Convert an overlay file for Analogue Camera Adapter V2.0B
for Apalis iMX6 module into Syntactic Sugar format, as this format
is strongly recommended in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Add support of Analogue Camera Adapter V2.0B for Apalis iMX6 module.
There are a lot warnings from dtc compiler about the absence of
necessary properties. [1]
Fix all of them by adding a "geometry" of nodes.
[1]
overlays/apalis-imx6_ov5640_overlay.dts:48.5-18: Warning (reg_format): /fragment@1/__overlay__/ov5640_mipi@3c:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
overlays/apalis-imx6_ov5640_overlay.dts:78.5-15: Warning (reg_format): /fragment@2/__overlay__/port@0:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_bus_num): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (simple_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (i2c_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (spi_bus_reg): Failed prerequisite 'reg_format'
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #size-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #size-cells value
apalis-imx6_ov5640_overlay.dtbo: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size'
apalis-imx6_ov5640_overlay.dtbo: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size'
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#address-cells' is -1, must be 1
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#size-cells' is -1, must be 0
Related-to: ELB-1316
Add support of MIPI CSI-2 serial camera interface for Apalis iMX6 module.
Note this version compatible both with V1.1A and V1.1B camera modules.
Naming format:
<machine>_<function>_overlay.dts
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
