path: root/.cproject
2018-02-28spi, can and general improvementsDominik Sliwa
SPI: -move to single transfer read -clear interrupt register on read -perform multibyte read transfers with DMA -make frame format consistant CAN: -move from mailbox to CAN FIFO -implement buffering -support for reading multiple frames per transfer General: -use PLL at 100MHz -remove debug task -do not compile release with debug console enabled -bumped version to 0.13 Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-05-16ksd:ksdk update to 2.2Dominik Sliwa
This include FreeRTOS update to version 9.0.0 Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-01-25Apalis_TK1_K20: SPI Communication, ADC, TSC, GPIODominik Sliwa
Support for Communication between TK1 SoC and K20 MCU This patch includes ADC, TSC and GPIO functionality. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-06-27k20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial ↵Dominik Sliwa
commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commit
