This patch modifies the makefiles to avoid the definition
of BL1_SOURCES and BL2_SOURCES in the tbbr makefiles, and
it lets to the platform makefiles to define them if they
actually need these images. In the case of BL2_AT_EL3
BL1 will not be needed usually because the Boot ROM will
jump directly to BL2.
Change-Id: Ib6845a260633a22a646088629bcd7387fe35dcf9
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
These source file definitions should be defined in generic
Makefiles so that all platforms can benefit. Ensure that the
symbols are properly marked as weak so they can be overridden
by platforms.
NOTE: This change is a potential compatibility break for
non-upstream platforms.
Change-Id: I7b892efa9f2d6d216931360dc6c436e1d10cffed
The errata reporting policy is as follows:
- If an errata workaround is enabled:
- If it applies (i.e. the CPU is affected by the errata), an INFO
message is printed, confirming that the errata workaround has been
applied.
- If it does not apply, a VERBOSE message is printed, confirming
that the errata workaround has been skipped.
- If an errata workaround is not enabled, but would have applied had
it been, a WARN message is printed, alerting that errata workaround
is missing.
The CPU errata messages are printed by both BL1 (primary CPU only) and
runtime firmware on debug builds, once for each CPU/errata combination.
Relevant output from Juno r1 console when ARM Trusted Firmware is built
with PLAT=juno LOG_LEVEL=50 DEBUG=1:
VERBOSE: BL1: cortex_a57: errata workaround for 806969 was not applied
VERBOSE: BL1: cortex_a57: errata workaround for 813420 was not applied
INFO: BL1: cortex_a57: errata workaround for disable_ldnp_overread was applied
WARNING: BL1: cortex_a57: errata workaround for 826974 was missing!
WARNING: BL1: cortex_a57: errata workaround for 826977 was missing!
WARNING: BL1: cortex_a57: errata workaround for 828024 was missing!
WARNING: BL1: cortex_a57: errata workaround for 829520 was missing!
WARNING: BL1: cortex_a57: errata workaround for 833471 was missing!
VERBOSE: BL31: cortex_a57: errata workaround for 806969 was not applied
VERBOSE: BL31: cortex_a57: errata workaround for 813420 was not applied
INFO: BL31: cortex_a57: errata workaround for disable_ldnp_overread was applied
WARNING: BL31: cortex_a57: errata workaround for 826974 was missing!
WARNING: BL31: cortex_a57: errata workaround for 826977 was missing!
WARNING: BL31: cortex_a57: errata workaround for 828024 was missing!
WARNING: BL31: cortex_a57: errata workaround for 829520 was missing!
WARNING: BL31: cortex_a57: errata workaround for 833471 was missing!
VERBOSE: BL31: cortex_a53: errata workaround for 826319 was not applied
INFO: BL31: cortex_a53: errata workaround for disable_non_temporal_hint was applied
Also update documentation.
Change-Id: Iccf059d3348adb876ca121cdf5207bdbbacf2aba
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
This patch adds generic changes in BL1 to support AArch32 state.
New AArch32 specific assembly/C files are introduced and
some files are moved to AArch32/64 specific folders.
BL1 for AArch64 is refactored but functionally identical.
BL1 executes in Secure Monitor mode in AArch32 state.
NOTE: BL1 in AArch32 state ONLY handles BL1_RUN_IMAGE SMC.
Change-Id: I6e2296374c7efbf3cf2aa1a0ce8de0732d8c98a5
This patch moves the PSCI services and BL31 frameworks like context
management and per-cpu data into new library components `PSCI` and
`el3_runtime` respectively. This enables PSCI to be built independently from
BL31. A new `psci_lib.mk` makefile is introduced which adds the relevant
PSCI library sources and gets included by `bl31.mk`. Other changes which
are done as part of this patch are:
* The runtime services framework is now moved to the `common/` folder to
enable reuse.
* The `asm_macros.S` and `assert_macros.S` helpers are moved to architecture
specific folder.
* The `plat_psci_common.c` is moved from the `plat/common/aarch64/` folder
to `plat/common` folder. The original file location now has a stub which
just includes the file from new location to maintain platform compatibility.
Most of the changes wouldn't affect platform builds as they just involve
changes to the generic bl1.mk and bl31.mk makefiles.
