NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200
Signed-off-by: Julius Werner <jwerner@chromium.org>
When pointer authentication is enabled, the LR value saved on the stack
contains a Pointer Authentication Code (PAC). It must be stripped to
retrieve the return address.
The PAC field is stored on the high bits of the address and defined as:
- PAC field = Xn[54:bottom_PAC_bit], when address tagging is used.
- PAC field = Xn[63:56, 54:bottom_PAC_bit], without address tagging.
With bottom_PAC_bit = 64 - TCR_ELx.TnSZ
Change-Id: I21d804e58200dfeca1da4c2554690bed5d191936
Signed-off-by: Louis Mayencourt <louis.mayencourt@arm.com>
Corrects typos in core code, documentation files, drivers, Arm
platforms and services.
None of the corrections affect code; changes are limited to comments
and other documentation.
Change-Id: I5c1027b06ef149864f315ccc0ea473e2a16bfd1d
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
It's better to have them in a separate file instead of having them spread
across the Makefile. This is what the stack protector is already doing.
Change-Id: Id30742c0af10de5ea6d10674ca25bf52b0f2b262
