Change-Id: I8676a22649dce92d0ddd98013fc6dafcfbe94c90
Signed-off-by: David Cunado <david.cunado@arm.com>
Use TF_LDFLAGS from the Makefiles, and still append LDFLAGS as well to
the compiler's invocation. This allows passing extra options from the
make command line using LDFLAGS.
Document new LDFLAGS Makefile option.
Change-Id: I88c5ac26ca12ac2b2d60a6f150ae027639991f27
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
Apply workarounds for A53 Cat A Errata 835769 and 843419
These errata are only applicable to AArch64 state. See the errata notice
for more details:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.epm048406/index.html
Introduce the build options ERRATA_A53_835769 and ERRATA_A53_843419.
Enable both of them for Juno.
Apply the 835769 workaround as following:
* Compile with -mfix-cortex-a53-835769
* Link with --fix-cortex-a53-835769
Apply the 843419 workaround as following:
* Link with --fix-cortex-a53-843419
The erratum 843419 workaround can lead the linker to create new sections
suffixed with "*.stub*" and 4KB aligned. The erratum 835769 can lead the
linker to create new "*.stub" sections with no particular alignment.
Also add support for LDFLAGS_aarch32 and LDFLAGS_aarch64 in Makefile for
architecture-specific linker options.
Change-Id: Iab3337e338b7a0a16b0d102404d9db98c154f8f8
SPE is only supported in non-secure state. Accesses to SPE specific
registers from SEL1 will trap to EL3. During a world switch, before
`TTBR` is modified the SPE profiling buffers are drained. This is to
avoid a potential invalid memory access in SEL1.
SPE is architecturally specified only for AArch64.
Change-Id: I04a96427d9f9d586c331913d815fdc726855f6b0
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
It doesn't make sense to use the `-pedantic` flag when building the
Trusted Firmware as we use GNU extensions and so our code is not
fully ISO C compliant. This flag only makes sense if the code intends to
be ISO C compliant.
Change-Id: I6273564112759ff57f03b273f5349733a5f38aef
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Reduce code size when building with Trusted Board Boot enabled
Only the compiler is switched to ARM Compiler 6. The assembler and linker
are provided by the GCC toolchain.
ARM Compiler 6 is used to build TF when the base name of the path assigned
to `CC` matches the string 'armclang'.
`CROSS_COMPILE` is still needed and should point to the appropriate
GCC toolchain.
Tested with ARM CC 6.7.
Change-Id: Ib359bf9c1e8aeed3f662668e44830864f3fe7b4a
Only the compiler is switched to clang. The assembler and linker are
clang is used to build TF when the base name of the path assigned to
`CC` contains the string 'clang'.
GCC toolchain.
Tested with clang 3.9.x and 4.0.x.
Change-Id: I53236d64e3c83ad27fc843bae5fcdae30f2e325e
Tools are built using the compiler specified in `HOSTCC` instead of
reusing the `CC` variable. By default, gcc is used.
Change-Id: I83636a375c61f4804b4e80784db9d061fe20af87
Since TF uses GCC extensions, switch the C environment
from c99 to gnu99.
This change allows armclang to build TF.
Change-Id: Iaacb2726ba1458af59faf607ae9405d6eedb9962
Collect headers shared between TF and host-tools into include/tools_share
This is a reduced version of `snprintf` that only supports formats '%d',
'%i' and '%u'. It can be used when the full `snprintf` is not needed in
order to save memory. If it finds an unknown format specifier, it
prints an error message and panics.
Change-Id: I2cb06fcdf74cda2c43caf73ae0762a91499fc04e
Platforms aligned with TBBR are supposed to use their own OIDs, but
defining the same macros with different OIDs does not provide any
value (at least technically).
For easier use of TBBR, this commit allows platforms to reuse the OIDs
obtained by ARM Ltd. This will be useful for non-ARM vendors that
do not need their own extension fields in their certificate files.
The OIDs of ARM Ltd. have been moved to include/tools_share/tbbr_oid.h
Platforms can include <tbbr_oid.h> instead of <platform_oid.h> by
defining USE_TBBR_DEFS as 1. USE_TBBR_DEFS is 0 by default to keep the
backward compatibility.
