This tool packages Secure Partitions and Resource Descriptor blobs into
a simple file that can be loaded by SPM.
Change-Id: If3800064f30bdc3d7fc6a15ffbb3007ef632bcaa
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Setting E=0 in the make command line disables -Werror in CPPFLAGS.
Signed-off-by: Yann Gautier <yann.gautier@st.com>
The list of warning is taken from kernel and also divided in 3.
The option to activate that is W=x, with x=1, 2 or 3.
The current SPM is a prototype that only supports one secure partition
in EL0. The objective of SPM is to have multiple partitions. The current
MM interface isn't adequate for this, so it is needed to modify heavily
the code to add proper support for it.
However, there are platforms which are already using this (like SGI) and
removing the code would break it. For this reason, the current SPM code
has been duplicated in order to temporarily preserve compatibility. All
new improvements/changes to SPM will be done in the non-deprecated copy,
that may change without notice.
The new build option SPM_DEPRECATED has been introduced to select the SPM
implementation. It defaults to 1, that selects the deprecated SPM.
Change-Id: Ic9f80b53b450e97b4d3f47e4ef4a138ee8d87443
Now that we have switched to using the stack in MULTI_CONSOLE_API
framework functions and have factored all code involved in crash
reporting out into a separate file, there's really no reason to keep the
main framework code in assembly anymore. This patch rewrites it in C
which allows us to have a single implementation across aarch32/64 and
should be much easier to maintain going forward.
Change-Id: I6c85a01e89a79e8b233f3f8bee812f0dbd026221
Signed-off-by: Julius Werner <jwerner@chromium.org>
This patch makes the build system link the console framework code by
default, like it already does with other common libraries (e.g. cache
helpers). This should not make a difference in practice since TF is
linked with --gc-sections, so the linker will garbage collect all
functions and data that are not referenced by any other code. Thus, if a
platform doesn't want to include console code for size reasons and
doesn't make any references to console functions, the code will not be
included in the final binary.
To avoid compatibility issues with older platform ports, only make this
change for the MULTI_CONSOLE_API.
Change-Id: I153a9dbe680d57aadb860d1c829759ba701130d3
It's better to have them in a separate file instead of having them spread
across the Makefile. This is what the stack protector is already doing.
Change-Id: Id30742c0af10de5ea6d10674ca25bf52b0f2b262
Change-Id: I0b8ccba15024c55bb03927cdb50370913eb8010c
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Commit <ee1ba6d4ddf1> ("Makefile: Support totally quiet output with -s")
broke verbose (V=1) builds on Windows. This patch fixes it by adding
helpers to silence echo prints in a OS-dependent way.
Change-Id: I24669150457516e9fb34fa32fa103398efe8082d
"-s" is a command line option to the make tool, to suppress normal output,
something to the effect of prepending every line with '@' in the Makefile.
However with our V={0|1} support, we now print the shortened command line
output in any case (even with V=1, in addition to the long line!).
Normally -s helps to not miss non-fatal warnings, which tend to scroll out
of the window easily.
Introduce a new Makefile variable ECHO, to control the shortened output.
We only set it in the (current default) V=0 case, and replace every
occurence of "@echo" with that variable.
When the user specifies "-s", we set ECHO to some magic string which
changes the output line into a comment, so the output is suppressed.
Beside suppressing every output for "-s", we also avoid the redundant
short output when compiling with V=1.
This changes the output to:
$ make -s PLAT=.... bl31
Built build/.../release/bl31.bin
$ make PLAT=.... bl31
CC lib/libc/strncmp.c
CC lib/libc/strnlen.c
$ make V=1 PLAT=.... bl31
gcc -DDEBUG=0 .... -o build/.../release/libc/strncmp.o
gcc -DDEBUG=0 .... -o build/.../release/libc/strnlen.o
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Remove incorrect tabulation in Makefile
Enable Multi Console API in AArch32
When attempting to compile TF-A with "SPD=something ARCH=aarch32", the
following error message is printed:
Makefile:291: *** recipe commences before first target. Stop.
This is because the call to the error function is indented using a tab
whereas it's not part of a rule's recipe. Replace the tab by spaces.
