This patch disables routing of external aborts from lower exception levels to
EL3 and ensures that a SError interrupt generated as a result of execution in
EL3 is taken locally instead of a lower exception level.
The SError interrupt is enabled in the TSP code only when the operation has not
been directly initiated by the normal world. This is to prevent the possibility
of an asynchronous external abort which originated in normal world from being
taken when execution is in S-EL1.
Fixes ARM-software/tf-issues#153
Change-Id: I157b996c75996d12fd86d27e98bc73dd8bce6cd5
Move the TSP private declarations out of tsp.h and into a new
header, tsp_private.h. This clarifies the TSP interface to the TSPD.
Change-Id: I39af346eeba3350cadcac56c02d97a5cb978c28b
Fix the following issues with the console log output:
* Make sure the welcome string is the first thing in the log output
(during normal boot).
* Prefix each message with the BL image name so it's clear which
BL the output is coming from.
* Ensure all output is wrapped in one of the log output macros so it can
be easily compiled out if necessary. Change some of the INFO() messages
to VERBOSE(), especially in the TSP.
* Create some extra NOTICE() and INFO() messages during cold boot.
* Remove all usage of \r in log output.
Fixes ARM-software/tf-issues#231
Change-Id: Ib24f7acb36ce64bbba549f204b9cde2dbb46c8a3
Call platform_is_primary_cpu() only from reset handler
This patch adds support for BL3-2 initialization by asynchronous
method where BL3-1 transfers control to BL3-2 using world switch.
After BL3-2 initialization, it transfers control to BL3-3 via SPD
service handler. The SPD service handler initializes the CPU context
to BL3-3 entrypoint depending on the return function indentifier from
TSP initialization.
Fixes ARM-software/TF-issues#184
Change-Id: I7b135c2ceeb356d3bb5b6a287932e96ac67c7a34
The purpose of platform_is_primary_cpu() is to determine after reset
(BL1 or BL3-1 with reset handler) if the current CPU must follow the
cold boot path (primary CPU), or wait in a safe state (secondary CPU)
until the primary CPU has finished the system initialization.
This patch removes redundant calls to platform_is_primary_cpu() in
subsequent bootloader entrypoints since the reset handler already
guarantees that code is executed exclusively on the primary CPU.
Additionally, this patch removes the weak definition of
platform_is_primary_cpu(), so the implementation of this function
becomes mandatory. Removing the weak symbol avoids other
bootloaders accidentally picking up an invalid definition in case the
porting layer makes the real function available only to BL1.
The define PRIMARY_CPU is no longer mandatory in the platform porting
because platform_is_primary_cpu() hides the implementation details
(for instance, there may be platforms that report the primary CPU in
a system register). The primary CPU definition in FVP has been moved
to fvp_def.h.
The porting guide has been updated accordingly.
Fixes ARM-software/tf-issues#219
Change-Id: If675a1de8e8d25122b7fef147cb238d939f90b5e
Simplify management of SCTLR_EL3 and SCTLR_EL1
Ag/tf issues#198
This patch reworks the manner in which the M,A, C, SA, I, WXN & EE bits of
SCTLR_EL3 & SCTLR_EL1 are managed. The EE bit is cleared immediately after reset
in EL3. The I, A and SA bits are set next in EL3 and immediately upon entry in
S-EL1. These bits are no longer managed in the blX_arch_setup() functions. They
do not have to be saved and restored either. The M, WXN and optionally the C
bit are set in the enable_mmu_elX() function. This is done during both the warm
and cold boot paths.
Fixes ARM-software/tf-issues#226
Change-Id: Ie894d1a07b8697c116960d858cd138c50bc7a069
Print out Trusted Firmware version at runtime at each BL stage.
Message consists of TF version as defined statically in the Makefile
(e.g. v0.4), build mode (debug|release) and a customizable build
string:
1. By defining BUILD_STRING in command line when building TF
2. Default string is git commit ID
3. Empty if git meta-data is not available
Fixes ARM-software/tf-issues#203
Change-Id: I5c5ba438f66ab68810427d76b49c5b9177a957d6
This patch implements a "tf_printf" which supports only the commonly
used format specifiers in Trusted Firmware, which uses a lot less
stack space than the stdlib printf function.
