Add pwr_domain_pwr_down_wfi callback for i.MX8QX.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Sync SCFW API to commit 6dcd0242ae
Signed-off-by: Ranjani Vaidyanathan <ranjani.vaidyanathan@nxp.com>
As per design team's suggestion, L2 cache's ECC & parity
should be enabled for A72 cluster.
SC_R_GIC_SMMU is a master resource, we can't set peripheral
permission to this resource, otherwise the API will return below error
on latest SCFW, because SCFW has added a resource type check.
On old SCFW, the API does nothing to a master resource. So remove the
resource from ns_access_allowed array.
ERROR: sc_rm_set_peripheral_permissions: rsrc 14, ret 3
Signed-off-by: Ye Li <ye.li@nxp.com>
Add system_reset2 support for i.MX8QM/i.MX8QX to support
WARM/COLD/BOARD reset.
MU_SR register bit[30] is cold boot flag passed from SCU,
w0 is random value and would clear the flag incorrectly,
and cause system partition reboot fail if Linux is in suspend.
So this patch initializes it to 0x80000000 which is exactly
the same with first time board power up before writting to MU_SR
register.
With partition reboot enabled, console_list variable which is
located in data section is NOT reset, system will be busy looping
in early console operation of flush_loop() if console_list is
NOT 0 while HW console is NOT initialized, so we have to clear
this variable to make partition reboot work.
The issue of A53 cluster runtime power ON/OFF has been
identified as fifo reset issue, and there is software
workaround to avoid such issue and A53 cluster now can
be turned OFF.
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
GICR_WAKER.ProcessorSleep can only be set to zero when:
— GICR_WAKER.Sleep bit[0] == 0.
— GICR_WAKER.Quiescent bit[31] == 0.
On some platforms, when system reboot with GIC in sleep
mode but with power ON, such as on NXP's i.MX8QM, Linux
kernel enters suspend but could be requested to reboot,
and GIC is in sleep mode and it is inside a power domain
which is ON in this scenario, when CPU reset, the GIC
driver trys to set CORE's redistributor interface to awake,
with GICR_WAKER.Sleep bit[0] and GICR_WAKER.Quiescent bit[31]
both set, the ProcessorSleep bit[1] will never be clear
and cause system hang.
This patch makes sure GICR_WAKER.Sleep bit[0] and
GICR_WAKER.Quiescent bit[31] are both zeor before clearing
ProcessorSleep bit[1].
Due imx8qm_mek's UART0_RTS_B and UART0_CTS_0 pad
reuse to be the UART2 for base bard which operated by
M4_1, so don't touch these two pads in ATF.
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
Acked-by: Pete Zhang <pete.zhang@nxp.com>
With flash_uboot_cm4ddr in imx-mkimage, the m4 code will access ddr.
However after m4 core moved to non-secure partition, the ddr memory
is still in secure partition. Then m4 core will fault.
So postpone moving resources including m4 core, until other resources,
such as memory/pin moved to non-secure partition.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 1c8ce0ad5f583ec41026d4ab5bef622f1b45aecd)
(cherry picked from commit 5b026e05b8f71b3d86da0953c5ca196d5ba5cc66)
With default configuration, M4 and A35 in one partition, M4 is loaded by ROM.
"err = sc_rm_move_all(ipc_handle, secure_part, os_part, true, true);"
M4 core will first be moved to non-secure OS part, then the resource used
by M4 will be moved to non-secure OS part later. But before the resource be
moved to non-secure OS part, M4 core is still running, so a non-secure M4
core access a secure resource will trigger error in M4 side.
First mark M4 core as non-movable, after all other resoures moved to OS
part, move M4 to OS part. No need to check whether M4 is created a new
partition by SCFW, if a partition already created, the call to mark
M4 as non-removable will fail, because it M4 is in its own partition.
(cherry picked from commit 44e209cb87f078abc78839c5e138aae5122ddd78)
Since we use ATF version string to provide commit id, we must ensure
the commit id is in this string. But when a commit is tagged, the
git describe will default output the tag string. Add the '--long' option
to output a full string with commit id contained.
(cherry picked from commit c80009f7c58534b257892f0bca168fd187779e58)
Add tzc380 debug support.
Test if a partition reboot has taken place with the MU
interrupt bit. Check before returning the entrypoint
Signed-off-by: Teo Hall <teo.hall@nxp.com>
NXP's i.MX8 SoCs with system controller inside support outputting
debug message to system controller's console via calling SCFW API,
since TF-A shares debug console with Linux kernel which will have
confliction if Linux kernel and TF-A's console are both enabled,
this patch adds support for switching TF-A debug console to system
controller to easy TF-A debug.
For NXP's SoCs with system controller inside, partition reboot
is supported in SCFW, change the system reset API from board reset
to partition reboot, so each partition can reboot independently.
Add WDOG functions SIP support.
A small set of misc changes to ensure correctness before the v2.2
release tagging.
Change-Id: I888840b9483ea1a1633d204fbbc0f9594072101e
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
Removed deprecated interfaces that have been removed from the TF-A
project, updated the deprecated list with new deprecations for v2.2
Release, added upcoming release information, remove mentions of PR from
github.
