add LPDDR4 DVFS support on imx8mm.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
All the DRAM timing related config is saved by SPL in OCRAM_S,
so no need to do save for these configs in ATF anymore.
On i.MX8MM, the OCRAM's last 128K is dedicated for ATF, so move
bl31 to this memory region.
BuildInfo:
- IMX-MKIMAGE: ee5ad91b
The debug version of TF-A has below assert, fix
it by making sure no memory map overlap.
ASSERT: lib/xlat_tables/xlat_tables_common.c:129
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Switch to MULTI_CONSOLE_API to make debug UART work.
Rule 5.1: External identifiers shall be distinct
Some of the identifier names in the GICv3 driver were so long that the
first 31 characters were identical. This patch shortens these names to
make sure they are different.
Fixed for:
LOG_LEVEL=50 PLAT=fvp
Change-Id: Iecd551e3a015d144716b87b42c83dd3ab8c34d90
Signed-off-by: Daniel Boulby <daniel.boulby@arm.com>
Accessing the interrupt_props array only happens inside a loop over
interrupt_props_num, so the GICv3 driver can cope with no secure
interrupts. This allows us to relax the asserts that insists on
a non-NULL interrupt_props pointer and at least one secure interrupt.
This enables GICv3 platforms which have no need for a secure interrupt.
This only covers the non-deprecated code paths.
Change-Id: I49db291906512f56af065772f69acb281dfbdcfb
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
skip init the dram info if the ddr type is DDR4,
support for it will be added later.
Add SIP service for OTP reading/writing for use
in u-boot
Signed-off-by: Teo Hall <teo.hall@nxp.com>
Update API based on following commit:
commit 24fa33d2f95707e739f01cc04d38a62bec707ceb
Author: Chuck Cannon <chuck.cannon@nxp.com>
Date: Thu Jun 28 15:00:03 2018 -0500
SCF-105: Add disclaimer to docs.
Signed-off-by: Chuck Cannon <chuck.cannon@nxp.com>
For use of the misc otp service
This patch enables necessary erratas for A53 r0p4
according to docs/cpu-specific-build-macros.rst.
Add support for Cortex-A76 and Cortex-Ares
Fast path SMCCC_ARCH_WORKAROUND_1 calls from AArch32
Implement workaround for CVE-2018-3639 on Cortex A57/A72/A73 and A75
services/arm_arch_svc/arm_arch_svc_setup.c
SC_R_IRQSTR_SCU2 can be OFF in system suspend if there
is no wakeup irq enabled from non-secure OS partion.
Add wakeup source check to decide if turning off
SC_R_IRQSTR_SCU2 or NOT when suspend.
When GIC is power down, all the GIC state will be lost. All
the redistributor's state need save/resotre. Additionally,
the redistributor's restore need to be done after distributor
DB is NOT necessary for irqsteer on i.MX8QXP,
it can be OFF when linux suspend.
Add MU power off support for suspend, it needs
to be re-initialized after system resume.
Only enable the wakeup irq when system enter DSM mode.
use ARRAY_SIZE to get the array size.
enable DSM mode on i.MX8MM.
re-design the dram power management code to make it more
common for all i.MX8M SOCs. code need to refact and optimize
to make more better. Using this common code on i.MX8MM first,
for i.MX8MQ, will move to this later.
Switch the CKIL clock source to 32K OSC. On i.MX8MM,
after SOC PoR, the default clock source for CKIL is from
divided 24MHz OSC, as 24MHz OSC will be power down when
system enters DSM mdoe. So it is better to use 32K OSC
as the default clock source after system bootup.
VPU, GPU and PCIE's clock need to be on before power on
these power domains.
When system enter deepest cpuilde(WAIT mode), the L2 cache memory
can be on for retention to increase the system performance. So
the WAIT mode with cluster power down should be defined as
rentention power state in PSCI. changing the WAIT_OFF_STATE to
WAIT_RET_STATE to make sure the l2 cache memory is not
clean & invalidate.
A53 WAIT mode is specific for OS cpuilde. The MASTER1 & MASTER2
mapping in A53 domain should be clear, otherwise the 'noc2supermix'
and 'supermix2noc' ADB400 async port will be power down when A53
enters WAIT mode.If the ADB400 is power down in WAIT mode, all the bus
request from supermix to noc wrapper will be blocked.
With default configuration, M4 and A35 in one partition, M4 is loaded by ROM.
"err = sc_rm_move_all(ipc_handle, secure_part, os_part, true, true);"
M4 core will first be moved to non-secure OS part, then the resource used
by M4 will be moved to non-secure OS part later. But before the resource be
moved to non-secure OS part, M4 core is still running, so a non-secure M4
core access a secure resource will trigger error in M4 side.
