Atmel MXT TS describles in a main DT. Remove duplicated
stuff.
Related-to: ELB-2943
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Make LVDS overlay compatible with display-lt170410_overlay.dts.
The on-board RTC (M41T0M6) is enabled in the main DT. The overlay to
enable it again is not pointless. Remove it.
LVDS interface uses mxcfb1 node. Enable it.
Also the lvds channels need to be enabled too. Do it.
Now the lcd interface is disabled by default in the main DT.
Reverse the overlay to enable the LCD interface.
Atmel MXT multitouch on Aster board uses pins for int/reset are not
conflicted with pwm pins. Remove disabling pwm2, pwm3.
Fix the mux domain for int/reset pins used by atmel mxt touch screen.
After removing the atmel_mxt_ts node from the main device tree,
we should clain the int/reset pins in the overlay.
Also the node enabling is not needed.
Remove senseless status property from atmel mxt ts.
Build and install an overlay to enbale a prallel RGB interface and panel
on Apalis-iMX8X.
Related-to: ELB-3054, ELB-2943
LCDIF interface, backlight and DPI panel are disabled by default in
toradex_5.4-2.1.x-imx kernel. Add an overlay that enables lcdif interface,
backlight and panel-dpi.
Apalis iMX8X uses common GPIO5/GPIO6 pins as int/reset signals
for atmel_mxt. Use proper pinctrl groups in the driver.
Use official names of SoM in compatible options.
Affected apalis-imx8, apalis-imx8x, colibri-imx8x.
The official name of SoM is Apalis-iMX8. Rename overlay files
accordingly.
Fix Makefile accordingly.
Some NXP SoC subsystems are renamed. Fix names in overlay files to make
them compatible to kernel version toradex_5.4-2.1.x-imx.
Related-to: ELB-2900
Add a device tree overlay supporting the Toradex CSI camera module 5MP
OV5640 on Verdin iMX8M Mini.
Update Verdin display adapter overlays lt8912 aka DSI to HDMI and
sn65dsi84 aka DSI to LVDS to take latest pin muxing changes into account.
This should make all versions up and including V1.0B (albeit with removed
IC4) operational.
Related-to: ELB-2691
panel-dpi/panel-lvds are compatible with a set of our modules.
Reflect this fact in overlays.
Related-to: ELB-2907
toradex_5.4-2.1.x-imx kernel. Revert overlay to enable lcdif interface,
The prefix to the pad macros changed in 5.4.24_2.1.0. Follow that.
Add device tree overlay for Verdin DSI to LVDS Adapter orderable at
Toradex.
Add device tree overlay for Verdin DSI to HDMI Adapter orderable at
Toradex.
Convert an overlay file for LT170410 10" LVDS display on Apalis-iMX8QXP
module into the Syntactic Sugar format. This format is strongly
recommended in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Convert an overlay file for LT161010 7" display for Apalis iMX8QXP
Convert an overlay file for Atmel MXT multitouch adapter
for Apalis iMX8QXP module into Syntactic Sugar format, as this format
is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for analogue touch controller AD7879
Convert an overlay for the external RTC ST m41t0 for Apalis-iMX8QM
Convert an overlay file for LT170410 10" LVDS display on Apalis-iMX8QM
for Apalis iMX8QM module into Syntactic Sugar format, as this format
There is no /disp0 node in Apalis iMX6 at all.
Apalis iMX6 has an lcd_display node that describes a parallel RGB
interface and is enabled by default.
To make the overlay for a parallel RGB have sense, convert it to
disabling and use proper node name.
Convert an overlay file for enabling the Parallel RGB interface (eLCDIF)
on Colibri-iMX8QXP module into the Syntactic Sugar format. This format is
Convert an overlay file to enable LVDS display on Apalis iMX6 module
into Syntactic Sugar format, as this format is strongly recommended
for Apalis iMX6 module into Syntactic Sugar format, as this format
for Colibri iMX8QXP module into Syntactic Sugar format, as this format
for Colibri iMX8QXP module into Syntactic Sugar format.
This format is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for disabling the Parallel RGB interface (eLCDIF)
The LT170410 10" LVDS display has resolution 1280x800, whereas there
the 800x480 resolution was used. Fix it.
Fixes: fc95c1137968 ("overlays: add initial overlays")
Convert an overlay file for LT170410 10" LVDS display on Colibri-iMX8QXP
Convert an overlay file for MIPI-DSI-to-HDMI adapter into the Syntactic
Sugar format. This format is strongly recommended in Embedded Linux
Wiki [1].
for Colibri iMX7 module + Aster board into Syntactic Sugar format.
for Colibri iMX7 module + Evaluation Board into Syntactic Sugar format.
for Colibri iMX6 module + Aster board into Syntactic Sugar format.
for Colibri iMX6 module + Evaluation Board into Syntactic Sugar format.
Convert an overlay file for EDT5.7 display into the Syntactic Sugar
format. This format is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for EDT7.0 display into the Syntactic Sugar
Convert an overlay file for LT161010 7" display into the Syntactic Sugar
Convert an overlay file for LT170410 10" LVDS display into
the Syntactic Sugar format. This format is strongly recommended
Naming format:
<machine>_<function>_overlay.dts
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
