Tester build includes:
-Disabled CAN,
-No debug interface,
-Most GPIOs configured as input and accesible from linux driver
-Special fw version number (0xFE)
SPI:
-move to single transfer read
-clear interrupt register on read
-perform multibyte read transfers with DMA
-make frame format consistant
CAN:
-move from mailbox to CAN FIFO
-implement buffering
-support for reading multiple frames per transfer
General:
-use PLL at 100MHz
-remove debug task
-do not compile release with debug console enabled
-bumped version to 0.13
This include FreeRTOS update to version 9.0.0
commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial
