To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
The build option `ENABLE_ASSERTIONS` should be used instead. That way
both C and ASM assertions can be enabled or disabled together.
All occurrences of `ASM_ASSERTION` in common code and ARM platforms have
been replaced by `ENABLE_ASSERTIONS`.
ASM_ASSERTION has been removed from the user guide.
Change-Id: I51f1991f11b9b7ff83e787c9a3270c274748ec6f
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Add the new build option `ENABLE_ASSERTIONS` that controls whether or
not assert functions are compiled out. It defaults to 1 for debug builds
and to 0 for release builds.
Additionally, a following patch will be done to allow this build option
to hide auxiliary code used for the checks done in an `assert()`. This
code is is currently under the DEBUG build flag.
Assert messages are now only printed if LOG_LEVEL >= LOG_LEVEL_INFO,
which is the default for debug builds.
This patch also updates the User Guide.
Change-Id: I1401530b56bab25561bb0f274529f1d12c5263bc
The desired behaviour is to call `plat_panic_handler()`, and to use
`no_ret` to do so from ASM.
Change-Id: I88b2feefa6e6c8f9bf057fd51ee0d2e9fb551e4f
This API makes sure that all the characters sent to the crash console
are output before returning from it.
Porting guide updated.
Change-Id: I1785f970a40f6aacfbe592b6a911b1f249bb2735
There are many instances in ARM Trusted Firmware where control is
transferred to functions from which return isn't expected. Such jumps
are made using 'bl' instruction to provide the callee with the location
from which it was jumped to. Additionally, debuggers infer the caller by
examining where 'lr' register points to. If a 'bl' of the nature
described above falls at the end of an assembly function, 'lr' will be
left pointing to a location outside of the function range. This misleads
the debugger back trace.
This patch defines a 'no_ret' macro to be used when jumping to functions
from which return isn't expected. The macro ensures to use 'bl'
instruction for the jump, and also, for debug builds, places a 'nop'
instruction immediately thereafter (unless instructed otherwise) so as
to leave 'lr' pointing within the function range.
Change-Id: Ib34c69fc09197cfd57bc06e147cc8252910e01b0
Co-authored-by: Douglas Raillard <douglas.raillard@arm.com>
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
This patch removes the tight loop that calls `plat_report_exception`
in unhandled exceptions in AArch64 state.
The new behaviour is to call the `plat_report_exception` only
once followed by call to `plat_panic_handler`.
This allows platforms to take platform-specific action when
there is an unhandled exception, instead of always spinning
in a tight loop.
Note: This is a subtle break in behaviour for platforms that
expect `plat_report_exception` to be continuously executed
when there is an unhandled exception.
Change-Id: Ie2453804b9b7caf9b010ee73e1a90eeb8384e4e8
This patch moves the PSCI services and BL31 frameworks like context
management and per-cpu data into new library components `PSCI` and
`el3_runtime` respectively. This enables PSCI to be built independently from
BL31. A new `psci_lib.mk` makefile is introduced which adds the relevant
PSCI library sources and gets included by `bl31.mk`. Other changes which
are done as part of this patch are:
* The runtime services framework is now moved to the `common/` folder to
enable reuse.
* The `asm_macros.S` and `assert_macros.S` helpers are moved to architecture
specific folder.
* The `plat_psci_common.c` is moved from the `plat/common/aarch64/` folder
to `plat/common` folder. The original file location now has a stub which
just includes the file from new location to maintain platform compatibility.
Most of the changes wouldn't affect platform builds as they just involve
changes to the generic bl1.mk and bl31.mk makefiles.
NOTE: THE `plat_psci_common.c` FILE HAS MOVED LOCATION AND THE STUB FILE AT
THE ORIGINAL LOCATION IS NOW DEPRECATED. PLATFORMS SHOULD MODIFY THEIR
MAKEFILES TO INCLUDE THE FILE FROM THE NEW LOCATION.
Change-Id: I6bd87d5b59424995c6a65ef8076d4fda91ad5e86
Build option to include AArch32 registers in cpu context
The system registers that are saved and restored in CPU context include
AArch32 systems registers like SPSR_ABT, SPSR_UND, SPSR_IRQ, SPSR_FIQ,
DACR32_EL2, IFSR32_EL2 and FPEXC32_EL2. Accessing these registers on an
AArch64-only (i.e. on hardware that does not implement AArch32, or at
least not at EL1 and higher ELs) platform leads to an exception. This patch
introduces the build option `CTX_INCLUDE_AARCH32_REGS` to specify whether to
include these AArch32 systems registers in the cpu context or not. By default
this build option is set to 1 to ensure compatibility. AArch64-only platforms
must set it to 0. A runtime check is added in BL1 and BL31 cold boot path to
verify this.
