path: root/bl31/bl31.ld.S
2020-02-09plat: imx8mq: move the stack & xlat table into ocram_sJacky Bai
Move the stack & xlat table into ocram_s due to the ocram is not enough. Signed-off-by: Jacky Bai <ping.bai@nxp.com>
2019-02-07locks: linker variables to calculate per-cpu bakery lock sizeVarun Wadekar
This patch introduces explicit linker variables to mark the start and end of the per-cpu bakery lock section to help bakery_lock_normal.c calculate the size of the section. This patch removes the previously used '__PERCPU_BAKERY_LOCK_SIZE__' linker variable to make the code uniform across GNU linker and ARM linker. Change-Id: Ie0c51702cbc0fe8a2076005344a1fcebb48e7cca Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2019-01-16Merge pull request #1738 from ardbiesheuvel/synquacer-spmSoby Mathew
synquacer: add SPM support
2019-01-15spm: permit platform to override the VMA placement of the vector tableArd Biesheuvel
On some systems, it may be preferred to place the secure EL1/0 vector table outside of the static placement of the BL31 image itself, for instance when the latter is located in non-shareable SRAM which does not tolerate inner shareable WBWA mappings (as is the case on SynQuacer) So permit the platform to #define SPM_SHIM_EXCEPTIONS_VMA in its supplementary linker script, in which case it will be used as the VMA region for the vector table. Note that the LMA does not change, and it is up to the platform to copy the contents to the right place at init time. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
2019-01-15Correct typographical errorsPaul Beesley
Corrects typos in core code, documentation files, drivers, Arm platforms and services. None of the corrections affect code; changes are limited to comments and other documentation. Change-Id: I5c1027b06ef149864f315ccc0ea473e2a16bfd1d Signed-off-by: Paul Beesley <paul.beesley@arm.com>
2019-01-04Sanitise includes across codebaseAntonio Nino Diaz
Enforce full include path for includes. Deprecate old paths. The following folders inside include/lib have been left unchanged: - include/lib/cpus/${ARCH} - include/lib/el3_runtime/${ARCH} The reason for this change is that having a global namespace for includes isn't a good idea. It defeats one of the advantages of having folders and it introduces problems that are sometimes subtle (because you may not know the header you are actually including if there are two of them). For example, this patch had to be created because two headers were called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform to avoid collision."). More recently, this patch has had similar problems: 46f9b2c3a282 ("drivers: add tzc380 support"). This problem was introduced in commit 4ecca33988b9 ("Move include and source files to logical locations"). At that time, there weren't too many headers so it wasn't a real issue. However, time has shown that this creates problems. Platforms that want to preserve the way they include headers may add the removed paths to PLAT_INCLUDES, but this is discouraged. Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-12-17BL31: correct GOT section omissionSoby Mathew
When the patch SHA 931f7c6 introduced PIE support for BL31, adding the GOT section when the SEPARATE_CODE_AND_RODATA=0 to the linker script was erroneously omitted. This patch corrects the same. Also the patch reduces the alignment requirement for GOT and RELA sections from 16 bytes to 8. Comments are added explain the intent for alignment. Change-Id: I8035cbf75f346f99bd56b13f32e0b3b70dd2fe6c Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2018-10-29PIE: Position Independant Executable support for BL31Soby Mathew
This patch introduces Position Independant Executable(PIE) support in TF-A. As a initial prototype, only BL31 can support PIE. A trivial dynamic linker is implemented which supports fixing up Global Offset Table(GOT) and Dynamic relocations(.rela.dyn). The fixup_gdt_reloc() helper function implements this linker and this needs to be called early in the boot sequence prior to invoking C functions. The GOT is placed in the RO section of BL31 binary for improved security and the BL31 linker script is modified to export the appropriate symbols required for the dynamic linker. The C compiler always generates PC relative addresses to linker symbols and hence referencing symbols exporting constants are a problem when relocating the binary. Hence the reference to the `__PERCPU_TIMESTAMP_SIZE__` symbol in PMF is removed and is now calculated at runtime based on start and end addresses. Change-Id: I1228583ff92cf432963b7cef052e95d995cca93d Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2018-10-16scmi: Optimize bakery locks when HW_ASSISTED_COHERENCY is enabledRoberto Vargas
