A small set of misc changes to ensure correctness before the v2.2
release tagging.
Change-Id: I888840b9483ea1a1633d204fbbc0f9594072101e
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
User guide:
1. Remove obsolete note saying only FVP is supported with AArch32
2. Switch compiler for Juno AArch32 to arm-eabi
3. Mention SOFTWARE folder in Juno Linaro release
Index.rst:
1. Switch default FVP model to Version 11.6 Build 45
Signed-off-by: Artsem Artsemenka <artsem.artsemenka@arm.com>
Change-Id: Ib47a2ea314e2b8394a20189bf91796de0e17de53
Currently links between documents are using the format:
<path/to/><filename>.rst
This was required for services like GitHub because they render each
document in isolation - linking to another document is like linking
to any other file, just provide the full path.
However, with the new approach, the .rst files are only the raw
source for the documents. Once the documents have been rendered
the output is now in another format (HTML in our case) and so,
when linking to another document, the link must point to the
rendered version and not the .rst file.
The RST spec provides a few methods for linking between content.
The parent of this patch enabled the automatic creation of anchors
for document titles - we will use these anchors as the targets for
our links. Additional anchors can be added by hand if needed, on
section and sub-section titles, for example.
An example of this new format, for a document with the title
"Firmware Design" is :ref:`Firmware Design`.
One big advantage of this is that anchors are not dependent on
paths. We can then move documents around, even between directories,
without breaking any links between documents. Links will need to be
updated only if the title of a document changes.
Change-Id: I9e2340a61dd424cbd8fd1ecc2dc166f460d81703
Make the spinlock implementation use ARMv8.1-LSE CAS instruction based
on a platform build option. The CAS-based implementation used to be
unconditionally selected for all ARM8.1+ platforms.
The previous CAS spinlock implementation had a bug wherein the spin_unlock()
implementation had an `sev` after `stlr` which is not sufficient. A dsb is
needed to ensure that the stlr completes prior to the sev. Having a dsb is
heavyweight and a better solution would be to use load exclusive semantics
to monitor the lock and wake up from wfe when a store happens to the lock.
The patch implements the same.
Change-Id: I5283ce4a889376e4cc01d1b9d09afa8229a2e522
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Signed-off-by: Olivier Deprez <olivier.deprez@arm.com>
Change-Id: I3b866e927d93f4b690aa4891940fc8afabf4146e
Signed-off-by: Louis Mayencourt <louis.mayencourt@arm.com>
- Updated Linaro release version number to 19.06
- Updated links to Linaro instructions and releases
- Removed the Linaro old releases link
Signed-off-by: zelalem-aweke <zelalem.aweke@arm.com>
Change-Id: Ib786728106961e89182b42183e7b889f6fc74190
This patch provides the following features and makes modifications
listed below:
- Individual APIAKey key generation for each CPU.
- New key generation on every BL31 warm boot and TSP CPU On event.
- Per-CPU storage of APIAKey added in percpu_data[]
of cpu_data structure.
- `plat_init_apiakey()` function replaced with `plat_init_apkey()`
which returns 128-bit value and uses Generic timer physical counter
value to increase the randomness of the generated key.
The new function can be used for generation of all ARMv8.3-PAuth keys
- ARMv8.3-PAuth specific code placed in `lib\extensions\pauth`.
- New `pauth_init_enable_el1()` and `pauth_init_enable_el3()` functions
generate, program and enable APIAKey_EL1 for EL1 and EL3 respectively;
pauth_disable_el1()` and `pauth_disable_el3()` functions disable
PAuth for EL1 and EL3 respectively;
`pauth_load_bl31_apiakey()` loads saved per-CPU APIAKey_EL1 from
cpu-data structure.
- Combined `save_gp_pauth_registers()` function replaces calls to
`save_gp_registers()` and `pauth_context_save()`;
`restore_gp_pauth_registers()` replaces `pauth_context_restore()`
and `restore_gp_registers()` calls.
- `restore_gp_registers_eret()` function removed with corresponding
code placed in `el3_exit()`.
- Fixed the issue when `pauth_t pauth_ctx` structure allocated space
for 12 uint64_t PAuth registers instead of 10 by removal of macro
CTX_PACGAKEY_END from `include/lib/el3_runtime/aarch64/context.h`
and assigning its value to CTX_PAUTH_REGS_END.
- Use of MODE_SP_ELX and MODE_SP_EL0 macro definitions
in `msr spsel` instruction instead of hard-coded values.
- Changes in documentation related to ARMv8.3-PAuth and ARMv8.5-BTI.
Change-Id: Id18b81cc46f52a783a7e6a09b9f149b6ce803211
Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
* changes:
Remove RSA PKCS#1 v1.5 support from cert_tool
Add documentation for new KEY_SIZE option
Add cert_create tool support for RSA key sizes
Support larger RSA key sizes when using MBEDTLS
Support for PKCS#1 v1.5 was deprecated in SHA 1001202 and fully removed
in SHA fe199e3, however, cert_tool is still able to generate
certificates in that form. This patch fully removes the ability for
cert_tool to generate these certificates.