NOTE: THE `plat_psci_common.c` FILE HAS MOVED LOCATION AND THE STUB FILE AT
THE ORIGINAL LOCATION IS NOW DEPRECATED. PLATFORMS SHOULD MODIFY THEIR
MAKEFILES TO INCLUDE THE FILE FROM THE NEW LOCATION.
Change-Id: I6bd87d5b59424995c6a65ef8076d4fda91ad5e86
Firmware update(a.k.a FWU) feature is part of the TBB architecture.
BL1 is responsible for carrying out the FWU process if platform
specific code detects that it is needed.
This patch adds support for FWU feature support in BL1 which is
included by enabling `TRUSTED_BOARD_BOOT` compile time flag.
This patch adds bl1_fwu.c which contains all the core operations
of FWU, which are; SMC handler, image copy, authentication, execution
and resumption. It also adds bl1.h introducing #defines for all
BL1 SMCs.
Following platform porting functions are introduced:
int bl1_plat_mem_check(uintptr_t mem_base, unsigned int mem_size,
unsigned int flags);
This function can be used to add platform specific memory checks
for the provided base/size for the given security state.
The weak definition will invoke `assert()` and return -ENOMEM.
__dead2 void bl1_plat_fwu_done(void *cookie, void *reserved);
This function can be used to initiate platform specific procedure
to mark completion of the FWU process.
The weak definition waits forever calling `wfi()`.
plat_bl1_common.c contains weak definitions for above functions.
FWU process starts when platform detects it and return the image_id
other than BL2_IMAGE_ID by using `bl1_plat_get_next_image_id()` in
`bl1_main()`.
NOTE: User MUST provide platform specific real definition for
bl1_plat_mem_check() in order to use it for Firmware update.
Change-Id: Ice189a0885d9722d9e1dd03f76cac1aceb0e25ed
As of now BL1 loads and execute BL2 based on hard coded information
provided in BL1. But due to addition of support for upcoming Firmware
Update feature, BL1 now require more flexible approach to load and
run different images using information provided by the platform.
This patch adds new mechanism to load and execute images based on
platform provided image id's. BL1 now queries the platform to fetch
the image id of the next image to be loaded and executed. In order
to achieve this, a new struct image_desc_t was added which holds the
information about images, such as: ep_info and image_info.
This patch introduces following platform porting functions:
unsigned int bl1_plat_get_next_image_id(void);
This is used to identify the next image to be loaded
and executed by BL1.
struct image_desc *bl1_plat_get_image_desc(unsigned int image_id);
This is used to retrieve the image_desc for given image_id.
void bl1_plat_set_ep_info(unsigned int image_id,
struct entry_point_info *ep_info);
This function allows platforms to update ep_info for given
image_id.
The plat_bl1_common.c file provides default weak implementations of
all above functions, the `bl1_plat_get_image_desc()` always return
BL2 image descriptor, the `bl1_plat_get_next_image_id()` always return
BL2 image ID and `bl1_plat_set_ep_info()` is empty and just returns.
These functions gets compiled into all BL1 platforms by default.
Platform setup in BL1, using `bl1_platform_setup()`, is now done
_after_ the initialization of authentication module. This change
provides the opportunity to use authentication while doing the
platform setup in BL1.
In order to store secure/non-secure context, BL31 uses percpu_data[]
to store context pointer for each core. In case of BL1 only the
primary CPU will be active hence percpu_data[] is not required to
store the context pointer.
This patch introduce bl1_cpu_context[] and bl1_cpu_context_ptr[] to
store the context and context pointers respectively. It also also
re-defines cm_get_context() and cm_set_context() for BL1 in
bl1/bl1_context_mgmt.c.
BL1 now follows the BL31 pattern of using SP_EL0 for the C runtime
environment, to support resuming execution from a previously saved
context.
NOTE: THE `bl1_plat_set_bl2_ep_info()` PLATFORM PORTING FUNCTION IS
NO LONGER CALLED BY BL1 COMMON CODE. PLATFORMS THAT OVERRIDE
THIS FUNCTION MAY NEED TO IMPLEMENT `bl1_plat_set_ep_info()`
INSTEAD TO MAINTAIN EXISTING BEHAVIOUR.
Change-Id: Ieee4c124b951c2e9bc1c1013fa2073221195d881
This patch introduces a framework which will allow CPUs to perform
implementation defined actions after a CPU reset, during a CPU or cluster power
down, and when a crash occurs. CPU specific reset handlers have been implemented
in this patch. Other handlers will be implemented in subsequent patches.
