii <chiaki.fujii.wj@renesas.com>
Change-Id: Ia4fc9456876a14a9cf3ced93163477974f6cc8bf
This consists of ensuring that the left operand of each shift is
unsigned when the operation might overflow into the sign bit.
Change-Id: I54560fe290e7dc52d364d0fe1c81a16f4c8d9a7b
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
[IPL/DDR]
- Update E3 DDR setting rev.0.12.
Signed-off-by: Hiroyuki Nakano <hiroyuki.nakano.cj@renesas.com>
Change-Id: Ic9fb7ed1cd7588fab169a99c4070a8dfc40038dc
Change-Id: I51278beacbe6da79853c3f0f0f94cd806fc9652c
Change-Id: Ib7ec8ed3423e9b9b32be2388520bc27ee28f6370
Change-Id: I78f386f5ac171d6e52383a3e42003e6fb3e96b57
Designware MMC DMA FIFO threshold shouldn't be changed as it broke
Poplar platform's uboot MMC
Signed-off-by: Tien Hock, Loh <tien.hock.loh@intel.com>
Change-Id: I87ec9d5a78e1bf45119cb73797e402b25a914c13
* changes:
qemu: use new console interface in aarch32
warp7: remove old console from makefile
Remove MULTI_CONSOLE_API flag and references to it
Console: removed legacy console API
The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
* changes:
intel: Add ncore ccu driver
intel: Fix watchdog driver structure
intel: Fix qspi driver write config
intel: Pull out common drivers into platform common
Signed-off-by: Hadi Asyrafi <muhammad.hadi.asyrafi.abdul.halim@intel.com>
Change-Id: Ib79e2c6fe6e66dec5004701133ad6a5f4c78f2fa
This interface has been deprecated in favour of MULTI_CONSOLE_API.
Change-Id: I6170c1c8c74a890e5bd6d05396743fe62024a08a
Fix a typo, no functional change.
Change-Id: Id6abb4c192729f55b3500505860c7f7718944c62
Now that PFC drivers are cleaned up , move them out of staging.
Change-Id: Ie594b53558c2bfb8e5d88e5b0354752c17a2487e
Checkpatch cleanups of the PFC common init code macros.
Change-Id: Ifa444dd506387dba92b550729e56598198faeb49
Replace function name with non-camel-case one. No functional change.
Change-Id: Ie93e7fccdc81a3ffa5c371d49846fcf6c840f145
There's no point in having forward declaration just before the function
itself, drop it. No functional change.
Change-Id: I302cff2014bb6e513b6fb48fcf6df7ade684039e
Utilise existing BIT() macro. No functional change.
Change-Id: I0f6c1cadf51cfe49322ec5408e6661287747e0ae
Checkpatch cleanups of the PFC init code and remaining SoC specific macros.
Change-Id: I3a9527db01afa909f61efd9556cc291e254a5e33
Drop local copy of register macros and switch to common header.
Change-Id: I9d14180a7ae63a97d4bd1c87e717db71a852525e
Change-Id: I3cf5bbc388431144c8bbc53ae9f9338276674eee
Change-Id: Ibf5f242cad70cdd51ca6415b1c7c56b35317ea52
Change-Id: I6b026f5b333ee8008510604b9f51a0aa8e60b6fc
Change-Id: Ic41a5a01e8d803e116bf02d66735ede6f47e343a
Change-Id: I1ff9fe8fb2f1644e4ee3b877ed5979cdf99d3d85
Remove unused and irrelevant macros. No functional change.
Change-Id: Idcc34db77cb04db885ae5532689c83c0e8ddfd0b
Change-Id: I5bbb585c3762374bb713d4b9fe25495658d89e65
Change-Id: I26cd58706d7fc9fc92de280bfd77ae162924533d
Change-Id: I374c4e90729cd13aa4c5878bb3d0917071fa19f1
Change-Id: I4cd541f6485a454bd32bd34a3c95d50fd183052f
Change-Id: Iea1f0625ecc461168342e591e30947b543501bac
Change-Id: If39ba51685ef0bb993010658d98be6981253dce0
Change-Id: I98317def6640aebe559aa2edc4304029acf80505
