path: root/bl2u/bl2u.ld.S
2018-02-27Add comments about mismatched TCR_ELx and xlat tablesAntonio Nino Diaz
When the MMU is enabled and the translation tables are mapped, data read/writes to the translation tables are made using the attributes specified in the translation tables themselves. However, the MMU performs table walks with the attributes specified in TCR_ELx. They are completely independent, so special care has to be taken to make sure that they are the same. This has to be done manually because it is not practical to have a test in the code. Such a test would need to know the virtual memory region that contains the translation tables and check that for all of the tables the attributes match the ones in TCR_ELx. As the tables may not even be mapped at all, this isn't a test that can be made generic. The flags used by enable_mmu_xxx() have been moved to the same header where the functions are. Also, some comments in the linker scripts related to the translation tables have been fixed. Change-Id: I1754768bffdae75f53561b1c4a5baf043b45a304 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-11-29Replace magic numbers in linkerscripts by PAGE_SIZEAntonio Nino Diaz
When defining different sections in linker scripts it is needed to align them to multiples of the page size. In most linker scripts this is done by aligning to the hardcoded value 4096 instead of PAGE_SIZE. This may be confusing when taking a look at all the codebase, as 4096 is used in some parts that aren't meant to be a multiple of the page size. Change-Id: I36c6f461c7782437a58d13d37ec8b822a1663ec1 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-03-31Add support for GCC stack protectionDouglas Raillard
Introduce new build option ENABLE_STACK_PROTECTOR. It enables compilation of all BL images with one of the GCC -fstack-protector-* options. A new platform function plat_get_stack_protector_canary() is introduced. It returns a value that is used to initialize the canary for stack corruption detection. Returning a random value will prevent an attacker from predicting the value and greatly increase the effectiveness of the protection. A message is printed at the ERROR level when a stack corruption is detected. To be effective, the global data must be stored at an address lower than the base of the stacks. Failure to do so would allow an attacker to overwrite the canary as part of an attack which would void the protection. FVP implementation of plat_get_stack_protector_canary is weak as there is no real source of entropy on the FVP. It therefore relies on a timer's value, which could be predictable. Change-Id: Icaaee96392733b721fa7c86a81d03660d3c1bc06 Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
2017-02-06Introduce unified API to zero memoryDouglas Raillard
Introduce zeromem_dczva function on AArch64 that can handle unaligned addresses and make use of DC ZVA instruction to zero a whole block at a time. This zeroing takes place directly in the cache to speed it up without doing external memory access. Remove the zeromem16 function on AArch64 and replace it with an alias to zeromem. This zeromem16 function is now deprecated. Remove the 16-bytes alignment constraint on __BSS_START__ in firmware-design.md as it is now not mandatory anymore (it used to comply with zeromem16 requirements). Change the 16-bytes alignment constraints in SP min's linker script to a 8-bytes alignment constraint as the AArch32 zeromem implementation is now more efficient on 8-bytes aligned addresses. Introduce zero_normalmem and zeromem helpers in platform agnostic header that are implemented this way: * AArch32: * zero_normalmem: zero using usual data access * zeromem: alias for zero_normalmem * AArch64: * zero_normalmem: zero normal memory using DC ZVA instruction (needs MMU enabled) * zeromem: zero using usual data access Usage guidelines: in most cases, zero_normalmem should be preferred. There are 2 scenarios where zeromem (or memset) must be used instead: * Code that must run with MMU disabled (which means all memory is considered device memory for data accesses). * Code that fills device memory with null bytes. Optionally, the following rule can be applied if performance is important: * Code zeroing small areas (few bytes) that are not secrets should use memset to take advantage of compiler optimizations. Note: Code zeroing security-related critical information should use zero_normalmem/zeromem instead of memset to avoid removal by compilers' optimizations in some cases or misbehaving versions of GCC. Fixes ARM-software/tf-issues#408 Change-Id: Iafd9663fc1070413c3e1904e54091cf60effaa82 Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
2016-07-08Introduce SEPARATE_CODE_AND_RODATA build flagSandrine Bailleux
At the moment, all BL images share a similar memory layout: they start with their code section, followed by their read-only data section. The two sections are contiguous in memory. Therefore, the end of the code section and the beginning of the read-only data one might share a memory page. This forces both to be mapped with the same memory attributes. As the code needs to be executable, this means that the read-only data stored on the same memory page as the code are executable as well. This could potentially be exploited as part of a security attack. This patch introduces a new build flag called SEPARATE_CODE_AND_RODATA, which isolates the code and read-only data on separate memory pages. This in turn allows independent control of the access permissions for the code and read-only data. This has an impact on memory footprint, as padding bytes need to be introduced between the code and read-only data to ensure the segragation of the two. To limit the memory cost, the memory layout of the read-only section has been changed in this case. - When SEPARATE_CODE_AND_RODATA=0, the layout is unchanged, i.e. the read-only section still looks like this (padding omitted): | ... | +-------------------+ | Exception vectors | +-------------------+ | Read-only data | +-------------------+ | Code | +-------------------+ BLx_BASE In this case, the linker script provides the limits of the whole read-only section. - When SEPARATE_CODE_AND_RODATA=1, the exception vectors and read-only data are swapped, such that the code and exception vectors are contiguous, followed by the read-only data. This gives the following new layout (padding omitted): | ... | +-------------------+ | Read-only data | +-------------------+ | Exception vectors | +-------------------+ | Code | +-------------------+ BLx_BASE In this case, the linker script now exports 2 sets of addresses instead: the limits of the code and the limits of the read-only data. Refer to the Firmware Design guide for more details. This provides platform code with a finer-grained view of the image layout and allows it to map these 2 regions with the appropriate access permissions. Note that SEPARATE_CODE_AND_RODATA applies to all BL images. Change-Id: I936cf80164f6b66b6ad52b8edacadc532c935a49
2015-12-09FWU: Add Generic BL2U FWU image support in BL2Yatharth Kochar
The Firmware Update (FWU) feature needs support for an optional secure world image, BL2U, to allow additional secure world initialization required by FWU, for example DDR initialization. This patch adds generic framework support to create BL2U. NOTE: A platform makefile must supply additional `BL2U_SOURCES` to build the bl2u target. A subsequent patch adds bl2u support for ARM platforms. Change-Id: If2ce036199bb40b39b7f91a9332106bcd4e25413