When HW_ASSISTED_COHERENCY is enabled we can use spinlocks instead of using the more complex and slower bakery algorithm. Change-Id: I9d791a70050d599241169b9160a67e57d5506564 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-07-11Use ALIGN instead of NEXT in linker scriptsRoberto Vargas
Clang linker doesn't support NEXT. As we are not using the MEMORY command to define discontinuous memory for the output file in any of the linker scripts, ALIGN and NEXT are equivalent. Change-Id: I867ffb9c9a76d4e81c9ca7998280b2edf10efea0 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-06-13SPM: Treat SP xlat tables the same as othersSandrine Bailleux
The translation tables allocated for the Secure Partition do not need to be treated as a special case. They can be put amongst the other tables mapping BL31's general purpose memory. They will be mapped with the same attributes as them, which is fine. The explicit alignment constraint in BL31's linker script to pad the last page of memory allocated to the Secure Partition's translation tables is useless too, as page tables are per se pages, thus their end address is naturally aligned on a page-boundary. In fact, this patch does not change the existing behaviour. Since patch 22282bb68a31 ("SPM: Move all SP-related info to SP context struct"), the secure_partition.c file has been renamed into sp_xlat.c but the linker script has not been properly updated. As a result, the SP translation tables are not specifically put at the start of the xlat_table linker section, the __SP_IMAGE_XLAT_TABLES_START__/_END__ symbols have the same value, the size of the resulting mmap_region covering these xlat tables is 0 and so it is ignored. Change-Id: I4cf0a4cc090298811cca53fc9cee74df0f2b1512 Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
2018-02-27Add comments about mismatched TCR_ELx and xlat tablesAntonio Nino Diaz
When the MMU is enabled and the translation tables are mapped, data read/writes to the translation tables are made using the attributes specified in the translation tables themselves. However, the MMU performs table walks with the attributes specified in TCR_ELx. They are completely independent, so special care has to be taken to make sure that they are the same. This has to be done manually because it is not practical to have a test in the code. Such a test would need to know the virtual memory region that contains the translation tables and check that for all of the tables the attributes match the ones in TCR_ELx. As the tables may not even be mapped at all, this isn't a test that can be made generic. The flags used by enable_mmu_xxx() have been moved to the same header where the functions are. Also, some comments in the linker scripts related to the translation tables have been fixed. Change-Id: I1754768bffdae75f53561b1c4a5baf043b45a304 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-11-29Replace magic numbers in linkerscripts by PAGE_SIZEAntonio Nino Diaz
When defining different sections in linker scripts it is needed to align them to multiples of the page size. In most linker scripts this is done by aligning to the hardcoded value 4096 instead of PAGE_SIZE. This may be confusing when taking a look at all the codebase, as 4096 is used in some parts that aren't meant to be a multiple of the page size. Change-Id: I36c6f461c7782437a58d13d37ec8b822a1663ec1 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-11-08SPM: Introduce Secure Partition ManagerAntonio Nino Diaz
A Secure Partition is a software execution environment instantiated in S-EL0 that can be used to implement simple management and security services. Since S-EL0 is an unprivileged exception level, a Secure Partition relies on privileged firmware e.g. ARM Trusted Firmware to be granted access to system and processor resources. Essentially, it is a software sandbox that runs under the control of privileged software in the Secure World and accesses the following system resources: - Memory and device regions in the system address map. - PE system registers. - A range of asynchronous exceptions e.g. interrupts. - A range of synchronous exceptions e.g. SMC function identifiers. A Secure Partition enables privileged firmware to implement only the absolutely essential secure services in EL3 and instantiate the rest in a partition. Since the partition executes in S-EL0, its implementation cannot be overly complex. The component in ARM Trusted