We've seen issues with some THG based UFS chips, where
after reset the LUNs don't always enumerate properly.
After some debugging, we found that extending the mdelay
here seems to resolve the issue by giving the chips enough
time to complete reset.
Change-Id: I848f810b2438ed6ad3d33db614c61d2cef9ac400
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Florian La Roche <Florian.LaRoche@gmail.com>
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Ensure (where possible) that switch statements in drivers comply with
MISRA rules 16.1 - 16.7.
Change-Id: I7a91e04b02af80fbc4673a52293386c0f81a0f7a
Signed-off-by: Jonathan Wright <jonathan.wright@arm.com>
Hynix ufs has deviations on hi36xx platform which will result
in ufs bursts transfer failures at a very low probability.
To fix the problem, the Hynix device must set the register
VS_DebugSaveConfigTime to 0x10, which will set time reference
for SaveConfigTime is 250 ns. The time reference for SaveConfigTime
is 40 ns by default.
Signed-off-by: fengbaopeng <fengbaopeng@hisilicon.com>
Should use AND (&), not &&.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
If UFS device is initialized, we could just make it out of
hibernation by UFS_FLAGS_SKIPINIT. And vendor's dirver is always
focus on PHY setting. We could use UFS driver directly if it
exits from hibernation.
There're eight LUNs in UFS device. The UFS driver only provides
the read/write API with LUN. User could define his own read/write
since user may want to access different LUNs.