Fixes ARM-software/tf-issues#116
Change-Id: I7dfa1944f4c1e634b3e2d571f49afe02d109a351
This patch uses stacks allocated in normal memory to enable the MMU early in the
warm boot path thus removing the dependency on stacks allocated in coherent
memory. Necessary cache and stack maintenance is performed when a cpu is being
powered down and up. This avoids any coherency issues that can arise from
reading speculatively fetched stale stack memory from another CPUs cache. These
changes affect the warm boot path in both BL3-1 and BL3-2.
The EL3 system registers responsible for preserving the MMU state are not saved
and restored any longer. Static values are used to program these system
registers when a cpu is powered on or resumed from suspend.
Change-Id: I8357e2eb5eb6c5f448492c5094b82b8927603784
This patch reworks the cold boot path across the BL1, BL2, BL3-1 and BL3-2 boot
loader stages to not use stacks allocated in coherent memory for early platform
setup and enabling the MMU. Stacks allocated in normal memory are used instead.
Attributes for stack memory change from nGnRnE when the MMU is disabled to
Normal WBWA Inner-shareable when the MMU and data cache are enabled. It is
possible for the CPU to read stale stack memory after the MMU is enabled from
another CPUs cache. Hence, it is unsafe to turn on the MMU and data cache while
using normal stacks when multiple CPUs are a part of the same coherency
domain. It is safe to do so in the cold boot path as only the primary cpu
executes it. The secondary cpus are in a quiescent state.
This patch does not remove the allocation of coherent stack memory. That is done
in a subsequent patch.
Change-Id: I12c80b7c7ab23506d425c5b3a8a7de693498f830
fvp: Reuse BL1 and BL2 memory through image overlaying (v2)
This patch re-organizes the memory layout on FVP as to give the
BL3-2 image as much memory as possible.
Considering these two facts:
- not all images need to live in memory at the same time. Once
in BL3-1, the memory used by BL1 and BL2 can be reclaimed.
- when BL2 loads the BL3-1 and BL3-2 images, it only considers the
PROGBITS sections of those 2 images. The memory occupied by the
NOBITS sections will be touched only at execution of the BL3-x
images;
Then it is possible to choose the different base addresses such that
the NOBITS sections of BL3-1 and BL3-2 overlay BL1 and BL2.
On FVP we choose to put:
- BL1 and BL3-1 at the top of the Trusted RAM, with BL3-1 NOBITS
sections overlaying BL1;
- BL3-2 at the bottom of the Trusted RAM, with its NOBITS sections
overlaying BL2;
This is illustrated by the following diagram:
0x0404_0000 ------------ ------------------
| BL1 | <= | BL3-1 NOBITS |
| | <= | BL3-1 PROGBITS |
| BL2 | <= | BL3-2 NOBITS |
| | <= | BL3-2 PROGBITS |
0x0400_0000 ------------ ------------------
New platform-specific constants have been introduced to easily check
at link time that BL3-1 and BL3-2 PROGBITS sections don't overwrite
BL1 and BL2. These are optional and the platform code is free to define
them or not. If not defined, the linker won't attempt to check
image overlaying.
Fixes ARM-software/tf-issues#117
Change-Id: I5981d1c3d66ee70eaac8bd052630c9ac6dd8b042
Refactor the FVP gic code in plat/fvp/fvp_gic.c to be a generic ARM
GIC driver in drivers/arm/gic/arm_gic.c. Provide the platform
specific inputs in the arm_gic_setup() function so that the driver
has no explicit dependency on platform code.
Provide weak implementations of the platform interrupt controller
API in a new file, plat/common/plat_gic.c. These simply call through
to the ARM GIC driver.
Move the only remaining FVP GIC function, fvp_gic_init() to
plat/fvp/aarch64/fvp_common.c and remove plat/fvp/fvp_gic.c
Fixes ARM-software/tf-issues#182
Change-Id: Iea82fe095fad62dd33ba9efbddd48c57717edd21
Exclude stdlib files because they do not follow kernel code style.
Fixes ARM-software/tf-issues#73
Change-Id: I4cfafa38ab436f5ab22c277cb38f884346a267ab
Rename the ic_* platform porting functions to plat_ic_* to be
consistent with the other functions in platform.h. Also rename
bl31_get_next_image_info() to bl31_plat_get_next_image_ep_info()
and remove the duplicate declaration in bl31.h.
