path: root/bl1/aarch32
2017-06-28Merge pull request #978 from etienne-lms/minor-builddanh-arm
Minor build fixes
2017-06-23bl1: include bl1_private.h in aarch* filesEtienne Carriere
This change avoids warnings when setting -Wmissing-prototypes or when using sparse tool. Signed-off-by: Yann Gautier <yann.gautier@st.com> Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
2017-06-23bl: security_state should be of type unsigned intEtienne Carriere
security_state is either 0 or 1. Prevent sign conversion potential error (setting -Werror=sign-conversion results in a build error). Signed-off-by: Yann Gautier <yann.gautier@st.com> Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
2017-06-21Fully initialise essential control registersDavid Cunado
This patch updates the el3_arch_init_common macro so that it fully initialises essential control registers rather then relying on hardware to set the reset values. The context management functions are also updated to fully initialise the appropriate control registers when initialising the non-secure and secure context structures and when preparing to leave EL3 for a lower EL. This gives better alignement with the ARM ARM which states that software must initialise RES0 and RES1 fields with 0 / 1. This patch also corrects the following typos: "NASCR definitions" -> "NSACR definitions" Change-Id: Ia8940b8351dc27bc09e2138b011e249655041cfc Signed-off-by: David Cunado <david.cunado@arm.com>
2017-05-15AArch32: Add `TRUSTED_BOARD_BOOT` supportdp-arm
This patch adds `TRUSTED_BOARD_BOOT` support for AArch32 mode. To build this patch the "mbedtls/include/mbedtls/bignum.h" needs to be modified to remove `#define MBEDTLS_HAVE_UDBL` when `MBEDTLS_HAVE_INT32` is defined. This is a workaround for "https://github.com/ARMmbed/mbedtls/issues/708" NOTE: TBBR support on Juno AArch32 is not currently supported. Change-Id: I86d80e30b9139adc4d9663f112801ece42deafcf Signed-off-by: dp-arm <dimitris.papastamos@arm.com> Co-Authored-By: Yatharth Kochar <yatharth.kochar@arm.com>
2017-05-12AArch32: Rework SMC context save and restore mechanismSoby Mathew
The current SMC context data structure `smc_ctx_t` and related helpers are optimized for case when SMC call does not result in world switch. This was the case for SP_MIN and BL1 cold boot flow. But the firmware update usecase requires world switch as a result of SMC and the current SMC context helpers were not helping very much in this regard. Therefore this patch does the following changes to improve this: 1. Add monitor stack pointer, `spmon` to `smc_ctx_t` The C Runtime stack pointer in monitor mode, `sp_mon` is added to the SMC context, and the `smc_ctx_t` pointer is cached in `sp_mon` prior to exit from Monitor mode. This makes is easier to retrieve the context when the next SMC call happens. As a result of this change, the SMC context helpers no longer depend on the stack to save and restore the register. This aligns it with the context save and restore mechanism in AArch64. 2. Add SCR in `smc_ctx_t` Adding the SCR register to `smc_ctx_t` makes it easier to manage this register state when switching between non secure and secure world as a result of an SMC call. Change-Id: I5e12a7056107c1701b457b8f7363fdbf892230bf Signed-off-by: Soby Mathew <soby.mathew@arm.com> Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2016-09-23AArch32: Fix detection of virtualization supportYatharth Kochar
The Virtualization field in the ID_PFR1 register has only 2 valid values (0 or 1) but it was incorrectly checked against unrelated value tied to the SPSR register instead. This patch fixes the detection of virtualization support by using the valid values in BL1 context management code. Change-Id: If12592e343770e1da90f0f5fecf0a3376047ac29
2016-09-21AArch32: Add generic changes in BL1Yatharth Kochar
This patch adds generic changes in BL1 to support AArch32 state. New AArch32 specific assembly/C files are introduced and some files are moved to AArch32/64 specific folders. BL1 for AArch64 is refactored but functionally identical. BL1 executes in Secure Monitor mode in AArch32 state. NOTE: BL1 in AArch32 state ONLY handles BL1_RUN_IMAGE SMC. Change-Id: I6e2296374c7efbf3cf2aa1a0ce8de0732d8c98a5
