Convert an overlay file for CSI camera ov5640 V1.1B for Apalis iMX6 module
into Syntactic Sugar format, as this format is strongly recommended
in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Convert an overlay file for LVDS display for Apalis iMX6 module
Convert an overlay file for Atmel MXT multitouch adapter
for Apalis iMX6 module into Syntactic Sugar format, as this format
is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for Analogue Camera Adapter V2.0B
Add support of Analogue Camera Adapter V2.0B for Apalis iMX6 module.
There are a lot warnings from dtc compiler about the absence of
necessary properties. [1]
Fix all of them by adding a "geometry" of nodes.
[1]
overlays/apalis-imx6_ov5640_overlay.dts:48.5-18: Warning (reg_format): /fragment@1/__overlay__/ov5640_mipi@3c:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
overlays/apalis-imx6_ov5640_overlay.dts:78.5-15: Warning (reg_format): /fragment@2/__overlay__/port@0:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_bus_num): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (simple_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (i2c_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (spi_bus_reg): Failed prerequisite 'reg_format'
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #size-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #size-cells value
apalis-imx6_ov5640_overlay.dtbo: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size'
apalis-imx6_ov5640_overlay.dtbo: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size'
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#address-cells' is -1, must be 1
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#size-cells' is -1, must be 0
Related-to: ELB-1316
Add support of MIPI CSI-2 serial camera interface for Apalis iMX6 module.
Note this version compatible both with V1.1A and V1.1B camera modules.
Naming format:
<machine>_<function>_overlay.dts
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