Change-Id: I4851842069d3cff14c0a468daacc0a891a7ede84
Previously, the enable_mmu_elX() functions were implicitly part of
the platform porting layer since they were included by generic
code. These functions have been placed behind 2 new platform
functions, bl31_plat_enable_mmu() and bl32_plat_enable_mmu().
These are weakly defined so that they can be optionally overridden
by platform ports.
Also, the enable_mmu_elX() functions have been moved to
lib/aarch64/xlat_tables.c for optional re-use by platform ports.
These functions are tightly coupled with the translation table
initialization code.
Fixes ARM-software/tf-issues#152
Change-Id: I0a2251ce76acfa3c27541f832a9efaa49135cc1c
FVP specific files and functions containing the word "plat" have been
renamed to use the word "fvp" to distinguish them from the common
platform functionality and porting functions.
Change-Id: I39f9673dab3ee9c74bd18b3e62b7c21027232f7d
Some platform porting functions were in BL specific header files.
These have been moved to platform.h so that all porting functions
are in the same place. The functions are now grouped by BL.
Obsolete BL headers files have been removed.
Also, the weak declaration of the init_bl2_mem_layout() function
has been moved out the header file and into the source file
(bl_common.c) using the more succinct #pragma syntax. This
mitigates the risk of 2 weak definitions being created and the
wrong one being picked up by the compiler.
Change-Id: Ib19934939fd755f3e5a5a5bceec88da684308a83
Previously, platform.h contained many declarations and definitions
used for different purposes. This file has been split so that:
* Platform definitions used by common code that must be defined
by the platform are now in platform_def.h. The exact include
path is exported through $PLAT_INCLUDES in the platform makefile.
* Platform definitions specific to the FVP platform are now in
/plat/fvp/fvp_def.h.
* Platform API declarations specific to the FVP platform are now
in /plat/fvp/fvp_private.h.
* The remaining platform API declarations that must be ported by
each platform are still in platform.h but this file has been
moved to /include/plat/common since this can be shared by all
platforms.
Change-Id: Ieb3bb22fbab3ee8027413c6b39a783534aee474a
Currently the platform code gets to define the base address of each
boot loader image. However, the linker scripts couteract this
flexibility by enforcing a fixed overall layout of the different
images. For example, they require that the BL3-1 image sits below
the BL2 image. Choosing BL3-1 and BL2 base addresses in such a way
that it violates this constraint makes the build fail at link-time.
This patch requires the platform code to now define a limit address
for each image. The linker scripts check that the image fits within
these bounds so they don't rely anymore on the position of a given
image in regard to the others.
Fixes ARM-software/tf-issues#163
Change-Id: I8c108646825da19a6a8dfb091b613e1dd4ae133c
The TSP has a number of entrypoints used by the TSP on different
occasions. These were provided to the TSPD as a table of function
pointers, and required the TSPD to read the entry in the table,
which is in TSP memory, in order to program the exception return
address.
Ideally, the TSPD has no access to the TSP memory.
This patch changes the table of function pointers into a vector
table of single instruction entrypoints. This allows the TSPD to
calculate the entrypoint address instead of read it.
Fixes ARM-software/tf-issues#160
Change-Id: Iec6e055d537ade78a45799fbc6f43765a4725ad3
Implements support for Non Secure Interrupts preempting the
Standard SMC call in EL1. Whenever an IRQ is trapped in the
Secure world we securely handover to the Normal world
to process the interrupt. The normal world then issues
"resume" smc call to resume the previous interrupted SMC call.
Fixes ARM-software/tf-issues#105
Change-Id: I72b760617dee27438754cdfc9fe9bcf4cc024858
This patch enables secure physical timer during TSP initialisation and
maintains it across power management operations so that a timer
interrupt is generated every half second.
Fixes ARM-software/tf-issues#104
Fixes ARM-software/tf-issues#134
Change-Id: I66c6cfd24bd5e6035ba75ebf0f047e568770a369
This patch adds support in the TSP to handle FIQ interrupts that are
generated when execution is in the TSP. S-EL1 interrupt are handled
normally and execution resumes at the instruction where the exception
was originally taken. S-EL3 interrupts i.e. any interrupt not
recognized by the TSP are handed to the TSPD. Execution resumes
normally once such an interrupt has been handled at EL3.
