path: root/common
2018-03-05Dynamic cfg: Do not populate args if already initializedAmit Daniel Kachhap
This patch modifies the common utility function `populate_next_bl_params_config()` to only modify the entrypoint arguments to an executable image only if they are not initialized earlier. This issue was detected while testing Optee on ARM platforms which needed the current arguments to be preserved in the absence of corresponding config files. Change-Id: I1e3fb4be8176fc173959e72442396dd33a99a316 Signed-off-by: Amit Daniel Kachhap <amit.kachhap@arm.com> Signed-off-by: David Cunado <david.cunado@arm.com>
2018-02-28Fix MISRA rule 8.5 Part 1Roberto Vargas
Rule 8.5: An external object or function shall be declared once in one and only one file. Fixed for: make DEBUG=1 PLAT=fvp LOG_LEVEL=50 all Change-Id: I2420c58134c280db90706cad2d5e7a190f9f9311 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-02-26Dynamic cfg: MISRA fixesSoby Mathew
Change-Id: I1d85b76af002b8b672fcaeca94939b7420bc8243 Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2018-02-26ARM Platforms: Load HW_CONFIG in BL2Soby Mathew
The patch adds the necessary changes to load HW_CONFIG in BL2 for ARM Platforms : 1. The load address of HW_CONFIG is specified via the `hw_config_addr` property in TB_FW_CONFIG is loaded by BL1. The `hw_config_max_size` property defines the maximum size to be expected for the HW_CONFIG. The `arm_dyn_cfg_helpers.c` and corresponding header implements utility functions to parse these DT properties defined. The `arm_dyn_cfg.c` implements wrappers to these helpers to enable them to be invoked from ARM platform layer. 2. `HW_CONFIG` is added to the `bl2_mem_params_descs[]` array which is the list of images to be loaded by BL2. 3. The `libfdt` sources are now included when BL2 is built 4. A new helper `populate_next_bl_params_config()` is introduced in desc_image_load.c to populate the subsequent executable BL images with the `hw_config` and the corresponding `fw_config` if available. The `plat_get_next_bl_params()` API for ARM platforms is modified to invoke this new helper. 5. The implementation of `bl2_early_platform_setup2()` is modified to consider `arg0` as well in addition to `arg1` passed from BL1. 6. Bump up the BL2 size for Juno to accommodate the inclusion of libfdt. Change-Id: I80f1554adec41753e0d179a5237364f04fe13a3f Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2018-02-26Dynamic cfg: Introduce fdt wrappersSoby Mathew
Change-Id: I9b1cdaf2430a1998a69aa366ea1461224a3d43dc Co-Authoured-by: Jeenu Viswambharan <Jeenu.Viswambharan@arm.com> Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2018-02-02image_decompress: add APIs for decompressing imagesMasahiro Yamada
These APIs are used by platforms that need to decompress images. image_decompress_init(): This registers a temporary buffer and a decompressor callback. This should be called from platform init code. image_decompress_prepare(): This should be called before each compressed image is loaded. The best location to call this will be bl*_plat_handle_pre_image_load(). image_decompress(): This should be called after each compressed image is loaded. The best location to call this will be bl*_plat_handle_post_image_load(). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-12-15Add support to left-pad with zeroes in tf_printfAntonio Nino Diaz
Add support to formats %i, %d, %p, %x and %u for left-padding numbers with zeroes (e.g. `%08x`). Change-Id: Ifd4795a82a8d83da2c00b44b9e482a2d9be797e3 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-12-05Unify cache flush code path after image loadSoby Mathew
Previously the cache flush happened in 2 different places in code depending on whether TRUSTED_BOARD_BOOT is enabled or not. This patch unifies this code path for both the cases. The `load_image()` function is now made an internal static function. Change-Id: I96a1da29d29236bbc34b1c95053e6a9a7fc98a54 Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2017-11-08ARMv7 may not support Virtualization ExtensionsEtienne Carriere
ARMv7-A Virtualization extensions brings new instructions and resources that were supported by later architectures. Reference ARM ARM Issue C.c [DDI0406C_C]. ERET and extended MSR/MRS instructions, as specified in [DDI0406C_C] in ID_PFR1 description of bits[15:12] (Virtualization Extensions): A value of 0b0001 implies implementation of the HVC, ERET, MRS (Banked register), and MSR (Banked register) instructions. The ID_ISARs do not identify whether these instructions are implemented. UDIV/SDIV were introduced with the Virtualization extensions, even if not strictly related to the virtualization extensions. If ARMv7 based platform does not set ARM_CORTEX_Ax=yes, platform shall define ARMV7_SUPPORTS_VIRTUALIZATION to enable virtualization extension related resources. Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
