This patch adds the functionality needed for platforms to provide
Branch Target Identification (BTI) extension, introduced to AArch64
in Armv8.5-A by adding BTI instruction used to mark valid targets
for indirect branches. The patch sets new GP bit [50] to the stage 1
Translation Table Block and Page entries to denote guarded EL3 code
pages which will cause processor to trap instructions in protected
pages trying to perform an indirect branch to any instruction other
than BTI.
BTI feature is selected by BRANCH_PROTECTION option which supersedes
the previous ENABLE_PAUTH used for Armv8.3-A Pointer Authentication
and is disabled by default. Enabling BTI requires compiler support
and was tested with GCC versions 9.0.0, 9.0.1 and 10.0.0.
The assembly macros and helpers are modified to accommodate the BTI
instruction.
This is an experimental feature.
Note. The previous ENABLE_PAUTH build option to enable PAuth in EL3
is now made as an internal flag and BRANCH_PROTECTION flag should be
used instead to enable Pointer Authentication.
Note. USE_LIBROM=1 option is currently not supported.
Change-Id: Ifaf4438609b16647dc79468b70cd1f47a623362e
Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
The size increase after enabling options related to ARMv8.3-PAuth is:
| | text | bss | data | rodata |
| CTX_INCLUDE_PAUTH_REGS = 1 | +40 | +0 | +0 | +0 |
| | 0.2% | | | |
| ENABLE_PAUTH = 1 | +664 | +0 | +16 | +0 |
| | 3.1% | | 0.9% | |
Results calculated with the following build configuration:
make PLAT=fvp SPD=tspd DEBUG=1 \
SDEI_SUPPORT=1 \
EL3_EXCEPTION_HANDLING=1 \
TSP_NS_INTR_ASYNC_PREEMPT=1 \
CTX_INCLUDE_PAUTH_REGS=1 \
ENABLE_PAUTH=1
The changes for BL2_AT_EL3 aren't done in this commit.
Change-Id: I8c803b40c7160525a06173bc6cdca21c4505837d
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
The code of LOAD_IMAGE_V2=0 has been removed.
Change-Id: Iea03e5bebb90c66889bdb23f85c07d0c9717fffe
Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
If the system is in near idle conditions, this erratum could cause a
deadlock or data corruption. This patch applies the workaround that
prevents this.
This DSU erratum affects only the DSUs that contain the ACP interface
and it was fixed in r2p0. The workaround is applied only to the DSUs
that are actually affected.
Link to respective Arm documentation:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.epm138168/index.html
Change-Id: I033213b3077685130fc1e3f4f79c4d15d7483ec9
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
TF Makefile was linking all the objects files generated for the
Mbed TLS library instead of creating a static library that could be
used in the linking stage.
Change-Id: I8e4cd843ef56033c9d3faeee71601d110b7e4c12
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
This patch adds an argument to bl1_plat_post/pre_image_load() APIs
to make it more future proof. The default implementation of
these are moved to `plat_bl1_common.c` file.
These APIs are now invoked appropriately in the FWU code path prior
to or post image loading by BL1 and are not restricted
to LOAD_IMAGE_V2.
The patch also reorganizes some common platform files. The previous
`plat_bl2_el3_common.c` and `platform_helpers_default.c` files are
merged into a new `plat_bl_common.c` file.
NOTE: The addition of an argument to the above mentioned platform APIs
is not expected to have a great impact because these APIs were only
recently added and are unlikely to be used.
Change-Id: I0519caaee0f774dd33638ff63a2e597ea178c453
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This patch modifies the makefiles to avoid the definition
of BL1_SOURCES and BL2_SOURCES in the tbbr makefiles, and
it lets to the platform makefiles to define them if they
actually need these images. In the case of BL2_AT_EL3
BL1 will not be needed usually because the Boot ROM will
jump directly to BL2.
Change-Id: Ib6845a260633a22a646088629bcd7387fe35dcf9
This patch enables BL2 to execute at the highest exception level
without any dependancy on TF BL1. This enables platforms which already
have a non-TF Boot ROM to directly load and execute BL2 and subsequent BL
stages without need for BL1. This is not currently possible because
BL2 executes at S-EL1 and cannot jump straight to EL3.
Change-Id: Ief1efca4598560b1b8c8e61fbe26d1f44e929d69
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
These source file definitions should be defined in generic
Makefiles so that all platforms can benefit. Ensure that the
symbols are properly marked as weak so they can be overridden
by platforms.
NOTE: This change is a potential compatibility break for
non-upstream platforms.
Change-Id: I7b892efa9f2d6d216931360dc6c436e1d10cffed
This patch adds generic changes in BL2 to support AArch32 state.
New AArch32 specific assembly/C files are introduced and
some files are moved to AArch32/64 specific folders.
BL2 for AArch64 is refactored but functionally identical.
BL2 executes in Secure SVC mode in AArch32 state.