Signed-off-by: Lauren Wehrmeister <lauren.wehrmeister@arm.com>
Change-Id: I2b59d351cde9860ad0dcb6520a8bd2827ad403cf
Giving a bit more background information about the issue tracker
and mailing lists.
Change-Id: I68921d54e3113d348f1e16c685f74d32df2ca19f
integration
integration
Change-Id: I53a7706016539e7de7fdbe87b786d99665bbe1d8
The list of upstream platforms on the index page is growing
quite long, especially with all the FVP variants being listed
individually.
This patch leverages the "Platform Ports" chapter in the docs
table of contents to condense this information. Almost all
platform ports now have documentation, so the table of
contents serves as the list of upstream platforms by itself.
For those upstream platforms that do not have corresponding
documentation, the top-level "Platform Ports" page mentions
them individually. It also mentions each Arm FVP, just as
the index page did before.
Note that there is an in-progress patch that creates new
platform port documentation for the Arm Juno and Arm FVP
platforms, so this list of "other platforms" will soon be
reduced further as those platforms become part of the
table of contents as well.
Change-Id: I6b1eab8cba71a599d85a6e22553a34b07f213268
The index.rst page is now the primary landing page for the TF-A
documentation. It contains quite a lot of content these days,
including:
- The project purpose and general intro
- A list of functionality
- A list of planned functionality
- A list of supported platforms
- "Getting started" links to other documents
- Contact information for raising issues
This patch creates an "About" chapter in the table
of contents and moves some content there. In order,
the above listed content:
- Stayed where it is. This is the right place for it.
- Moved to About->Features
- Moved to About->Features (in subsection)
- Stayed where it is. Moved in a later patch.
- Was expanded in-place
- Moved to About->Contact
Change-Id: I254bb87560fd09140b9e485cf15246892aa45943
integration
integration
The WARMBOOT_ENABLE_DCACHE_EARLY allows caches to be turned on early during
the boot. But the xlat_change_mem_attributes_ctx() API did not do the required
cache maintenance after the mmap tables are modified if
WARMBOOT_ENABLE_DCACHE_EARLY is enabled. This meant that when the caches are turned
off during power down, the tables in memory are accessed as part of cache
maintenance for power down, and the tables are not correct at this point which
results in a data abort.
This patch removes the optimization within xlat_change_mem_attributes_ctx()
when WARMBOOT_ENABLE_DCACHE_EARLY is enabled.
Signed-off-by: Artsem Artsemenka <artsem.artsemenka@arm.com>
Change-Id: I82de3decba87dd13e9856b5f3620a1c8571c8d87
We would need to update this version for the release but, in fact,
it is not required for our publishing workflow; the hosted version
of the docs uses git commit/tag information in place of these
variables anyway.
Instead of updating the version, just remove these variables
entirely.
Change-Id: I424c4e45786e87604e91c7197b7983579afe4806
User guide:
1. Remove obsolete note saying only FVP is supported with AArch32
2. Switch compiler for Juno AArch32 to arm-eabi
3. Mention SOFTWARE folder in Juno Linaro release
Index.rst:
1. Switch default FVP model to Version 11.6 Build 45
Change-Id: Ib47a2ea314e2b8394a20189bf91796de0e17de53
Signed-off-by: Deepika Bhavnani <deepika.bhavnani@arm.com>
Change-Id: Ia03701e2e37e3a00a501b144960a4a65aedbfde9
The version of the Linaro release that is used for testing was
updated in 35010bb8 and the user guide was updated with the
correct version, however the version is also mentioned on the
index page and that was missed. Update the index page with the
new version.
We can come back and de-duplicate this content later, to ease
future maintenance.
Change-Id: I3fe83d7a1c59ab8d3ce2b18bcc23e16c93f7af97
Tidying up a few Sphinx warnings that had built-up over time.
None of these are critical but it cleans up the Sphinx output.
At the same time, fixing some spelling errors that were detected.
Change-Id: I38209e235481eed287f8008c6de9dedd6b12ab2e
Change-Id: I497072575231730a216220f84a6d349a48eaf5e3
Signed-off-by: Balint Dobszay <balint.dobszay@arm.com>
The readme.rst file in the project root is the front-page that
is displayed on Github and if viewing the TF-A repository on
git.trustedfirmware.org in the "about" view. It now contains a
small amount of stub content, and directs readers to the
ReadTheDocs documentation via trustedfirmware.org/docs/tf-a.
The Github renderer is displaying the content fine but the cgit
viewer displays some "backlink" errors because some content
substitutions were left in place (terms surrounded by pipe
symbols), e.g. |TF-A|.
This patch removes those substitutions, that are not supported
by cgit, and also updates one heading to clarify where to find
the new docs.
Change-Id: I358451df45b8c99975ba0b6db8ea61253a10560d
* changes:
doc: Add guide for building the docs locally
doc: De-duplicate readme and license files
doc: Convert internal links to RST format
This new page contains instructions for doing a local
build of the documentation, plus information on the environment
setup that needs to be done beforehand.
Change-Id: If563145ab40639cabbe25d0f62759981a33692c6
