Change-Id: Ic3b30de13e314efca30fc71370227d3e76f1148b
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
A bug recently fixed in bl2/aarch32/bl2_el3_entrypoint.S relates to
programming the lower-order 16 bits of the SPSR to populate into the CPSR
on eret.
The BL1 smc-handler code is identical and has the same shortfall in
programming the SPSR from the platform defined struct
entry_point_info->spsr.
msr spsr, r1 will only update bits f->[31:24] and c->[7:0] respectively. In
order to ensure the 16 lower-order processor mode bits x->[15:8] and
c->[7:0] this patch changes msr spsr, r1 to msr spsr_xc, r1.
This change ensures we capture the x field, which we are interested in and
not the f field which we are not.
Fixes: f3b4914be3b4 ('AArch32: Add generic changes in BL1')
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
The size increase after enabling options related to ARMv8.3-PAuth is:
| | text | bss | data | rodata |
| CTX_INCLUDE_PAUTH_REGS = 1 | +108 | +192 | +0 | +0 |
| | 0.5% | 0.8% | | |
| ENABLE_PAUTH = 1 | +748 | +192 | +16 | +0 |
| | 3.7% | 0.8% | 7.0% | |
Results calculated with the following build configuration:
make PLAT=fvp SPD=tspd DEBUG=1 \
SDEI_SUPPORT=1 \
EL3_EXCEPTION_HANDLING=1 \
TSP_NS_INTR_ASYNC_PREEMPT=1 \
CTX_INCLUDE_PAUTH_REGS=1 \
ENABLE_PAUTH=1
Change-Id: I3a7d02feb6a6d212be32a01432b0c7c1a261f567
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
The translation library is useful elsewhere. Even though this repository
doesn't exercise the EL2 support of the library, it is better to have it
here as well to make it easier to maintain.
enable_mmu_secure() and enable_mmu_direct() have been deprecated. The
functions are still present, but they are behind ERROR_DEPRECATED and
they call the new functions enable_mmu_svc_mon() and
enable_mmu_direct_svc_mon().
Change-Id: I13ad10cd048d9cc2d55e0fff9a5133671b67dcba
When the source code says 'SMCC' it is talking about the SMC Calling
Convention. The correct acronym is SMCCC. This affects a few definitions
and file names.
Some files have been renamed (smcc.h, smcc_helpers.h and smcc_macros.S)
but the old files have been kept for compatibility, they include the
new ones with an ERROR_DEPRECATED guard.
Change-Id: I78f94052a502436fdd97ca32c0fe86bd58173f2f
Add 'lr_svc' as a boot parameter in AArch32 bl1. This is used by Optee
and Trusty to get the non-secure entry point on AArch32 platforms.
This change is not ported in AArch64 mode where the BL31, not BL32,
is in charge of booting the non secure image (BL33).
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Minor build fixes
This change avoids warnings when setting -Wmissing-prototypes or when
using sparse tool.
Signed-off-by: Yann Gautier <yann.gautier@st.com>
Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
security_state is either 0 or 1. Prevent sign conversion potential
error (setting -Werror=sign-conversion results in a build error).
This patch updates the el3_arch_init_common macro so that it fully
initialises essential control registers rather then relying on hardware
to set the reset values.
The context management functions are also updated to fully initialise
the appropriate control registers when initialising the non-secure and
secure context structures and when preparing to leave EL3 for a lower
EL.
This gives better alignement with the ARM ARM which states that software
must initialise RES0 and RES1 fields with 0 / 1.
This patch also corrects the following typos:
"NASCR definitions" -> "NSACR definitions"
Change-Id: Ia8940b8351dc27bc09e2138b011e249655041cfc
Signed-off-by: David Cunado <david.cunado@arm.com>
This patch adds `TRUSTED_BOARD_BOOT` support for AArch32 mode.
To build this patch the "mbedtls/include/mbedtls/bignum.h"
needs to be modified to remove `#define MBEDTLS_HAVE_UDBL`
when `MBEDTLS_HAVE_INT32` is defined. This is a workaround
for "https://github.com/ARMmbed/mbedtls/issues/708"
NOTE: TBBR support on Juno AArch32 is not currently supported.
Change-Id: I86d80e30b9139adc4d9663f112801ece42deafcf
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
Co-Authored-By: Yatharth Kochar <yatharth.kochar@arm.com>
The current SMC context data structure `smc_ctx_t` and related helpers are
optimized for case when SMC call does not result in world switch. This was
the case for SP_MIN and BL1 cold boot flow. But the firmware update usecase
requires world switch as a result of SMC and the current SMC context helpers
were not helping very much in this regard. Therefore this patch does the
following changes to improve this:
1. Add monitor stack pointer, `spmon` to `smc_ctx_t`
The C Runtime stack pointer in monitor mode, `sp_mon` is added to the
SMC context, and the `smc_ctx_t` pointer is cached in `sp_mon` prior
to exit from Monitor mode. This makes is easier to retrieve the
context when the next SMC call happens. As a result of this change,
the SMC context helpers no longer depend on the stack to save and
restore the register.
This aligns it with the context save and restore mechanism in AArch64.
2. Add SCR in `smc_ctx_t`
Adding the SCR register to `smc_ctx_t` makes it easier to manage this
register state when switching between non secure and secure world as a
result of an SMC call.
Change-Id: I5e12a7056107c1701b457b8f7363fdbf892230bf
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
The Virtualization field in the ID_PFR1 register has only 2
valid values (0 or 1) but it was incorrectly checked against
unrelated value tied to the SPSR register instead.
This patch fixes the detection of virtualization support by
using the valid values in BL1 context management code.
Change-Id: If12592e343770e1da90f0f5fecf0a3376047ac29
This patch adds generic changes in BL1 to support AArch32 state.
New AArch32 specific assembly/C files are introduced and
some files are moved to AArch32/64 specific folders.
BL1 for AArch64 is refactored but functionally identical.
BL1 executes in Secure Monitor mode in AArch32 state.
NOTE: BL1 in AArch32 state ONLY handles BL1_RUN_IMAGE SMC.
Change-Id: I6e2296374c7efbf3cf2aa1a0ce8de0732d8c98a5