Fixes ARM-software/tf-issues#386
Change-Id: I720cdbd7ed7f7d8516635a2ec80d025f478b95ee
This patch introduces some assembler macros to simplify the
declaration of the exception vectors. It abstracts the section
the exception code is put into as well as the alignments
constraints mandated by the ARMv8 architecture. For all TF images,
the exception code has been updated to make use of these macros.
This patch also updates some invalid comments in the exception
vector code.
Change-Id: I35737b8f1c8c24b6da89b0a954c8152a4096fa95
Added a new platform porting function plat_panic_handler, to allow
platforms to handle unexpected error situations. It must be
implemented in assembly as it may be called before the C environment
is initialized. A default implementation is provided, which simply
spins.
Corrected all dead loops in generic code to call this function
instead. This includes the dead loop that occurs at the end of the
call to panic().
All unnecesary wfis from bl32/tsp/aarch64/tsp_exceptions.S have
been removed.
Change-Id: I67cb85f6112fa8e77bd62f5718efcef4173d8134
Change-Id: I6f49bd779f2a4d577c6443dd160290656cdbc59b
This patch removes the dash character from the image name, to
follow the image terminology in the Trusted Firmware Wiki page:
https://github.com/ARM-software/arm-trusted-firmware/wiki
Changes apply to output messages, comments and documentation.
non-ARM platform files have been left unmodified.
Change-Id: Ic2a99be4ed929d52afbeb27ac765ceffce46ed76
The upcoming Firmware Update feature needs transitioning across
Secure/Normal worlds to complete the FWU process and hence requires
context management code to perform this task.
Currently context management code is part of BL31 stage only.
This patch moves the code from (include)/bl31 to (include)/common.
Some function declarations/definitions and macros have also moved
to different files to help code sharing.
Change-Id: I3858b08aecdb76d390765ab2b099f457873f7b0c
In order for the symbol table in the ELF file to contain the size of
functions written in assembly, it is necessary to report it to the
assembler using the .size directive.
To fulfil the above requirements, this patch introduces an 'endfunc'
macro which contains the .endfunc and .size directives. It also adds
a .func directive to the 'func' assembler macro.
The .func/.endfunc have been used so the assembler can fail if
endfunc is omitted.
Fixes ARM-Software/tf-issues#295
Change-Id: If8cb331b03d7f38fe7e3694d4de26f1075b278fc
Signed-off-by: Kévin Petit <kevin.petit@arm.com>
This patch provides a workaround for the ASM_ASSERT label issue
and also reworks the use of labels in assembly macros.
If the caller of the ASM_ASSERT macro happened to use the
label '1' to jump past the ASM_ASSERT macro, it would not have
worked since the ASM_ASSERT macro internally used the same label.
Hence, as a workaround, this patch makes the label a high
number in the expectation that the caller will never use it.
Also updated the other assembly macros using numerical labels to
named lables.
Change-Id: Iec892359db84f2391ad2a83a92141c4d7049776a
This patch reworks the crash reporting mechanism to further
optimise the stack and code size. The reporting makes use
of assembly console functions to avoid calling C Runtime
to report the CPU state. The crash buffer requirement is
reduced to 64 bytes with this implementation. The crash
buffer is now part of per-cpu data which makes retrieving
the crash buffer trivial.
Also now panic() will use crash reporting if
invoked from BL3-1.
Fixes ARM-software/tf-issues#199
Change-Id: I79d27a4524583d723483165dc40801f45e627da5
The patch implements a macro ASM_ASSERT() which can
be invoked from assembly code. When assertion happens,
file name and line number of the check is written
to the crash console.
Fixes ARM-software/tf-issues#95
Change-Id: I6f905a068e1c0fa4f746d723f18df60daaa00a86
Reduce the number of header files included from other header
files as much as possible without splitting the files. Use forward
declarations where possible. This allows removal of some unnecessary
"#ifndef __ASSEMBLY__" statements.
Also, review the .c and .S files for which header files really need
including and reorder the #include statements alphabetically.
Fixes ARM-software/tf-issues#31
Change-Id: Iec92fb976334c77453e010b60bcf56f3be72bd3e
bl1/aarch64/early_exceptions.S used to be re-used by BL2, BL3-1 and
BL3-2. There was some early SMC handling code in there that was not
required by the other bootloader stages. Therefore this patch
introduces an even simpler exception vector source file for BL2,
BL3-1 and BL3-2.
Change-Id: I0244b80e9930b0f8035156a0bf91cc3e9a8f995d