Also moved cpu_helpers.S to the new directory lib/cpus/aarch64/.
Change-Id: I1ca1bade4d101d11a898fb30fea2669f9b37b956
Remove all usage of the vpath keyword in makefiles as it was prone
to mistakes. Specify the relative paths to source files instead.
Also reorder source files in makefiles alphabetically.
Fixes ARM-software/tf-issues#121
Change-Id: Id15f60655444bae60e0e2165259efac71a50928b
Move almost all system include files to a logical sub-directory
under ./include. The only remaining system include directories
not under ./include are specific to the platform. Move the
corresponding source files to match the include directory
structure.
Also remove pm.h as it is no longer used.
Change-Id: Ie5ea6368ec5fad459f3e8a802ad129135527f0b3
bl1/aarch64/early_exceptions.S used to be re-used by BL2, BL3-1 and
BL3-2. There was some early SMC handling code in there that was not
required by the other bootloader stages. Therefore this patch
introduces an even simpler exception vector source file for BL2,
BL3-1 and BL3-2.
Fixes ARM-software/tf-issues#38
Change-Id: I0244b80e9930b0f8035156a0bf91cc3e9a8f995d
At present, the entry point for each BL image is specified via the
Makefiles and provided on the command line to the linker. When using a
link script the entry point should rather be specified via the ENTRY()
directive in the link script.
This patch updates linker scripts of all BL images to specify the entry
point using the ENTRY() directive. It also removes the --entry flag
passed to the linker through Makefile.
Fixes issue ARM-software/tf-issues#66
Change-Id: I1369493ebbacea31885b51185441f6b628cf8da0
This change requires all platforms to now specify a list of source files
rather than object files.
New source files should preferably be specified by using the path as
well and we should add this in the future for all files so we can remove
use of vpath. This is desirable because vpath hides issues like the fact
that BL2 currently pulls in a BL1 file bl1/aarch64/early_exceptions.S
and if in the future we added bl2/aarch64/early_exceptions.S then it's
likely only one of the two version would be used for both bootloaders.
This change also removes the 'dump' build target and simply gets
bootloaders to always generate a dump file. At the same time the -x
option is added so the section headers and symbols table are listed.
Fixes ARM-software/tf-issues#11
Change-Id: Ie38f7be76fed95756c8576cf3f3ea3b7015a18dc
Signed-off-by: Jon Medhurst <tixy@linaro.org>
This patch factors out the ARM FVP specific code to create MMU
translation tables so that it is possible for a boot loader stage to
create a different set of tables instead of using the default ones.
The default translation tables are created with the assumption that
the calling boot loader stage executes out of secure SRAM. This might
not be true for the BL3_2 stage in the future.
A boot loader stage can define the `fill_xlation_tables()` function as
per its requirements. It returns a reference to the level 1
translation table which is used by the common platform code to setup
the TTBR_EL3.
This patch is a temporary solution before a larger rework of
translation table creation logic is introduced.
Change-Id: I09a075d5da16822ee32a411a9dbe284718fb4ff6
Tidy up the spacing of variable definitions within the makefiles to make
them more consistent, easier to read and amend.
Change-Id: Ic6d7c8489ca4330824abb5cd1ead8f1d449d1a85
Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org>
Move all explicit platform or architecture specific references
into a new platform.mk file that is defined for each platform.
Change-Id: I9d6320d1ba957e0cc8d9b316b3578132331fa428
Change-Id: Ic7fb61aabae1d515b9e6baf3dd003807ff42da60
- This change is split into two separate patches in order to
simplify the history as interpreted by 'git'. The split is
between the move/rename and addition of new files.
- Remove dependency on toolchain C library headers and functions in
order to ensure behavioural compatibility between toolchains.
- Use FreeBSD as reference for C library implementation.
- Do not let GCC use default library include paths.
- Remove unused definitions in modified headers and implementations.
- Move C library files to 'lib/stdlib' and 'include/stdlib'.
- Break std.c functions out into separate files.
Change-Id: I91cddfb3229775f770ad781589670c57d347a154
- Add instructions for contributing to ARM Trusted Firmware.
- Update copyright text in all files to acknowledge contributors.
Change-Id: I9311aac81b00c6c167d2f8c889aea403b84450e5