2017-11-06Merge pull request #1153 from robertovargas-arm/fix-macrosdavidcunado-arm
Avoid use of undefined macros
2017-11-01Include debug.h in debug.SRoberto Vargas
debug.S was using macros defined in debug.h, but since it didn't include it, these macros were taking the value 0, which means that all the preprocessor conditionals were wrong. Change-Id: If4ca81cc5a1662991589f914a2557ceff0eaaede Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2017-10-24Add platform hooks for boot redundancy supportRoberto Vargas
These hooks are intended to allow one platform to try load images from alternative places. There is a hook to initialize the sequence of boot locations and a hook to pass to the next sequence. Change-Id: Ia0f84c415208dc4fa4f9d060d58476db23efa5b2 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2017-09-11Implement log frameworkSoby Mathew
This patch gives users control over logging messages printed from the C code using the LOG macros defined in debug.h Users now have the ability to reduce the log_level at run time using the tf_log_set_max_level() function. The default prefix string can be defined by platform by overriding the `plat_log_get_prefix()` platform API which is also introduced in this patch. The new log framework results in saving of some RO data. For example, when BL1 is built for FVP with LOG_LEVEL=LOG_LEVEL_VERBOSE, resulted in saving 384 bytes of RO data and increase of 8 bytes of RW data. The framework also adds about 108 bytes of code to the release build of FVP. Fixes ARM-software/tf-issues#462 Change-Id: I476013d9c3deedfdd4c8b0b0f125665ba6250554 Co-authored-by: Eleanor Bonnici <Eleanor.bonnici@arm.com> Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2017-09-11Introduce tf_vprintf() and tf_string_print()Soby Mathew
This patch introduces tf_vprintf() and tf_string_print() APIs which is needed by the logging framework introduced in a later patch. Change-Id: Ie4240443d0e04e070502b51e371e546dd469fd33 Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2017-08-21Fix x30 reporting for unhandled exceptionsJulius Werner
Some error paths that lead to a crash dump will overwrite the value in the x30 register by calling functions with the no_ret macro, which resolves to a BL instruction. This is not very useful and not what the reader would expect, since a crash dump should usually show all registers in the state they were in when the exception happened. This patch replaces the offending function calls with a B instruction to preserve the value in x30. Change-Id: I2a3636f2943f79bab0cd911f89d070012e697c2a Signed-off-by: Julius Werner <jwerner@chromium.org>
2017-06-14Tegra: enable 'signed-comparison' compilation warning/errorsVarun Wadekar
This patch enables the 'sign-compare' flag, to enable warning/errors for comparisons between signed/unsigned variables. The warning has been enabled for all the Tegra platforms, to start with. Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2017-05-24Introduce `tf_snprintf`Antonio Nino Diaz
This is a reduced version of `snprintf` that only supports formats '%d', '%i' and '%u'. It can be used when the full `snprintf` is not needed in order to save memory. If it finds an unknown format specifier, it prints an error message and panics. Change-Id: I2cb06fcdf74cda2c43caf73ae0762a91499fc04e Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-05-15Align tf_printf implementation between AArch32 and AArch64dp-arm
No need for these wrapper functions anymore. The compiler-rt builtins provide runtime support for 64-bit division and modulo operations. Change-Id: Ib785d37c86f0c82ebd34c35023a4c1822c03e7df Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-05-04Merge pull request #925 from dp-arm/dp/spdxdavidcunado-arm
Use SPDX license identifiers
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-04-26Update terminology: standard SMC to yielding SMCDavid Cunado
