There is no /disp0 node in Apalis iMX6 at all.
Apalis iMX6 has an lcd_display node that describes a parallel RGB
interface and is enabled by default.
To make the overlay for a parallel RGB have sense, convert it to
disabling and use proper node name.
Convert an overlay file for enabling the Parallel RGB interface (eLCDIF)
on Colibri-iMX8QXP module into the Syntactic Sugar format. This format is
strongly recommended in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Convert an overlay file to enable LVDS display on Apalis iMX6 module
into Syntactic Sugar format, as this format is strongly recommended
Convert an overlay file for Atmel MXT multitouch adapter
for Apalis iMX6 module into Syntactic Sugar format, as this format
is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for analogue touch controller AD7879
for Colibri iMX8QXP module into Syntactic Sugar format, as this format
for Colibri iMX8QXP module into Syntactic Sugar format.
This format is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for disabling the Parallel RGB interface (eLCDIF)
The LT170410 10" LVDS display has resolution 1280x800, whereas there
the 800x480 resolution was used. Fix it.
Fixes: fc95c1137968 ("overlays: add initial overlays")
Convert an overlay file for LT170410 10" LVDS display on Colibri-iMX8QXP
module into the Syntactic Sugar format. This format is strongly
Convert an overlay file for MIPI-DSI-to-HDMI adapter into the Syntactic
Sugar format. This format is strongly recommended in Embedded Linux
Wiki [1].
for Colibri iMX7 module + Aster board into Syntactic Sugar format.
for Colibri iMX7 module + Evaluation Board into Syntactic Sugar format.
for Colibri iMX6 module + Aster board into Syntactic Sugar format.
for Colibri iMX6 module + Evaluation Board into Syntactic Sugar format.
Convert an overlay file for EDT5.7 display into the Syntactic Sugar
format. This format is strongly recommended in Embedded Linux Wiki [1].
Convert an overlay file for EDT7.0 display into the Syntactic Sugar
Convert an overlay file for LT161010 7" display into the Syntactic Sugar
Convert an overlay file for LT170410 10" LVDS display into
the Syntactic Sugar format. This format is strongly recommended
Naming format:
<machine>_<function>_overlay.dts
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
