2016-09-08 | examples: use correct types in format stringsColibri_VF61_M4_FreeRTOS_V1.0.0_20160908 | Stefan Agner | |
Use correct types in format strings to avoid warnings. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-09-08 | examples: add forward decleration | Stefan Agner | |
Add forward declartion for platform interrupt definitions to avoid warnings. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-08-24 | examples: rpmsg_str_echo: Fix minor print message bug | Sanchayan Maity | |
Vybrid has A5 core and not A7. Fix this in the print message. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-08-02 | examples: vf6xx_colibri_m4: rpmsg: Add pingpong and string echo rpmsg examples | Sanchayan Maity | |
Add pingpong and string echo rpmsg examples for Vybrid. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-08-02 | open-amp: porting: vf6xx_m4: Add support for Vybrid | Sanchayan Maity | |
Support Vybrid in open-amp for using rpmsg for communication between A5 core running Linux and M4 core running FreeRTOS. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-07-22 | examples: imx7xxx: Update cmake files to add new debug console code | Bhuvanchandra DV | |
Update cmake files of imx7 examples to add the new debug_console code. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> | |||
2016-07-22 | examples: vf6xx_colibri_m4: Add UART and GPIO example code | Bhuvanchandra DV | |
Add hello_world and gpio example code. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> | |||
2016-07-22 | platform: drivers: Add Vybrid GPIO support | Bhuvanchandra DV | |
Add Vybrid GPIO driver Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> | |||
2016-07-22 | platform: utilities: debug_console: Add Vybrid debug console support | Bhuvanchandra DV | |
2016-07-22 | platform: utilities: debug_console: split platform independent code | Bhuvanchandra DV | |
2016-07-22 | platform: drivers: Add Vybrid UART support | Bhuvanchandra DV | |
Add Vybrid lpuart driver Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> | |||
2016-07-22 | platform: drivers: Add Vybrid clock contorl module support | Bhuvanchandra DV | |
Add Vybrid CCM driver Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> | |||
2016-07-22 | platform: devices: Add VF6XX support | Bhuvanchandra DV | |
Add support for VF6XX Cortex-M4 Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> | |||
2016-02-02 | Minor fix.HEADColibri_iMX7_M4_FreeRTOS_V1.0.0_20160210master | Wojciech Strozynski | |
2016-02-02 | Added new linker script - ocram | Wojciech Strozynski | |
2016-01-22 | [#5806] Added CCM gates for PWMs | Wojciech Strozynski | |
2016-01-18 | imx7_colibri_m4: remove QSPI example | Stefan Agner | |
The Colibri iMX7 module does not provide QSPI flash, hence drop the QSPI example. | |||
2016-01-18 | imx7_colibri_m4: changed pinmux for I2C4, changed board I2C interface to I2C4 | Mateusz Majchrzycki | |
Pin assignment for I2C4 changed to redirect the bus to SODIMM pins 194 and 196 (standard Colibri I2C interface) | |||
2016-01-12 | updated gitignore | Stefan Agner | |
2016-01-12 | examples: imx7_colibri_m4: adopted GPIO example | Stefan Agner | |
Use Colibri EXT_IO0-2 as Key/LED GPIO. Those signals can easily be connected to a real button/LED on the Colibri Evaluation board: EXT_IO0 => X21-LED1 EXT_IO1 => X21-SW6 EXT_IO2 => X21-SW5 | |||
2016-01-12 | examples: imx7_colibri_m4: renamed board name | Stefan Agner | |
2016-01-12 | examples: imx7_colibri_m4: use DTE mode for debug UART2 | Stefan Agner | |
2016-01-12 | examples: imx7d_sdb_m4/imx7d_val_m4: explicitly request DCE mode | Stefan Agner | |
2016-01-12 | platform: debug_console_imx: add modem mode support | Stefan Agner | |
Add mode parameter which allows to select DCE/DTE mode of the debug UART. | |||
2016-01-12 | renamed demo_apps and driver_examples project names | Stefan Agner | |
2016-01-12 | initial commit imx7_colibri_m4 examples | Stefan Agner | |
This adds initial examples for imx7_colibri_m4, currently just a copy of the imx7d_sdb_m4 examples. | |||
2016-01-12 | add gitignore | Stefan Agner | |
2016-01-12 | drivers: uart_imx: fix modem mode | Stefan Agner | |
Fix assertion in modem mode to allow using DTE mode. | |||
2016-01-12 | initial commit, FreeRTOS_BSP_1.0.0_iMX7D | Stefan Agner | |