Since Issue B (November 2016) of the SMC Calling Convention document standard SMC calls are renamed to yielding SMC calls to help avoid confusion with the standard service SMC range, which remains unchanged. http://infocenter.arm.com/help/topic/com.arm.doc.den0028b/ARM_DEN0028B_SMC_Calling_Convention.pdf This patch adds a new define for yielding SMC call type and deprecates the current standard SMC call type. The tsp is migrated to use this new terminology and, additionally, the documentation and code comments are updated to use this new terminology. Change-Id: I0d7cc0224667ee6c050af976745f18c55906a793 Signed-off-by: David Cunado <david.cunado@arm.com>
2017-04-24Merge pull request #911 from danh-arm/dh/refactor-bl2-image-loaddavidcunado-arm
Minor refactor of BL2 image load v2
2017-04-20Remove build option `ASM_ASSERTION`Antonio Nino Diaz
The build option `ENABLE_ASSERTIONS` should be used instead. That way both C and ASM assertions can be enabled or disabled together. All occurrences of `ASM_ASSERTION` in common code and ARM platforms have been replaced by `ENABLE_ASSERTIONS`. ASM_ASSERTION has been removed from the user guide. Change-Id: I51f1991f11b9b7ff83e787c9a3270c274748ec6f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-04-19Minor refactor of BL2 image load v2Dan Handley
Previously, get_next_bl_params_from_mem_params_desc() populated arg0 in the EL3 runtime entrypoint with a bl_params_t pointer. This is the responsibility of the generic LOAD_IMAGE_V2 framework instead of the descriptor-based image loading utility functions. Therefore this patch moves that code to bl2_load_images(). Also, this patch moves the code that flushes the bl_params structure to flush_bl_params_desc(), together with the other descriptor-based image loading flushing code. Change-Id: I4541e3f50e3878dde7cf89e9e8f31fe0b173fb9d Signed-off-by: Dan Handley <dan.handley@arm.com>
2017-04-19Add `ENABLE_ASSERTIONS` build optionAntonio Nino Diaz
Add the new build option `ENABLE_ASSERTIONS` that controls whether or not assert functions are compiled out. It defaults to 1 for debug builds and to 0 for release builds. Additionally, a following patch will be done to allow this build option to hide auxiliary code used for the checks done in an `assert()`. This code is is currently under the DEBUG build flag. Assert messages are now only printed if LOG_LEVEL >= LOG_LEVEL_INFO, which is the default for debug builds. This patch also updates the User Guide. Change-Id: I1401530b56bab25561bb0f274529f1d12c5263bc Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-03-31Remove dead loops in assert() in C and ASMAntonio Nino Diaz
The desired behaviour is to call `plat_panic_handler()`, and to use `no_ret` to do so from ASM. Change-Id: I88b2feefa6e6c8f9bf057fd51ee0d2e9fb551e4f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-03-31Add and use plat_crash_console_flush() APIAntonio Nino Diaz
This API makes sure that all the characters sent to the crash console are output before returning from it. Porting guide updated. Change-Id: I1785f970a40f6aacfbe592b6a911b1f249bb2735 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-03-08Simplify translation tables headers dependenciesAntonio Nino Diaz
The files affected by this patch don't really depend on `xlat_tables.h`. By changing the included file it becomes easier to switch between the two versions of the translation tables library. Change-Id: Idae9171c490e0865cb55883b19eaf942457c4ccc Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-02-06Introduce unified API to zero memoryDouglas Raillard
Introduce zeromem_dczva function on AArch64 that can handle unaligned addresses and make use of DC ZVA instruction to zero a whole block at a time. This zeroing takes place directly in the cache to speed it up without doing external memory access. Remove the zeromem16 function on AArch64 and replace it with an alias to zeromem. This zeromem16 function is now deprecated. Remove the 16-bytes alignment constraint on __BSS_START__ in firmware-design.md as it is now not mandatory anymore (it used to comply with zeromem16 requirements). Change the 16-bytes alignment constraints in SP min's linker script to a 8-bytes alignment constraint as the AArch32 zeromem implementation is now more efficient on 8-bytes aligned addresses. Introduce zero_normalmem and zeromem helpers in platform agnostic header that are implemented this way: * AArch32: * zero_normalmem: zero using usual data access * zeromem: alias for zero_normalmem * AArch64: * zero_normalmem: zero normal memory using DC ZVA instruction (needs MMU enabled) * zeromem: zero using usual data access Usage guidelines: in most