Firmware responsible for managing a Secure Partition is called the Secure Partition Manager (SPM). The SPM is responsible for the following: - Validating and allocating resources requested by a Secure Partition. - Implementing a well defined interface that is used for initialising a Secure Partition. - Implementing a well defined interface that is used by the normal world and other secure services for accessing the services exported by a Secure Partition. - Implementing a well defined interface that is used by a Secure Partition to fulfil service requests. - Instantiating the software execution environment required by a Secure Partition to fulfil a service request. Change-Id: I6f7862d6bba8732db5b73f54e789d717a35e802f Co-authored-by: Douglas Raillard <douglas.raillard@arm.com> Co-authored-by: Sandrine Bailleux <sandrine.bailleux@arm.com> Co-authored-by: Achin Gupta <achin.gupta@arm.com> Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com> Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-10-23BL31: Introduce Publish and Subscribe frameworkJeenu Viswambharan
This light-weight framework enables some EL3 components to publish events which other EL3 components can subscribe to. Publisher can optionally pass opaque data for subscribers. The order in which subscribers are called is not defined. Firmware design updated. Change-Id: I24a3a70b2b1dedcb1f73cf48313818aebf75ebb6 Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-03-31Add support for GCC stack protectionDouglas Raillard
Introduce new build option ENABLE_STACK_PROTECTOR. It enables compilation of all BL images with one of the GCC -fstack-protector-* options. A new platform function plat_get_stack_protector_canary() is introduced. It returns a value that is used to initialize the canary for stack corruption detection. Returning a random value will prevent an attacker from predicting the value and greatly increase the effectiveness of the protection. A message is printed at the ERROR level when a stack corruption is detected. To be effective, the global data must be stored at an address lower than the base of the stacks. Failure to do so would allow an attacker to overwrite the canary as part of an attack which would void the protection. FVP implementation of plat_get_stack_protector_canary is weak as there is no real source of entropy on the FVP. It therefore relies on a timer's value, which could be predictable. Change-Id: Icaaee96392733b721fa7c86a81d03660d3c1bc06 Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
2017-02-06Introduce unified API to zero memoryDouglas Raillard
Introduce zeromem_dczva function on AArch64 that can handle unaligned addresses and make use of DC ZVA instruction to zero a whole block at a time. This zeroing takes place directly in the cache to speed it up without doing external memory access. Remove the zeromem16 function on AArch64 and replace it with an alias to zeromem. This zeromem16 function is now deprecated. Remove the 16-bytes alignment constraint on __BSS_START__ in firmware-design.md as it is now not mandatory anymore (it used to comply with zeromem16 requirements). Change the 16-bytes alignment constraints in SP min's linker script to a 8-bytes alignment constraint as the AArch32 zeromem implementation is now more efficient on 8-bytes aligned addresses. Introduce zero_normalmem and zeromem helpers in platform agnostic header that are implemented this way: * AArch32: * zero_normalmem: zero using usual data access * zeromem: alias for zero_normalmem * AArch64: * zero_normalmem: zero normal memory using DC ZVA instruction (needs MMU enabled) * zeromem: zero using usual data access Usage guidelines: in most cases, zero_normalmem should be preferred. There are 2 scenarios where zeromem (or memset) must be used instead: * Code that must run with MMU disabled (which means all memory is considered device memory for data accesses). * Code that fills device memory with null bytes. Optionally, the following rule can be applied if performance is important: * Code zeroing small areas (few bytes) that are not secrets should use memset to take advantage of compiler optimizations. Note: Code zeroing security-related critical information should use zero_normalmem/zeromem instead of memset to avoid removal by compilers' optimizations in some cases or misbehaving versions of GCC. Fixes ARM-software/tf-issues#408 Change-Id: Iafd9663fc1070413c3e1904e54091cf60effaa82 Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
2016-10-25rockchip: optimize the link mechanism for SRAM codeCaesar Wang
