path: root/drivers/rpi3
2019-09-13rpi3: Move rng driver to driversAndre Przywara
To allow sharing the driver between the RPi3 and RPi4, move the random number generator driver into the generic driver directory. Change-Id: Iae94d7cb22c6bce3af9bff709d76d4caf87b14d1 Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2019-09-13rpi3: Move VC mailbox driver into generic drivers directoryAndre Przywara
To allow sharing the driver between the RPi3 and RPi4, move the mailbox driver into the generic driver directory. Change-Id: I463e49acf82b02bf004f3d56482b7791f3020bc0 Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2019-02-27rpi3: sdhost: SDHost driver improvementYing-Chun Liu (PaulLiu)
This commit improves the SDHost driver for RPi3 as following: * Unblock MMC_CMD(17). Using MMC_CMD(17) is more efficient on block reading. * In some low probability that SEND_OP_COND might results CRC7 error. We can consider that the command runs correctly. We don't need to retry this command so removing the code for retry. * Using MMC_BUS_WIDTH_1 as MMC default value to improve the stability. * Increase the clock to 50Mhz in data mode to speed up the io. * Change the pull resistors configuration to gain more stability. Signed-off-by: Ying-Chun Liu (PaulLiu) <paulliu@debian.org>
2019-02-01rpi3: Add SDHost driverYing-Chun Liu (PaulLiu)
This commit adds SDHost driver for RaspberryPi3. SDHost driver uses the GPIO driver to connect the SDCard and SDHost. By using this driver it is able to read/write raw blocks on SDCard. Signed-off-by: Ying-Chun Liu (PaulLiu) <paulliu@debian.org>
2019-01-26rpi3: Add GPIO driverYing-Chun Liu (PaulLiu)
This commit adds GPIO driver for RaspberryPi3. The GPIO driver for RPi3 also provides the way to do pinmux selections. Signed-off-by: Ying-Chun Liu (PaulLiu) <paulliu@debian.org>