cases, zero_normalmem should be preferred. There are 2 scenarios where zeromem (or memset) must be used instead: * Code that must run with MMU disabled (which means all memory is considered device memory for data accesses). * Code that fills device memory with null bytes. Optionally, the following rule can be applied if performance is important: * Code zeroing small areas (few bytes) that are not secrets should use memset to take advantage of compiler optimizations. Note: Code zeroing security-related critical information should use zero_normalmem/zeromem instead of memset to avoid removal by compilers' optimizations in some cases or misbehaving versions of GCC. Fixes ARM-software/tf-issues#408 Change-Id: Iafd9663fc1070413c3e1904e54091cf60effaa82 Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
2016-12-20Merge pull request #791 from jeenu-arm/asm-assert-32danh-arm
AArch32: Print ASM_ASSERT and panic messages
2016-12-20Export is_mem_free() functionSandrine Bailleux
The is_mem_free() function used to be local to bl_common.c. This patch exports it so that it can be used outside of bl_common.c. Change-Id: I01dcb4229f3a36f56a4724b567c5e6c416dc5e98 Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
2016-12-19AArch32: Print ASM_ASSERT and panic messagesJeenu Viswambharan
ASM_ASSERT failure and panic messages are suppressed at present. This patch enables printing the PC location for panic messages, and file name and line number upon assembly assert failure. Change-Id: I80cb715988e7ce766f64da1e1d7065a74a096a0c Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2016-12-12Merge pull request #774 from jeenu-arm/no-return-macrodanh-arm
Define and use no_ret macro where no return is expected
2016-12-05Define and use no_ret macro where no return is expectedJeenu Viswambharan
There are many instances in ARM Trusted Firmware where control is transferred to functions from which return isn't expected. Such jumps are made using 'bl' instruction to provide the callee with the location from which it was jumped to. Additionally, debuggers infer the caller by examining where 'lr' register points to. If a 'bl' of the nature described above falls at the end of an assembly function, 'lr' will be left pointing to a location outside of the function range. This misleads the debugger back trace. This patch defines a 'no_ret' macro to be used when jumping to functions from which return isn't expected. The macro ensures to use 'bl' instruction for the jump, and also, for debug builds, places a 'nop' instruction immediately thereafter (unless instructed otherwise) so as to leave 'lr' pointing within the function range. Change-Id: Ib34c69fc09197cfd57bc06e147cc8252910e01b0 Co-authored-by: Douglas Raillard <douglas.raillard@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2016-11-29Optimize cache flush when authenticating imagesAntonio Nino Diaz
When loading and authenticating an image, all parent images must also be authenticated. The parent images are just certificates that don't need to be used by any other CPU except the one loading the image, and so there is no need to flush the cache of memory regions where they are loaded. Change-Id: Ice8d6979d1c02eabf1a543281ae1a07d098e4a99 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2016-09-21AArch32: Common changes needed for BL1/BL2Yatharth Kochar
This patch adds common changes to support AArch32 state in BL1 and BL2. Following are the changes: * Added functions for disabling MMU from Secure state. * Added AArch32 specific SMC function. * Added semihosting support. * Added reporting of unhandled exceptions. * Added uniprocessor stack support. * Added `el3_entrypoint_common` macro that can be shared by BL1 and BL32 (SP_MIN) BL stages. The `el3_entrypoint_common` is similar to the AArch64 counterpart with the main difference in the assembly instructions and the registers that are relevant to AArch32 execution state. * Enabled `LOAD_IMAGE_V2` flag in Makefile for `ARCH=aarch32` and added check to make sure that platform has not overridden to disable it. Change-Id: I33c6d8dfefb2e5d142fdfd06a0f4a7332962e1a3
2016-09-20Add new version of image loading.Yatharth Kochar
