Add a device tree overlay for the CSI Camera Module 5MP AR0521 from
e-con Systems.
Related to: PMS-387
Add device tree overlay for a 2nd CSI Camera Module 5MP OV5640 formerly
orderable at Toradex connected to the Apalis iMX8 TS Mezzanine's X4 aka
MIPI CSI-2, CSI_3 (QUAD LANE) with JP3 and JP4 in position 2-3.
Related to: PMS-387
Add device tree overlay for CSI Camera Module 5MP OV5640 formerly
orderable at Toradex.
Related to: PMS-387
This keeps the numbering of the /sys/class/pwmchipX independent of
which overlays are loaded and allows the use of Verdin PWM_3_DSI from
user space if it is not used as a backlight PWM.
Related-to: ELB-3411
Use clearer label names for the labels connecting to the kernel
device tree.
Related to: ELB-3209
device tree.
While at it fix missing status property
Fixes af6ea0f ("overlays: verdin-imx8mp_sn65dsi84_overlay:
verdin dsi to lvds adapter").
Add device tree overlays for Verdin DSI to LVDS Adapter and a connected
display lt170410 orderable at Toradex.
Add device tree overlay for Verdin DSI to HDMI Adapter orderable at
Toradex.
The missing gpio level leads to stuck the kernel if the overlay
is applied.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
According to the decision to use overlays just for enabling
subsystems, remove the definition of Atmel MXT touchscreen device,
leaving only enabling it and related stuff.
Related-to: ELB-3240
The VGA interface and related stuff remain disabled in the main
devicetree. Add the overlay to enable using VGA monitors.
The HDMI interface and related stuff remain disabled in the main
devicetree. Add the overlay to be able using it with HDMI monitors.
Now the LCD overlay enables the parallel RGB interface instead of
disabing it. Fix the description accordingly.
Realted-to: ELB-3240
The STMPE resistive touchscreen device remains disabled in the main devicetree.
Add the overlay to be able using it with Resistive Touch Display 7".
The backlight device remains disabled in the main devicetree.
Enable it to have the LCD/LVDS displays worked properly.
The new kernel has a different ports structure of mipi0_dsi_host. Fix it.
Also, remove unneeded stuff.
Related-to: ELB-3234, ELB-2943
The LVDS display connects via RGB->LVDS converter, so that we can use
the parallel-rgb overlay, setting only timing and data modes.
Related-to: ELB-2943
Handle Interrupt and Reset pin groups by atmel mxt ts driver.
The overlay for the main LVDS display connected to ldb1 SoC port.
Add an overlay to support FullHD monitors connected to
a VGA connector.
Atmel MXT TS describles in a main DT. Remove duplicated
stuff.
Make LVDS overlay compatible with display-lt170410_overlay.dts.
The on-board RTC (M41T0M6) is enabled in the main DT. The overlay to
enable it again is not pointless. Remove it.
LVDS interface uses mxcfb1 node. Enable it.
Also the lvds channels need to be enabled too. Do it.
Now the lcd interface is disabled by default in the main DT.
Reverse the overlay to enable the LCD interface.
Atmel MXT multitouch on Aster board uses pins for int/reset are not
conflicted with pwm pins. Remove disabling pwm2, pwm3.
Fix the mux domain for int/reset pins used by atmel mxt touch screen.
After removing the atmel_mxt_ts node from the main device tree,
we should clain the int/reset pins in the overlay.
Also the node enabling is not needed.
Remove senseless status property from atmel mxt ts.
Build and install an overlay to enbale a prallel RGB interface and panel
on Apalis-iMX8X.
Related-to: ELB-3054, ELB-2943
LCDIF interface, backlight and DPI panel are disabled by default in
toradex_5.4-2.1.x-imx kernel. Add an overlay that enables lcdif interface,
backlight and panel-dpi.
Apalis iMX8X uses common GPIO5/GPIO6 pins as int/reset signals
for atmel_mxt. Use proper pinctrl groups in the driver.
Use official names of SoM in compatible options.
Affected apalis-imx8, apalis-imx8x, colibri-imx8x.
The official name of SoM is Apalis-iMX8. Rename overlay files
accordingly.
Fix Makefile accordingly.
Some NXP SoC subsystems are renamed. Fix names in overlay files to make
them compatible to kernel version toradex_5.4-2.1.x-imx.
Related-to: ELB-2900
Add a device tree overlay supporting the Toradex CSI camera module 5MP
OV5640 on Verdin iMX8M Mini.
Update Verdin display adapter overlays lt8912 aka DSI to HDMI and
sn65dsi84 aka DSI to LVDS to take latest pin muxing changes into account.
This should make all versions up and including V1.0B (albeit with removed
IC4) operational.
Related-to: ELB-2691
panel-dpi/panel-lvds are compatible with a set of our modules.
Reflect this fact in overlays.
Related-to: ELB-2907
toradex_5.4-2.1.x-imx kernel. Revert overlay to enable lcdif interface,
The prefix to the pad macros changed in 5.4.24_2.1.0. Follow that.
Add device tree overlay for Verdin DSI to LVDS Adapter orderable at
Toradex.
Toradex.
Convert an overlay file for LT170410 10" LVDS display on Apalis-iMX8QXP
module into the Syntactic Sugar format. This format is strongly
recommended in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Convert an overlay file for LT161010 7" display for Apalis iMX8QXP
Convert an overlay file for Atmel MXT multitouch adapter
for Apalis iMX8QXP module into Syntactic Sugar format, as this format
is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for analogue touch controller AD7879
Convert an overlay for the external RTC ST m41t0 for Apalis-iMX8QM
Convert an overlay file for LT170410 10" LVDS display on Apalis-iMX8QM