Change-Id: Ic9b603837a0e43f2f7070cb39137541c332365d2
Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
This patch introduces a build flag "RECLAIM_INIT_CODE" to mark boot time
code which allows platforms to place this memory in an appropriate
section to be reclaimed later. This features is primarily targeted for
BL31. Appropriate documentation updates are also done.
Change-Id: If0ca062851614805d769c332c771083d46599194
Signed-off-by: Daniel Boulby <daniel.boulby@arm.com>
Update the version to 2.0
Change-Id: Icbc556d47a58d0870577b1bf1cd27cc5827fd56d
Change-Id: I567a406edb090ae9d109382f6874846a79dd7473
Co-authored-by: Roberto Vargas <roberto.vargas@arm.com>
The code of LOAD_IMAGE_V2=0 has been removed.
Change-Id: Iea03e5bebb90c66889bdb23f85c07d0c9717fffe
Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Change-Id: I40d040aa05bcbf11536a96ce59827711456b93a8
The old driver is now in deprecated_console.S, in a similar way to the
AArch64 driver.
Change-Id: Ib57209c322576c451d466d7406a94adbf01ab8fd
Change-Id: I67382383fc9d18ab57c7e51f793145cb14c6fec5
Signed-off-by: Sathees Balya <sathees.balya@arm.com>
This function diplays the backtrace, the current EL and security state
to allow a post-processing tool to choose the right binary to interpret
the dump.
The output can be fed to GNU addr2line to resolve function names given
an ELF binary compiled with debug information. The "-i" flag is
recommended to improve display in case of inlined functions. The *.dump
files generated during the build process can also be used.
The function works in AArch64 and AArch32. In AArch32 it only works in
A32 mode (without T32 interworking), which is enforced in the Makefile.
Sample output of a backtrace at EL3:
BACKTRACE: START: function_name
0: EL3: 0x798
1: EL3: 0x538
2: EL3: 0x550
3: EL3: 0x55c
4: EL3: 0x568
5: EL3: 0x5a8
6: EL3: 0xf4
BACKTRACE: END: function_name
In order to enable it the new option ENABLE_BACKTRACE must be set to 1.
This option is set to 1 by default only in AArch64 debug builds. As
usual, it can be overridden by the platform makefile and in the build
command line.
Change-Id: Icaff39b0e5188329728be2f3c72b868b2368e794
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
At the moment the AArch32 instruction set isn't specified in the command
line, which means that the compiler is free to choose the one it sees
fit. This decision may change between compiler versions, so it is better
to specify it manually.
The build option AARCH32_INSTRUCTION_SET has been introduced for this
reason. This option can be set to T32 or A32 to pass the correct flags
to the compiler.
The current behaviour is to default to T32 due to it's smaller size.
Change-Id: I02297eb1d9404b5868ff7c054fbff9b3cda7fdb6
armclang replaces calls to printf by calls to one of the symbols
__0printf, __1printf or __2printf. This patch adds new functions with
these names that internally call printf so that the Trusted Firmware can
be compiled with this compiler.
Change-Id: I06a0e3e5001232fe5b2577615666ddd66e81eef0
Change their names to printf and snprintf. They are much smaller than
the previous versions we had, which makes them better suited for the
Trusted Firmware.
Change-Id: Ia872af91b7b967c47fce012eccecede7873a3daf
Memory Partitioning And Monitoring is an Armv8.4 feature that enables
various memory system components and resources to define partitions.
Software running at various ELs can then assign themselves to the
desired partition to control their performance aspects.
With this patch, when ENABLE_MPAM_FOR_LOWER_ELS is set to 1, EL3 allows
lower ELs to access their own MPAM registers without trapping to EL3.
This patch however doesn't make use of partitioning in EL3; platform
initialisation code should configure and use partitions in EL3 if
required.
Change-Id: I5a55b6771ccaa0c1cffc05543d2116b60cbbcdcd
Co-authored-by: James Morse <james.morse@arm.com>
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
Romlib is a new image that is stored in ROM and contains the code of
several libraries that can be shared between different images. All
the functions within in the library are accessed using a jump table
which allows to update the romlib image whithout changing the binary
compatibility. This jump table can be also stored in RAM and it can
allow to patch a romlib with potential bugs fixes..
