path: root/bl2u
2019-10-03TF-A: Add support for ARMv8.3-PAuth in BL1 SMC calls and BL2UAlexei Fedorov
This patch adds support for ARMv8.3-PAuth in BL1 SMC calls and BL2U image for firmware updates by programming APIAKey_EL1 registers and enabling Pointer Authentication in EL3 and EL1 respectively. Change-Id: I875d952aba8242caf74fb5f4f2d2af6f0c768c08 Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
2019-08-01Switch AARCH32/AARCH64 to __aarch64__Julius Werner
NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__. All common C compilers pre-define the same macros to signal which architecture the code is being compiled for: __arm__ for AArch32 (or earlier versions) and __aarch64__ for AArch64. There's no need for TF-A to define its own custom macros for this. In order to unify code with the export headers (which use __aarch64__ to avoid another dependency), let's deprecate the AARCH32 and AARCH64 macros and switch the code base over to the pre-defined standard macro. (Since it is somewhat unintuitive that __arm__ only means AArch32, let's standardize on only using __aarch64__.) Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200 Signed-off-by: Julius Werner <jwerner@chromium.org>
2019-03-12Apply stricter speculative load restrictionJohn Tsichritzis
The SCTLR.DSSBS bit is zero by default thus disabling speculative loads. However, we also explicitly set it to zero for BL2 and TSP images when each image initialises its context. This is done to ensure that the image environment is initialised in a safe state, regardless of the reset value of the bit. Change-Id: If25a8396641edb640f7f298b8d3309d5cba3cd79 Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
2019-01-04Sanitise includes across codebaseAntonio Nino Diaz
Enforce full include path for includes. Deprecate old paths. The following folders inside include/lib have been left unchanged: - include/lib/cpus/${ARCH} - include/lib/el3_runtime/${ARCH} The reason for this change is that having a global namespace for includes isn't a good idea. It defeats one of the advantages of having folders and it introduces problems that are sometimes subtle (because you may not know the header you are actually including if there are two of them). For example, this patch had to be created because two headers were called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform to avoid collision."). More recently, this patch has had similar problems: 46f9b2c3a282 ("drivers: add tzc380 support"). This problem was introduced in commit 4ecca33988b9 ("Move include and source files to logical locations"). At that time, there weren't too many headers so it wasn't a real issue. However, time has shown that this creates problems. Platforms that want to preserve the way they include headers may add the removed paths to PLAT_INCLUDES, but this is discouraged. Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-08-03Add atexit function to libcRoberto Vargas
We had exit but we didn't have atexit, and we were calling panic and tf_printf from exit, which generated a dependency from exit to them. Having atexit allows to set a different function pointer in every image. Change-Id: I95b9556d680d96249ed3b14da159b6f417da7661 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-07-11Add .extab and .exidx sectionsRoberto Vargas
These sections are required by clang when the code is compiled for aarch32. These sections are related to the unwind of the stack in exceptions, but in the way that clang defines and uses them, the garbage collector cannot get rid of them. Change-Id: I085efc0cf77eae961d522472f72c4b5bad2237ab Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-07-11Use ALIGN instead of NEXT in linker scriptsRoberto Vargas
Clang linker doesn't support NEXT. As we are not using the MEMORY command to define discontinuous memory for the output file in any of the linker scripts, ALIGN and NEXT are equivalent. Change-Id: I867ffb9c9a76d4e81c9ca7998280b2edf10efea0 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-02-28Merge pull request #1282 from robertovargas-arm/misra-changesdavidcunado-arm
Misra changes
2018-02-28Fix MISRA rule 8.4 in common codeRoberto Vargas
Rule 8.4: A compatible declaration shall be visible when an object or function with external linkage is defined. Change-Id: I26e042cb251a6f9590afa1340fdac73e42f23979 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-02-27Add comments about mismatched TCR_ELx and xlat tablesAntonio Nino Diaz
When the MMU is enabled and the translation tables are mapped, data read/writes to the translation tables are made using the attributes specified in the translation tables themselves. However, the MMU performs table walks with the attributes specified in TCR_ELx. They are completely independent, so special care has to be taken to make sure that they are the same. This has to be done manually because it is not practical to have a test in the code. Such a test would need to know the virtual memory region that contains the translation tables and check that for all of the tables the attributes match the ones in TCR_ELx. As the tables may not even be mapped at all, this isn't a test that can be made generic. The flags used by enable_mmu_xxx() have been moved to the same header where the functions are. Also, some comments in the linker scripts related to the translation tables have been fixed. Change-Id: I1754768bffdae75f53561b1c4a5baf043b45a304 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-11-29Replace magic numbers in linkerscripts by PAGE_SIZEAntonio Nino Diaz