This patch adds capability to load BL images based on image descriptors instead of hard coded way of loading BL images. This framework is designed such that it can be readily adapted by any BL stage that needs to load images. In order to provide the above capability the following new platform functions are introduced: bl_load_info_t *plat_get_bl_image_load_info(void); This function returns pointer to the list of images that the platform has populated to load. bl_params_t *plat_get_next_bl_params(void); This function returns a pointer to the shared memory that the platform has kept aside to pass trusted firmware related information that next BL image needs. void plat_flush_next_bl_params(void); This function flushes to main memory all the params that are passed to next image. int bl2_plat_handle_post_image_load(unsigned int image_id) This function can be used by the platforms to update/use image information for given `image_id`. `desc_image_load.c` contains utility functions which can be used by the platforms to generate, load and executable, image list based on the registered image descriptors. This patch also adds new version of `load_image/load_auth_image` functions in-order to achieve the above capability. Following are the changes for the new version as compared to old: - Refactor the signature and only keep image_id and image_info_t arguments. Removed image_base argument as it is already passed through image_info_t. Given that the BL image base addresses and limit/size are already provided by the platforms, the meminfo_t and entry_point_info arguments are not needed to provide/reserve the extent of free memory for the given BL image. - Added check for the image size against the defined max size. This is needed because the image size could come from an unauthenticated source (e.g. the FIP header). To make this check, new member is added to the image_info_t struct for identifying the image maximum size. New flag `LOAD_IMAGE_V2` is added in the Makefile. Default value is 0. NOTE: `TRUSTED_BOARD_BOOT` is currently not supported when `LOAD_IMAGE_V2` is enabled. Change-Id: Ia7b643f4817a170d5a2fbf479b9bc12e63112e79
2016-08-31AArch32: resolve build error when LOG_LEVEL=50Soby Mathew
This patch resolves a build error in Trusted Firmware when `ARCH=aarch32` and LOG_LEVEL >= 50. Change-Id: I62a23ded4a25304533cdcc5ff11442aee041709b
2016-08-31Merge pull request #689 from yatharth-arm/yk/plat_report_expndavidcunado-arm
Remove looping around `plat_report_exception`
2016-08-22Remove looping around `plat_report_exception`Yatharth Kochar
This patch removes the tight loop that calls `plat_report_exception` in unhandled exceptions in AArch64 state. The new behaviour is to call the `plat_report_exception` only once followed by call to `plat_panic_handler`. This allows platforms to take platform-specific action when there is an unhandled exception, instead of always spinning in a tight loop. Note: This is a subtle break in behaviour for platforms that expect `plat_report_exception` to be continuously executed when there is an unhandled exception. Change-Id: Ie2453804b9b7caf9b010ee73e1a90eeb8384e4e8
2016-08-18Merge pull request #686 from danh-arm/dh/remove-inv-dcache-after-authdanh-arm
Remove dcache invalidation after image authentication
2016-08-17Remove dcache invalidation after image authenticationDan Handley
At the end of successful image authentication in load_auth_image(), the data cache for the virtual address range corresponding to the image is invalidated (by a call to inv_dcache_range()). The intent seems to be to ensure the data caches do not contain any sensitive data used during authentication, which subsequent code can read. However, this same address range is already flushed (cleaned and invalidated by a call to flush_dcache_range()) at the end of load_image(), and the subsequent invalidate has no functional effect. This patch removes the redundant call to inv_dcache_range(). It also moves the flush_dcache_range() call from the end of load_image() to the end of load_auth_image(), so the image data will remain in the caches during authentication, improving performance. This also improves the comments that explain the rationale for calling flush_dcache_range() after image loading/authentication. Change-Id: I14f17ad2935075ef6f3d1327361c5088bfb2d284
2016-08-10AArch32: Add API to invoke runtime service handlerSoby Mathew
This patch adds an API in runtime service framework to invoke the registered handler corresponding to the SMC function identifier. This is helpful for AArch32 because the number of arguments required by the handler is more than registers available as per AArch32 program calling conventions and requires the use of stack. Hence this new API will do the necessary argument setup and invoke the appropriate handler. Although this API is primarily intended for AArch32, it can be used for AArch64 as well. Change-Id: Iefa15947fe5a1df55b0859886e677446a0fd7241