Change-Id: Ia3ada9a4fb15670afcc12538a6456f21efe58a8f
This patch adds support in the TSP for handling S-EL1 interrupts
handed over by the TSPD. It includes GIC support in its platform port,
updates various statistics related to FIQ handling, exports an entry
point that the TSPD can use to hand over interrupts and defines the
handover protocol w.r.t what context is the TSP expected to preserve
and the state in which the entry point is invoked by the TSPD.
Change-Id: I93b22e5a8133400e4da366f5fc862f871038df39
This patch adds support in the TSP to program the secure physical
generic timer to generate a EL-1 interrupt every half second. It also
adds support for maintaining the timer state across power management
operations. The TSPD ensures that S-EL1 can access the timer by
programming the SCR_EL3.ST bit.
This patch does not actually enable the timer. This will be done in a
subsequent patch once the complete framework for handling S-EL1
interrupts is in place.
Change-Id: I1b3985cfb50262f60824be3a51c6314ce90571bc
The TSP used to execute from secure DRAM on the FVPs because there was
not enough space in Trusted SRAM to fit it in. Thanks to recent RAM
usage enhancements being implemented, we have made enough savings for
the TSP to execute in SRAM.
However, there is no contiguous free chunk of SRAM big enough to hold
the TSP. Therefore, the different bootloader images need to be moved
around to reduce memory fragmentation. This patch keeps the overall
memory layout (i.e. keeping BL1 R/W at the bottom, BL2 at the top and
BL3-1 in between) but moves the base addresses of all the bootloader
images in such a way that:
- memory fragmentation is reduced enough to fit BL3-2 in;
- new base addresses are suitable for release builds as well as debug
ones;
- each image has a few extra kilobytes for future growth.
BL3-1 and BL3-2 are the images which received the biggest slice
of the cake since they will most probably grow the most.
A few useful numbers for reference (valid at the time of this patch):
| image size (debug) | extra space for the future
BL1 R/W | 20 KB | 4 KB
BL2 | 44 KB | 4 KB
BL3-1 | 108 KB | 12 KB
BL3-2 | 56 KB | 8 KB
Total | 228 KB | 28 KB = 256 KB
Although on FVPs the TSP now executes from Trusted SRAM by default,
this patch keeps the option to execute it from Trusted DRAM. This is
controlled by the build configuration 'TSP_RAM_LOCATION'.
Fixes ARM-Software/tf-issues#81
Change-Id: Ifb9ef2befa9a2d5ac0813f7f79834df7af992b94
The TSP's linker script used to assume that the TSP would
execute from secure DRAM. Although it is currently the case
on FVPs, platforms are free to use any secure memory they wish.
This patch introduces the flexibility to load the TSP into any
secure memory. The platform code gets to specify the extents of
this memory in the platform header file, as well as the BL3-2 image
limit address. The latter definition allows to check in a generic way
that the BL3-2 image fits in its bounds.
Change-Id: I9450f2d8b32d74bd00b6ce57a0a1542716ab449c
The issues addressed in this patch are:
1. Remove meminfo_t from the common interfaces in BL3-x,
expecting that platform code will find a suitable mechanism
to determine the memory extents in these images and provide
it to the BL3-x images.
2. Remove meminfo_t and bl31_plat_params_t from all FVP BL3-x
code as the images use link-time information to determine
memory extents.
meminfo_t is still used by common interface in BL1/BL2 for
loading images
Change-Id: I4e825ebf6f515b59d84dc2bdddf6edbf15e2d60f
On FVP, the file 'plat/fvp/aarch64/plat_helpers.S' contains an
FVP-specific implementation of the function 'plat_report_exception()',
which is meant to override the default implementation. However, this
file was not included into the BL3-2 image, meaning it was still
using the default implementation. This patch fixes the FVP makefile
to compile this file in.
Change-Id: I3d44b9ec3a9de7e2762e0887d3599b185d3e28d2
Instead of having a single version of the MMU setup functions for all
bootloader images that can execute either in EL3 or in EL1, provide
separate functions for EL1 and EL3. Each bootloader image can then
call the appropriate version of these functions. The aim is to reduce
the amount of code compiled in each BL image by embedding only what's
needed (e.g. BL1 to embed only EL3 variants).