When defining different sections in linker scripts it is needed to align them to multiples of the page size. In most linker scripts this is done by aligning to the hardcoded value 4096 instead of PAGE_SIZE. This may be confusing when taking a look at all the codebase, as 4096 is used in some parts that aren't meant to be a multiple of the page size. Change-Id: I36c6f461c7782437a58d13d37ec8b822a1663ec1 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-08-02Fix BL2U entrypoint possible parameter corruptionDouglas Raillard
Replace the use of r12 by r10 to save the value of a parameter of bl2u_entrypoint to pass it to bl2u_early_platform_setup at the end of the function. r10 is a callee saved register so it will not become corrupted by C code, whereas r12 is the The Intra-Procedure-call scratch register potentially used by veneers. See the ARM AAPCS document (ARM IHI 0042F). Change-Id: I4f37e54a6b550719edb40bb24cd8f498827e2749 Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
2017-07-12Fix order of #includesIsla Mitchell
This fix modifies the order of system includes to meet the ARM TF coding standard. There are some exceptions in order to retain header groupings, minimise changes to imported headers, and where there are headers within the #if and #ifndef statements. Change-Id: I65085a142ba6a83792b26efb47df1329153f1624 Signed-off-by: Isla Mitchell <isla.mitchell@arm.com>
2017-05-15AArch32: Add BL2U supportYatharth Kochar
Add support for firmware upgrade on AArch32. This patch has been tested on the FVP models. NOTE: Firmware upgrade on Juno AArch32 is not currently supported. Change-Id: I1ca8078214eaf86b46463edd14740120af930aec Signed-off-by: dp-arm <dimitris.papastamos@arm.com> Co-Authored-By: Yatharth Kochar <yatharth.kochar@arm.com>
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-04-12Merge pull request #885 from antonio-nino-diaz-arm/an/console-flushdavidcunado-arm
Implement console_flush()
2017-03-31Add support for GCC stack protectionDouglas Raillard
Introduce new build option ENABLE_STACK_PROTECTOR. It enables compilation of all BL images with one of the GCC -fstack-protector-* options. A new platform function plat_get_stack_protector_canary() is introduced. It returns a value that is used to initialize the canary for stack corruption detection. Returning a random value will prevent an attacker from predicting the value and greatly increase the effectiveness of the protection. A message is printed at the ERROR level when a stack corruption is detected. To be effective, the global data must be stored at an address lower than the base of the stacks. Failure to do so would allow an attacker to overwrite the canary as part of an attack which would void the protection. FVP implementation of plat_get_stack_protector_canary is weak as there is no real source of entropy on the FVP. It therefore relies on a timer's value, which could be predictable. Change-Id: Icaaee96392733b721fa7c86a81d03660d3c1bc06 Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
2017-03-31Flush console where necessaryAntonio Nino Diaz
Call console_flush() before execution either terminates or leaves an exception level. Fixes: ARM-software/tf-issues#123 Change-Id: I64eeb92effb039f76937ce89f877b68e355588e3 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-03-20Move plat/common source file definitions to generic Makefilesdp-arm
These source file definitions should be defined in generic Makefiles so that all platforms can benefit. Ensure that the symbols are properly marked as weak so they can be overridden by platforms. NOTE: This change is a potential compatibility break for non-upstream platforms. Change-Id: I7b892efa9f2d6d216931360dc6c436e1d10cffed Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-02-06Introduce unified API to zero memoryDouglas Raillard
Introduce zeromem_dczva function on AArch64 that can handle unaligned addresses and make use of DC ZVA instruction to zero a whole block at a time. This zeroing takes place directly in the cache to speed it up without doing external memory access. Remove the zeromem16 function on AArch64 and replace it with an alias to zeromem. This zeromem16 function is now deprecated. Remove the 16-bytes alignment constraint on __BSS_START__ in firmware-design.md as it is now not mandatory anymore (it used to comply with zeromem16 requirements). Change the 16-bytes alignment constraints in SP min's linker script to a 8-bytes alignment constraint as the AArch32 zeromem implementation is now more efficient on 8-bytes aligned addresses. Introduce zero_normalmem and zeromem helpers in platform agnostic header that are implemented this way: * AArch32: * zero_normalmem: zero using usual data access * zeromem: alias for zero_normalmem * AArch64: * zero_normalmem: zero normal memory using DC ZVA instruction (needs MMU enabled) * zeromem: zero using usual data access Usage guidelines: in most cases, zero_normalmem should be preferred. There are 2 scenarios where zeromem (or memset) must be used instead: * Code that must run with MMU disabled (which means all memory is considered device memory for data accesses). * Code that fills device memory with null bytes. Optionally, the following rule can be applied if performance is important: * Code zeroing small areas (few bytes) that are not secrets should use memset to take advantage of compiler optimizations. Note: Code zeroing security-related critical information should use zero_normalmem/zeromem instead of memset to avoid removal by compilers' optimizations in some cases or misbehaving versions of GCC. Fixes ARM-software/tf-issues#408 Change-Id: Iafd9663fc1070413c3e1904e54091cf60effaa82 Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
