Introduce BspRootDirPath to cleanup paths. Also suppress
generation of install files since we do cross compilation of
firmwares by default.
But remove EPD OCRAM, since this is not clocked during suspend. Use
TCM instead.
Add interrupt and polling examples based on the stander colibri SPI (ECSPI3).
SODIMM_88 - SPI CLK
SODIMM_92 - SPI TXD
SODIMM_90 - SPI RXD
SODIMM_86 - SPI CS
To test this example, connect SODIMM_92 to SODIMM_90 in order to create a loop back.
Signed-off-by: Raul Munoz <raul.munoz@toradex.com>
The Colibri standard SPI is connected to the SoCs ECSPI3 instance. Add
defines as BOARD_ECSPI_... Also add board level pinmux and clock
readout support.
GPTA is supposed to run directly of the 24MHz OSC. Fix a type which
update GPTB's root clock instead of GPTA.
Note: GPTB seems to rely on the System PLL PFD0, which seems to be
influenced by Linux' SDHC driver. Freezes of both systems have been
observed. Disabling the SDHC driver on the Linux side or using the
24MHz clock source for GPTB seem to avoid freezes.
Synchronize examples with latest versions from the imx7d_sdb_m4 board.
The Colibri iMX7 module does not provide QSPI flash, hence drop
the QSPI example.
Pin assignment for I2C4 changed to redirect the bus to SODIMM pins 194 and 196 (standard Colibri I2C interface)
Use Colibri EXT_IO0-2 as Key/LED GPIO. Those signals can easily
be connected to a real button/LED on the Colibri Evaluation board:
EXT_IO0 => X21-LED1
EXT_IO1 => X21-SW6
EXT_IO2 => X21-SW5
This adds initial examples for imx7_colibri_m4, currently just a
copy of the imx7d_sdb_m4 examples.