Change-Id: Ib86831d5450cf778ae78c9c1f7553fe91274c2fa
Reduce the number of header files included from other header
files as much as possible without splitting the files. Use forward
declarations where possible. This allows removal of some unnecessary
"#ifndef __ASSEMBLY__" statements.
Also, review the .c and .S files for which header files really need
including and reorder the #include statements alphabetically.
Fixes ARM-software/tf-issues#31
Change-Id: Iec92fb976334c77453e010b60bcf56f3be72bd3e
Add tag names to all unnamed structs in header files. This
allows forward declaration of structs, which is necessary to
reduce header file nesting (to be implemented in a subsequent
commit).
Also change the typedef names across the codebase to use the _t
suffix to be more conformant with the Linux coding style. The
coding style actually prefers us not to use typedefs at all but
this is considered a step too far for Trusted Firmware.
Also change the IO framework structs defintions to use typedef'd
structs to be consistent with the rest of the codebase.
Change-Id: I722b2c86fc0d92e4da3b15e5cab20373dd26786f
Remove all usage of the vpath keyword in makefiles as it was prone
to mistakes. Specify the relative paths to source files instead.
Also reorder source files in makefiles alphabetically.
Fixes ARM-software/tf-issues#121
Change-Id: Id15f60655444bae60e0e2165259efac71a50928b
Move almost all system include files to a logical sub-directory
under ./include. The only remaining system include directories
not under ./include are specific to the platform. Move the
corresponding source files to match the include directory
structure.
Also remove pm.h as it is no longer used.
Change-Id: Ie5ea6368ec5fad459f3e8a802ad129135527f0b3
The BL images share common stack management code which provides
one coherent and one cacheable stack for every CPU. BL1 and BL2
just execute on the primary CPU during boot and do not require
the additional CPU stacks. This patch provides separate stack
support code for UP and MP images, substantially reducing the
RAM usage for BL1 and BL2 for the FVP platform.
This patch also provides macros for declaring stacks and
calculating stack base addresses to improve consistency where
this has to be done in the firmware.
The stack allocation source files are now included via
platform.mk rather than the common BLx makefiles. This allows
each platform to select the appropriate MP/UP stack support
for each BL image.
Each platform makefile must be updated when including this
commit.
Fixes ARM-software/tf-issues#76
Change-Id: Ia251f61b8148ffa73eae3f3711f57b1ffebfa632
This extends the --gc-sections behaviour to the many assembler
support functions in the firmware images by placing each function
into its own code section. This is achieved by creating a 'func'
macro used to declare each function label.
Fixes ARM-software/tf-issues#80
Change-Id: I301937b630add292d2dec6d2561a7fcfa6fec690
All common functions are being built into all binary images,
whether or not they are actually used. This change enables the
use of -ffunction-sections, -fdata-sections and --gc-sections
in the compiler and linker to remove unused code and data from
the images.
Change-Id: Ia9f78c01054ac4fa15d145af38b88a0d6fb7d409
bl1/aarch64/early_exceptions.S used to be re-used by BL2, BL3-1 and
BL3-2. There was some early SMC handling code in there that was not
required by the other bootloader stages. Therefore this patch
introduces an even simpler exception vector source file for BL2,
BL3-1 and BL3-2.
Fixes ARM-software/tf-issues#38
Change-Id: I0244b80e9930b0f8035156a0bf91cc3e9a8f995d
The Test Secure-EL1 Payload implementation should always have a
platform-specific component. Therefore, there should always
be a platform-specific sub-makefile for the TSP. If there is
none then assume TSP is not supported on this specific platform
and throw an error at build time if the user tries to compile it.
Change-Id: Ibfbe6e4861cc7786a29f2fc0341035b852925193
At present, the entry point for each BL image is specified via the
Makefiles and provided on the command line to the linker. When using a
link script the entry point should rather be specified via the ENTRY()
directive in the link script.
This patch updates linker scripts of all BL images to specify the entry
point using the ENTRY() directive. It also removes the --entry flag
passed to the linker through Makefile.
Fixes issue ARM-software/tf-issues#66
Change-Id: I1369493ebbacea31885b51185441f6b628cf8da0
So it updates each time a bootloader changes, not just when bl*_main.c
files are recompiled.
Fixes ARM-software/tf-issues#33
Change-Id: Ie8e1a7bd7e1913d2e96ac268606284f76af8c5ab
Signed-off-by: Jon Medhurst <tixy@linaro.org>