Change-Id: If980ccdaca24b7aaca900e32acc68baf6f94ab35
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
Mbebtls include paths are controlled by the user using the variable
MBEDTLS_DIR and they are out of the TF source tree. Since these
includes have a different origin it is better to move them to a
different variable.
This change makes easier for the romlib Makefile to parse the include
paths.
Change-Id: I3e4c99300f1012bc7f88c6b9f5bc0ec1f7b5aa8d
TF Makefile was linking all the objects files generated for the
c library instead of creating a static library that could be
used in the linking stage.
Change-Id: I721daea097e9b13cbb42c9f8eaa2af8fea0799cf
This patch adds all the make macros needed to create a library archive
and to use it in the link stage.
Change-Id: I26597bfd6543649d0b68a9b1e06aec1ba353e6de
Change-Id: I562c5de91e12fe384245df41225dfb9122a13a85
Change-Id: Ib90b767e46360ef07c1f22526e3f3eb5fe366d5d
This patch allows the user to override the value of the LD Makefile
variable. This feature can be used to force the use of the new Clang
linker.
Change-Id: I97ffeb18e48fa75346702a479d7dc1e8abcb3621
Alignment fault checking is always enabled in TF (by setting the
SCTLR.A bit). Thus, all instructions that load or store one or more
registers have an alignment check that the address being accessed is
aligned to the size of the data element(s) being accessed. If this
check fails it causes an Alignment fault, which is taken as a Data
Abort exception.
The compiler needs to be aware that it must not emit load and store
instructions resulting in unaligned accesses. It already is for
AArch64 builds (see commit fa1d37122c "Add -mstrict-align to the gcc
options"), this patch does the same for AArch32 builds.
Change-Id: Ic885796bc6ed0ff392aae2d49f3a13f517e0169f
This is an add-on feature that allows processing
device tree with external includes.
"-Iinclude" is also added to INCLUDES.
It allows inclusion of dt-bindings files either in dts files or drivers,
as those files will be in include/dt-bindings/.
"-i fdts" is added to the DTC command line.
As the pre-processed files are in build directory, the DT source directory
has to be explicitely included, to manages /include/ directives.
fixes arm-software/tf-issues#595
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
This patch allows platforms to dynamically disable authentication of
images during cold boot. This capability is controlled via the
DYN_DISABLE_AUTH build flag and is only meant for development
purposes.
Change-Id: Ia3df8f898824319bb76d5cc855b5ad6c3d227260
RAS support
The ARMv8.4 RAS extensions introduce architectural support for software
to inject faults into the system in order to test fault-handling
software. This patch introduces the build option FAULT_HANDLING_SUPPORT
to allow for lower ELs to use registers in the Standard Error Record to
inject fault. The build option RAS_EXTENSIONS must also be enabled along
with fault injection.
This feature is intended for testing purposes only, and is advisable to
keep disabled for production images.
Change-Id: I6f7a4454b15aec098f9505a10eb188c2f928f7ea
RAS extensions are mandatory for ARMv8.2 CPUs, but are also optional
extensions to base ARMv8.0 architecture.
This patch adds build system support to enable RAS features in ARM
Trusted Firmware. A boolean build option RAS_EXTENSION is introduced for
this.
With RAS_EXTENSION, an Exception Synchronization Barrier (ESB) is
inserted at all EL3 vector entry and exit. ESBs will synchronize pending
external aborts before entering EL3, and therefore will contain and
attribute errors to lower EL execution. Any errors thus synchronized are
detected via. DISR_EL1 register.
When RAS_EXTENSION is set to 1, HANDLE_EL3_EA_FIRST must also be set to 1.
Change-Id: I38a19d84014d4d8af688bd81d61ba582c039383a
At present, any External Abort routed to EL3 is reported as an unhandled
exception and cause a panic. This patch enables ARM Trusted Firmware to
handle External Aborts routed to EL3.