Change-Id: Ifaacbc2a91f8640876385b953adb24744d9dbde3
This patch adds changes in BL1 & BL2 to use new version
of image loading to load the BL images.
Following are the changes in BL1:
-Use new version of load_auth_image() to load BL2
-Modified `bl1_init_bl2_mem_layout()` to remove using
`reserve_mem()` and to calculate `bl2_mem_layout`.
`bl2_mem_layout` calculation now assumes that BL1 RW
data is at the top of the bl1_mem_layout, which is more
restrictive than the previous BL1 behaviour.
Following are the changes in BL2:
-The `bl2_main.c` is refactored and all the functions
for loading BLxx images are now moved to `bl2_image_load.c`
`bl2_main.c` now calls a top level `bl2_load_images()` to
load all the images that are applicable in BL2.
-Added new file `bl2_image_load_v2.c` that uses new version
of image loading to load the BL images in BL2.
All the above changes are conditionally compiled using the
`LOAD_IMAGE_V2` flag.
Change-Id: Ic6dcde5a484495bdc05526d9121c59fa50c1bf23
This patch moves the assembly exclusive lock library code
`spinlock.S` into architecture specific folder `aarch64`.
A stub file which includes the file from new location is
retained at the original location for compatibility. The BL
makefiles are also modified to include the file from the new
location.
Change-Id: Ide0b601b79c439e390c3a017d93220a66be73543
Remove all usage of the vpath keyword in makefiles as it was prone
to mistakes. Specify the relative paths to source files instead.
Also reorder source files in makefiles alphabetically.
Fixes ARM-software/tf-issues#121
Change-Id: Id15f60655444bae60e0e2165259efac71a50928b
Move almost all system include files to a logical sub-directory
under ./include. The only remaining system include directories
not under ./include are specific to the platform. Move the
corresponding source files to match the include directory
structure.
Also remove pm.h as it is no longer used.
Change-Id: Ie5ea6368ec5fad459f3e8a802ad129135527f0b3
bl1/aarch64/early_exceptions.S used to be re-used by BL2, BL3-1 and
BL3-2. There was some early SMC handling code in there that was not
required by the other bootloader stages. Therefore this patch
introduces an even simpler exception vector source file for BL2,
BL3-1 and BL3-2.
Fixes ARM-software/tf-issues#38
Change-Id: I0244b80e9930b0f8035156a0bf91cc3e9a8f995d
At present, the entry point for each BL image is specified via the
Makefiles and provided on the command line to the linker. When using a
link script the entry point should rather be specified via the ENTRY()
directive in the link script.
This patch updates linker scripts of all BL images to specify the entry
point using the ENTRY() directive. It also removes the --entry flag
passed to the linker through Makefile.
Fixes issue ARM-software/tf-issues#66
Change-Id: I1369493ebbacea31885b51185441f6b628cf8da0
This change requires all platforms to now specify a list of source files
rather than object files.
New source files should preferably be specified by using the path as
well and we should add this in the future for all files so we can remove
use of vpath. This is desirable because vpath hides issues like the fact
that BL2 currently pulls in a BL1 file bl1/aarch64/early_exceptions.S
and if in the future we added bl2/aarch64/early_exceptions.S then it's
likely only one of the two version would be used for both bootloaders.
This change also removes the 'dump' build target and simply gets
bootloaders to always generate a dump file. At the same time the -x
option is added so the section headers and symbols table are listed.
Fixes ARM-software/tf-issues#11
Change-Id: Ie38f7be76fed95756c8576cf3f3ea3b7015a18dc
Signed-off-by: Jon Medhurst <tixy@linaro.org>
Tidy up the spacing of variable definitions within the makefiles to make
them more consistent, easier to read and amend.
Change-Id: Ic6d7c8489ca4330824abb5cd1ead8f1d449d1a85
Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org>
Move all explicit platform or architecture specific references
into a new platform.mk file that is defined for each platform.
Change-Id: I9d6320d1ba957e0cc8d9b316b3578132331fa428
Change-Id: Ic7fb61aabae1d515b9e6baf3dd003807ff42da60
- This change is split into two separate patches in order to
simplify the history as interpreted by 'git'. The split is
between the move/rename and addition of new files.
- Remove dependency on toolchain C library headers and functions in
order to ensure behavioural compatibility between toolchains.
- Use FreeBSD as reference for C library implementation.
- Do not let GCC use default library include paths.
- Remove unused definitions in modified headers and implementations.
- Move C library files to 'lib/stdlib' and 'include/stdlib'.
- Break std.c functions out into separate files.
Change-Id: I91cddfb3229775f770ad781589670c57d347a154
- Add instructions for contributing to ARM Trusted Firmware.
- Update copyright text in all files to acknowledge contributors.
Change-Id: I9311aac81b00c6c167d2f8c889aea403b84450e5