Add the common extra.ld.S and customized rk3399.ld.S to extend to more features for different platforms. For example, we can add SRAM section and specific address to load there if we need it, and the common bl31.ld.S not need to be modified. Therefore, we can remove the unused codes which copying explicitly from the function pmusram_prepare(). It looks like more clear. Change-Id: Ibffa2da5e8e3d1d2fca80085ebb296ceb967fce8 Signed-off-by: Xing Zheng <zhengxing@rock-chips.com> Signed-off-by: Caesar Wang <wxt@rock-chips.com>
2016-07-08Introduce SEPARATE_CODE_AND_RODATA build flagSandrine Bailleux
At the moment, all BL images share a similar memory layout: they start with their code section, followed by their read-only data section. The two sections are contiguous in memory. Therefore, the end of the code section and the beginning of the read-only data one might share a memory page. This forces both to be mapped with the same memory attributes. As the code needs to be executable, this means that the read-only data stored on the same memory page as the code are executable as well. This could potentially be exploited as part of a security attack. This patch introduces a new build flag called SEPARATE_CODE_AND_RODATA, which isolates the code and read-only data on separate memory pages. This in turn allows independent control of the access permissions for the code and read-only data. This has an impact on memory footprint, as padding bytes need to be introduced between the code and read-only data to ensure the segragation of the two. To limit the memory cost, the memory layout of the read-only section has been changed in this case. - When SEPARATE_CODE_AND_RODATA=0, the layout is unchanged, i.e. the read-only section still looks like this (padding omitted): | ... | +-------------------+ | Exception vectors | +-------------------+ | Read-only data | +-------------------+ | Code | +-------------------+ BLx_BASE In this case, the linker script provides the limits of the whole read-only section. - When SEPARATE_CODE_AND_RODATA=1, the exception vectors and read-only data are swapped, such that the code and exception vectors are contiguous, followed by the read-only data. This gives the following new layout (padding omitted): | ... | +-------------------+ | Read-only data | +-------------------+ | Exception vectors | +-------------------+ | Code | +-------------------+ BLx_BASE In this case, the linker script now exports 2 sets of addresses instead: the limits of the code and the limits of the read-only data. Refer to the Firmware Design guide for more details. This provides platform code with a finer-grained view of the image layout and allows it to map these 2 regions with the appropriate access permissions. Note that SEPARATE_CODE_AND_RODATA applies to all BL images. Change-Id: I936cf80164f6b66b6ad52b8edacadc532c935a49
2016-06-16Add Performance Measurement Framework(PMF)Yatharth Kochar
This patch adds Performance Measurement Framework(PMF) in the ARM Trusted Firmware. PMF is implemented as a library and the SMC interface is provided through ARM SiP service. The PMF provides capturing, storing, dumping and retrieving the time-stamps, by enabling the development of services by different providers, that can be easily integrated into ARM Trusted Firmware. The PMF capture and retrieval APIs can also do appropriate cache maintenance operations to the timestamp memory when the caller indicates so. `pmf_main.c` consists of core functions that implement service registration, initialization, storing, dumping and retrieving the time-stamp. `pmf_smc.c` consists SMC handling for registered PMF services. `pmf.h` consists of the macros that can be used by the PMF service providers to register service and declare time-stamp functions. `pmf_helpers.h` consists of internal macros that are used by `pmf.h` By default this feature is disabled in the ARM trusted firmware. To enable it set the boolean flag `ENABLE_PMF` to 1. NOTE: The caller is responsible for specifying the appropriate cache maintenance flags and for acquiring/releasing appropriate locks before/after capturing/retrieving the time-stamps. Change-Id: Ib45219ac07c2a81b9726ef6bd9c190cc55e81854
2015-12-14Remove dashes from image names: 'BL3-x' --> 'BL3x'Juan Castillo
This patch removes the dash character from the image name, to follow the image terminology in the Trusted Firmware Wiki page: https://github.com/ARM-software/arm-trusted-firmware/wiki Changes apply to output messages, comments and documentation. non-ARM platform files have been left unmodified. Change-Id: Ic2a99be4ed929d52afbeb27ac765ceffce46ed76