2016-08-10AArch32: Add tf_printf supportSoby Mathew
The tf_printf library uses 64 bit division to print numbers in appropriate formats but AArch32 mode cannot do 64 bit division natively. Hence this patch adds additional number printing routines to handle AArch32 mode in tf_printf library. The decimal format printing capability is limited to 32 bit integers whereas 64 bits are supported in hexadecimal format. The library assumes that secure world is running in Little-Endian mode to do bit manipulations on 64 bit. Suitable assertions are present to enforce this assumption. Change-Id: I55a21e448cef4915d1834d76e48a84ccf0bec36d
2016-08-10AArch32: Add assembly helpersSoby Mathew
This patch adds various assembly helpers for AArch32 like : * cache management : Functions to flush, invalidate and clean cache by MVA. Also helpers to do cache operations by set-way are also added. * stack management: Macros to declare stack and get the current stack corresponding to current CPU. * Misc: Macros to access co processor registers in AArch32, macros to define functions in assembly, assert macros, generic `do_panic()` implementation and function to zero block of memory. Change-Id: I7b78ca3f922c0eda39beb9786b7150e9193425be
2016-07-28Merge pull request #673 from soby-mathew/sm/coverity_issuedanh-arm
Improve debug assertion for runtime svc number
2016-07-26Improve debug assertion for runtime svc numberSoby Mathew
This patch improves the debug assertion for runtime svc number - Remove useless comparison ensuring that the number of descriptors is a positive number. The variable is an unsigned integer so can't be negative. - Check that the end address of the descriptors is sane relative to the start address. Change-Id: Iea7be6b34e33b8b1cbd394eb923cc834ea964831
2016-07-25Ensure addresses in is_mem_free() don't overflowSandrine Bailleux
This patch adds some runtime checks to prevent some potential pointer overflow issues in the is_mem_free() function. The overflow could happen in the case where the end addresses, computed as the sum of a base address and a size, results in a value large enough to wrap around. This, in turn, could lead to unpredictable behaviour. If such an overflow is detected, the is_mem_free() function will now declare the memory region as not free. The overflow is detected using a new macro, called check_uptr_overflow(). This patch also modifies all other places in the 'bl_common.c' file where an end address was computed as the sum of a base address and a size and instead keeps the two values separate. This avoids the need to handle pointer overflows everywhere. The code doesn't actually need to compute any end address before the is_mem_free() function is called other than to print information message to the serial output. This patch also introduces 2 slight changes to the reserve_mem() function: - It fixes the end addresses passed to choose_mem_pos(). It was incorrectly passing (base + size) instead of (base + size - 1). - When the requested allocation size is 0, the function now exits straight away and says so using a warning message. Previously, it used to actually reserve some memory. A zero-byte allocation was not considered as a special case so the function was using the same top/bottom allocation mechanism as for any other allocation. As a result, the smallest area of memory starting from the requested base address within the free region was reserved. Change-Id: I0e695f961e24e56ffe000718014e0496dc6e1ec6
2016-07-25Make runtime_svc_init() function more robustSandrine Bailleux
- Added some debug assertions checking that the runtime services indexes computed by get_unique_oen() are sane. - Do not print the name of the service when its descriptor is invalid. If the descriptor is corrupted then its name field could be corrupted as well and we would end up reading an arbitrary amount of invalid memory. Change-Id: I16f61065277d01fe1555d5a9cf743f7b52ccaa60
2016-07-25Improvements to runtime service init codeSandrine Bailleux
Light refactoring of the code in runtime_svc.c file. - Declare validate_rt_svc_desc()'s argument as const. - Remove 'goto' path in runtime_svc_init(). It was used in one place only. - Improve code readability by declaring a local variable holding the service pointer. Change-Id: I3b15c5adb9f37b786b5b993a9be70ea9dd017a83
