UART baudrate is 115200 on i.MX8QM ARM2 board.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
When secondary CPUs are offline, some platforms do NOT
support shutting down secondary CPUs by themself, need
to use other online CPU to shutdown those CPUs which
are being offline, this patch adds killing offline CPUs.
Add i.MX8QXP platform support.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add i.MX8QM platform support.
This patch adds i.MX8 SoCs ATFW support, including below
basic features:
* LPUART
* SCFW RPC
* SMP boot up
Each SoC will have its own platform definition and driver
to support.
Add interface to enable FIQ routing in SCR_EL3 to make
interrupts can wake up ARM from WFI when executing in EL3,
as all interrupts are signaled as FIQ in EL3.
Add bool/true/false type to make it easy for porting
code from other platforms.
Release v1.4: Update minor version number to 4
Updates user guide following out of box testing.
Change-Id: I0cd355d9fc7f14fb4eabb443d596d6f0858f609e
Signed-off-by: Eleanor Bonnici <Eleanor.bonnici@arm.com>
Update readme for v1.4 release
Change-Id: I8676a22649dce92d0ddd98013fc6dafcfbe94c90
Signed-off-by: David Cunado <david.cunado@arm.com>
Release v1.4: update change-log.rst
Updated change-log.rst with summary of changes since release v1.3.
Change-Id: Iecd31ed315bd9ad7ffe8bce6550f7c90e1e3a9b0
Migrate to Linaro release 17.04
ARM TF has been tested against Linaro Release 17.04 - the Linaro
binaries have been update and also the version of the compiler.
Linaro binaries: 17.01 --> 17.04
AArch64 & AArch32 compilers: 5.3-2015.05 (gcc 5.3) -> 6.2-2016.11 (gcc 6.2)
This patch updates the User Guide is to state that Linaro
release 17.04 is supported.
Additionally, the following fixes are made to the User Guide:
- Removed out of date reference to Linaro release 16.06.
- Updated the Juno variant coverage to include r2.
Change-Id: Iebbced3356f8c6b3c2bff2df62574db9f937ca7b
Update Foundation, AEM and Cortex Models versions
Update the release notes (readme.rst) for the ARM Trusted Firmware v1.4 release.
Also, reorder and fix some of the links following the conversion to
reStructured text format.
Change-Id: I8f5e8aa86cb891f61b6b62cf9fab0ad0f0ebb36b
Signed-off-by: Dan Handley <dan.handley@arm.com>
Trusted Firmware has been tested as part of its CI system against Cortex
and Foundation models in the 11.0 Model release available on
developer.arm.com. Trusted Firmware has also been tested against the v8.5
AEM model.
This patch updates the user guide documentation to reflect the version of
the Foundation, AEM and Cortex Models that Trusted Firmware has been
tested against.
Change-Id: I3b5b4d1e4220bda1dcc88aa9cfa01fa711ed92cd
Convert Markdown to reStructuredText
Removed Markdown documents as they have been converted to
reStructuredText.
Change-Id: I3148222eb31258f158f64de4ddcdda4b232ce483
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
Non-automated fixes to the converted documentation.
Change-Id: I61f3d37c7a8d6a56a7351048060b970c5b3751e4
Due to recent issues in the rendering of the documentation on GitHub and
some long-standing issues like the lack of automatic table of content in
Markdown, the documentation has been converted to reStructuredText.
Basic constructs looks pretty similar to Markdown.
Automatically convert GitHub markdown documentation to reStructuredText
using pandoc.
Change-Id: If20b695acedc6d1b49c8d9fb64efd6b6ba23f4a9
Change some hard-to-convert constructs to cleaner ones.
Fix a broken link.
Change-Id: Ida70aa1da0af7a107b0e05eb20b8d46669a0380b
Enable integration of ARM TrustZone Cryptocell for TBB
This patch implements the platform APIs plat_get_rotpk_info,
plat_get_nv_ctr, plat_set_nv_ctr to invoke CryptoCell SBROM
APIs when ARM_CRYPTOCELL_INT is set.
Change-Id: I693556b3c7f42eceddd527abbe6111e499f55c45
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This patch implements the basic lifecycle state check when CryptoCell
SBROM is initialized. Currently the check ensures that if the lifecycle
state is Security Disabled (SD), the boot process does not proceed
further.
Change-Id: I5101335453cd3ea413e97bcfb9138a96c05e1aea
This patch makes the necessary changes to enable ARM platform to
successfully integrate CryptoCell during Trusted Board Boot. The
changes are as follows:
* A new build option `ARM_CRYPTOCELL_INTEG` is introduced to select
the CryptoCell crypto driver for Trusted Board boot.
* The TrustZone filter settings for Non Secure DRAM is modified
to allow CryptoCell to read this memory. This is required to
authenticate BL33 which is loaded into the Non Secure DDR.
* The CSS platforms are modified to use coherent stacks in BL1 and BL2
when CryptoCell crypto is selected. This is because CryptoCell makes
use of DMA to transfer data and the CryptoCell SBROM library allocates
buffers on the stack during signature/hash verification.
