GICR_WAKER.ProcessorSleep can only be set to zero when:
— GICR_WAKER.Sleep bit[0] == 0.
— GICR_WAKER.Quiescent bit[31] == 0.
On some platforms, when system reboot with GIC in sleep
mode but with power ON, such as on NXP's i.MX8QM, Linux
kernel enters suspend but could be requested to reboot,
and GIC is in sleep mode and it is inside a power domain
which is ON in this scenario, when CPU reset, the GIC
driver trys to set CORE's redistributor interface to awake,
with GICR_WAKER.Sleep bit[0] and GICR_WAKER.Quiescent bit[31]
both set, the ProcessorSleep bit[1] will never be clear
and cause system hang.
This patch makes sure GICR_WAKER.Sleep bit[0] and
GICR_WAKER.Quiescent bit[31] are both zeor before clearing
ProcessorSleep bit[1].
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add tzc380 debug support.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Currently for Armv7 plaforms the quotient calculated in pl011
uart init code is moved to register r1.
This patch moves the quotient to register r2 as done for other
platforms in the udiv instruction. Value of register r2 is then
used to calculate the values for IBRD and FBRD register
Change-Id: Ie6622f9f0e6d634378b471df5d02823b492c8a24
Signed-off-by: Avinash Mehta <avinash.mehta@arm.com>
This patch provides declaration and definition of new GICv3 driver
API: gicv3_rdistif_probe().This function delegates the responsibility
of discovering the corresponding Redistributor base frame to each CPU
itself. It is a modified version of gicv3_rdistif_base_addrs_probe()
and is executed by each CPU in the platform unlike the previous
approach in which only the Primary CPU did the discovery of all the
Redistributor frames for every CPU.
The flush operations as part of gicv3_driver_init() function are
made necessary even for platforms with WARMBOOT_ENABLE_DCACHE_EARLY
because the GICv3 driver data structure contents are accessed by CPU
with D-Cache turned off during power down operations.
Change-Id: I1833e81d3974b32a3e4a3df4766a33d070982268
Signed-off-by: Madhukar Pappireddy <madhukar.pappireddy@arm.com>
This patch fixes GICv3 driver bug which causes assertion
when full range of SPI INTIDs 32-1019 is supported in
GICv3 implementation.
Change-Id: Ib6da4b6eea868cff271cb32c7c7570bf5547ab47
Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200
Signed-off-by: Julius Werner <jwerner@chromium.org>
NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
This interface has been deprecated in favour of MULTI_CONSOLE_API.
Change-Id: I6170c1c8c74a890e5bd6d05396743fe62024a08a
According to Arm GIC spec(IHI0069E, section 4.6.1),
when GICD_CTLR.DS == 0, Secure Group 1 interrupts
are treated as Group 0 by a CPU interface if:
- The PE does not implement EL3.
- ICC_SRE_EL1(S).SRE == 0
When a cpu enter suspend or deep idle, it might be
powered off. When the cpu resume, according to
the GIC spec(IHI0069E, section 9.2.15, 9.2.16 and
9.2.22) the ICC_SRE_EL1.SRE reset value is 0 (if
write is allowed) and G0/G1S/G1NS interrupt of the
GIC cpu interface are all disabled.
If a G1S SPI interrupt occurred and the target cpu
of the SPI is assigned to a specific cpu which is
in suspend and is powered off, when the cpu resume
and start to initial the GIC cpu interface, the
initial sequence might affect the interrupt group
type of the pending interrupt on the cpu interface.
Current initial sequence on the cpu interface is:
1. Enable G0 interrupt
2. Enable G1S interrupt
3. Enable ICC_SRE_EL1(S).SRE
It is possible to treat the pending G1S interrupt
as G0 interrupt on the cpu interface if the G1S
SPI interrupt occurred between step2 and step3.
To prevent the above situation happend, the initial
sequence should be changed as follows:
1. Enable ICC_SRE_EL1(S).SRE
2. Enable G0 interrupt
3. Enable G1S interrupt
Change-Id: Ie34f6e0b32eb9a1677ff72571fd4bfdb5cae25b0
Signed-off-by: James Kung <kong1191@gmail.com>
Payload length of the get dram mapping information message is 0.