For clarification, I inserted a blank line between headers from the
include/ directory (#include <...>) and ones from a local directory
(#include "..." ).
Some header files need to be shared between TF and host programs.
For fiptool, two headers are copied to the tools/fiptool directory,
but it looks clumsy.
This commit introduces a new directory, include/tools_share, which
collects headers that should be shared between TF and host programs.
This will clarify the interface exposed to host tools. We should
add new headers to this directory only when we really need to do so.
(#include "..." ).
Add support for firmware upgrade on AArch32.
This patch has been tested on the FVP models.
NOTE: Firmware upgrade on Juno AArch32 is not currently supported.
Change-Id: I1ca8078214eaf86b46463edd14740120af930aec
Co-Authored-By: Yatharth Kochar <yatharth.kochar@arm.com>
This patch adds `TRUSTED_BOARD_BOOT` support for AArch32 mode.
To build this patch the "mbedtls/include/mbedtls/bignum.h"
needs to be modified to remove `#define MBEDTLS_HAVE_UDBL`
when `MBEDTLS_HAVE_INT32` is defined. This is a workaround
for "https://github.com/ARMmbed/mbedtls/issues/708"
NOTE: TBBR support on Juno AArch32 is not currently supported.
Change-Id: I86d80e30b9139adc4d9663f112801ece42deafcf
This patch enables compiler-rt for the AArch32 target. The code is
not used for AArch64 as the architecture supports the 64-bit division
and modulo operations natively.
Change-Id: I1703a92872b0bb56ac0b98c67193830683963b13
Minor makefile fixes
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Some recent changes have added direct use of the echo command without
parameters. This fails on a Windows shell, because echo without
parameters reports the mode ("ECHO is on").
This is corrected using the ECHO_BLANK_LINE macro already provided
for that purpose.
Change-Id: I5fd7192861b4496f6f46b4f096e80a752cd135d6
Signed-off-by: Evan Lloyd <evan.lloyd@arm.com>
PSCI: Build option to enable D-Caches early in warmboot
The build option `ENABLE_ASSERTIONS` should be used instead. That way
both C and ASM assertions can be enabled or disabled together.
All occurrences of `ASM_ASSERTION` in common code and ARM platforms have
been replaced by `ENABLE_ASSERTIONS`.
ASM_ASSERTION has been removed from the user guide.
Change-Id: I51f1991f11b9b7ff83e787c9a3270c274748ec6f
Add the new build option `ENABLE_ASSERTIONS` that controls whether or
not assert functions are compiled out. It defaults to 1 for debug builds
and to 0 for release builds.
Additionally, a following patch will be done to allow this build option
to hide auxiliary code used for the checks done in an `assert()`. This
code is is currently under the DEBUG build flag.
Assert messages are now only printed if LOG_LEVEL >= LOG_LEVEL_INFO,
which is the default for debug builds.
This patch also updates the User Guide.
Change-Id: I1401530b56bab25561bb0f274529f1d12c5263bc
This patch introduces a build option to enable D-cache early on the CPU
after warm boot. This is applicable for platforms which do not require
interconnect programming to enable cache coherency (eg: single cluster
platforms). If this option is enabled, then warm boot path enables
D-caches immediately after enabling MMU.
Fixes ARM-Software/tf-issues#456
Change-Id: I44c8787d116d7217837ced3bcf0b1d3441c8d80e
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Build: add generic way to include SCP_BL2 into FIP image
Add support for GCC stack protection
Include all makefiles before build option checks
If SCP_BL2 is passed in from the command line, it is recognized by
make_helpers/tbbr/tbbr_tools.mk, and the cert_create tool generates
the corresponding key and content certificates.
On the other hand, the top-level Makefile does not care SCP_BL2, so
the --scp-fw option is not passed to the fiptool. As far as I see
plat/arm/css/common/css_common.mk, it looks like a platform's job to
add $(eval $(call FIP_ADD_IMG,SCP_BL2,--scp-fw)).
