Add an overlay to enable all parallel RGG related subsystems.
Related-to: ELB-3395
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Make lvds overlay working properly, enabling backlight, pwm for
backlight and lvds channel.
Related-to: ELB-3240
As it's decided, move all definitions back to the main devicetree.
As it was decided, move all definitions back to the main devicetree.
Rename the overlay according to approved naming scheme.
The VGA interface and related stuff remain disabled in the main
devicetree. Add the overlay that turns it on, enabling to use VGA
monitors.
The HDMI interface and related stuff remain disabled in the main
devicetree. Add the overlay that turns it on, enabling to use HDMI
monitors.
The STMPE resistive touchscreen device remains disabled in the main
devicetree. Add the overlay that turns on this device, enabling to
use it with a Resistive Touch Display 7".
According to the decision to use overlays just for enabling
subsystems, remove the definition of Atmel MXT touchscreen device,
leaving only enabling it and related stuff.
The overlay was not compatible with the upstream kernel.
Fix this so that the overlay is able to turn on the Parallel RGB
and the DPI panel well.
Add the initial version of Makefile using
the reference solution from the commit
10a077204e0c ("overlays: add makefile using regular kbuild infrastructure")
Realted-to: ELB-3239
i2c0 as label in the overlay does not exist (it is only an alias).
Therefore, the overlay for atmel-mxt fails to apply on Apalis iMX6. This
commit changes i2c0 to i2c1 which is the correct label.
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
Convert an overlay file for LT170410 10" LVDS display into
the Syntactic Sugar format. This format is strongly recommended
in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Convert an overlay file for LT161010 7" display into the Syntactic Sugar
format. This format is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for EDT7.0 display into the Syntactic Sugar
Convert an overlay file for EDT5.7 display into the Syntactic Sugar
Convert an overlay file for Atmel MXT multitouch adapter
for Colibri iMX7 module + Evaluation Board into Syntactic Sugar format.
for Colibri iMX7 module + Aster board into Syntactic Sugar format.
for Colibri iMX6 module + Evaluation Board into Syntactic Sugar format.
for Colibri iMX6 module + Aster board into Syntactic Sugar format.
Convert an overlay file for CSI camera ov5640 V1.1B for Apalis iMX6 module
into Syntactic Sugar format, as this format is strongly recommended
Convert an overlay file for LVDS display for Apalis iMX6 module
for Apalis iMX6 module into Syntactic Sugar format, as this format
Convert an overlay file for Analogue Camera Adapter V2.0B
Add support of Analogue Camera Adapter V2.0B for Apalis iMX6 module.
There are a lot warnings from dtc compiler about the absence of
necessary properties. [1]
Fix all of them by adding a "geometry" of nodes.
[1]
overlays/apalis-imx6_ov5640_overlay.dts:48.5-18: Warning (reg_format): /fragment@1/__overlay__/ov5640_mipi@3c:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
overlays/apalis-imx6_ov5640_overlay.dts:78.5-15: Warning (reg_format): /fragment@2/__overlay__/port@0:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_bus_num): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (simple_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (i2c_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (spi_bus_reg): Failed prerequisite 'reg_format'
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #size-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #size-cells value
apalis-imx6_ov5640_overlay.dtbo: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size'
apalis-imx6_ov5640_overlay.dtbo: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size'
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#address-cells' is -1, must be 1
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#size-cells' is -1, must be 0
Related-to: ELB-1316
Add support of MIPI CSI-2 serial camera interface for Apalis iMX6 module.
Note this version compatible both with V1.1A and V1.1B camera modules.
Naming format:
<machine>_<function>_overlay.dts
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
