path: root/middleware
2016-11-25open-amp: introduce RPMSG_NUM_BUFS to declare number of buffersStefan Agner
Add a define with the same name we have on the Linux side to define the number of VirtIO buffers we are going to allocate. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-11-10adjust DDR locations to be at the end of 256MiB boundaryStefan Agner
The linker file to build a firmware running from DDR memory (MCIMX7D_M4_ddr.ld) currently puts the firmware at the end of the 512MiB boundary. That is not a valid memory area for the Colibri iMX7S module (which comes with 256MiB of DDR memory). In practise it actually does work because out-of-bound addresses usually just mirror the content of the lower address, but it is a behavior which should not be relied upon. This change moves the firmware location to a valid location for all our modules at the end of the 256MiB boundary (0x8ff00000, allows for a firmware up to ~960kiB). Furthermore, the VirtIO VRING offset is currently at the end of the 1024MiB boundary. Again, due to the mirroring behavior this worked in practise, but it should not be relied upon. Hence move the VRING to the end of the 256MiB boundary too (0x8fff0000). The firmware size has been choosen so that the VRING just fits after the firmware. Note that since the VRING offsets are hardcoded, this change needs a corresponding change in the Linux kernel source: arch/arm/mach-imx/imx_rpmsg.c (function imx_rpmsg_probe) Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-05-09resync with FreeRTOS_BSP_1.0.1_iMX7DStefan Agner
2016-01-12initial commit, FreeRTOS_BSP_1.0.0_iMX7DStefan Agner