We can make the top-level Makefile kind enough to take care of it.
This is useful when we want to have optional SCP_BL2 firmware.
Adjust css_common.mk so that Juno still requires SCP_BL2 by default.
Introduce new build option ENABLE_STACK_PROTECTOR. It enables
compilation of all BL images with one of the GCC -fstack-protector-*
options.
A new platform function plat_get_stack_protector_canary() is introduced.
It returns a value that is used to initialize the canary for stack
corruption detection. Returning a random value will prevent an attacker
from predicting the value and greatly increase the effectiveness of the
protection.
A message is printed at the ERROR level when a stack corruption is
detected.
To be effective, the global data must be stored at an address
lower than the base of the stacks. Failure to do so would allow an
attacker to overwrite the canary as part of an attack which would void
the protection.
FVP implementation of plat_get_stack_protector_canary is weak as
there is no real source of entropy on the FVP. It therefore relies on a
timer's value, which could be predictable.
Change-Id: Icaaee96392733b721fa7c86a81d03660d3c1bc06
At present, the build option checks are done prior to inclusion of
BL makefiles. This meant if the BL makefiles modified any of the options
then these checks were bypassed. This patch corrects this problem.
Change-Id: I0b591392a74d6d456d2b19bbe292f42b5aeae048
These source file definitions should be defined in generic
Makefiles so that all platforms can benefit. Ensure that the
symbols are properly marked as weak so they can be overridden
by platforms.
NOTE: This change is a potential compatibility break for
non-upstream platforms.
Change-Id: I7b892efa9f2d6d216931360dc6c436e1d10cffed
Patches for platforms with hardware-assisted coherency
Introduce version 2 of the translation tables library
The folder lib/xlat_tables_v2 has been created to store a new version
of the translation tables library for further modifications in patches
to follow. At the moment it only contains a basic implementation that
supports static regions.
This library allows different translation tables to be modified by
using different 'contexts'. For now, the implementation defaults to
the translation tables used by the current image, but it is possible
to modify other tables than the ones in use.
Added a new API to print debug information for the current state of
the translation tables, rather than printing the information while
the tables are being created. This allows subsequent debug printing
of the xlat tables after they have been changed, which will be useful
when dynamic regions are implemented in a patch to follow.
The common definitions stored in `xlat_tables.h` header have been moved
to a new file common to both versions, `xlat_tables_defs.h`.
All headers related to the translation tables library have been moved to
a the subfolder `xlat_tables`.
Change-Id: Ia55962c33e0b781831d43a548e505206dffc5ea9
ARM Trusted Firmware keeps certain data structures in a memory region
with non-cacheable attributes (termed as "coherent memory") to keep data
coherent with observers that are cache-coherent, and those not. These
data structures pertain to power management and mutual exclusion. Using
coherent memory also costs at least an additional page to map memory
with special memory attributes.
On systems with hardware-assisted coherency, all CPUs that participate
in power management and mutual exclusion are cache-coherent, obviating
the need for special memory attributes for such data structures.
Instead, they can be placed in normal memory, along with rest of data.
On systems with hardware-assisted coherency, where build option
HW_ASSISTED_COHERENCY will be set, also having USE_COHERENT_MEMORY
enabled only wastes a page of memory without any
benefit. Therefore, with HW_ASSISTED_COHERENCY set to 1, require that
USE_COHERENT_MEMORY is explicitly set to 0.
Change-Id: I5101657ae6b1a46278069f23e2d88ee5cbd98efa
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
The boolean build option HW_ASSISTED_COHERENCY is introduced to enable
various optimizations in ARM Trusted Software, when built for such
systems. It's set to 0 by default.
Change-Id: I638390da6e1718fe024dcf5b402e07084f1eb014
build: Use separate CFLAGS for tools
Introduce locking primitives using CAS instruction
Makefile: use git describe for BUILD_STRING
The ARMv8v.1 architecture extension has introduced support for far
atomics, which includes compare-and-swap. Compare and Swap instruction
is only available for AArch64.
