Add following overlays:
- Parallel RGB support
- Parallel RGB LVDS support
- Atmel MXT TS for boards with Capacitive Touch Connector
- Atmel MXT TS for Capacitive Touch Adapter
- Toradex 7" resistive touchscreen ad7879
Related-to: ELB-4065
Related-to: ELB-4080
Signed-off-by: Oleksii Bidnichenko <oleksii.bidnichenko@toradex.com>
When the overlays was converting to the syntactic sugar, the ov5640
driver was sat to the wrong i2c channel. Fix it.
Fixes: 9b0e73d2115d ("apalis-imx6: convert ov5640 v1.1b to syntactic sugar")
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
The correct name for the node is adv_7280, as declared in
imx6qdl-apalis.dtsi.
Related-to: TOR-1692
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
Sort overlays' entries in Makefile alphabetically.
Add the overlay to support the LCD-LVDS transceiver on Iris v2.0A
in single-channel RGB24 mode.
Related-to: ELB-3898
Add the overlay to support LCD-LVDS transceiver on Iris v2.0A.
Add missing emmc version of the module into the compatible lists.
Related-to: ELB-3849
colibri-imx7d-emmc target should be compatible to
support capacitive touchscreen on imx7d-emmc
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
Add overlays for:
- Fusion F0710A TS for boards with Capacitive Touch Connector
- Fusion F0710A TS for Capacitive Touch Adapter
Use the same license as we use on regular linux-tree
Related-to: ELB-2958
Signed-off-by: Philippe Schenker's avatarPhilippe Schenker <philippe.schenker@toradex.com>
Add overlays for:
Related-to: ELB-3243
The LCD interface of colibri-imx6 codes 24-bit mode in a different way
than all other colibri modules. Thus using RGB24 mode prevents this
overlay to be used with colibri-imx6. Use default RGB666 mode to
make the overlay compatible with all colibri modules.
Fixes: ecde642a77ee ("overlays: colibri-imx8x: move LVDS stuff to common display overlay")
Add an overlay to support the standard VGA monitor.
Related-to: ELB-3246
Add an overlay to support FullHD monitor connected to
a VGA connector of Eval/Aster/Iris board.
Fix compatible string sets for display and colibri-imx6 overlays.
The HDMI interface remains disabled in the main devicetree.
Add the overlay that turns it on, making able to use HDMI monitors.
The LVDS display connects via RGB->LVDS converter, so that we can use
the parallel-rgb overlay, setting up only timing and data modes.
The AD7879 resistive touchscreen device remains disabled in the main
devicetree. Add the overlay which turns it on for using with a
Resistive Touch Display 7".
Related-to: ELB-3395
The LCDIF interface and related devices remain disabled in the main
devicetree. Add an overlay to enable an LCDIF (Parallel RGB)
interface and all related subsystems.
The STMPE resistive touchscreen device remains disabled in the main devicetree.
Add the overlay to be able using it with Resistive Touch Display 7".
Add an overlay to enable all parallel RGG related subsystems.
Make lvds overlay working properly, enabling backlight, pwm for
backlight and lvds channel.
Related-to: ELB-3240
As it's decided, move all definitions back to the main devicetree.
As it was decided, move all definitions back to the main devicetree.
Rename the overlay according to approved naming scheme.
The VGA interface and related stuff remain disabled in the main
devicetree. Add the overlay that turns it on, enabling to use VGA
monitors.
The HDMI interface and related stuff remain disabled in the main
devicetree. Add the overlay that turns it on, enabling to use HDMI
monitors.
devicetree. Add the overlay that turns on this device, enabling to
use it with a Resistive Touch Display 7".
According to the decision to use overlays just for enabling
subsystems, remove the definition of Atmel MXT touchscreen device,
leaving only enabling it and related stuff.
The overlay was not compatible with the upstream kernel.
Fix this so that the overlay is able to turn on the Parallel RGB
and the DPI panel well.
Add the initial version of Makefile using
the reference solution from the commit
10a077204e0c ("overlays: add makefile using regular kbuild infrastructure")
Realted-to: ELB-3239
i2c0 as label in the overlay does not exist (it is only an alias).
Therefore, the overlay for atmel-mxt fails to apply on Apalis iMX6. This
commit changes i2c0 to i2c1 which is the correct label.
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
Convert an overlay file for LT170410 10" LVDS display into
the Syntactic Sugar format. This format is strongly recommended
in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Convert an overlay file for LT161010 7" display into the Syntactic Sugar
format. This format is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for EDT7.0 display into the Syntactic Sugar
Convert an overlay file for EDT5.7 display into the Syntactic Sugar
Convert an overlay file for Atmel MXT multitouch adapter
for Colibri iMX7 module + Evaluation Board into Syntactic Sugar format.
for Colibri iMX7 module + Aster board into Syntactic Sugar format.
for Colibri iMX6 module + Evaluation Board into Syntactic Sugar format.
for Colibri iMX6 module + Aster board into Syntactic Sugar format.
Convert an overlay file for CSI camera ov5640 V1.1B for Apalis iMX6 module
into Syntactic Sugar format, as this format is strongly recommended
Convert an overlay file for LVDS display for Apalis iMX6 module
for Apalis iMX6 module into Syntactic Sugar format, as this format
Convert an overlay file for Analogue Camera Adapter V2.0B
Add support of Analogue Camera Adapter V2.0B for Apalis iMX6 module.
There are a lot warnings from dtc compiler about the absence of
necessary properties. [1]
Fix all of them by adding a "geometry" of nodes.
[1]
overlays/apalis-imx6_ov5640_overlay.dts:48.5-18: Warning (reg_format): /fragment@1/__overlay__/ov5640_mipi@3c:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
overlays/apalis-imx6_ov5640_overlay.dts:78.5-15: Warning (reg_format): /fragment@2/__overlay__/port@0:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_bus_num): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (simple_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (i2c_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (spi_bus_reg): Failed prerequisite 'reg_format'
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #size-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #size-cells value
apalis-imx6_ov5640_overlay.dtbo: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size'
apalis-imx6_ov5640_overlay.dtbo: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size'
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#address-cells' is -1, must be 1
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#size-cells' is -1, must be 0
Related-to: ELB-1316
Add support of MIPI CSI-2 serial camera interface for Apalis iMX6 module.
Note this version compatible both with V1.1A and V1.1B camera modules.
Naming format:
<machine>_<function>_overlay.dts
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