Additionally, this patch also fixes a bug where the issuing certificate
was a RSA and the issued certificate was EcDSA. In this case, the issued
certificate would be signed using PKCS#1 v1.5 instead of RSAPSS per
PKCS#1 v2.1, preventing TF-A from verifying the image signatures. Now
that PKCS#1 v1.5 support is removed, all certificates that are signed
with RSA now use the more modern padding scheme.
Change-Id: Id87d7d915be594a1876a73080528d968e65c4e9a
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
This patch adds documentation for the new KEY_SIZE build option that is
exposed by cert_create, and instructions on how to use it.
Change-Id: I09b9b052bfdeeaca837e0f0026e2b01144f2472c
Some of the platform (ie. Agilex) make use of CCU IPs which will only be
initialized during bl2_el3_early_platform_setup. Any operation to the
cache beforehand will crash the platform. Hence, this will provide an
option to skip the data cache invalidation upon bl2 entry at EL3
Signed-off-by: Hadi Asyrafi <muhammad.hadi.asyrafi.abdul.halim@intel.com>
Change-Id: I2c924ed0589a72d0034714c31be8fe57237d1f06
integration
* changes:
Add documentation for CTX_INCLUDE_MTE_REGS
Enable MTE support in both secure and non-secure worlds
This patch adds support for the Undefined Behaviour sanitizer. There are
two types of support offered - minimalistic trapping support which
essentially immediately crashes on undefined behaviour and full support
with full debug messages.
The full support relies on ubsan.c which has been adapted from code used
by OPTEE.
Change-Id: I417c810f4fc43dcb56db6a6a555bfd0b38440727
A new build flag, CTX_INCLUDE_MTE_REGS, has been added; this patch adds
documentation for it in the User Guide along with instructions of what
different values mean.
Change-Id: I430a9c6ced06b1b6be317edbeff4f5530e30f63a
Change-Id: Ib12ecc0b283274c74cdfa57caf9e1a105dce3afe
At the time of writting, GCC 8.3-2019.03 is the latest version available
on developer.arm.com.
Switch to bare-metal toolchain (arm-eabi-) for AArch32. This allows to
have a finer control on the use of floating-point and SIMD instructions.
Change-Id: I4438401405eae1e5f6d531b0162e8fa06f69135e
Change-Id: I755e4c42242d9a052570fd1132ca3d937acadb13
Signed-off-by: Balint Dobszay <balint.dobszay@arm.com>
Change-Id: I0d9dbef7041fcf950bcafcdbbc17c72b4dea9e40
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Change-Id: Ib021c721652d96f6c06ea18741f19a72bba1d00f
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
This patch adds the functionality needed for platforms to provide
Branch Target Identification (BTI) extension, introduced to AArch64
in Armv8.5-A by adding BTI instruction used to mark valid targets
for indirect branches. The patch sets new GP bit [50] to the stage 1
Translation Table Block and Page entries to denote guarded EL3 code
pages which will cause processor to trap instructions in protected
pages trying to perform an indirect branch to any instruction other
than BTI.
BTI feature is selected by BRANCH_PROTECTION option which supersedes
the previous ENABLE_PAUTH used for Armv8.3-A Pointer Authentication
and is disabled by default. Enabling BTI requires compiler support
and was tested with GCC versions 9.0.0, 9.0.1 and 10.0.0.
The assembly macros and helpers are modified to accommodate the BTI
instruction.
This is an experimental feature.
Note. The previous ENABLE_PAUTH build option to enable PAuth in EL3
is now made as an internal flag and BRANCH_PROTECTION flag should be
used instead to enable Pointer Authentication.
Note. USE_LIBROM=1 option is currently not supported.
Change-Id: Ifaf4438609b16647dc79468b70cd1f47a623362e
The documentation contains plenty of notes and warnings. Enable
special rendering of these blocks by converting the note prefix
into a .. note:: annotation.
Change-Id: I34e26ca6bf313d335672ab6c2645741900338822
Several code blocks do not specify a language for syntax
highlighting. This results in Sphinx using a default highlighter
which is Python.
This patch adds the correct language to each code block that doesn't
already specify it.
Change-Id: Icce1949aabfdc11a334a42d49edf55fa673cddc3
These are no longer needed as there will always be a table of contents
rendered to the left of every page.
Some of these lists can be quite long and, when opening a page, the
reader sees nothing but a huge list of contents! After this patch,
the document contents are front-and-centre and the contents are
nicely rendered in the sidebar without duplication.
Change-Id: I444754d548ec91d00f2b04e861de8dde8856aa62
This patch attempts to standardise the document titles as well as
adding titles to documents that were missing one. The aim is to
remove needless references to "TF-A" or "Trusted Firmware" in the
title of every document and to make sure that the title matches
with the document content.
Change-Id: I9b93ccf43b5d57e8dc793a5311b8ed7c4dd245cc
This change creates the following directories under docs/
in order to provide a grouping for the content:
- components
- design
- getting_started
- perf
- process
In each of these directories an index.rst file is created
and this serves as an index / landing page for each of the
groups when the pages are compiled. Proper layout of the
top-level table of contents relies on this directory/index
structure.
Without this patch it is possible to build the documents
correctly with Sphinx but the output looks messy because
there is no overall hierarchy.
Change-Id: I3c9f4443ec98571a56a6edf775f2c8d74d7f429f