Introduce build options to choose the architecture versions to target
ARM Trusted Firmware:
- ARM_ARCH_MAJOR: selects the major version of target ARM
Architecture. Default value is 8.
- ARM_ARCH_MINOR: selects the minor version of target ARM
Architecture. Default value is 0.
When:
(ARM_ARCH_MAJOR > 8) || ((ARM_ARCH_MAJOR == 8) && (ARM_ARCH_MINOR >= 1)),
for AArch64, Compare and Swap instruction is used to implement spin
locks. Otherwise, the implementation falls back to using
load-/store-exclusive instructions.
Update user guide, and introduce a section in Firmware Design guide to
summarize support for features introduced in ARMv8 Architecture
Extensions.
Change-Id: I73096a0039502f7aef9ec6ab3ae36680da033f16
This patch introduces the following three platform interfaces:
* void plat_psci_stat_accounting_start(const psci_power_state_t *state_info)
This is an optional hook that platforms can implement in order
to perform accounting before entering a low power state. This
typically involves capturing a timestamp.
* void plat_psci_stat_accounting_stop(const psci_power_state_t *state_info)
to perform accounting after exiting from a low power state. This
* u_register_t plat_psci_stat_get_residency(unsigned int lvl,
const psci_power_state_t *state_info,
unsigned int last_cpu_index)
to calculate the PSCI stat residency.
If any of these interfaces are overridden by the platform, it is
recommended that all of them are.
By default `ENABLE_PSCI_STAT` is disabled. If `ENABLE_PSCI_STAT`
is set but `ENABLE_PMF` is not set then an alternative PSCI stat
collection backend must be provided. If both are set, then default
weak definitions of these functions are provided, using PMF to
calculate the residency.
NOTE: Previously, platforms did not have to explicitly set
`ENABLE_PMF` since this was automatically done by the top-level
Makefile.
Change-Id: I17b47804dea68c77bc284df15ee1ccd66bc4b79b
Currently, the BUILD_STRING is just 7-digits git hash. It is true
we can identify which version is running, but we can not get a quick
idea about how new or old it is.
The command "git describe" provides us a bit more useful information
in the format of:
(tag-name)-(number of commits on top the tag)-g(7 digits hash)
I added some options:
--always
Make "git describe" work without any tag in case the upstream
ATF is cloned, but all the tags are locally dropped.
--tags
Use any tag instead of only annotated tags. In ATF, only some
tags are annotated, actually the last annotated tag is "v0.2",
whereas we are on "v1.3" tag now. This option is needed to get
something like v1.3-233-gbcc2bf0 instead of v0.2-1713-gbcc2bf0.
--dirty
The mark "-dirty" is appended if the source tree is locally
modified.
With this commit, the welcome string
NOTICE: BL1: v1.3(debug):bcc2bf0
will become like follows:
NOTICE: BL1: v1.3(debug):v1.3-233-gbcc2bf0-dirty
While we are here, let's add "2> /dev/null" as well to silently
ignore any error message from git. We should not assume that users
always work in a git repository; the ATF might be released in a
tarball form instead of a git repository. In such a case, the git
command will fail, then the ugly message "fatal: Not a git ..." will
be displayed during the build:
$ make CROSS_COMPILE=aarch64-linux-gnu-
fatal: Not a git repository (or any of the parent directories): .git
Building fvp
CC drivers/io/io_semihosting.c
CC lib/semihosting/semihosting.c
Errata printing infrastructure
fiptool: Alignment support + misc refactoring
Sharing the same CFLAGS for both the firmware and host tools is not
useful and can lead to compilation failure when CFLAGS is set on the
command line.
This patch make MAKEOVERRIDES special variable empty so make's command
line variable definitions are not implicitly forwarded to sub make
invocations. However, make options are still forwarded like "-s" option
to make the build silent.
Change-Id: Ia921c02beb1fd2041696a26160b9e7974ae000fa
The errata reporting policy is as follows:
- If an errata workaround is enabled:
- If it applies (i.e. the CPU is affected by the errata), an INFO
message is printed, confirming that the errata workaround has been
applied.
