path: root/examples/imx7_colibri_m4/driver_examples/ecspi
2017-03-24simplify CMake by using BspRootDirPathcolibri-imx7-m4-freertos-v8-lpdStefan Agner
Introduce BspRootDirPath to cleanup paths. Also suppress generation of install files since we do cross compilation of firmwares by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-02-20spi: example: add SPI exampleRaul Munoz
Add interrupt and polling examples based on the stander colibri SPI (ECSPI3). SODIMM_88 - SPI CLK SODIMM_92 - SPI TXD SODIMM_90 - SPI RXD SODIMM_86 - SPI CS To test this example, connect SODIMM_92 to SODIMM_90 in order to create a loop back. Signed-off-by: Raul Munoz <raul.munoz@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