Change-Id: I1e6f6dcd1899784f1edeabfa2a9f279bbfb90e31
This patch adds a crypto driver which utilizes the ARM® TrustZone®
CryptoCell-712 to verify signature and hash during Trusted Board Boot. Along
with this driver, the CryptoCell SBROM library is required to successfully
build the BL image. The path to this library is specified via
the `CCSBROM_LIB_PATH` variable. Please note that, mbedTLS is still required
to do the X509 certificate ASN.1 parsing and CryptoCell is only utilized for
signature and hash verification.
Change-Id: If82dfbae0d7772ba1c64839f0b27850c103fe253
This patch adds header files with required declarations and
macro definitions to enable integration with CryptoCell SBROM
version `CC712 – Release 1.0.0.1061`. These headers enable ARM
Trusted Firmware to build and link with CryptoCell SBROM
library.
Change-Id: I501eda7fe1429acb61db8e1cab78cc9aee9c1871
This patch defines the variable `LDLIBS` which allows external
libraries to be specified to 'ld' to enable it to link the
libraries.
Change-Id: I02a490eca1074063d00153ccb0ee974ef8859a0e
Introduce TF_LDFLAGS and improve CFLAGS documentation
CFLAGS content can be set on the command line to allow passing extra
options to the compiler. Its content is appended after the options set
by the Makefile (TF_CFLAGS).
The Makefiles must use TF_CFLAGS instead of CFLAGS, as the latter can be
completely overriden by setting it on the command line.
Also tell about LDFLAGS in the "Debugging options" section.
Change-Id: Iaf27b424002898ef3040133f78cb133983a37aee
Use TF_LDFLAGS from the Makefiles, and still append LDFLAGS as well to
the compiler's invocation. This allows passing extra options from the
make command line using LDFLAGS.
Document new LDFLAGS Makefile option.
Change-Id: I88c5ac26ca12ac2b2d60a6f150ae027639991f27
Add Juno AArch32 and AArch64 User Guide instructions
Updated section 6, building a FIP for Juno and FVP, adding
instructions for AArch32 and AArch64.
Updated section 4.1, summary of build options, to include a
description of the `JUNO_AARCH32_EL3_RUNTIME` build flag.
Change-Id: I4ed006522cab981371c382859063f088fbfcb8f7
Signed-off-by: Isla Mitchell <isla.mitchell@arm.com>
Improve format of exception vectors in BL1 description
rockchip: enable A53's erratum 855873 for rk3399
Fix broken link in documentation
Apply workarounds for A53 Cat A Errata 835769 and 843419
Resolve signed-unsigned comparison issues
Minor build fixes
Without the additional newlines all the text becomes a single paragraph
and next newlines are ignored.
Change-Id: I783198477f654e3923fcabb21248f2bc62c33e9d
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
For rk3399, the L2ACTLR[14] is 0 by default, as ACE CCI-500 doesn't
support WriteEvict. and you will hit the condition L2ACTLR[3] with 0,
as the Evict transactions should propagate to CCI-500 since it has
snoop filters.
Maybe this erratum applies to all Cortex-A53 cores so far, especially
if RK3399's A53 is a r0p4. we should enable it to avoid data corruption,
Change-Id: Ib86933f1fc84f8919c8e43dac41af60fd0c3ce2f
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
juno/aarch32: Fix boot on Cortex A57 and A72
Fix link in docs/firmware-update.md and docs/change-log.md:
https://github.com/ARM-software/arm-trusted-firmware/wiki/ARM-Trusted-Firmware-Image-Terminology
Change-Id: I2d51d373fd0f7da59b548cd6bed52c47772014fd
A recent commit 030567e6f51731982a7e71cbd387de93bc0e35fd added U()/ULL()
macro to TF constants. This has caused some signed-unsigned comparison
warnings / errors in the TF static analysis.
This patch addresses these issues by migrating impacted variables from
signed ints to unsigned ints and vice verse where applicable.
Change-Id: I4b4c739a3fa64aaf13b69ad1702c66ec79247e53
Fix Tegra CFLAGS usage
On Juno AArch32, the L2 cache may contain garbage after the warm reset
from AArch64 to AArch32. This is all fine until the MMU is configured
and the data caches enabled. To avoid fetching stale data from the L2
unified cache, invalidate it before the warm reset to AArch32 state.
Change-Id: I7d27e810692c02c3e83c9f31de67f6bae59a960a
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
Before BL2 loads the SCP ram firmware, `SCP_BOOT_CFG_ADDR` specifies
the primary core. After the SCP ram firmware has started executing,
`SCP_BOOT_CFG_ADDR` is modified. This is not normally an issue but
the Juno AArch32 boot flow is a special case. BL1 does a warm reset
into AArch32 and the core jumps to the `sp_min` entrypoint. This is
effectively a `RESET_TO_SP_MIN` configuration. `sp_min` has to be
able to determine the primary core and hence we need to restore
`SCP_BOOT_CFG_ADDR` to the cold boot value before `sp_min` runs.
This magically worked when booting on A53 because the core index was
zero and it just so happened to match with the new value in
`SCP_BOOT_CFG_ADDR`.
Change-Id: I105425c680cf6238948625c1d1017b01d3517c01