2015-09-25Fix relocation of __PERCPU_BAKERY_LOCK_SIZE__Vikram Kanigiri
When a platform port does not define PLAT_PERCPU_BAKERY_LOCK_SIZE, the total memory that should be allocated per-cpu to accommodate all bakery locks is calculated by the linker in bl31.ld.S. The linker stores this value in the __PERCPU_BAKERY_LOCK_SIZE__ linker symbol. The runtime value of this symbol is different from the link time value as the symbol is relocated into the current section (.bss). This patch fixes this issue by marking the symbol as ABSOLUTE which allows it to retain its correct value even at runtime. The description of PLAT_PERCPU_BAKERY_LOCK_SIZE in the porting-guide.md has been made clearer as well. Change-Id: Ia0cfd42f51deaf739d792297e60cad5c6e6e610b
2015-09-14Make generic code work in presence of system cachesAchin Gupta
On the ARMv8 architecture, cache maintenance operations by set/way on the last level of integrated cache do not affect the system cache. This means that such a flush or clean operation could result in the data being pushed out to the system cache rather than main memory. Another CPU could access this data before it enables its data cache or MMU. Such accesses could be serviced from the main memory instead of the system cache. If the data in the sysem cache has not yet been flushed or evicted to main memory then there could be a loss of coherency. The only mechanism to guarantee that the main memory will be updated is to use cache maintenance operations to the PoC by MVA(See section D3.4.11 (System level caches) of ARMv8-A Reference Manual (Issue A.g/ARM DDI0487A.G). This patch removes the reliance of Trusted Firmware on the flush by set/way operation to ensure visibility of data in the main memory. Cache maintenance operations by MVA are now used instead. The following are the broad category of changes: 1. The RW areas of BL2/BL31/BL32 are invalidated by MVA before the C runtime is initialised. This ensures that any stale cache lines at any level of cache are removed. 2. Updates to global data in runtime firmware (BL31) by the primary CPU are made visible to secondary CPUs using a cache clean operation by MVA. 3. Cache maintenance by set/way operations are only used prior to power down. NOTE: NON-UPSTREAM TRUSTED FIRMWARE CODE SHOULD MAKE EQUIVALENT CHANGES IN ORDER TO FUNCTION CORRECTLY ON PLATFORMS WITH SUPPORT FOR SYSTEM CACHES. Fixes ARM-software/tf-issues#205 Change-Id: I64f1b398de0432813a0e0881d70f8337681f6e9a
2015-09-11Re-design bakery lock memory allocation and algorithmAndrew Thoelke
This patch unifies the bakery lock api's across coherent and normal memory implementation of locks by using same data type `bakery_lock_t` and similar arguments to functions. A separate section `bakery_lock` has been created and used to allocate memory for bakery locks using `DEFINE_BAKERY_LOCK`. When locks are allocated in normal memory, each lock for a core has to spread across multiple cache lines. By using the total size allocated in a separate cache line for a single core at compile time, the memory for other core locks is allocated at link time by multiplying the single core locks size with (PLATFORM_CORE_COUNT - 1). The normal memory lock algorithm now uses lock address instead of the `id` in the per_cpu_data. For locks allocated in coherent memory, it moves locks from tzfw_coherent_memory to bakery_lock section. The bakery locks are allocated as part of bss or in coherent memory depending on usage of coherent memory. Both these regions are initialised to zero as part of run_time_init before locks are used. Hence, bakery_lock_init() is made an empty function as the lock memory is already initialised to zero. The above design lead to the removal of psci bakery locks from non_cpu_power_pd_node to psci_locks. NOTE: THE BAKERY LOCK API WHEN USE_COHERENT_MEM IS NOT SET HAS CHANGED. THIS IS A BREAKING CHANGE FOR ALL PLATFORM PORTS THAT ALLOCATE BAKERY LOCKS IN NORMAL MEMORY. Change-Id: Ic3751c0066b8032dcbf9d88f1d4dc73d15f61d8b
2015-01-22Remove coherent memory from the BL memory mapsSoby Mathew
This patch extends the build option `USE_COHERENT_MEMORY` to conditionally remove coherent memory from the memory maps of all boot loader stages. The patch also adds necessary documentation for coherent memory removal in firmware-design, porting and user guides. Fixes ARM-Software/tf-issues#106 Change-Id: I260e8768c6a5c2efc402f5804a80657d8ce38773
2014-09-19Fix LENGTH attribute value in linker scriptsJuan Castillo
