The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
The old version of the macro is deprecated.
Commit cc5859ca19ff ("Multi-console: Deprecate the
`finish_console_register` macro") provides more details.
Change-Id: I3d1cdf6496db7d8e6cfbb5804f508ff46ae7e67e
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Signed-off-by: Alexei Colin <acolin@isi.edu>
The `finish_console_register` macro is used by the multi console
framework to register the `console_t` driver callbacks. It relied
on weak references to the `ldr` instruction to populate 0 to the
callback in case the driver has not defined the appropriate
function. Use of `ldr` instruction to load absolute address to a
reference makes the binary position dependant. These instructions
should be replaced with adrp/adr instruction for position independant
executable(PIE). But adrp/adr instructions don't work well with weak
references as described in GNU ld bugzilla issue 22589.
This patch defines a new version of `finish_console_register` macro
which can spcify which driver callbacks are valid and deprecates the
old one. If any of the argument is not specified, then the macro
populates 0 for that callback. Hence the functionality of the previous
deprecated macro is preserved. The USE_FINISH_CONSOLE_REG_2 define
is used to select the new variant of the macro and will be removed
once the deprecated variant is removed.
All the upstream console drivers have been migrated to use the new
macro in this patch.
NOTE: Platforms be aware that the new variant of the
`finish_console_register` should be used and the old variant is
deprecated.
Change-Id: Ia6a67aaf2aa3ba93932992d683587bbd0ad25259
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
The comments with the prototypes of the register functions of the
console drivers are incorrect. The arguments are wrong. This patch fixes
them.
Change-Id: I38c4b481ee69e840780111c42f03c0752eb6315c
It is still a placeholder, but now it is registered correctly by the
macro finish_console_register.
Change-Id: Ic78c966d9be606cbc1a53cec43ead23b32963afe
Change-Id: Ib9eebbdff6f7868e1d1b8c41761cacc7501a25bd
This patch updates the Cadence CDNS console driver to support the new
console API. The driver will continue to support the old API as well by
checking the MULTI_CONSOLE_API compile-time flag.
Change-Id: I2ef8fb0d6ab72696997db1e0243a533499569d6b
Signed-off-by: Julius Werner <jwerner@chromium.org>
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
It is needed to add placeholders for this function because, as this is
not a `plat_xxx()` function, there aren't weak definitions of it in any
file.
If `console_flush()` is used and there isn't an implementation of
`console_core_flush()` in any file, the compilation will fail.
Change-Id: I50eb56d085c4c9fbc85d40c343e86af6412f3020
This patch moves the various assembly console drivers
into `aarch64` architecture specific folder. Stub files,
which include files from new location, are retained at the
original location for platform compatibility reasons.
Change-Id: I0069b6c1c0489ca47f5204d4e26e3bc3def533a8
Add a driver for the Cadence UART which is found in Xilinx Zynq SOCs.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
