path: root/drivers/cfi
2019-01-04Sanitise includes across codebaseAntonio Nino Diaz
Enforce full include path for includes. Deprecate old paths. The following folders inside include/lib have been left unchanged: - include/lib/cpus/${ARCH} - include/lib/el3_runtime/${ARCH} The reason for this change is that having a global namespace for includes isn't a good idea. It defeats one of the advantages of having folders and it introduces problems that are sometimes subtle (because you may not know the header you are actually including if there are two of them). For example, this patch had to be created because two headers were called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform to avoid collision."). More recently, this patch has had similar problems: 46f9b2c3a282 ("drivers: add tzc380 support"). This problem was introduced in commit 4ecca33988b9 ("Move include and source files to logical locations"). At that time, there weren't too many headers so it wasn't a real issue. However, time has shown that this creates problems. Platforms that want to preserve the way they include headers may add the removed paths to PLAT_INCLUDES, but this is discouraged. Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-10-10plat/arm: Move norflash driver to drivers/ folderAntonio Nino Diaz
This way it can be reused by other platforms if needed. Note that this driver is designed to work with the Versatile Express NOR flash of Juno and FVP. In said platforms, the memory is organized as an interleaved memory of two chips with a 16 bit word. Any platform that wishes to reuse it with a different configuration will need to modify the driver so that it is more generic. Change-Id: Ic721758425864e0cf42b7b9b04bf0d9513b6022e Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