This patch fixes the incorrect value of the LENGTH attribute in the linker scripts. This attribute must define the memory size, not the limit address. Fixes ARM-software/tf-issues#252 Change-Id: I328c38b9ec502debe12046a8912d7dfc54610c46
2014-08-20Introduce framework for CPU specific operationsSoby Mathew
This patch introduces a framework which will allow CPUs to perform implementation defined actions after a CPU reset, during a CPU or cluster power down, and when a crash occurs. CPU specific reset handlers have been implemented in this patch. Other handlers will be implemented in subsequent patches. Also moved cpu_helpers.S to the new directory lib/cpus/aarch64/. Change-Id: I1ca1bade4d101d11a898fb30fea2669f9b37b956
2014-08-12FVP: apply new naming conventions to memory regionsJuan Castillo
Secure ROM at address 0x0000_0000 is defined as FVP_TRUSTED_ROM Secure RAM at address 0x0400_0000 is defined as FVP_TRUSTED_SRAM Secure RAM at address 0x0600_0000 is defined as FVP_TRUSTED_DRAM BLn_BASE and BLn_LIMIT definitions have been updated and are based on these new memory regions. The available memory for each bootloader in the linker script is defined by BLn_BASE and BLn_LIMIT, instead of the complete memory region. TZROM_BASE/SIZE and TZRAM_BASE/SIZE are no longer required as part of the platform porting. FVP common definitions are defined in fvp_def.h while platform_def.h contains exclusively (with a few exceptions) the definitions that are mandatory in the porting guide. Therefore, platform_def.h now includes fvp_def.h instead of the other way around. Porting guide has been updated to reflect these changes. Change-Id: I39a6088eb611fc4a347db0db4b8f1f0417dbab05
2014-07-10fvp: Reuse BL1 and BL2 memory through image overlayingSandrine Bailleux
This patch re-organizes the memory layout on FVP as to give the BL3-2 image as much memory as possible. Considering these two facts: - not all images need to live in memory at the same time. Once in BL3-1, the memory used by BL1 and BL2 can be reclaimed. - when BL2 loads the BL3-1 and BL3-2 images, it only considers the PROGBITS sections of those 2 images. The memory occupied by the NOBITS sections will be touched only at execution of the BL3-x images; Then it is possible to choose the different base addresses such that the NOBITS sections of BL3-1 and BL3-2 overlay BL1 and BL2. On FVP we choose to put: - BL1 and BL3-1 at the top of the Trusted RAM, with BL3-1 NOBITS sections overlaying BL1; - BL3-2 at the bottom of the Trusted RAM, with its NOBITS sections overlaying BL2; This is illustrated by the following diagram: 0x0404_0000 ------------ ------------------ | BL1 | <= | BL3-1 NOBITS | ------------ <= ------------------ | | <= | BL3-1 PROGBITS | ------------ ------------------ | BL2 | <= | BL3-2 NOBITS | ------------ <= ------------------ | | <= | BL3-2 PROGBITS | 0x0400_0000 ------------ ------------------ New platform-specific constants have been introduced to easily check at link time that BL3-1 and BL3-2 PROGBITS sections don't overwrite BL1 and BL2. These are optional and the platform code is free to define them or not. If not defined, the linker won't attempt to check image overlaying. Fixes ARM-software/tf-issues#117 Change-Id: I5981d1c3d66ee70eaac8bd052630c9ac6dd8b042
2014-05-23Split platform.h into separate headersDan Handley
Previously, platform.h contained many declarations and definitions used for different purposes. This file has been split so that: * Platform definitions used by common code that must be defined by the platform are now in platform_def.h. The exact include path is exported through $PLAT_INCLUDES in the platform makefile. * Platform definitions specific to the FVP platform are now in /plat/fvp/fvp_def.h. * Platform API declarations specific to the FVP platform are now in /plat/fvp/fvp_private.h. * The remaining platform API declarations that must be ported by each platform are still in platform.h but this file has been moved to /include/plat/common since this can be shared by all platforms. Change-Id: Ieb3bb22fbab3ee8027413c6b39a783534aee474a
2014-05-23Make the memory layout more flexibleSandrine Bailleux
Currently the platform code gets to define the base address of each boot loader image. However, the linker scripts couteract this flexibility by enforcing a fixed overall layout of the different images. For example, they require that the BL3-1 image sits below the BL2 image. Choosing BL3-1 and BL2 base addresses in such a way that it violates this constraint makes the build fail at link-time. This patch requires the platform code to now define a limit address for each image. The linker scripts check that the image fits within these bounds so they don't rely anymore on the position of a given image in regard to the others. Fixes ARM-software/tf-issues#163 Change-Id: I8c108646825da19a6a8dfb091b613e1dd4ae133c