First mark M4 core as non-movable, after all other resoures moved to OS
part, move M4 to OS part. No need to check whether M4 is created a new
partition by SCFW, if a partition already created, the call to mark
M4 as non-removable will fail, because it M4 is in its own partition.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
- configure Secure memory partition
- allocate all CAAM JR to Linux
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
Reviewed-by: Aymen Sghaier <aymen.sghaier@nxp.com>
move CSU and RDC driver to common/i.mx8m folder
and enable the driver for i.mx8mm
fix entry point for the OP-TEE
Enable the WAIT mode support in cpuilde to save power.
cleanup XLAT and STACK defines
the OCRAM size for ATF is big enough for i.MX 8mm
there is no need to move code to OCRAM_S
Acked-by: Jacky Bai <ping.bai@nxp.com>
Similar to imx8mq, the U-boot calls SIP call for HAB interfaces, and trap to ATF
to run the HAB.
Since HAB codes locates in ROM, and need to access OCRAM, CAAM RAM and DDR to
authenticate image. Add these relevant memory region to MMU. Also extend the
stack size of each core to avoid stack overflow, and extend the BL31 limit
to OCRAM end 0x940000.
Signed-off-by: Ye Li <ye.li@nxp.com>
i.MX8MM is a new soc of the i.MX8M family, this patch
add the basic support for i.MX8MM. further code optimization
needed. WAIT mode support is currently disabled, will be enabled
later.
As the i.MX8MM and i.MX8MQ share the same hab file, move it
to common/imx8m, make it reusable for all i.MX8M SOCs.
make sure to put IRQSTEER SCU into correct power modes.
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
For the i.MX8 media processor, we have i.MX8MQ and i.MX8MM etc.
so rename the file name of imx8m_bl31_setup.c and imx8m_psci.c
to imx8mq_xxx to make it more clear that these file is specific
to i.MX8MQ.
clean up the license identifier with short SPDX short identifier.
Signed-off-by: Ann Thornton <ann.thornton@nxp.com>
Use MU0 to comply with boot image usage of MU,
Also power on and pass MU1 for OS/Hypervisor.
Use MU0 to comply with boot image usage of MU0
In order to save power when AP side is suspend,
the DBLOG need to be put into low power mode.
GIC need to be power off to save power. before GIC
power off, we need to save the GIC setting, then
after resume, we need to restore the gic setting.
irqsteer need to be used to wakeup the AP side
when wakeup interrupt is pending for AP side.
The GICv3 save/restore is necessary when GIC is going
to power off. the save/restore is common for all imx8
platform, so make it common for imx8.
The irqstr for scu2 is used for AP wakeup if gic is power off,
so this resource need to be added to the sec rsrc.
The SCFW API is updated based on below commit in SCFW:
commit 433c7fb773e3a5853e2744ff1f958bb225cd338a
Date: Tue Apr 17 16:09:56 2018 -0500
Only default start CPUs for EMUL, SIMU, and test builds.
this patch adds some configuration to test CSU and RDC feature
by default this is disable. to enable it add
$(eval $(call add_define,CSU_RDC_TEST)) to the platform.mk file
under plat/freescale/imx8mq/include
this patch configure
- CSU for GPIO5 to be secure only
- RDC for Cortex A to be Domain ID 0
- GPIO4 to be rw by domain ID 2
to test, stops boot at uboot and run following command:
u-boot=> md 0x3024000
03024000:"Synchronous Abort" handler, esr 0x96000210
ELR: 40257504
LR: 402574c0
x0 : 0000000000000009 x1 : 00000000308600b4
x2 : 00000000fdf28804 x3 : 0000000000000000
x4 : 0000000003024000 x5 : 00000000fdf73ad0
x6 : 0000000000000004 x7 : 000000000000000f
x8 : 00000000fc8ff7e0 x9 : 0000000000000000
x10: 00000000fc8ff049 x11: 0000000000000021
x12: 0000000000000008 x13: 00000000ffffffff
x14: 00000000fc8ffb1c x15: 00000000fc8ffc40
x16: 0000000000000000 x17: 0000000000000000
x18: 00000000fc907da0 x19: 0000000000000040
x20: 0000000000000004 x21: 0000000003024000
x22: 0000000003024000 x23: 00000000fdf7348d
x24: 0000000000000008 x25: 0000000000000009
x26: 0000000000000004 x27: 0000000000000004
x28: 00000000fc8ff928 x29: 00000000fc8ff8a0
Resetting CPU ...
resetting ...
CPU tried to acces GPIO 5 registers and crashes
u-boot=> md 0x30230000
30230000:"Synchronous Abort" handler, esr 0x96000210
ELR: 40257504
LR: 402574c0
x4 : 0000000030230000 x5 : 00000000fdf73ad0
x20: 0000000000000004 x21: 0000000030230000
x22: 0000000030230000 x23: 00000000fdf7348d
Resetting CPU ...
resetting ...
CPU tried to acces GPIO 4 registers and crashes
Reviewed-by: Peng Fan <peng.fan@nxp.com>
there is a bug in the CSL assignment.
the CSL(n) and CSL(n+1) configuration were reversed.