The mbx_mem->len parameter should be 4, it only contains
message header.
Fixes: b67d202 ("plat/synquacer: enable SCMI support")
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
Change-Id: If1cd4c855da2dc5dc4b6da3bea152b8441971de7
For security DMA should be blocked at the SMMU by default
unless explicitly enabled for a device. SMMU is disabled
after reset with all streams bypassing the SMMU, and
abortion of all incoming transactions implements a default
deny policy on reset.
This patch also moves "bl1_platform_setup()" function from
arm_bl1_setup.c to FVP platforms' fvp_bl1_setup.c and
fvp_ve_bl1_setup.c files.
Change-Id: Ie0ffedc10219b1b884eb8af625bd4b6753749b1a
This patch is a preparation for the subsequent changes in
SMMUv3 driver. It introduces a new "smmuv3_poll" function
and replaces inline functions for accessing SMMU registers
with mmio read/write operations. Also the infinite loop
for the poll has been replaced with a counter based timeout.
Change-Id: I7a0547beb1509601f253e126b1a7a6ab3b0307e7
Add a driver for configuring the SBSA Generic Watchdog which aids in
the detection of errant system behaviour.
Change-Id: I5a1e7149c69fd8b85be7dfbcf511f431339946f4
Signed-off-by: Aditya Angadi <aditya.angadi@arm.com>
Types tzc_action_t and tzc_region_attributes_t are deprecated.
Change-Id: Ieefeb8521a0e1130f39d09b5c0d2728f05084773
The old version of the macro is deprecated.
Commit cc5859ca19ff ("Multi-console: Deprecate the
`finish_console_register` macro") provides more details.
Change-Id: I3d1cdf6496db7d8e6cfbb5804f508ff46ae7e67e
Improved support for W=2 compilation flag by solving some nested-extern
and sign-compare warnings.
The libraries are compiling with warnings (which turn into errors with
the Werror flag).
Outside of libraries, some warnings cannot be fixed.
Change-Id: I06b1923857f2a6a50e93d62d0274915b268cef05
Enable the SCMI protocol support in SynQuacer platform.
Aside from power domain, system power and apcore management protocol,
this commit adds the vendor specific protocol(0x80).
This vendor specific protocol is used to get the dram mapping information
from SCP.
Fix some typos and clarify some sentences.
Change-Id: Id276d1ced9a991b4eddc5c47ad9a825e6b29ef74
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Cortex a5 doesnt support hardware division such as sdiv and udiv commands.
This commit adds a software division function in assembly as well as include
appropriate files for software divison.
The software division algorithm is a modified version obtained from:
http://www.keil.com/support/man/docs/armasm/armasm_dom1359731155623.htm
Change-Id: Ib405a330da5f1cea1e68e07e7b520edeef9e2652
Signed-off-by: Usama Arif <usama.arif@arm.com>
Previously the GICv3 redistributor probe function
(gicv3_rdistif_base_addrs_probe()) asserted that the number of
per-CPU redistributor interfaces expected to be probed by the
platform is equal to the number exported by the redistributor
frame. This is a problem in case the number of CPUs in the
platform is less than the number of redistributor interfaces
in the frame. Hence this patch removes the assertion check
and allows probe for fewer redistributor interfaces as required
by the platform.
Change-Id: I3449763a3ad70817224442cbe184d001030c9874
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Change-Id: I670ea80e0331c2d4b2ccfa563a45469a43f6902d
Change-Id: Ia601d5ad65ab199e747fb60af4979b7db477d249
Change-Id: Ida5dae39478654405d0ee31a6cbddb4579e76a7f
Change-Id: Icc59cdaf2b56f6936e9847f1894594c671db2e94
Change-Id: I656753a1825ea7340a3708b950fa6b57455e9056
Change-Id: I8989d2aa0258bf3b50a856c5b81532d578600124
Corrects typos in core code, documentation files, drivers, Arm
platforms and services.
None of the corrections affect code; changes are limited to comments
and other documentation.
Change-Id: I5c1027b06ef149864f315ccc0ea473e2a16bfd1d
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
ccn: for RN-I, used node id instead of node postion
For RN-I, node id is used instead of node postion in the bitmap
to calculate the region id.