2016-12-05Define and use no_ret macro where no return is expectedJeenu Viswambharan
There are many instances in ARM Trusted Firmware where control is transferred to functions from which return isn't expected. Such jumps are made using 'bl' instruction to provide the callee with the location from which it was jumped to. Additionally, debuggers infer the caller by examining where 'lr' register points to. If a 'bl' of the nature described above falls at the end of an assembly function, 'lr' will be left pointing to a location outside of the function range. This misleads the debugger back trace. This patch defines a 'no_ret' macro to be used when jumping to functions from which return isn't expected. The macro ensures to use 'bl' instruction for the jump, and also, for debug builds, places a 'nop' instruction immediately thereafter (unless instructed otherwise) so as to leave 'lr' pointing within the function range. Change-Id: Ib34c69fc09197cfd57bc06e147cc8252910e01b0 Co-authored-by: Douglas Raillard <douglas.raillard@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2016-07-08Introduce SEPARATE_CODE_AND_RODATA build flagSandrine Bailleux
At the moment, all BL images share a similar memory layout: they start with their code section, followed by their read-only data section. The two sections are contiguous in memory. Therefore, the end of the code section and the beginning of the read-only data one might share a memory page. This forces both to be mapped with the same memory attributes. As the code needs to be executable, this means that the read-only data stored on the same memory page as the code are executable as well. This could potentially be exploited as part of a security attack. This patch introduces a new build flag called SEPARATE_CODE_AND_RODATA, which isolates the code and read-only data on separate memory pages. This in turn allows independent control of the access permissions for the code and read-only data. This has an impact on memory footprint, as padding bytes need to be introduced between the code and read-only data to ensure the segragation of the two. To limit the memory cost, the memory layout of the read-only section has been changed in this case. - When SEPARATE_CODE_AND_RODATA=0, the layout is unchanged, i.e. the read-only section still looks like this (padding omitted): | ... | +-------------------+ | Exception vectors | +-------------------+ | Read-only data | +-------------------+ | Code | +-------------------+ BLx_BASE In this case, the linker script provides the limits of the whole read-only section. - When SEPARATE_CODE_AND_RODATA=1, the exception vectors and read-only data are swapped, such that the code and exception vectors are contiguous, followed by the read-only data. This gives the following new layout (padding omitted): | ... | +-------------------+ | Read-only data | +-------------------+ | Exception vectors | +-------------------+ | Code | +-------------------+ BLx_BASE In this case, the linker script now exports 2 sets of addresses instead: the limits of the code and the limits of the read-only data. Refer to the Firmware Design guide for more details. This provides platform code with a finer-grained view of the image layout and allows it to map these 2 regions with the appropriate access permissions. Note that SEPARATE_CODE_AND_RODATA applies to all BL images. Change-Id: I936cf80164f6b66b6ad52b8edacadc532c935a49
2016-03-14Remove all non-configurable dead loopsAntonio Nino Diaz
Added a new platform porting function plat_panic_handler, to allow platforms to handle unexpected error situations. It must be implemented in assembly as it may be called before the C environment is initialized. A default implementation is provided, which simply spins. Corrected all dead loops in generic code to call this function instead. This includes the dead loop that occurs at the end of the call to panic(). All unnecesary wfis from bl32/tsp/aarch64/tsp_exceptions.S have been removed. Change-Id: I67cb85f6112fa8e77bd62f5718efcef4173d8134
2015-12-09FWU: Add Generic BL2U FWU image support in BL2Yatharth Kochar
The Firmware Update (FWU) feature needs support for an optional secure world image, BL2U, to allow additional secure world initialization required by FWU, for example DDR initialization. This patch adds generic framework support to create BL2U. NOTE: A platform makefile must supply additional `BL2U_SOURCES` to build the bl2u target. A subsequent patch adds bl2u support for ARM platforms. Change-Id: If2ce036199bb40b39b7f91a9332106bcd4e25413
