To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
It is needed to add placeholders for this function because, as this is
not a `plat_xxx()` function, there aren't weak definitions of it in any
file.
If `console_flush()` is used and there isn't an implementation of
`console_core_flush()` in any file, the compilation will fail.
Change-Id: I50eb56d085c4c9fbc85d40c343e86af6412f3020
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
This patch moves the various assembly console drivers
into `aarch64` architecture specific folder. Stub files,
which include files from new location, are retained at the
original location for platform compatibility reasons.
Change-Id: I0069b6c1c0489ca47f5204d4e26e3bc3def533a8
Add a driver for the Cadence UART which is found in Xilinx Zynq SOCs.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