Signed-off-by: Pankaj Gupta <pankaj.gupta@nxp.com>
MULTI_CONSOLE_API fixes and cleanups
This patch makes the build system link the console framework code by
default, like it already does with other common libraries (e.g. cache
helpers). This should not make a difference in practice since TF is
linked with --gc-sections, so the linker will garbage collect all
functions and data that are not referenced by any other code. Thus, if a
platform doesn't want to include console code for size reasons and
doesn't make any references to console functions, the code will not be
included in the final binary.
To avoid compatibility issues with older platform ports, only make this
change for the MULTI_CONSOLE_API.
Change-Id: I153a9dbe680d57aadb860d1c829759ba701130d3
This driver can be compiled in release builds, but GCC generates warnings
for some comparisons and that prevents the firmware from being built in
debug builds.
Change-Id: Ic52e1b4a11896ecf086864fbe2b5bfc143ec9b1b
Add tzc380 support.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
ccn: Introduce API to set and read value of node register
ARM CoreLink DMC-620 Dynamic Memory Controller includes a TZC controller
to setup secure or non-secure regions of DRAM memory. The TZC controller
allows to setup upto eight such regions of memory in DRAM. This driver
provides helper functions to setup the TZC controller within DMC-620.
Change-Id: Iee7692417c2080052bdb7b1c2873a024bc5d1d10
Signed-off-by: Vijayenthiran Subramaniam <vijayenthiran.subramaniam@arm.com>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
This function was needed at the time where we didn't have the
compiler_rt lib. An AArch32-specific variant was provided to handle
the 64-bit shift operation in 32-bit. This is no longer needed.
Change-Id: Ibab709a95e3a723ae2eeaddf873dba70ff2012b3
Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Multi-console: Deprecate the `finish_console_register` macro
The definitions FAIL_CONTROL_*_SHIFT were incorrect, they have been
fixed.
The types tzc_region_attributes_t and tzc_action_t have been removed and
replaced by unsigned int because it is not allowed to do logical
operations on enums.
Also, fix some address definitions in arm_def.h.
Change-Id: Id37941d76883f9fe5045a5f0a4224c133c504d8b
The `finish_console_register` macro is used by the multi console
framework to register the `console_t` driver callbacks. It relied
on weak references to the `ldr` instruction to populate 0 to the
callback in case the driver has not defined the appropriate
function. Use of `ldr` instruction to load absolute address to a
reference makes the binary position dependant. These instructions
should be replaced with adrp/adr instruction for position independant
executable(PIE). But adrp/adr instructions don't work well with weak
references as described in GNU ld bugzilla issue 22589.
This patch defines a new version of `finish_console_register` macro
which can spcify which driver callbacks are valid and deprecates the
old one. If any of the argument is not specified, then the macro
populates 0 for that callback. Hence the functionality of the previous
deprecated macro is preserved. The USE_FINISH_CONSOLE_REG_2 define
is used to select the new variant of the macro and will be removed
once the deprecated variant is removed.
All the upstream console drivers have been migrated to use the new
macro in this patch.
NOTE: Platforms be aware that the new variant of the
`finish_console_register` should be used and the old variant is
deprecated.
Change-Id: Ia6a67aaf2aa3ba93932992d683587bbd0ad25259
The comments with the prototypes of the register functions of the
console drivers are incorrect. The arguments are wrong. This patch fixes
them.
Change-Id: I38c4b481ee69e840780111c42f03c0752eb6315c
Enable Multi Console API in AArch32
Mark the GICv3, CCI and CCN code only used in Bl31 initialization
with __init to be reclaimed once no longer needed.
Change-Id: I3d77f36758450d9d1d87ecc60bc1c63fe4082667
Signed-off-by: Daniel Boulby <daniel.boulby@arm.com>
Change-Id: Ib9eebbdff6f7868e1d1b8c41761cacc7501a25bd
This driver is deprecated.
Change-Id: Ic6e154a5756e779743b17a329eed4570ccc61389
Change-Id: I9874883ec33dbf293f607f9779d7c56f23cb8023