2014-03-26Use --gc-sections during linkAndrew Thoelke
All common functions are being built into all binary images, whether or not they are actually used. This change enables the use of -ffunction-sections, -fdata-sections and --gc-sections in the compiler and linker to remove unused code and data from the images. Change-Id: Ia9f78c01054ac4fa15d145af38b88a0d6fb7d409
2014-03-20Specify image entry in linker scriptJeenu Viswambharan
At present, the entry point for each BL image is specified via the Makefiles and provided on the command line to the linker. When using a link script the entry point should rather be specified via the ENTRY() directive in the link script. This patch updates linker scripts of all BL images to specify the entry point using the ENTRY() directive. It also removes the --entry flag passed to the linker through Makefile. Fixes issue ARM-software/tf-issues#66 Change-Id: I1369493ebbacea31885b51185441f6b628cf8da0
2014-02-26Remove duplicate xlat_table descriptionsJeenu Viswambharan
The BL31 and BL2 linker scripts ended up having duplicate descriptions for xlat_tables section. This patch removes those duplicate descriptions. Change-Id: Ibbdda0902c57fca5ea4e91e0baefa6df8f0a9bb1
2014-02-20Factor out translation table setup in ARM FVP portAchin Gupta
This patch factors out the ARM FVP specific code to create MMU translation tables so that it is possible for a boot loader stage to create a different set of tables instead of using the default ones. The default translation tables are created with the assumption that the calling boot loader stage executes out of secure SRAM. This might not be true for the BL3_2 stage in the future. A boot loader stage can define the `fill_xlation_tables()` function as per its requirements. It returns a reference to the level 1 translation table which is used by the common platform code to setup the TTBR_EL3. This patch is a temporary solution before a larger rework of translation table creation logic is introduced. Change-Id: I09a075d5da16822ee32a411a9dbe284718fb4ff6
2014-02-17Add runtime services frameworkAchin Gupta
This patch introduces the framework to enable registration and initialisation of runtime services. PSCI is registered and initialised as a runtime service. Handling of runtime service requests will be implemented in subsequent patches. Change-Id: Id21e7ddc5a33d42b7d6e455b41155fc5441a9547
2014-02-17Setup VBAR_EL3 incrementallyAchin Gupta
This patch ensures that VBAR_EL3 points to the simple stack-less 'early_exceptions' when the C runtime stack is not correctly setup to use the more complex 'runtime_exceptions'. It is initialised to 'runtime_exceptions' once this is done. This patch also moves all exception vectors into a '.vectors' section and modifies linker scripts to place all such sections together. This will minimize space wastage from alignment restrictions. Change-Id: I8c3e596ea3412c8bd582af9e8d622bb1cb2e049d
2014-02-17Move translation tables into separate sectionJeenu Viswambharan
This patch moves the translation tables into their own section. This saves space that would otherwise have been lost in padding due to page table alignment constraints. The BL31 and BL32 bases have been consequently adjusted. Change-Id: Ibd65ae8a5ce4c4ea9a71a794c95bbff40dc63e65
2014-01-17Update year in copyright text to 2014Dan Handley
Change-Id: Ic7fb61aabae1d515b9e6baf3dd003807ff42da60
2013-12-05Enable third party contributionsDan Handley
- Add instructions for contributing to ARM Trusted Firmware. - Update copyright text in all files to acknowledge contributors. Change-Id: I9311aac81b00c6c167d2f8c889aea403b84450e5
2013-12-05Various improvements/cleanups on the linker scriptsSandrine Bailleux
- Check at link-time that bootloader images will fit in memory at run time and that they won't overlap each other. - Remove text and rodata orphan sections. - Define new linker symbols to remove the need for platform setup code to know the order of sections. - Reduce the size of the raw binary images by cutting some sections out of the disk image and allocating them at load time, whenever possible. - Rework alignment constraints on sections. - Remove unused linker symbols. - Homogenize linker symbols names across all BLs. - Add some comments in the linker scripts. Change-Id: I47a328af0ccc7c8ab47fcc0dc6e7dd26160610b9
2013-10-25ARMv8 Trusted Firmware release v0.2Achin Gupta
