LCDIF interface, backlight and DPI panel are disabled by default in
toradex_5.4-2.1.x-imx kernel. Revert overlay to enable lcdif interface,
backlight and panel-dpi.
Related-to: ELB-2907
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
The prefix to the pad macros changed in 5.4.24_2.1.0. Follow that.
Related-to: ELB-2943
Add device tree overlay for Verdin DSI to LVDS Adapter orderable at
Toradex.
Add device tree overlay for Verdin DSI to HDMI Adapter orderable at
Toradex.
Convert an overlay file for LT170410 10" LVDS display on Apalis-iMX8QXP
module into the Syntactic Sugar format. This format is strongly
recommended in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Convert an overlay file for LT161010 7" display for Apalis iMX8QXP
Convert an overlay file for Atmel MXT multitouch adapter
for Apalis iMX8QXP module into Syntactic Sugar format, as this format
is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for analogue touch controller AD7879
Convert an overlay for the external RTC ST m41t0 for Apalis-iMX8QM
Convert an overlay file for LT170410 10" LVDS display on Apalis-iMX8QM
for Apalis iMX8QM module into Syntactic Sugar format, as this format
There is no /disp0 node in Apalis iMX6 at all.
Apalis iMX6 has an lcd_display node that describes a parallel RGB
interface and is enabled by default.
To make the overlay for a parallel RGB have sense, convert it to
disabling and use proper node name.
Convert an overlay file for enabling the Parallel RGB interface (eLCDIF)
on Colibri-iMX8QXP module into the Syntactic Sugar format. This format is
Convert an overlay file to enable LVDS display on Apalis iMX6 module
into Syntactic Sugar format, as this format is strongly recommended
for Apalis iMX6 module into Syntactic Sugar format, as this format
for Colibri iMX8QXP module into Syntactic Sugar format, as this format
for Colibri iMX8QXP module into Syntactic Sugar format.
This format is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for disabling the Parallel RGB interface (eLCDIF)
The LT170410 10" LVDS display has resolution 1280x800, whereas there
the 800x480 resolution was used. Fix it.
Fixes: fc95c1137968 ("overlays: add initial overlays")
Convert an overlay file for LT170410 10" LVDS display on Colibri-iMX8QXP
Convert an overlay file for MIPI-DSI-to-HDMI adapter into the Syntactic
Sugar format. This format is strongly recommended in Embedded Linux
Wiki [1].
for Colibri iMX7 module + Aster board into Syntactic Sugar format.
for Colibri iMX7 module + Evaluation Board into Syntactic Sugar format.
for Colibri iMX6 module + Aster board into Syntactic Sugar format.
for Colibri iMX6 module + Evaluation Board into Syntactic Sugar format.
Convert an overlay file for EDT5.7 display into the Syntactic Sugar
format. This format is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for EDT7.0 display into the Syntactic Sugar
Convert an overlay file for LT161010 7" display into the Syntactic Sugar
Convert an overlay file for LT170410 10" LVDS display into
the Syntactic Sugar format. This format is strongly recommended
Naming format:
<machine>_<function>_overlay.dts
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