- If it does not apply, a VERBOSE message is printed, confirming
that the errata workaround has been skipped.
- If an errata workaround is not enabled, but would have applied had
it been, a WARN message is printed, alerting that errata workaround
is missing.
The CPU errata messages are printed by both BL1 (primary CPU only) and
runtime firmware on debug builds, once for each CPU/errata combination.
Relevant output from Juno r1 console when ARM Trusted Firmware is built
with PLAT=juno LOG_LEVEL=50 DEBUG=1:
VERBOSE: BL1: cortex_a57: errata workaround for 806969 was not applied
VERBOSE: BL1: cortex_a57: errata workaround for 813420 was not applied
INFO: BL1: cortex_a57: errata workaround for disable_ldnp_overread was applied
WARNING: BL1: cortex_a57: errata workaround for 826974 was missing!
WARNING: BL1: cortex_a57: errata workaround for 826977 was missing!
WARNING: BL1: cortex_a57: errata workaround for 828024 was missing!
WARNING: BL1: cortex_a57: errata workaround for 829520 was missing!
WARNING: BL1: cortex_a57: errata workaround for 833471 was missing!
VERBOSE: BL31: cortex_a57: errata workaround for 806969 was not applied
VERBOSE: BL31: cortex_a57: errata workaround for 813420 was not applied
INFO: BL31: cortex_a57: errata workaround for disable_ldnp_overread was applied
WARNING: BL31: cortex_a57: errata workaround for 826974 was missing!
WARNING: BL31: cortex_a57: errata workaround for 826977 was missing!
WARNING: BL31: cortex_a57: errata workaround for 828024 was missing!
WARNING: BL31: cortex_a57: errata workaround for 829520 was missing!
WARNING: BL31: cortex_a57: errata workaround for 833471 was missing!
VERBOSE: BL31: cortex_a53: errata workaround for 826319 was not applied
INFO: BL31: cortex_a53: errata workaround for disable_non_temporal_hint was applied
Also update documentation.
Change-Id: Iccf059d3348adb876ca121cdf5207bdbbacf2aba
Disable the automatic substitution of functions with builtins. The
existing -ffreestanding option should already do this but explicitly
adding -fno-builtin reduces the risk of compiler variation. With this
option, GCC is not supposed to be able to make assumptions on what the
function does, which could otherwise lead to security-sensitive code
removal.
This can lead to potentially less efficient code but improves
predictability of what code is actually compiled into the binary.
Change-Id: I06ad151c61318bd1b00d84976f051d2d94314acc
The current fiptool packs all the images without any padding between
them. So, the offset to each image has no alignment. This is not
efficient, for example, when the FIP is read from a block-oriented
device.
For example, (e)MMC is accessed by block-addressing. The block size
is 512 byte. So, the best case is each image is aligned by 512 byte
since the DMA engine can transfer the whole of the image to its load
address directly. The worst case is the offset does not have even
DMA-capable alignment (this is where we stand now). In this case,
we need to transfer every block to a bounce buffer, then do memcpy()
from the bounce buffer to our final destination. At least, this
should work with the abstraction by the block I/O layer, but the
CPU-intervention for the whole data transfer makes it really slow.
This commit adds a new option --align to the fiptool. This option,
if given, requests the tool to align each component in the FIP file
by the specified byte. Also, add a new Make option FIP_ALIGN for
easier access to this feature; users can give something like
FIP_ALIGN=512 from the command line, or add "FIP_ALIGN := 512" to
their platform.mk file.
When generating the list of files to check by checkpatch.pl, the list
generated by `git ls-files` is filtered by a regular expression with
grep. Due to a malformed regex, the dot of `.md` was considered a
wildcard instead of a dot. This patch fixes this so that it matches
only dots, thus allowing the two following files to be checked:
* tools/cert_create/include/cmd_opt.h
* tools/cert_create/src/cmd_opt.c
Also extended the list of library directories to check by checkpatch
to exclude any folder starting with libfdt.
Change-Id: Ie7bf18efe4df29e364e5d67ba1118515304ed9a4