With this patch, when an External Abort is received at EL3, its handling
is delegated to plat_ea_handler() function. Platforms can provide their
own implementation of this function. This patch adds a weak definition
of the said function that prints out a message and just panics.
In order to support handling External Aborts at EL3, the build option
HANDLE_EA_EL3_FIRST must be set to 1.
Before this patch, HANDLE_EA_EL3_FIRST wasn't passed down to
compilation; this patch fixes that too.
Change-Id: I4d07b7e65eb191ff72d63b909ae9512478cd01a1
Remove the unused macro NDEBUG
The C standards specify that this macro is used to
disable asserts but, in our code, the assert macro
is controlled with ENABLE_ASSERTIONS. Having this macro
here creates confusion about the behaviour of assert.
Change-Id: Iab8689a14dc2b8790729857d56585ce43c0c4f51
Due to differences in the bitfields of the SMC IDs, it is not possible
to support SMCCC 1.X and 2.0 at the same time.
The behaviour of `SMCCC_MAJOR_VERSION` has changed. Now, it is a build
option that specifies the major version of the SMCCC that the Trusted
Firmware supports. The only two allowed values are 1 and 2, and it
defaults to 1. The value of `SMCCC_MINOR_VERSION` is derived from it.
Note: Support for SMCCC v2.0 is an experimental feature to enable
prototyping of secure partition specifications. Support for this
convention is disabled by default and could be removed without notice.
Change-Id: I88abf9ccf08e9c66a13ce55c890edea54d9f16a7
In some use-cases BL2 will be stored in eXecute In Place (XIP) memory,
like BL1. In these use-cases, it is necessary to initialize the RW sections
in RAM, while leaving the RO sections in place. This patch enable this
use-case with a new build option, BL2_IN_XIP_MEM. For now, this option
is only supported when BL2_AT_EL3 is 1.
Signed-off-by: Jiafei Pan <Jiafei.Pan@nxp.com>
The Makefile was missing a check to verify that the value of
`ENABLE_SPM` is boolean.
Change-Id: I97222e4df9ae2fbd89cdb3263956dca52d360993
michpappas/tf-issues#567Platforms_cannot_override_ENABLE_STACK_PROTECTOR
Platforms cannot override ENABLE_STACK_PROTECTOR
Include stack_protector's makefile after including platform.mk
to allow platforms override ENABLE_STACK_PROTECTOR
Fixes ARM-software/tf-issues#567
Signed-off-by: Michalis Pappas <mpappas@fastmail.fm>
Change-Id: Ib215150272acc2ecec43f9b69624ebbbd5d7492d
Signed-off-by: David Cunado <david.cunado@arm.com>
For platforms that have not migrated to MULTI_CONSOLE_API == 1, there
are a lot of confusing deprecated declaration warnings relating to
use of console_init() and console_uninit(). Some of these relate to use
by the generic code, not the platform code. These functions are not really
deprecated but *removed* when MULTI_CONSOLE_API == 1.
This patch consolidates these warnings into a single preprocessor warning.
The __deprecated attribute is removed from the console_init() and
console_uninit() declarations.
For preprocessor warnings like this to not cause fatal build errors,
this patch adds -Wno-error=cpp to the build flags when
ERROR_DEPRECATED == 0.
This option (and -Wno-error=deprecated-declarations) is now added to
CPPFLAGS instead of TF_CFLAGS to ensure the build flags are used in the
assembler as well as the compiler.
This patch also disentangles the MULTI_CONSOLE_API and ERROR_DEPRECATED
build flags by defaulting MULTI_CONSOLE_API to 0 instead of
ERROR_DEPRECATED. This allows platforms that have not migrated to
MULTI_CONSOLE_API to use ERROR_DEPRECATED == 1 to emit a more meaningful
build error.
Finally, this patch bans use of MULTI_CONSOLE_API == 1 and AARCH32, since
the AArch32 console implementation does not support
Change-Id: If762165ddcb90c28aa7a4951aba70cb15c2b709c
Signed-off-by: Dan Handley <dan.handley@arm.com>
Rule 8.4: A compatible declaration shall be visible when
an object or function with external linkage is defined.
Change-Id: I26e042cb251a6f9590afa1340fdac73e42f23979
